2nd July 2012, 12:41 | #1041 | Link | |
Also, I just realized that I somehow lost the code I added for switching between languages in multiple language IDX/SUB files. I'll be adding that back in before the 1.0.0 final. |
2nd July 2012, 13:09 | #1043 | Link | |
PgcEdit daemon
It would be nice to be able to create a shortcut to BDSup2Sub++ with the option --load-settings --no-fix-invisible --minimum-time 0 --alpha-thr 40, to open the GUI in "DVD mode", without changing the other user settings. It's currently not possible, due to the missing --no-fix-invisible. Also, currently, my GUI converts normally the subs automatically (without loading the settings file), but it has an option to load the SUP in the GUI, and let the user modify what he wants before saving the converted sub manually. In that case, I would like to load the INI for some defaults, but force the "DVD mode". (Of course, the user can change the forced options, but it's his responsibility.) BTW, it's certainly why the java version has that possibility. [EDIT]
2nd July 2012, 13:15 | #1044 | Link |
PgcEdit daemon
I've found another bug. When trying to load a palette with the --palette-file arg, the program outputs always the same error message: ERROR: Not a valid palette file
The palette I was trying to load has been generated by my GUI, and the java version loads it without problem. I've tried to export a palette with the ++ version, and noticed that the file format is different. Now, it has a "[General]" category, not present in the java versions. So, I did the test again, this time with a file of the correct format, but the same error happens. Not sure why. BTW, I agree that the new format is better, as it's a real INI, but the new format will not be compatible with many other programs (including PgcEdit). That might be a problem.
2nd July 2012, 13:19 | #1045 | Link |
Can you upload the file? It should read the INI file just fine as I tested loading palette ini's exported from the Java program to verify it worked via the GUI. There's a bug in the CLI code probably.
The reason the output looks different is that I'm using Qt's INI writing class which uses the Win32 APIs whereas the Java used custom code to write it and that's why it looks different. |
2nd July 2012, 13:32 | #1048 | Link |
PgcEdit daemon
Indeed, the palettes can be loaded in ++ with the GUI. It's certainly a CLI bug.
bdsup2sub++.exe --language fr --palette-file "E:\TEMP\PGC2MKV TEMP\Subtitles_palette.ini" --alpha-thr 40 --minimum-time 0 -o "E:\TEMP\PGC2MKV TEMP\Subpictures_22.sub" "E:\TEMP\PGC2MKV TEMP\Subpictures_22.idx" Given the tests I've made with the java version, it requires a comment as the first line, beginning with "#COL". Without that line, I have never been able to load a palette (from CLI or GUI). But this palette can be loaded in both versions (GUI only for ++): Code:
#COL - VTST 2, 1 TTN 1 (2:51) Title 3 # Exported by PgcEdit's PGC2MKV plugin [General] Color_0=0, 0, 0 Color_1=0, 0, 0 Color_2=0, 0, 0 Color_3=0, 0, 0 Color_4=0, 0, 0 Color_5=0, 0, 0 Color_6=0, 0, 0 Color_7=0, 0, 0 Color_8=0, 0, 0 Color_9=0, 0, 0 Color_10=0, 0, 0 Color_11=0, 0, 0 Color_12=0, 0, 0 Color_13=204, 204, 204 Color_14=0, 0, 0 Color_15=0, 0, 0
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 2nd July 2012 at 13:35. |
2nd July 2012, 13:38 | #1049 | Link |
Yeah, I'm rewriting the code to output the palette so it's like the Java one. The program INI file will still use the Qt class so there will probably be incompatibilities there, but I don't really want to have to use a bunch of custom code for that.
2nd July 2012, 13:41 | #1050 | Link |
PgcEdit daemon
Oh, I think the CLI palette bug could be caused by the single \ characters. Is it necessary to convert them to / or \\ ?
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 2nd July 2012 at 13:46. |
2nd July 2012, 13:42 | #1051 | Link | |
PgcEdit daemon
Pity: it is probably not easy to add a comment in the INI with the Qt class.
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 2nd July 2012 at 13:44. |
2nd July 2012, 13:54 | #1053 | Link |
PgcEdit daemon
OK. But why dit it fail from the CLI but not in the GUI? Is it not the same code?
2nd July 2012, 14:37 | #1055 | Link |
Ok, well I have to go to work now. Palette writing code matches what Java version does when you export the DVD Palette and the detection code for specifying an input palette INI is fixed. I got the complementary "--no" CLI options in for the boolean options that can be read from the INI file (export palette, fix invisible frames, and verbatim logging) so they can be overridden if you want to also read in your settings INI. Also, in the GUI I've added default settings to the buttons in popup the dialogs so you can use the enter key to hit the okay button in the conversion dialog, to activate the move all in the move dialog, etc.
Changes that are set to be made are so that if you pass a non-wildcard input file but specify no output that it will load the GUI and set the options you passed in. Also there were two suggestions about switching between subtitles from the GUI by either using spacebar or pgup/pgdown. The keyboard shortcut will be implemented as well. Since this will take more time than I can do right now it'll have to wait until either tonight or tomorrow. New version to download is here. |
2nd July 2012, 15:04 | #1056 | Link |
PgcEdit daemon
Thanks! I'll test it tonight...
2nd July 2012, 15:25 | #1057 | Link |
PgcEdit daemon
Just did a test. There are still some problems:
bdsup2sub++.exe --language fr --palette-file Subtitles_palette.ini --alpha-thr 40 --minimum-time 0 -o Subpictures_22.sub Subpictures_22.IFO OPTION: Set alpha threshold to 40 OPTION: Set language to French (fr) OPTION: Loaded palette from Subtitles_palette.ini OPTION: Set delay to 0 QxtCommandOptions: option "no-verbatim" not found QxtCommandOptions: option "no-fix-invisible" not found Converting SUB/IDX There was 1 warning Conversion of 1 file(s) finished The original java version issues this warning: Code:
# 1 WARNING: Invisible caption due to zero alpha (not fixed due to user setting). The QxtCommandOptions messages are printed to stderr, so my GUI assumes that an error occurred, although it's not really the case. Anyway, these messages are abnormal.
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 2nd July 2012 at 15:28. |
2nd July 2012, 16:17 | #1058 | Link |
Hmm, I don't know why you get those messages since those options were added to the QxtCommandOptions class. Also, passing options to a program that it doesn't recognize seems to be an error to me so I don't see the problem with it writing that to stderr. Although it should have quit had it gotten unrecognized options so I'll see why it didn't.
And I don't know why the messages don't print out. I'll double check to make sure the signals/slots are all connected properly and being emitted as they should. Edit to add: I figured out the problem with the new options. I had accidently left out a , when I added to "no-verbatim" switch to the method that takes the option name and description. This caused it to be unrecognized. Though when I tested it it immediately showed the error, displayed the options list and then exited. Why it didn't exit for you I don't get. Also the console logging issue is fixed too. The way I was checking to see whether we were logging for the GUI or console had an issue. I'll be able to push out a version here in a few minutes. Last edited by SassBot; 2nd July 2012 at 16:35. |
2nd July 2012, 16:51 | #1059 | Link |
New version here with the aforementioned fixes.
So I was just testing the keyboard shortcut to rapidly change between subtitle numbers in the GUI and pgup/pgdown will be problematic due to the image windows that also accept those key presses. Spacebar would be a good key since it won't be used by those. Unless someone has a better key suggestion. Last edited by SassBot; 2nd July 2012 at 16:56. |
