Old 2nd December 2017, 19:54   #14541  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by mtamimi View Post
"VideoReDo or similar can recode only boundaries" << Does this make a difference?
Recode always lose quality, but it's the best choice if you need that cut.
If you need more info please open a thread in video subforum, is off topic here.
tebasuna51 is offline
Old 2nd December 2017, 20:14   #14542  |  Link
mtamimi
Does not worth it. I prefer the 8s silence...
mtamimi is offline
Old 5th December 2017, 17:59   #14543  |  Link
ashlar42
Is there any up to date GUI available?
ashlar42 is offline
Old 13th December 2017, 07:52   #14544  |  Link
pstn
Does anyone know if there are any risks or downside to demuxing from a share (LAN) or a mounted ISO?
pstn is offline
Old 13th December 2017, 08:09   #14545  |  Link
It's not much different to copying files. Mostly sequential reading from one file, and mostly sequential writing into a few other files. I would try to avoid both reading and writing over LAN due to low speed.
LigH is offline
Old 19th December 2017, 20:39   #14546  |  Link
Megalith
Can someone clarify whether or not "Removing AC3 dialog normalization" affects TrueHD tracks? Or does it only affect the AC3 "core" track?
Megalith is offline
Old 1st January 2018, 05:33   #14547  |  Link
Ripman
I was trying to convert a .ts file to mkv. I got a message about the audio track not being "clean". See below. What does that mean? Thanks and happy new year.
eac3to v3.34
command line: eac3to   war_requiem.ts 1: v.h264 2: a.flac
TS, 1 video track, 1 audio track, 1:30:00, 50p
1: h264/AVC, 720p50 (16:9)
2: AC3, German, 2.0 channels, 448kbps, 48kHz, dialnorm: -23dB, 9ms
[v01] Extracting video track number 1...
[a02] Extracting audio track number 2...
[a02] Removing AC3 dialog normalization...
[a02] Decoding with libav/ffmpeg...
[a02] Applying RAW/PCM delay...
[a02] Reducing depth from 64 to 24 bits...
[a02] Encoding FLAC with libFlac...
[v01] Creating file "v.h264"...
[a02] This track is not clean.  <WARNING>
[a02] Creating file "a.flac"...
[a02] Audio has a gap of 32ms at playtime 0:00:02.  <WARNING>
[a02] Starting 2nd pass...
[a02] Realizing RAW/PCM gaps...
Video track 1 contains 270021 frames.
eac3to processing took 1 hour, 18 minutes.
Done.
[edit] the output flac from the command above was 270min - was supposed to be 90 min. Must be a bad audio stream in that .Ts file. I’ll post the mediainfo.
[edit2]mediainfo -f
General
Count                                    : 327
Count of stream of this kind             : 1
Kind of stream                           : General
Stream identifier                        : 0
Count of video streams                   : 1
Count of audio streams                   : 1
Video_Format_List                        : AVC
Video_Format_WithHint_List               : AVC
Codecs Video                             : AVC
Audio_Format_List                        : AC-3
Audio_Format_WithHint_List               : AC-3
Audio codecs                             : AC3
Audio_Language_List                      : German
Complete name                            : C:\0\War_Requiem.ts
Folder name                              : C:\0
File name                                : War_Requiem
File extension                           : ts
Format                                   : MPEG-TS
Format                                   : MPEG-TS
Format/Extensions usually used           : ts m2t m2s m4t m4s tmf ts tp trp ty
Commercial name                          : MPEG-TS
Internet media type                      : video/MP2T
Codec                                    : MPEG-TS
Codec                                    : MPEG-TS
Codec/Extensions usually used            : ts m2t m2s m4t m4s tmf ts tp trp ty
File size                                : 6321633292
File size                                : 5.89 GiB
File size                                : 6 GiB
File size                                : 5.9 GiB
File size                                : 5.887 GiB
Duration                                 : 5400380.000000
Duration                                 : 1 h 30 min
Duration                                 : 1 h 30 min 0 s 380 ms
Duration                                 : 01:30:00.380
Duration                                 : 01:30:00:23
Duration                                 : 01:30:00.380 (01:30:00:23)
Overall bit rate mode                    : VBR
Overall bit rate mode                    : Variable
Overall bit rate                         : 9364703
Overall bit rate                         : 9 365 kb/s
Maximum Overall bit rate                 : 35500000
Maximum Overall bit rate                 : 35.5 Mb/s
Frame rate                               : 50.000
Frame rate                               : 50.000 FPS
Frame count                              : 270023
Stream size                              : 315367443
Stream size                              : 301 MiB (5%)
Stream size                              : 300.8 MiB
Proportion of this stream                : 0.04989
File creation date                       : UTC 2017-12-31 22:57:08.222
File creation date (local)               : 2017-12-31 17:57:08.222
File last modification date              : UTC 2015-10-16 14:42:01.150
File last modification date (local)      : 2015-10-16 09:42:01.150
OverallBitRate_Precision_Min             : 9364702
OverallBitRate_Precision_Max             : 9364704
Video
Count                                    : 338
Kind of stream                           : Video
StreamOrder                              : 0-0
Menu ID                                  : 1
Menu ID                                  : 1 (0x1)
Format                                   : AVC
Format/Url                               : http://developers.videolan.org/x264.html
Commercial name                          : AVC
Format profile                           : High@L4
Format settings                          : CABAC / 4 Ref Frames
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 4
Format settings, ReFrames                : 4 frames
Format settings, GOP                     : M=4, N=32
Internet media type                      : video/H264
Codec ID                                 : 27
Codec                                    : AVC
Codec                                    : AVC
Codec/Family                             : AVC
Codec/Info                               : Advanced Video Codec
Codec/Url                                : http://developers.videolan.org/x264.html
Codec profile                            : High@L4
Codec settings                           : CABAC / 4 Ref Frames
Codec settings, CABAC                    : Yes
Codec_Settings_RefFrames                 : 4
Duration                                 : 5400460
Duration                                 : 1 h 30 min 0 s 460 ms
Duration                                 : 01:30:00.460
Duration                                 : 01:30:00.460 (01:30:00:23)
Bit rate mode                            : VBR
Bit rate                                 : 8449420
Bit rate                                 : 8 449 kb/s
Maximum bit rate                         : 40000000
Maximum bit rate                         : 40.0 Mb/s
Width                                    : 1280
Width                                    : 1 280 pixels
Height                                   : 720
Height                                   : 720 pixels
Sampled_Width                            : 1280
Sampled_Height                           : 720
Pixel aspect ratio                       : 1.000
Display aspect ratio                     : 1.778
Frame rate                               : 50.000
Resolution                               : 8
Resolution                               : 8 bits
Colorimetry                              : 4:2:0
Bit depth                                : 8
Interlacement                            : PPF
Interlacement                            : Progressive
Bits/(Pixel*Frame)                       : 0.183
Delay                                    : 600000.000
Delay                                    : 10 min 0 s
Delay                                    : 10 min 0 s 0 ms
Delay                                    : 10 min 0 s
Delay                                    : 00:10:00.000
Delay, origin                            : Container
Stream size                              : 5703844345
Stream size                              : 5.31 GiB (90%)
Stream size                              : 5 GiB
Stream size                              : 5.3 GiB
Stream size                              : 5.312 GiB
Proportion of this stream                : 0.90227
Buffer size                              : 30000000
Audio
Count                                    : 306
Kind of stream                           : Audio
StreamOrder                              : 0-1
Menu ID                                  : 1
Menu ID                                  : 1 (0x1)
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Commercial name                          : AC-3
Format settings, Endianness              : Big
Codec ID                                 : 129
Codec                                    : AC3
Codec                                    : AC3
Duration                                 : 5400384
Duration                                 : 1 h 30 min 0 s 384 ms
Duration                                 : 01:30:00.384
Duration                                 : 01:30:43:29
Duration                                 : 01:30:00.384 (01:30:43:29)
Bit rate mode                            : CBR
Bit rate                                 : 448000
Bit rate                                 : 448 kb/s
Channel(s)                               : 2
Channel positions                        : Front: L R
Channel positions                        : 2/0/0
ChannelLayout                            : L R
Samples per frame                        : 1536
Sampling rate                            : 48000
Sampling rate                            : 48.0 kHz
Samples count                            : 259218432
Frame rate                               : 31.250
Frame rate                               : 31.250 FPS (1536 spf)
Frame count                              : 168762
Resolution                               : 16
Resolution                               : 16 bits
Bit depth                                : 16
Bit depth                                : 16 bits
Delay                                    : 600009.000
Delay                                    : 10 min 0 s
Delay                                    : 10 min 0 s 9 ms
Delay                                    : 10 min 0 s
Delay                                    : 00:10:00.009
Delay relative to video                  : 9
Delay relative to video                  : 9 ms
Delay relative to video                  : 00:00:00.009
Video0 delay                             : 9
Video0 delay                             : 9 ms
Video0 delay                             : 9 ms
Video0 delay                             : 9 ms
Video0 delay                             : 00:00:00.009
Stream size                              : 302421504
Stream size                              : 288 MiB (5%)
Stream size                              : 288.4 MiB
Proportion of this stream                : 0.04784
Language                                 : de
Language                                 : German
Language                                 : German
Language                                 : de
Language                                 : deu
Language                                 : de
Service kind                             : CM
Service kind                             : Complete Main
bsid                                     : 6
dialnorm                                 : -23
dialnorm                                 : -23 dB
compr                                    : -0.28
compr                                    : -0.28 dB
dsurmod                                  : 1
dsurmod                                  : Not Dolby Surround encoded
acmod                                    : 2
lfeon                                    : 0
dialnorm_Average                         : -23
dialnorm_Average                         : -23 dB
dialnorm_Minimum                         : -27
dialnorm_Minimum                         : -27 dB
dialnorm_Maximum                         : -23
dialnorm_Maximum                         : -23 dB
dialnorm_Count                           : 1885
compr_Average                            : -0.13
compr_Average                            : -0.13 dB
compr_Minimum                            : -0.28
compr_Minimum                            : -0.28 dB
compr_Maximum                            : 2.36
compr_Maximum                            : 2.36 dB
compr_Count                              : 1885
dynrng_Average                           : 0.11
dynrng_Average                           : 0.11 dB
dynrng_Minimum                           : 0.00
dynrng_Minimum                           : 0.00 dB
dynrng_Maximum                           : 2.15
dynrng_Maximum                           : 2.15 dB
dynrng_Count                             : 1885
format_identifier                        : AC-3
Ripman is offline
Old 1st January 2018, 13:09   #14548  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by Ripman View Post
...the output flac from the command above was 270min - was supposed to be 90 min.
Your AC3 seems have some frames 2.0, but most of them are 5.1.
Extract and split the AC3 track.
http://forum.doom9.org/showthread.ph...95#post1447695
Old 1st January 2018, 15:59   #14549  |  Link
Ripman
Thanks for that tip. Which line in the mediainfo report caught your attention? I tried the SplitAc3 program. Here is the log:
FileSize : 302421504 bytes
---------- First valid Header
Time eq. : 5400384 ms.
SamplCod : 0 (0:48, 1:44.1, 2:32 KHz.)
BitRate  : 448 Kb/s
ChanMode : 2 (1:1/0, 2:2/0, 3:3/0, 4:2/1, 5:3/1, 6:2/2, 7:3/2)
FrameSize: 1792 bytes
---------- Process ( 25.000000 fps is used for Trim)
Time: 0 ms.	Written: 69 frames 2.0	( 2208 ms.)
Time: 2208 ms.	Written: 2 frames 5.1	( 64 ms.)	Trim(55, 56)
Time: 2272 ms.	Skipped: 1792 bytes	(Maybe: 32 ms.)
Time: 2304 ms.	Written: 168665 frames 5.1	( 5397280 ms.)	Trim(58, 134989)
Time: 5399584 ms.	Written: 6 frames 2.0	( 192 ms.)
Time: 5399776 ms.	Written: 9 frames 5.1	( 288 ms.)	Trim(134994, 135000)
Time: 5400064 ms.	Written: 1 frames 2.0	( 32 ms.)
Time: 5400096 ms.	Written: 3 frames 5.1	( 96 ms.)	Trim(135002, 135003)
Time: 5400192 ms.	Skipped: 1792 bytes	(Maybe: 32 ms.)
Time: 5400224 ms.	Written: 5 frames 2.0	( 160 ms.)
---------- End of File
Total time: 5400384 ms. at EOF
T. written: 168679 frames 5.1.
T. written: 81 frames 2.0.
[edit] looking at the splitac3 log, it seems like my tv signal got a bit corrupted — a little at the start, and a little at the end. It seems like splitac3 put 2ch samples in one output file, and 5.1ch samples in another file.
I could go back to the source .ts file, trim 2.304 secs from the start, preserve the next 5397280 ms (01:29:57.28), discard everything after that, and then extract the audio. Or, I could "zero-out" the first 2 frames (64ms) from the SplitAc3 5.1ch output, and everything after (64ms + 5397280 ms). Does this sound about right? How do I account for delays in the original audio stream? Thanks again.
Ripman is offline
Old 1st January 2018, 19:34   #14550  |  Link
tebasuna51
tebasuna51's Avatar
Nothing in MediaInfo.
Is a typical problem, the output length is 3 times the expected because 5.1 have 3 times samples than 2.0
If you don't need the video I think is better cut the ts file, maybe commercials.
But if the video is OK you can use the 5.1 extracted by SplitAc3 with:
eac3to split51.ac3 one.ac3 -64ms
(the first 2 frames)
eac3to one.ac3 two.ac3 +2304ms
(audio/video delay)
And, maybe, you can delete the last 12 frames with DelayCut, only if sound bad.
Old 2nd January 2018, 14:17   #14551  |  Link
Ripman
>clever fellow
(audio/video delay)
Thanks for the tip. Video and audio recovered. SplitAc3 worked nicely - if'd be cool to have an option with that simple program to leave samples in contiguous numbered files.
Ripman is offline
Old 2nd January 2018, 15:26   #14552  |  Link
Ripman
Is there any plans to integrate eac3to with mkvextract/mkvmerge? I know it works with haali, but I wondered about the others too. Almost positive I read about this within the thread last year.
Ripman is offline
Old 2nd January 2018, 15:29   #14553  |  Link
nautilus7
nautilus7's Avatar
ffmpeg mkv muxing support would be easier.
nautilus7 is offline
Old 2nd January 2018, 18:25   #14554  |  Link
Midzuki
Unavailable
Midzuki's Avatar
I agree, Haali is dead, and Nero is dead as well, it's time to drop them.
Midzuki is offline
Old 3rd January 2018, 18:26   #14555  |  Link
stax76
stax76's Avatar
mp4 muxing for avc/hevc would also be useful because LSMASHVideoSource/LibavSMASHSource can open it without indexing. (something I miss from the mkv format)
stax76 is offline
Old 3rd January 2018, 18:48   #14556  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Agreed
SeeMoreDigital is offline
Old 3rd January 2018, 23:38   #14557  |  Link
Ripman
I like ffmpeg too. But I ended up at mkvmerge years ago, and the developer is pretty accessible via doom9.
Are there specific ffmpeg mkv capabilities that you use or prefer? Any capabilities that exist in ffmpeg but not in mkvmerge? Thanks.
Ripman is offline
Old 4th January 2018, 09:31   #14558  |  Link
stax76
stax76's Avatar
I think the discussion was meant about muxing libraries which mkvtoolnix probably don't expose, the ffmpeg library for muxing/demuxing is called libavformat I believe.
stax76 is offline
Old 4th January 2018, 11:29   #14559  |  Link
sneaker_ger
At what point does it become easier to add eac3to features to ffmpeg than vice versa?
sneaker_ger is offline
Old 4th January 2018, 14:28   #14560  |  Link
nautilus7
nautilus7's Avatar
Who said that?
If you're referring to me, I said that it would be easier to add mkv muxing with ffmpeg (libavformat), as eac3to already uses ffmpeg for decoding.
eac3to
