11th January 2014, 17:20 | #18761 | Link | |
I don't have Vista installed on any of my systems right now, so I can't test it. What version number shows when BD-RB runs under Vista (I can't remember)? |
11th January 2014, 18:31 | #18762 | Link |
well there won't be issues with windows itself, but their may be issues with the custom (accounting) software. For pdf functionality, it relies on a custom built (by them) of a pdf printer (non-adobe) which may stop working on the upgrade, same for in-app invoice mailing capabilities.
Inspect shows: windows version 6.0 [6002] for vista |
11th January 2014, 18:48 | #18763 | Link | |
11th January 2014, 20:07 | #18766 | Link | |
Thanks a lot for the new version. |
11th January 2014, 20:41 | #18767 | Link | |
Is 3D enabled "silently"? The menu structure and Settings look like before for 2D. I may probably be missing something ..... ? Edit: I just found that 3D encoding gets automatically enabled for "movie only" if the source is 3D. No special settings required. Now the question remains what to do it if I want the Movie Only backup in 2D? Last edited by Sharc; 11th January 2014 at 21:08. |
12th January 2014, 04:26 | #18770 | Link |
BD-RB fails to process a 704x464 MKV file
When BD-RB v0.45.05 processes a 704x464 pixel MKV file I have, it imports the file OK, but when I press Backup the process fails with the message "Haali Media Splitter. Error: can't open file: The media type of this file is not recognized." The file was produced by VidCoder (= Handbrake). Inspect.exe gives OK for all tests.
Here are the MKV file details: Width : 704 pixels Height : 464 pixels Display aspect ratio : 4:3 Original display aspect ratio : 4:3 Frame rate : 29.970 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) [jdobbs kindly commented on this problem in the tsMuxeR GUI thread, but moved the discussion (by mistake, I think) to the DVD Rebuilder thread rather than the BD-RB thread.] |
12th January 2014, 11:19 | #18771 | Link | |
It is perhaps a bit irritating that the log lists the irrelevant settings for 2-D as well, like - RESIZE 1920 to 1440 enabled - X264 Tweak(s) enabled These have no effect though; pure cosmetics. Last edited by Sharc; 12th January 2014 at 11:24. |
12th January 2014, 12:33 | #18772 | Link | |
I sent you a short sample; anything special with the format? Not terribly important as I had this problem only with this particular disc so far. |
12th January 2014, 12:34 | #18773 | Link |
thanks for the last BDRB version !!! I 've tried to make a BR3D movie only backup. i wish to do this without reencoding, but i cannot find how. for BR2D, if final size is lower than destination, then there is no reencode. but for 3D, there is always reencoding of the video part. Is there a way to do 3DBR without reencoding? |
12th January 2014, 12:41 | #18774 | Link | |
FORCE_NOENCODE=1 in the BDREBUILDER.ini ? (see hiddenopts.txt) |
12th January 2014, 14:14 | #18775 | Link | |
12th January 2014, 14:15 | #18776 | Link | |
12th January 2014, 14:17 | #18778 | Link | |
12th January 2014, 16:15 | #18779 | Link |
Can I use this soft to fix bug on 3D Blu-ray Disc? Because I have a problem with pop-up menu. So that if I keep the Pop-Up menu, it can play in 3D. But if I remove the Pop-Up menu in the playlist, I can play 3D clip normally. I think it's a problem when I using tsmuxer to remux the main clip and when I re-add the old Pop-up menu in to that playlist, it does not match the ID anymore. So does your software can correct that problem?
So I want to know clearly before going to use your software. Thank you so much. |
12th January 2014, 18:20 | #18780 | Link | |
How are you re-adding the pop-up, with BDEDIT? 3D gets tricky because there is additional stream information kept in MPLS and CLPI extensions. Last edited by jdobbs; 12th January 2014 at 18:23. |
