6th June 2020, 06:42 | #18563 | Link |
That sounds Greek to me. Literally... Can you summarize the meaning of this error in English?
PS: Apparently it's just the simple "application stopped working" message. Not much to learn from that one. May simply be a corrupt file. Last edited by LigH; 6th June 2020 at 07:16. |
9th June 2020, 08:21 | #18564 | Link |
Grumpy Old Man.
Update's
Hi Atak,
It's been about 5 weeks since the last update, and I have been sniffing around, and I think there are some newer builds available. L-smash, ffmpeg, mkvtoolnix, avisynth 3.60 and even the very important eac3to, it's latest (although old) is 3.34, and RB has 3.33. And there might even be a few more, eg:- x264 or x265, etc. Cheers
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) Last edited by Pauly Dunne; 9th June 2020 at 13:57. |
12th June 2020, 03:10 | #18565 | Link | |
The ability to delete multiple jobs at once, instead of removing them one by one. For example: Select multiple jobs -> and A) Press DEL key (currently does nothing) B) Click Remove (currently only removes the last job in selection and auto-selects next (makes total sense when removing one job but may cause confusion with multiple jobs selected)) C) Right click->Remove Job (currently doesn't exist; redundant anyway) Rationale: not an issue with a few jobs, but for those who deal with many small files it should be a welcome addition. I just had an unusually large number of jobs in the queue (67 mini conversions), and the ability to remove all 58 selected jobs at once would certainly be helpful, compared to clicking Remove 58 times. Thankfully my usual job count is nowhere near as large, but I assume that people who do full series batches with dozens of episodes would love it. |
12th June 2020, 03:44 | #18566 | Link | |
By the way, did you try Atak's suggestion of saving the code as a custom script? I'm curious how it'll work if I run it together with "KNLmeansCL" in the Denoise menu. Will it be processed similarly to "Mdegrain2+KNLmeansCL" or not? I assume it's not as simple (at the very least the processing order will probably be messed up), but I don't know AviSynth nearly well enough to guess. |
12th June 2020, 11:32 | #18567 | Link | |
Grumpy Old Man.
12th June 2020, 11:49 | #18568 | Link | |
Grumpy Old Man.
For KNLMeansCL (mono setting of 2):- #After_Prefetch_Denoise LoadPlugin("C:\RipBot264\Tools\AviSynth plugins\KNLMeansCL\KNLMeansCL.dll") video=KNLMeansCL(video,d=1, a=2, s=4, h=2, device_type="GPU", device_id=0) OR For KNLMeansCL (adaptive) (mono setting of 2):- #After_Prefetch_Denoise LoadPlugin("C:\RipBot264\Tools\AviSynth plugins\KNLMeansCL\KNLMeansCL.dll") denoisemask=ConvertToY(video) denoisedvideo=KNLMeansCL(video,d=1, a=2, s=4, h=2, device_type="GPU", device_id=0) video=Overlay(video,denoisedvideo,mask=denoisemask,opacity=1.0) Might look a bit like this :- #Custom LoadPlugin("C:\RipBot264\Tools\AviSynth plugins\KNLMeansCL\KNLMeansCL.dll") video=KNLMeansCL(video,d=1, a=2, s=4, h=2, device_type="GPU", device_id=0) LoadPlugin("C:\RipBot264\Tools\AviSynth plugins\mvtools\mvtools2.dll") super=MSuper(video,pel=2) bv1=MAnalyse(super,isb=true,delta=1,overlap=4) fv1=MAnalyse(super,isb=false,delta=1,overlap=4) bv2=MAnalyse(super,isb=true,delta=2,overlap=4) fv2=MAnalyse(super,isb=false,delta=2,overlap=4) bv3=MAnalyse(super,isb=true,delta=3,overlap=4) fv3=MAnalyse(super,isb=false,delta=3,overlap=4) video=MDegrain3(video,super,bv1,fv1,bv2,fv2,bv3,fv3,thSAD=800) or you could tidy that up a bit, as long as all the "command's" are there.
12th June 2020, 12:29 | #18569 | Link | |
Edit: By the way, is it possible to edit the list of the Lock Size values somewhere? I constantly have tweak them to adjust to my personal needs. As one example, for the dual-layer media I have, 8150 often produces oversized files. I use 8135 to get consistent results to fit it. The single-layer media I have is the opposite: 4480 is usally too low to hit the max capacity, so I use 4488 all the time. Last edited by Ripmann; 15th June 2020 at 17:28. |
16th June 2020, 01:49 | #18570 | Link | |
Grumpy Old Man.
As for a "hidden" setting for the Lock Size numbers, there doesn't seem to be one. But I'm sure someone could prove me wrong. HOWEVER, in "Batch" you can edit all the settings and then save them as default, so you could use Batch for your re sizing, either one at a time, or as many as you like You will find reference to these settings in the RipBot264.ini file. It would actually be a really nice addition to the main job settings, wouldn't it....
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) Last edited by Pauly Dunne; 16th June 2020 at 02:00. |
16th June 2020, 05:30 | #18571 | Link |
Hey everyone,
I recently discovered RipBot264 and found it really useful, especially because I want to use specific encode settings. Everything works fine, except for one setting: chroma-qp-offset I set --chroma-qp-offset -3, but for some reason the video file created has --chroma-qp-offset -6. Every other settings entered in the command line section of RipBot264 is respected. Any idea why this happens? And is it possible to have -3? Thank you! Encode settings: Code:
cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=32 / lookahead_threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=3000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=31250 / vbv_bufsize=31250 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=3:1.00 Code:
--cabac --ref 4 --deblock -1:-1 --partitions i4x4,i8x8,p8x8,b8x8 --me umh --subme 9 --psy-rd 1.00:0.15 --merange 24 --trellis 2 --8x8dct --cqm flat --deadzone-inter 21 --deadzone-intra 11 --chroma-qp-offset -3 --threads 32 --lookahead-threads 4 --bframes 3 --b-pyramid normal --b-adapt 2 --b-bias 0 --direct auto --weightp 2 --keyint 250 --min-keyint 25 --scenecut 40 --rc-lookahead 50 --bitrate 3000 --ratetol 1.0 --qcomp 0.60 --qpmin 0 --qpmax 69 --qpstep 4 --cplxblur 20.0 --qblur 0.5 --vbv-maxrate 31250 --vbv-bufsize 31250 --nal-hrd none --ipratio 1.40 --aq-mode 3 --aq-strength 1.00 |
16th June 2020, 15:00 | #18572 | Link | |
I see this
16th June 2020, 17:47 | #18574 | Link |
x264 encoder most likely automatically changes that value because in my case after adding --chroma-qp-offset -3 to default profile I got chroma_qp_offset=-5
I suspect that value (-3) is incorrect with other settings and thus has to be automatically corrected by x264.
16th June 2020, 21:48 | #18575 | Link | |
18th June 2020, 02:27 | #18577 | Link |
Grumpy Old Man.
You've asked about this before.....
I'm pretty sure that RB can not do this...(but I could be proven wrong) I would suggest that you give Handbrake a go... https://handbrake.fr/docs/en/latest/...ontainers.html or there's this :- (command line stuff, ) https://www.webmproject.org/
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) Last edited by Pauly Dunne; 18th June 2020 at 13:40. |
18th June 2020, 12:16 | #18578 | Link | |
18th June 2020, 13:49 | #18579 | Link | |
Grumpy Old Man.
It's also a shame that the creators of Handbrake don't seem to be interested in adding a distributing encoding function I guess to get the best out of HB is to have a powerful cpu, and fast storage (NVMe) I guess you have a legit reason for wanting this format. Cheers
20th June 2020, 15:50 | #18580 | Link |
i found this thread and this program searching for distributed x264 encoding. So i'm going to try this (finger crossed)! I've seen there is only a 2 pass mode. Could you add a 3 pass mode? I know most people think that even 2 pass its just useless, but comparing thoroughly entirely many films in my collection I've found that a third pass gives that little improvement (seen as better line, geometry, grain preservation) that in a "Archival" scenario is wanted, no matter what. So a 3 pass mode could be added? Thank you very much Last edited by Tlen; 20th June 2020 at 15:52. |
