Old 27th October 2015, 08:59   #341  |  Link
brunosso
brunosso's Avatar
Originally Posted by Zathor View Post
Which version do you use?
http://forum.doom9.org/showpost.php?...&postcount=332
this version... now i try the last you upload!
PS: I try to update some tools, but i have extract error!
http://pastebin.com/uMnYrneZ
i run megui as admin..
PS2: I manually download all packages from server, and extract all in the relative folder "tools".. now i try some encode...
brunosso is offline   Reply With Quote
Old 10th December 2015, 14:52   #342  |  Link
luke83
luke83's Avatar
[Error] Log
-[Information] Versions
--[Information] [10/12/2015 14:45:11] MeGUI Version : 2611 x64
--[Information] [10/12/2015 14:45:11] Operating System: Windows 8.1 Professional Edition x64 (6.3.0.9600)
--[Information] [10/12/2015 14:45:11] .NET Framework: 4.0 (4.0.0.0)
--[Information] [10/12/2015 14:45:11] .NET Framework: 4.5.2 (4.5.51650)
--[Information] [10/12/2015 14:45:11] AviSynth+: 2.6.0.5 (03-01-2014)
--[Information] [10/12/2015 14:45:11] AvisynthWrapper: (10-04-2010)
--[Information] [10/12/2015 14:45:11] Haali Matroska Splitter: 1.13.138.14 (14-04-2013)
--[Information] [10/12/2015 14:45:11] Haali DSS2: (14-04-2013)
--[Information] [10/12/2015 14:45:11] ICSharpCode.SharpZipLib: 0.85.5.452 (07-08-2008)
--[Information] [10/12/2015 14:45:11] MediaInfo: 0.7.61.0 (21-10-2012)
--[Information] [10/12/2015 14:45:11] MediaInfoWrapper: 0.7.61.0 (06-01-2013)
--[Information] [10/12/2015 14:45:11] MessageBoxExLib: 1.0.2218.28317 (19-12-2008)
--[Information] [10/12/2015 14:45:11] SevenZipSharp: 0.64.3890.29348 (02-01-2011)
--[Information] [10/12/2015 14:45:11] 7z: 9.20 (18-11-2010)
-[Error] Update detection
--[Information] [10/12/2015 14:45:11] Automatic update is disabled
--[Information] [10/12/2015 14:45:11] Using cached update config and server: http://megui.org/auto/
--[Information] [10/12/2015 14:45:11] There is 1 package which can be updated: AviSynth plugins
--[Information] [10/12/2015 14:45:15] There is 1 package which can be updated: AviSynth plugins
--[Information] [10/12/2015 14:45:18] 1/1 - updating package AviSynth plugins
--[Error] [10/12/2015 14:45:19] Old version of AviSynth plugins could not be accessed correctly. Check if it is in use. Accesso al percorso 'avisynth.h' negato.
--[Error] [10/12/2015 14:45:19] Could not install module 'AviSynth plugins'.
--[Error] [10/12/2015 14:45:19] Failed to install package AviSynth plugins: Backup file cannot be created.
--[Error] [10/12/2015 14:45:20] Packages which have not been successfully updated: 1
luke83 is offline   Reply With Quote
Old 16th January 2016, 13:55   #343  |  Link
Nikolausr
Just use the x86 build. x64 development has apparently stopped, the x264 version is from 2012 and it doesn't support x265.
If you really want to use the x64 version, here's how to get it working:
1. Download the latest version from the OP
2. Run the updates, but don't let it update MeGUI itself or it will update to the x86 version and screw everything up. Right-click MeGUI and do "ignore updates"
3. In the updater, check "show all packages", then right click on all the disabled packages and hit "Enable".
4. The program will still throw up an error at launch complaining that it can't find certain AviSynth plugins. The ones it is looking for are the x86 versions that will crash MeGUI x64. To get the error message to go away, you can manually install the x86 versions from here:
http://www.megui.org/auto/stable/avisynth-plugin_5.7z
Unzip that to tools\avisynth_plugin\ inside your MeGUI folder. DO NOT OVERWRITE ANYTHING. As previously stated, using any of the non-x64 plugins (including convolution3dyv12, fluxsmooth, decomb, tomsmocomp, dgavcdec) will crash MeGUI.
But seriously, just use the main x86 MeGUI.
Nikolausr is offline   Reply With Quote
Old 26th January 2016, 09:48   #344  |  Link
brunosso
brunosso's Avatar
Use this version! Is the last x64 edition! Updated with DEV server...you don't need to download anything else. Have avisynth portable, and all other stuff! .. maybe only haali splitter you must install!
https://mega.nz/#!74911TxK!G3z7PMywR...SmemUI_wekvomo
I use this everyday, works like a charm, and i don't have problem with mp3 audio, like the x86 version
PS: there is my profiles of x264 and Oneclick encoder
Old 19th February 2016, 10:06   #345  |  Link
tormento
Acid fr0g
tormento's Avatar
The inside exe is x86
@turment on Telegram
Old 19th February 2016, 15:48   #346  |  Link
brunosso
brunosso's Avatar
I notice that! I think some code on the updater, because i have the x64 version compiled, and if i run a clean setup, after first update, return the x86 exe
Old 23rd February 2016, 10:24   #347  |  Link
tormento
Acid fr0g
tormento's Avatar
Can you place 7z of x64?
Old 23rd February 2016, 10:27   #348  |  Link
brunosso
brunosso's Avatar
https://sourceforge.net/p/megui/bugs/824/
look here! if you use other version of 7z, extraction doesn't work!
Old 27th February 2016, 11:37   #349  |  Link
tormento
Acid fr0g
tormento's Avatar
I meant: can you upload an archive of the latest x64 version?
Old 1st May 2016, 09:44   #350  |  Link
chros
chros's Avatar
Thanks for your guide!
Yesterday I have been fooling around with x64 encoding chain (it was tedious to get it working through the command line since megui crashed all the time ), and I can confirm with anamorphic PAL interlaced DVD to hevc (x64 in both cases) that there's no need for x64 chain for that.
The script was fairly simple (I couldn't use yadif.dll for x64 so I found a yadifmod2 to try it out) though. This is the x32 version of it:
LoadPlugin("C:\Program Files (x86)\MeGUI\tools\dgindexnv\DGDecodeNV.dll")
DGSource("video.dgi",fieldop=0)
LoadPlugin("C:\Program Files (x86)\MeGUI\tools\avisynth_plugin\ColorMatrix.dll")
ColorMatrix(hints=true, interlaced=true)
Load_Stdcall_Plugin("C:\Program Files (x86)\MeGUI\tools\avisynth_plugin\yadif.dll")
Yadif(order=1)
Trim(19400,20900)
And the result:
x32
encoded 1501 frames in 454.17s (3.30 fps), 1135.52 kb/s, Avg QP:25.97
x64
encoded 1501 frames in 452.64s (3.32 fps), 1135.52 kb/s, Avg QP:25.96
So for this the bottleneck is definitely hevc (x64) encoding. Maybe this can be changed if you use more complex avs script.
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v385.28),Win10 LTSB 1607,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED65B8(2160p@23/24/25/29/30/50/59/60Hz)
Old 13th December 2016, 22:16   #351  |  Link
Zathor
MeGUI x64 work has been continued, as AviSynth+ is making progress. Most things should work, no workarounds needed like mentioned above.
But it seems I cannot get XviD to work. If you have any ideas, please share them. I know that currently only the x86 xvid package is downloaded but I was unable to find a working xvid_encraw x64 build. If no solution can be found I will disable xvid in MeGUI x64 completly.
Old 13th December 2016, 22:20   #352  |  Link
locotus
Just finished installing it. Update some files but fails to
do with the avysinth plugins foulder which couldn't be found in the server.
Should x86 avysinth plugins foulder be use instead?
locotus is online now   Reply With Quote
Old 13th December 2016, 22:25   #353  |  Link
Zathor
Simple reason - I forgot to upload the plugins
Now they are uploaded
Old 27th December 2016, 00:08   #354  |  Link
Glarioo
For MeGUi 32bit i use DGDecNV. Can i use it in the 64bit version?
Old 27th December 2016, 00:22   #355  |  Link
videoh
Useful n00b
I don't see why you cannot use the DGDecNV 64-bit executables with 64-bit MEGUI. Don't forget that you'll need 64-bit Avisynth+ also.
Old 27th December 2016, 10:17   #356  |  Link
Glarioo
Thanks, i wasn't quite sure that DGDecNV supported 64bit.
Avisynth+(r2294) is included in the MeGUI 64bit package.
Old 27th December 2016, 10:21   #357  |  Link
Glarioo
I've read this on the first page: - AudioLimiter (not available, downmix from 7+ channels to 5.1 will be available in reduced quality only)
What does "reduced quality" mean? Only Dolby Digital 5.1 @ 640 Kbps?
Old 27th December 2016, 10:34   #358  |  Link
amayra
Quality Checker
amayra's Avatar
What is the difference between 32-bit and 64-bit versions when you have avs4x26x or Avs4x264mod ?
I love Doom9
Old 3rd January 2017, 18:17   #359  |  Link
Zathor
I have no clue to be honest. One filter is not available which is used when downmixing > 6 channel sources within AviSynth. This is not used when the source is already a 6 (or less) channel one or if with the HD Streams Extractor only the core of such audio tracks is extracted. Feel free to make a comparison.
The 32bit MeGUI version has to use a 32bit AviSynth version. The 64bit one can only be used by MeGUI x64. 64bit AviSynth should have a performance gain compared to the 32bit one but this depends on your script/filters.
Old 23rd January 2017, 14:09   #360  |  Link
VincAlastor
i can't get running x265. My avisynth script is loading in preview but when i go on to encode with x265 megui ends with error "could not load avisynth". avisynth+ and x265 working in x64 while using simple x264/x265 gui but it's using avs2yuv v0.24bm5 instead of avs4x26x.
is someone getting x265 to work in megui x64?
VincAlastor is offline   Reply With Quote
