15th December 2013, 16:49 | #18581 | Link | |
Also, 80GB is a very small space to use as your workdrive. It is likely that at some point you are going to hit an error due to no disc space being available. Last edited by jdobbs; 15th December 2013 at 16:51. |
15th December 2013, 17:10 | #18582 | Link |
feedback on error
Okay, hmmm, interesting thoughts. I've looked at that error link before, but there doesn't seem to be a conclusion to it.
I'm only using 80GB, as I have limited data storage on the virtual device. I will just try something else on the VM and make it a thick client. As to whether the original files are being changed, I find that unlikely, as they're not being used by anything else, and what other program would be changing the files? Admittedly it does take 5+ hours (usually 10) to do the first 1/2 of decoding. Otherwise, any ideas? I'm just trying another rip direct from the BD player, but this isn't really practical for a final solution, as the BD drive is on a laptop that is constantly moving around, and can't be kept on all the time. |
15th December 2013, 17:27 | #18583 | Link | |
15th December 2013, 18:52 | #18584 | Link |
jbromley, I'm not sure if this is related to what you're trying to do but one time I tried to use the source and working path for BDRebuilder through the network as I was low on space on my local rig at that time and BDRebuilder wouldn't work properly. I think it was due to not being able to access the files properly as I was doing the encoding on my main rig but using my network drives as the space for the work that were on another pc in the network What I didn't think of at the time and this idea MAY work for you. If you want to use your network drives to do the work but use another pc for encoding you might want to try mapping the remote drives on your encoding rig to have BDRebuilder think that those drives are local as windows explorer will show that drive as a local drive with a drive letter. You would then use those mapped drives as your source and encoding folders.
It's just an idea that may or may not help you accomplish what you're trying to do. Last edited by Audiophile1178; 15th December 2013 at 18:58. |
15th December 2013, 21:59 | #18585 | Link | |
16th December 2013, 00:04 | #18586 | Link | |
16th December 2013, 00:32 | #18588 | Link | |
Just saw how to link to an actual post |
16th December 2013, 08:37 | #18589 | Link | |
It's all part his Master Plan for major fame...longest Beta in history. We're on to you.....!!!
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 16th December 2013 at 08:41. |
16th December 2013, 08:53 | #18590 | Link | |
17th December 2013, 19:07 | #18591 | Link |
when trying to import a .ts file into bd-rebuilder the log shows the following error: [18:21:31] Importing TS: NUHR_2013_-_DER_JAHRESRÜCKBLICK - Preparing TS for processing... [18:24:34]ERROR: Gathering source file information. Aborted. [18:24:35]ERROR: Gathering source file information. Aborted. - Collecting audio/video streams from source... [18:24:35]ERROR: Gathering source file information. Aborted. The file was recorded from TV and has the following specs: h264, 50 FPS progressive, 1280x720 AC3 2.0, 48 KHz, 448 kBit Any idea why this happens and how to get it working (inspect.exe shows no errror)? Thanks, Tobi |
17th December 2013, 19:12 | #18592 | Link | |
17th December 2013, 19:47 | #18593 | Link | |
So my guess is either long filenames and/or spaces in filenames caused the issue. I will try later to find out as I am encoding right now ;-). Thanks again Tobi |
17th December 2013, 20:36 | #18594 | Link |
As said in the very firstpost, the first time BD Rebuilder is lauched, there is a message to change the Codec in the Windows Ragistry.
Is there any risk that this change disturb the other programs installed in the PC ? Tks |
17th December 2013, 22:45 | #18596 | Link |
No, it shouldn't. It changes the default Directshow CODECs for VC-1, MPEG-2, and AVC to those found in FFDSHOW. The Directshow interface has been standardized, and if other programs access Directshow, these CODECs will work with them.
18th December 2013, 02:34 | #18597 | Link |
Hi
thank you for your works on bdrb I was wondering if there were other reasons for the video to freeze, but audio/subtitles to continue? With the common reason being a bad rip, some sort of video glitch. At first this common reason was sound, for me. I tried doing planes, trains and automobiles and I saw a , maybe a .3-5 seconds freeze before scene change, and the re encode got stuck on that the rest of way. But then it has happened to me again with The right stuff. And with that latest one the Original video looks fine. I did a newer title recently and no issues. I was just wondering if there was something I could do to look into it. I recently did a fresh install, everything updated and configured. A log would not shed light on this I believe? I mean..bd-rb finished the shrink to bd25 as per normal. No errors. Maybe this is just a coincidence? maybe viewing the original video for glitches does not tell all and theres something wrong with the rip. thank you for any insight. |
18th December 2013, 02:48 | #18598 | Link | |
18th December 2013, 04:25 | #18599 | Link |
Rodiefs
Can't open file errors
First I want to say what a wonderful job you are doing on BD-Rebuilder!
I'm wondering if someone can help me. I just tried to backup the Season 1 BDs for the original Star Trek TV Series. On Season 1 Disk 2, I am trying to backup track 00010 using the "Other movie-only playlist" under the mode tab. It completes Phase 1 and when Phase 2 starts it comes back with the following error: 18:43:48]PHASE TWO - Rebuild Started - [18:43:48] Rebuilding BD file Structure - Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta - Can't open file: D:\MULTIMEDIA FILES\TEMP\E5\WORKFILES\00075.track_4352.DTS [18:43:51] - Failed to REBUILD A similar error is also happening with track 00002 of the Season 1 Disc 3 Star Trek TV series. (Season 1 Disk 1 episodes backed up just fine). Now if I take the two (Disk 2 and 3) BD rips and do a full backup of them - BD-Rebuilder backs up the rips successfully. I can also drag the 00010.mpls file or Disk 2 and the 00002.mpls file of disk 3 from their BD Playlist Rip folder to MPC and it plays fine. I'm ripping the BDs to the hard drive using the latest version of AnyDVD HD. I'm just using BD-Rebuilder to strip away unwanted languages, subtitles, warning messages and previews, extras etc. I'm not doing any compression on my BD-Rebuilder backups but I am backing up using the movie-only backup option to the hard drive. I've tried these backups on two different Windows 7 64-bit Ultimate machines with the same two errors when using BD-Rebuilder V0.45.05. I've backed up several hundred BD movies using these settings with virtually no problems. But this is the first time that I tried backing-up TV BDs and by episode. I figured that 2 errors on 3 BDs seemed worth mentioning. Any thoughts? Attached is the log and BD-Rebuilder config files as well. |
18th December 2013, 13:55 | #18600 | Link | |
Why not just use the IMPORT function? |
