12th October 2020, 14:57 | #30061 | Link | |
But the pixelation is clearly visible. |
12th October 2020, 16:43 | #30063 | Link | |
2. I was getting pixelation on 1080p encodes from the older release (a few versions ago) of the UHD version of TSMUXER. But that was on H264 encodes on an HD disc. That was one of the reasons I've kept two copies of TSMUXER in the TOOLS folder. But it was reported as fixed in the TSMUXER change logs and in my tests it had stopped (at least in the examples in which I'd seen it). Just as a test, you might try downloading a newer release of TSMUXER here and see if it has any impact. You might also try adding ENABLE_NEW_TSMUXER=0 to your INI file. That should make BD-RB use the old muxer for H264 encode/muxes. At the least it might eliminate TSMUXER as a possible cause. Last edited by jdobbs; 12th October 2020 at 16:48. |
12th October 2020, 23:02 | #30065 | Link | |||||
Elit Amans
2. Will try replacing TSmuxer after finishing the currently ongoing test of encoding using different decoder. Should have a result in a cuple of hours. *sigh* I wish I could burn Dual Layered BD-RWs at a faster speed than 2x Thanks all for your suggestions and help. //LD Last edited by LowDead; 12th October 2020 at 23:02. Reason: small edit |
13th October 2020, 19:24 | #30069 | Link |
I have done a test with NVEnc encoder.
According to MediaInfo, the maximum bitrate is 15 Mb / s. Why is that bitrate so low? BDRebuilder Ini: TWEAK_ALTERNATE=--vbv-maxrate 50000 --vbv-bufsize 50000 And the Format Profile is 4 instead of 4.1 CRF was set to 20 in CQM (one pass). MediaInfo: Format : Matroska Format version : Version 2 File size : 13.9 GiB Duration : 2 h 15 min Overall bit rate mode : Variable Overall bit rate : 14.8 Mb/s Encoded date : UTC 2020-10-13 17:41:36 Writing application : mkvmerge v9.7.1 ('Pandemonium') 32bit Writing library : libebml v1.3.4 + libmatroska v1.4.5 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4 Format settings : CABAC / 3 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 3 frames Format settings, GOP : M=4, N=30 Codec ID : V_MPEG4/ISO/AVC Duration : 2 h 15 min Bit rate mode : Variable Bit rate : 14.1 Mb/s Maximum bit rate : 15.0 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (23976/1000) FPS Original frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.284 Stream size : 13.3 GiB (96%) Default : Yes Forced : No Last edited by Glarioo; 13th October 2020 at 19:50. |
14th October 2020, 01:27 | #30071 | Link |
@Glarioo
For ALTERNATE output to MKV/MP4 (Container types 1 & 5), 19 is the CRF breakpoint. CRF above 19 sets the max bitrate to 15Mbs, 19 or below it goes to 30Mbs. Those are based upon encode tests of average bitrates across a variety of sources. For specified bitrates of 12Mbs or less BD-RB sets the max to 15Mbs, a higher bitrate sets it to 30Mbs. For non-ALTERNATE it is based on the maximum for the specified target disc (after taking into consideration the required bitrate for audio/subs). In your example where your bitrate came out to 14.1Mbs -- the 15Mbs high end appears to be limiting (or at least implies it may be hitting it often). If my tests were right that would seem to be unusual (though admittedly it's been a long time since I did those tests). But, what I think I will do (in order to give more control to the user) is to add another option to the ALTERNATE configuration file (ALTERNATE.TXT) in which the maximum bitrate for containers 1 & 5 (MKV/MP4) can be set as a part of the preset. I'm glad you mentioned this. Because those maxrates were based upon 1080p encodes (and below). I need to go back and see if I adjusted for 2160p in those maxrate limits. I know I did on disc output -- but I don't remember if I did on ALTERNATE. Last edited by jdobbs; 14th October 2020 at 02:15. |
14th October 2020, 06:45 | #30072 | Link | |
It would be such a nice option if tweak alternate would also be possible for NVEnc encoder. Thanks in advance jdobbs. |
14th October 2020, 08:59 | #30073 | Link |
Life's clearer in 4K UHD
Old, new... Which model?
14th October 2020, 22:35 | #30075 | Link | |
But... In the meantime you should know that TWEAK_ALTERNATE is currently applied to NVENCC encodes that are targeted at containers 1 & 5 (MKV & MP4) -- so you can use it in the meantime. Once I implement TWEAK_ALTERNATE_NV, TWEAK_ALTERNATE will no longer apply to NVENCC. [Edit] As a test I just tried adding "--vbv-bufsize 30000 --max-bitrate 30000" to a command line that already had "--vbv-bufsize 15000 --max-bitrate 15000" in it -- and it worked (used the higher setting). I posted earlier in this post that it hadn't -- but found that I'd typed it wrong. So you should be able to use TWEAK_ALTERNATE to change it until the next release. [Edit] Well... even though I'd looked at the code and it appeared to add it to the command line -- I just did a test with TWEAK_ALTERNATE and it doesn't appear to have worked. Hmmm.... guess I need to try things before I post about them. [Another Edit] Yeah. TWEAK_ALTERNATE currently isn't applied to NVENCC for ALTERNATE CQM encodes. It only works for a ALTERNATE "VBR Bitrate Encoding" or "VBR Target Size [MB]" encoding. I'll change that for TWEAK_ALTERNATE_NV. Last edited by jdobbs; 14th October 2020 at 23:25. |
15th October 2020, 14:29 | #30077 | Link |
Elit Amans
Update: No success whatever method I have tried. The pixelation artefacts have been persistent over all tests. I have tried three decoders, latest (at the time) tsmuxer and using old version of tsmuxer. I also tried encoding with CQM and still same result.
Are there anyway to reduce the bitrate of the main movie so that the extras get more (maybe in this case for testing purposes alot more) so one can rule out bitrate starvation? //LD |
15th October 2020, 15:05 | #30078 | Link | |
15th October 2020, 17:44 | #30079 | Link |
Big Bit Savings Now !
LowDead, can you cut a part of the source and upload that somewhere ?
15th October 2020, 17:58 | #30080 | Link |
Elit Amans
---------------------- [10-15-20] BD Rebuilder v0.61.17 [03:20:50] Source: FLASH_GORDON_-_4K_UHD - Input BD size: 78,49 GB - Approximate total content: [02:40:38.926] - Target BD size: 46,26 GB - Windows Version: 6.2 [9200] - Quality: Highest (Very Slow), CQM - Decoding/Frame serving: NVENCC - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [03:20:50] PHASE ONE, Encoding - [03:20:50] Processing: VID_00002 (1 of 13) - [03:20:50] Extracting A/V streams [VID_00002] - [03:21:02] Reencoding video [VID_00002] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 481 frames - [03:21:02] Performing CQM Prediction... - Analyzing 1,00 16,80 17,90 18,55 19,05 19,40 [19,48] - [03:21:44] Encoding using constant quality mode. - [03:21:57] Video Encode complete - [03:21:57] Processing audio tracks - Track 4352 (eng): Keeping original audio - [03:21:57] Multiplexing M2TS - [03:22:01] Processing: VID_00003 (2 of 13) - [03:22:01] Extracting A/V streams [VID_00003] - [03:22:05] Reencoding video [VID_00003] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 289 frames - [03:22:05] Performing CQM Prediction... - Analyzing 38,80 34,70 32,50 30,90 29,70 28,85 28,25 27,65 27,05 26,75 26,45 26,10 [26,10] - [03:23:22] Encoding using constant quality mode. - [03:23:31] Video Encode complete - [03:23:31] Processing audio tracks - [03:23:31] Multiplexing M2TS - [03:23:34] Processing: VID_00004 (3 of 13) - [03:23:34] Extracting A/V streams [VID_00004] - [03:23:38] Reencoding video [VID_00004] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 157 frames - Bitrate: 2 086 Kbs - [03:23:38] Reencoding: VID_00004, Pass 1 of 2 - [03:23:43] Reencoding: VID_00004, Pass 2 of 2 - [03:23:43] Video Encode complete - [03:23:43] Processing audio tracks - [03:23:43] Multiplexing M2TS - [03:23:47] Processing: VID_00005 (4 of 13) - [03:23:47] Extracting A/V streams [VID_00005] - [03:23:50] Reencoding video [VID_00005] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 121 frames - Bitrate: 2 182 Kbs - [03:23:50] Reencoding: VID_00005, Pass 1 of 2 - [03:23:55] Reencoding: VID_00005, Pass 2 of 2 - [03:23:55] Video Encode complete - [03:23:55] Processing audio tracks - [03:23:55] Multiplexing M2TS - [03:23:59] Processing: VID_00006 (5 of 13) - [03:23:59] Extracting A/V streams [VID_00006] - [03:24:02] Reencoding video [VID_00006] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 120 frames - Bitrate: 500 Kbs - [03:24:02] Reencoding: VID_00006, Pass 1 of 2 - [03:24:07] Reencoding: VID_00006, Pass 2 of 2 - [03:24:07] Video Encode complete - [03:24:07] Processing audio tracks - [03:24:07] Multiplexing M2TS - [03:24:10] Processing: VID_00007 (6 of 13) - [03:24:10] Extracting A/V streams [VID_00007] - [03:24:14] Reencoding video [VID_00007] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 192 frames - Bitrate: 1 861 Kbs - [03:24:14] Reencoding: VID_00007, Pass 1 of 2 - [03:24:21] Reencoding: VID_00007, Pass 2 of 2 - [03:24:21] Video Encode complete - [03:24:21] Processing audio tracks - [03:24:21] Multiplexing M2TS - [03:24:24] Processing: VID_00008 (7 of 13) - [03:24:24] Extracting A/V streams [VID_00008] - [03:24:27] Reencoding video [VID_00008] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 192 frames - Bitrate: 542 Kbs - [03:24:28] Reencoding: VID_00008, Pass 1 of 2 - [03:24:34] Reencoding: VID_00008, Pass 2 of 2 - [03:24:34] Video Encode complete - [03:24:34] Processing audio tracks - [03:24:34] Multiplexing M2TS - [03:24:37] Processing: VID_00009 (8 of 13) - [03:24:37] Extracting A/V streams [VID_00009] - [03:24:41] Reencoding video [VID_00009] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 261 frames - [03:24:41] Performing CQM Prediction... - Analyzing 37,70 35,45 34,40 33,60 33,15 32,80 [32,80] - [03:25:20] Encoding using constant quality mode. - [03:25:28] Video Encode complete - [03:25:28] Processing audio tracks - [03:25:28] Multiplexing M2TS - [03:25:31] Processing: VID_00010 (9 of 13) - [03:25:31] Extracting A/V streams [VID_00010] - [03:25:35] Reencoding video [VID_00010] - Source Video: HEVC, 3840x2160 - Rate/Length: 23,976fps, 240 frames - [03:25:35] Performing CQM Prediction... - Analyzing 31,05 26,70 23,80 21,55 19,65 17,95 1,00 17,80 9,40 13,60 [14,12] - [03:26:40] Encoding using constant quality mode. - Performing size-correcting second pass... - [03:26:55] Video Encode complete - [03:26:55] Processing audio tracks - [03:26:55] Multiplexing M2TS - [03:26:59] Processing: VID_00011 (10 of 13) - [03:26:59] Extracting A/V streams [VID_00011] - [03:27:02] Reencoding video [VID_00011] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 168 frames - Bitrate: 1 704 Kbs - [03:27:02] Reencoding: VID_00011, Pass 1 of 2 - [03:27:08] Reencoding: VID_00011, Pass 2 of 2 - [03:27:08] Video Encode complete - [03:27:08] Processing audio tracks - [03:27:08] Multiplexing M2TS - [03:27:11] Processing: VID_01000 (11 of 13) - [03:27:11] Extracting A/V streams [VID_01000] - [04:01:06] Reencoding video [VID_01000] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 160 554 frames - [04:01:06] Performing CQM Prediction... - Analyzing 1,00 17,05 18,15 18,90 19,60 20,30 20,95 21,55 21,90 22,05 [22,08] - [04:08:44] Encoding using constant quality mode. - [05:15:08] Video Encode complete - [05:15:08] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (deu): Keeping original audio - Track 4355 (fra): Keeping original audio - Track 4356 (eng): Keeping original audio - Track 4357 (eng): Keeping original audio - [05:15:08] Multiplexing M2TS - Bitstream exception. Adjusting... success. - [05:55:18] Processing: VID_02000 (12 of 13) - [05:55:18] Extracting A/V streams [VID_02000] - [05:56:28] Reencoding video [VID_02000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24,000fps, 40 089 frames - [05:56:28] Performing CQM Prediction... - Analyzing 20,80 22,95 [23,02] - [05:56:41] Encoding using constant quality mode. - Performing size-correcting second pass... - [06:03:00] Video Encode complete - [06:03:00] Processing audio tracks - Track 4352 (eng): Keeping original audio - [06:03:00] Multiplexing M2TS - [06:03:19] Processing: VID_02001 (13 of 13) - [06:03:19] Extracting A/V streams [VID_02001] - [06:04:40] Reencoding video [VID_02001] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24,000fps, 20 814 frames - [06:04:40] Performing CQM Prediction... - Analyzing 11,50 19,90 20,15 [20,17] - [06:04:54] Encoding using constant quality mode. - [06:07:22] Video Encode complete - [06:07:22] Processing audio tracks - Track 4352 (eng): Keeping original audio - [06:07:22] Multiplexing M2TS [06:07:43]PHASE ONE complete [06:07:43]PHASE TWO - Rebuild Started - [06:07:43] Rebuilding BD file Structure [06:09:31] - Encode and Rebuild complete [06:09:31] JOB: FLASH_GORDON_-_4K_UHD finished. VID_02000 (12 of 13) is the extra I have used for tests which gets CQM of - Analyzing 20,80 22,95 [23,02]. After that It displays a message - Performing size-correcting second pass... Can this be something of interest? //LD |
