8th February 2008, 09:11 | #282 | Link |
HDConvertToX author
http://www.64k.it/andres/data/automen/AutoMen44.exe
added you "YouTube Optimized" check, thanks to ricardo.santos BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
8th February 2008, 10:57 | #284 | Link |
HDConvertToX author
yes, it' possible.. but i prefer leaving choice to users
anyway you see the bitrate in status bar BHH
11th February 2008, 23:05 | #285 | Link | |
A Joy Forever
This is an example .bat file I use, with mencoder, to create FLV for YouTube: Code:
"c:\base\v\automen\mencoder.exe" "e:\input.avi" -o out.flv -mc 0 -ofps 25 -srate 44100 -oac mp3lame -lameopts vbr=2:q=8:aq=0:mode=1:lowpassfreq=17200 -ovc lavc -of lavf -lavfopts format=flv -lavcopts vcodec=flv:vbitrate=246:keyint=200: mbd=2:trell:v4mv:cbp:last_pred=3:predia=4:dia=4:preme=2:vpass=1 "c:\base\v\automen\mencoder.exe" "e:\input.avi" -o out.flv -mc 0 -ofps 25 -srate 44100 -oac mp3lame -lameopts vbr=2:q=8:aq=0:mode=1:lowpassfreq=17200 -ovc lavc -of lavf -lavfopts format=flv -lavcopts vcodec=flv:vbitrate=246:keyint=200: mbd=2:trell:v4mv:cbp:last_pred=3:predia=4:dia=4:preme=2:vpass=2 My sources are usually raw RGB bitmap avi, or huffYUV lossless YV12 avi, and already scaled to 448x336 resolution. Audio is also stereo pcm 44.1 kHz/16 bit already. Here's an example: http://youtube.com/watch?v=DYbibozTnWk (349 kbit/s a+v bitrate flashvideo) The things you need to change per video: audio demands: q=8 can also be q=7 (higher bitrate) or q=9 (even lower audio bitrate) lowpassfreq=17200 can also be raised when using q=7, and lowered to 15500 for q=9 (for example), still better than FM Stereo! video demands: -ofps to your preferred framerate (mind the -mc 0 setting!) vbitrate and keyint can be adapted to your taste as well. Last edited by jult; 23rd February 2008 at 05:46. |
27th February 2008, 02:45 | #286 | Link |
first of all awesome work i love this GUI, i use it for all encoding work now *damn microsoft and their flakey Xbox 360 avi support* anyway.... one issue ive noticed is version 4.4 crashes with the crop detect option all versions have worked corectly up untill this one not sure if anyone else is having the issue, to try and correct i downloaded the 4.3 full release and placed the 4.4 exe in the same dir and same result Machine specs are: Vista Ultimate Pentium D 3.2GHz 2.5GB Ram a couple of request's i have is add more settings to the ini file... ie threads, video quality, audio quality, and maybe normalize volume, i absolutely hate normalized audio is it also posible to add a aspect ratio drop down listing all common aspects and maybe auto aspect? keep up the good work and hope to see some more improvements |
4th March 2008, 10:20 | #287 | Link | |||
HDConvertToX author
@dat720
First of All Welcome to the Forum and sorry for the late answer! Quote:
i can suggest to try some http://ffdshow.faireal.net/mirror/mplayer/ builds.. till you found the correct one (and report IT!) Quote:
about normalization you can deactivate it in advanced settings.. other settings is to set every time Quote:
now development is stopped, but as always i am open to suggestion i can glady suggest to try some advanced like AutoFF (look at my sign) BHH
4th March 2008, 20:49 | #288 | Link |
http://ffdshow.faireal.net/mirror/mp...r2008.02.06.7z this build fixed my issue's thanks for the info
to use this build you must put pthreadGC2.dll in the automen directory Last edited by dat720; 5th March 2008 at 09:46. |
4th March 2008, 21:56 | #290 | Link |
HDConvertToX author
the project has reached the final stage.. just it
... maybe tomorrow i will publish the 4.5 with the possibility to select AR for encoding... BHH
5th March 2008, 17:14 | #291 | Link |
HDConvertToX author
update 4.6 http://www.64k.it/andres/data/automen/AutoMen46.exe
added: no odml option added: possibility to specify aspect ratio BHH
7th March 2008, 04:24 | #292 | Link |
thanks for that, your a champ
i still dont see extra ini settings but i guess i can live with that i'll try out a few movies and let you know how it goes i dont spose theres a chance of adding a ipod profile? automen is too good you should'nt stop dev what's the chance of getting the source code? i know nothing about programming but it's never too late to learn, ive become great at modifying *personalising* exsisting code weather its java html or others, but couldnt write somthing like that from scratch again good work Last edited by dat720; 7th March 2008 at 04:33. |
9th April 2008, 17:57 | #295 | Link | |
HDConvertToX author
sorry for late answer!
@dansus maybe no audio.. other options i think is out @Goldbaas you must know the pid.. BUT if you use the Preview button you will ear the selected pid! BHH
12th April 2008, 04:39 | #296 | Link |
HDConvertToX author
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 Last edited by buzzqw; 22nd April 2008 at 13:02. |
22nd April 2008, 07:09 | #298 | Link |
anyone had a look at the code?
i was hoping to open the code with purebasic compile it and run for a start.... then go about my way making changes, unfortunetly i have no formal experience in programing and am very lost, i get errors when trying to compile and just cant get anywhere |
22nd April 2008, 07:17 | #299 | Link |
HDConvertToX author
@dat720
i am a newby too at programming, just 2 year of self learning. Put PureBasic is easy to read and understund, please post (pm) or on purebasic forum your problem. BHH
22nd April 2008, 07:25 | #300 | Link |
#BufferLength
#MEM_DROPFILES = 10 #WideCharLen_=#MAX_PATH*4 #shut [16:18:33] [COMPILER] Line 47: Constant not found: #MAX_PATH this is one of them i figured that changing it to a number is ok, but if this is your source why does it give errors |
automen, ffmpeg, handbrake, mencoder, x264 |
