Old 27th August 2020, 14:21   #1041  |  Link
Well - different project, different author. IIRC, it is closer related to MPC-BE than MPC-HC.
Old 27th August 2020, 14:29   #1042  |  Link
PCU
it could be bundled with for example: install: madvr & mpc video renderer.
& what about haali video renderer? is it worth staying with mpc-hc?
PCU is offline   Reply With Quote
Old 28th August 2020, 07:19   #1043  |  Link
You mean, the installer retrieving (and registering) the latest releases from madshi's webspace or from Aleksoid1978's github releases on demand?
Haali is pretty obsolete today. The splitter got superseded by LAV Filters (only the AviSynth source filter may be interesting for an edge case), and I don't remember which advantage the renderer may have had once...
Old 28th August 2020, 10:58   #1044  |  Link
PCU
Yes & Haali is dead & should be removed, & what about those old Logitech keyboards with lcds?
One more a bit off-topic question: How is such a thing possible that my GPU doesn't support DX12, but when I set my emulator's backend renderer to DX12, it runs it without any problem?
Is it possible that if in future devs developed a DX12 video renderer, my DX11 GPU can support it?
Old 29th August 2020, 03:12   #1045  |  Link
adipose
Maybe ask k-lite to distribute them together. It's a different project but as it's open-source on github it wouldn't be that hard to build it along-side, I guess.
adipose is offline   Reply With Quote
Old 29th August 2020, 08:32   #1046  |  Link
PCU
First LAV Filters wasn't bundled with MPC-HC, but now it is. I think at least MPC Video Renderer is a must-have.
Old 29th August 2020, 09:41   #1047  |  Link
v0lt
Haali VR gives a better picture than System Default, VMR-9w, Old VR and Overlay Mixer Renderer. Also Haali VR is better at reducing frame size than VMR-9r and EVR-CP.
Old 29th August 2020, 11:27   #1048  |  Link
PCU
But most users don't use it & last update of Haali is 7 years ago!
Old 29th August 2020, 11:46   #1049  |  Link
v0lt
Haali VR hasn't messed up, and the rest of the video renderers (which I have listed) have not improved. Only the VMR-9r and EVR-CP were getting changes, but this did not solve the problem with frame reduction.
It is wrong to remove support by the date of the last update.
Old 29th August 2020, 12:35   #1050  |  Link
PCU
What about MPC VR? does it have the same FR problem?
Old 29th August 2020, 12:38   #1051  |  Link
it still works and as long as no work is needed to keep it working then there is no need to remove it.
a "discontinued/superseeded" could be added but that again is wasted dev time.
Old 29th August 2020, 14:27   #1052  |  Link
clsid
There is no reason to remove support for any of the renderers. Haali VR is a good choice for old and low powered systems.
@v0lt
Are there any plans to add support to MPC VR for software scaling? That would be useful for situations where DXVA processing and Shader support are unavailable.
DirectX has the ability to use software rendering. So the DX12 functionality is being emulated on your system. DX12 has no benefits for video rendering.
Old 29th August 2020, 14:48   #1053  |  Link
PCU
Old 29th August 2020, 17:06   #1054  |  Link
v0lt
MPC VR has no problem with frame reduction. EVR-CP (in MPC-BE) also does not have this problem.
Download the Divers_-_Illustrated_London_News_Feb_6_1873-2.PNG picture (2939×3666) from Wikipedia and open it in windowed mode using the video renderers you are interested in.
Not planned.
Old 30th August 2020, 18:30   #1055  |  Link
el Filou
el Filou's Avatar
There is the API, and then what MS calls "feature level". You GPU driver probably supports the DirectX 12 API, but at the Direct3D feature level "11_something".
You can check by running 'dxdiag'
Old 31st August 2020, 15:00   #1056  |  Link
PCU
Runtime 12.0, HW 11.1
Old 7th September 2020, 11:09   #1057  |  Link
PCU
MPC doesn't open any HEIF files, does this format supported by MPC?
Old 7th September 2020, 14:11   #1058  |  Link
clsid
No. It does not support such image files.
Old 7th September 2020, 14:49   #1059  |  Link
PCU
Why LAV Filters that is based on FFmpeg doesn't support it? Starting iOS 11 the default image format is HEIF & looks like JPEG is dead!
Old 8th September 2020, 03:06   #1060  |  Link
adipose
Heif
Wikipedia: As of May 2020, no browser supports HEIC natively
If no browser supports it, I'm not sure a media player needs to. Windows 10 recently got support for the format.
https://github.com/nokiatech/heif may be useful in the future.
