17th March 2017, 20:54 | #14162 | Link |
Acid fr0g
Just found, dunno if #old:
aften.dll git-20091226-icl11_1_054 dcadec.dll 0.2.0 Tested and working. If somebody has other newer and working dll's to replace, please post.
@turment on Telegram |
20th March 2017, 13:44 | #14164 | Link | |
47.952fps@71.928Hz
The git for FFMPEG should be more updated than GitHub. commits from foo86: https://git.ffmpeg.org/gitweb/ffmpeg...author&s=foo86 commits about avcodec/dca in general: https://git.ffmpeg.org/gitweb/ffmpeg...=avcodec%2Fdca Madshi might have to remove dcadec DLL's in favor of FFMPEG udpates. Which means, we'd just have to wait for madshi to update his modified libraries whenever FFMPEG goes through major updates.
Win10 (x64) build 19041 NVIDIA GeForce GTX 1060 3GB (GP106) 3071MB/GDDR5 | (r435_95-4) NTSC | DVD: R1 | BD: A AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
20th March 2017, 18:13 | #14165 | Link |
The same for aften dll's, maybe are fast thanks to wisodev optimizations, but with the same problems than old aften
The AC3 encoder included in ffmpeg is the preferred.
22nd March 2017, 02:36 | #14166 | Link |
Newbie trying to get eac3to to work with test
Hello all,
I have been lurking the doom9 forums for quite some time now, and been experimenting to get eac3to work, but I am a little stuck. Running a test on my command line, I am getting the following messages: Microsoft Windows [Version 6.1.7601] Copyright (c) 2009 Microsoft Corporation. All rights reserved. C:\Users\User\Documents\Conversions>C:\Users\User\Documents\eac3to\eac3to.exe -t est eac3to (v3.31) is up to date Nero Audio Decoder (Nero 6 or older) doesn't seem to be installed http://www.nero.com/eng/store-blu-ray.html CAUTION: You need Nero 7. Nero 8 won't work with eac3to. ArcSoft DTS Decoder doesn't seem to be installed http://www.arcsoft.com/products/totalmediatheatre Sonic Audio Decoder (3.31.0.0) doesn't seem to be installed Haali Matroska Muxer (2013-04-14) is installed Nero AAC Encoder (1.5.4.0) is installed Surcode DTS Encoder (1.0.29.0) is installed Does anybody know where I can find/buy the Nero Audio decoder? As well as the ArcSoft and Sonic ones? Also, which versions will work best? Are Libav / ffmpeg the same program? Thank you for all of your help. I usually use Headac3e and tsMuxer, but I am hearing this is a much better encoder. Would love to get started, thank you for your support! Sorry for all the questions, just trying to get started! |
22nd March 2017, 05:34 | #14167 | Link | |
Welcome.
Depends on the desired meaning... The ffmpeg project contains libraries for the handling of containers (libavformat) and contents (libavcodec). During some stage of development, some developers split and created a fork of ffmpeg, named libav. It doesn't matter much, probably, from which fork you prefer to use the codec libraries as long as they are up to date, so they can handle modern HD audio formats as well. Quote:
Toughest question, regarding the ArcSoft decoder; several versions have different (dis-)advantages. I believe only "fanatic" audiophiles care. Home users won't recognize a difference to the results of libav* decoders while just listening in their living rooms, especially after compressing with another lossy format... |
22nd March 2017, 13:37 | #14169 | Link | |
You can extract the AAC track from a .mkv and use other free tool (ffmpeg,...) to recode, if you need recode, most the times is better preserve the AAC track as is. Install not free Nero 7 for only this function is not recommended. - ArcSoft (not free) DTS Decoder is only needed to decode DTS Express (some comentary audio tracks in BD's) like sneaker_ger say. Also ffmpeg can be used for that. The included decoder (dcadec) is equal, or best, than ArcSoft for DTS standard and HD. - Sonic Audio Decoder (not free) is not needed at all. It was used at first time to compare outputs, but now it is not recommended. You can work with eac3to without these 3 commercial soft's.
24th March 2017, 01:45 | #14170 | Link |
This is wrong. libdcadec can decode the full lossless DTS-HD parts, even the "strange setup" streams that ArcSoft does not decode lossless in all cases.
24th March 2017, 02:28 | #14171 | Link |
eac3to v3.31 + ArcSoft DTS Decoder doesn't work anymore?
Just one question,
When I had eac3to v3.27, I could decode DTS Master Audio with ArcSoft Decoder: Code:
eac3to v3.27 command line: "C:\Program Files (x86)\eac3to\eac3to.exe" "F:\BDRips\Bob Marley & The Wailers\Legend\Blu-ray\FullDisc\BD_VOLUME\BDMV\STREAM" 1) 4:"D:\MyBDRips\1_4_audio.flac" -progressnumbers ------------------------------------------------------------------------------ M2TS, 1 video track, 3 audio tracks, 1:07:21, 24p /1.001 1: Chapters, 16 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: RAW/PCM, English, 2.0 channels, 24 bits, 96kHz 4: DTS Master Audio, English, 5.1 channels, 24 bits, 96kHz (core: DTS-96/24, 5.1 channels, 24 bits, 1509kbps, 96kHz) 5: TrueHD/AC3, English, 5.1 channels, 96kHz (embedded: AC3, 5.1 channels, 640kbps, 48kHz) [a04] Extracting audio track number 4... [a04] Decoding with ArcSoft DTS Decoder... [a04] Encoding FLAC with libFlac... [a04] Creating file "D:\MyBDRips\1_4_audio.flac"... [a04] The original audio track has a constant bit depth of 24 bits. Video track 2 contains 96897 frames. eac3to processing took 41 minutes, 17 seconds. Done. Code:
[22:11:40] Retrieving features [22:11:40] Arguments: "F:\BDRips\Bob Marley & The Wailers\Legend \Blu-ray\FullDisc\BD_VOLUME\BDMV" [22:11:41] Feature Retrieval Completed [22:11:41] Retrieving streams [22:11:41] Arguments: "F:\BDRips\Bob Marley & The Wailers\Legend \Blu-ray\FullDisc\BD_VOLUME\BDMV" 1) -progressnumbers [22:11:46] Stream Retrieval Completed [22:11:58] Extracting streams [22:11:59] Arguments: "F:\BDRips\Bob Marley & The Wailers\Legend \Blu-ray\FullDisc\BD_VOLUME\BDMV" 1) 4:"D:\MyBDRips\Bob Marley & The Wailers\Legend\Blu-ray\FullDisc\BD_VOLUME\BDMV\1_4_audio.flac" -progressnumbers [22:12:04] a04 Extracting audio track number 4... [22:12:04] a04 Decoding with libDcaDec DTS Decoder... [22:12:04] a04 libDcaDec reported the warning "XLL output not lossless". [22:12:04] a04 Encoding FLAC with libFlac... [22:12:05] a04 Creating file "D:\MyBDRips\Bob Marley & The Wailers\Legend\Blu-ray\FullDisc\BD_VOLUME\BDMV\1_4_audio.flac"... [22:12:15] Stream Extraction Completed Code:
C:\Program Files (x86)\eac3to>eac3to -test eac3to (v3.31) is up to date Nero Audio Decoder (Nero 6 or older) doesn't seem to be installed http://www.nero.com/eng/store-blu-ray.html CAUTION: You need Nero 7. Nero 8 won't work with eac3to. ArcSoft DTS Decoder (1.1.0.0) works fine Sonic Audio Decoder (3.31.0.0) doesn't seem to be installed Haali Matroska Muxer doesn't seem to be installed http://haali.net/mkv Nero AAC Encoder could not be located http://www.nero.com/eng/nero-aac-codec.html Copy NeroAacEnc.exe to the eac3to or to the Windows folder. Surcode DTS Encoder doesn't seem to be installed http://www.surcode.com Does anybody know what's going on? Thank you very much
Greetings GONZALO |
24th March 2017, 02:36 | #14172 | Link | |
Greetings GONZALO Last edited by gonzalo76; 24th March 2017 at 06:20. Reason: wrong info |
24th March 2017, 05:50 | #14174 | Link | |
Yeah, it seems as if you need a very early version of ArcSoft... I tried installing ArcSoft TotalMedia Theatre 6.7 and eac3to doesn't seem to pick up the DTS Decoder. Even when I moved it into System Folders. |
24th March 2017, 06:41 | #14175 | Link | |
Unavailable
P.S.:
24th March 2017, 07:02 | #14176 | Link |
OK, I downloaded the latest release version 0.2.0, released on 4 Jan 2016. The warning message "XLL output not lossless" disappeared now!!!
But instead of 24 bits, the decoded file has 16 bits, with libDcaDec DTS Decoder and also with ArcSoft DTS Decoder Decoding with libDcaDec DTS Decoder... Code:
eac3to v3.31 command line: "C:\Program Files (x86)\eac3to\eac3to.exe" "D:\BDrips\Def Leppard\ Viva! Hysteria\BDMV" 2) 1:"D:\BDrips\Def Leppard\Viva! Hysteria\2_1_chapter.txt" 3:"D:\BDrips\Def Leppard\Viva! Hysteria\2_3_audio.flac" -progressnumbers ------------------------------------------------------------------------------ M2TS, 1 video track, 2 audio tracks, 0:38:44, 24p /1.001 1: Chapters, 8 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: DTS Master Audio, English, 5.1 channels, 24 bits, 48kHz (core: DTS, 5.1 channels, 1509kbps, 48kHz) 4: DTS Master Audio, English, 2.0 channels, 24 bits, 48kHz (core: DTS, 2.0 channels, 1509kbps, 48kHz) Creating file "D:\BDrips\Def Leppard\Viva! Hysteria\2_1_chapter.txt"... [a03] Extracting audio track number 3... [a03] Decoding with libDcaDec DTS Decoder... [a03] Encoding FLAC with libFlac... [a03] Creating file "D:\BDrips\Def Leppard\Viva! Hysteria\2_3_audio.flac"... [a03] The original audio track has a constant bit depth of 16 bits. [a03] Superfluous zero bytes detected, will be stripped in 2nd pass. [a03] Starting 2nd pass... [a03] Decoding FLAC... [a03] Reducing depth from 24 to 16 bits... [a03] Encoding FLAC with libFlac... [a03] Creating file "D:\BDRips\Def Leppard\Viva! Hysteria\2_3_audio.flac"... [a03] The processed audio track has a constant bit depth of 16 bits. Video track 2 contains 55725 frames. eac3to processing took 10 minutes, 50 seconds. Done. Code:
==> ..\BDMV\PLAYLIST\01002.mpls >> M2TS, 1 video track, 2 audio tracks, 1:25:21, 24p /1.001 (16 chapters) > 3: DTS Master Audio, English, 5.1 channels, 24 bits, 48kHz > 4: DTS Master Audio, English, 2.0 channels, 24 bits, 48kHz > eac3to v3.31 command line: "eac3to.exe" "D:\BDrips\Def Leppard\Viva! Hysteria\BDMV\PLAYLIST\01002.mpls" 1) 4:"D:\BDrips\Def Leppard\Viva! Hysteria\Output.wav" -arcsoft -progressnumbers ------------------------------------------------------------------------------ M2TS, 1 video track, 2 audio tracks, 1:25:21, 24p /1.001 1: Chapters, 16 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: DTS Master Audio, English, 5.1 channels, 24 bits, 48kHz (core: DTS, 5.1 channels, 1509kbps, 48kHz) 4: DTS Master Audio, English, 2.0 channels, 24 bits, 48kHz (core: DTS, 2.0 channels, 1509kbps, 48kHz) [a04] Extracting audio track number 4... [a04] Decoding with ArcSoft DTS Decoder... [a04] Writing WAV... [a04] Creating file "D:\BDrips\Def Leppard\Viva! Hysteria\Output.wav"... [a04] The original audio track has a constant bit depth of 16 bits. [a04] Superfluous zero bytes detected, will be stripped in 2nd pass. [a04] Starting 2nd pass... [a04] Reading WAV... [a04] Stripping zero bytes... [a04] Writing WAV... [a04] Creating file "D:\BDrips\Def Leppard\Viva! Hysteria\Output.wav"... Video track 2 contains 122783 frames. eac3to processing took 6 minutes, 37 seconds. Done. Thank you. Last edited by gonzalo76; 24th March 2017 at 07:45. Reason: added ArcSoft log |
24th March 2017, 07:46 | #14177 | Link |
47.952fps@71.928Hz
IIRC, all decoders for DTS (dcadec, arcsoft) do the same thing with "XLL output no lossless".
Except, they were all silent, so the only difference was that the recent dcadec allowed the message to be seen. One user did make a custom build that just hid the message again for the placebo users who want that message "out of sigh of mind". Arcsoft has so many versions, and no one has thoroughly tested the last version (1.09), so we can't really say if it behaves the same as previous versions or has different negative behaviours like some versions of Arcsoft. For Arcsoft, v1.0.0.0 is the most known version to handle most scenarios. But Dcadec should be the same and handle all formats (including Strange Setup, which Arcsoft requires a specific version) except for DTS Express.
24th March 2017, 07:48 | #14178 | Link |
47.952fps@71.928Hz
Superfluous means "unnecessary", so it was really 16bit stored in a 24bit.
24th March 2017, 09:59 | #14179 | Link | |
Unavailable
https://github.com/foo86/dcadec/issues/33 |
eac3to |
