22nd August 2018, 14:37 | #5581 | Link | |
Errr... Are you sure that you have write access to the directory where the ini resides? If so, try out the following: - backup your ini file - set the player to not use ini file - delete the ini file - set the player back to use ini file - now try out again
23rd August 2018, 01:25 | #5582 | Link | |
There was no need to delete the ini file, it disappeared automatically when the player was set to not use ini file, and reappeared automatically when the player was set back to use the ini file. After doing what you suggested I went through the four steps I posted previously. The player still retains the last subtitle selected, and does not honor the Prefer external subtitle flag. If, however, I deselect the option Keep history of recently opened files, then the Prefer external subtitle flag is honored. It looks then like the behavior is related to that Keep history flag, rather than the use of the ini file. Even without an ini file, the player remembers the last selected subtitle if the Keep history flag is selected. |
23rd August 2018, 03:36 | #5583 | Link |
Yes - history remember selected subtitles. And it's remember even if select external(auto-loaded) subtitles.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 Last edited by Aleksoid1978; 23rd August 2018 at 03:45. |
23rd August 2018, 14:50 | #5584 | Link | |
24th August 2018, 00:09 | #5585 | Link | |
I use the keep history flag principally to remember the last opened position of a video file i.e. to resume play from that position. There may be another way to do that, but I don't know of one. Last edited by raymondjpg; 24th August 2018 at 00:21. |
24th August 2018, 08:59 | #5586 | Link |
Sorry if this has been asked before but is there a way so that the chapter name is always visible in the 'time code' bar right next to 'Play', 'Pause' or what ever the current status is ???
When I jump to a chapter the name is displayed only for a few seconds !! I find that useful for music content like concerts, etc. |
24th August 2018, 11:25 | #5587 | Link |
MPC-BE latest beta b3788 always (!) freezes when using After Playback - Standby. I didn't have this issue with 1.5.2 beta b3445. Can somebody confirm this? Thanks
25th August 2018, 07:20 | #5589 | Link |
25th August 2018, 12:16 | #5590 | Link | |
27th August 2018, 17:12 | #5593 | Link |
Is there any way to make MPC-BE auto-size window with album covers? "Limit window proportions on resize" doesn't seem to work either with album covers.
It looks like this when you open a music file with album cover: https://i.imgur.com/cfmQGDJ.png Would be much cleaner if it looked like this when opening a file instead: https://i.imgur.com/yBJSVcp.png Worked like this in MPC-HC but I prefer to use MPC-BE as I like it more overall. Is there some setting I'm missing or is this not possible? |
27th August 2018, 22:31 | #5594 | Link |
Auto-size with covers don't support.
28th August 2018, 06:00 | #5595 | Link |
Check - no freezes, MPC-BE close, system StandBy.
28th August 2018, 10:04 | #5596 | Link |
Thanks for checking! I still got the freeze every time (!) with latest beta and nightly. I'll put back beta b3445 today to see what happens.
To clarify it what happens: - set player to standby - it properly put the computer into sleep - but when I wake up Windows then MPC-BE app is still there (it should have quit properly) and there's a Windows popup with 3 buttons that the application isn't responding
28th August 2018, 13:31 | #5598 | Link | |
29th August 2018, 01:48 | #5599 | Link | |
