Old 11th January 2010, 17:23   #2981  |  Link
neo_sapien
StaxRip is such an awesome program, and I use it a great deal. Thanks so much for all the work you put into it!
I have a couple questions:
1) Using StaxRip with x264, if, instead of resizing your video, say to 720x400 for 16:9, you keep the video at 720x480 and tell the mkv to display it as 16:9, will this result in a higher quality video, though at the cost of increased bitrate?
2) Are you sure that a 55% compressibility check is optimal? In the 55% compressibility check encodes that I've done, the resulting videos come out at times showing signs of overcompression. A smoothed image where you would expect to find a sharp, detailed image, etc. My encodes thus far have been with the "speed" setting set to medium. Or maybe setting it to slow or slower would help the quality?
neo_sapien is offline
Old 11th January 2010, 17:33   #2982  |  Link
stax76
stax76's Avatar
can you add a option to exit and minimize StaxRip to the system tray etc when no jobs are running?
Why not close it if you don't use it? Regarding LINQBridge, it's probably to late to consider using it. Do you know which version of the .NET Framework is included with Win 7, if it's 3.5 then LINQBridge isn't much interesting.
stax76 is offline
Old 11th January 2010, 17:38   #2983  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@neo_sapien
dont resize unless you want to or have to as to hit a certain size or device as far compressibility checks try your next encode with the x264 Film HQ Preset instead of a Two Pass one and see if it works for you cheers
MuLTiTaSK is offline
Old 11th January 2010, 18:01   #2984  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@stax76
Windows Seven Ultimate Edition x64 (6.1.0.7600)
Old 11th January 2010, 18:27   #2985  |  Link
stax76
stax76's Avatar
@MuLTiTaSK
Looks good, StaxRip should run out the box on Win 7 then.
stax76 is offline
Old 11th January 2010, 18:51   #2986  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@stax76
it did for me
Old 11th January 2010, 19:04   #2987  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@stax76
try to link up with Zathor to see if he can help you get DGIndexNV working with StaxRip cause he's done a great job integrating it with MeGUI i just tested it out and DGIndexNV is working
Old 11th January 2010, 19:44   #2988  |  Link
stax76
stax76's Avatar
@MuLTiTaSK
I've not tested recent MeGUI builts but from reading the thread I noticed Zathor is doing a good job. He gave me a hint to add a delay but since it's still crashing for now best thing I can do is wait until my card arrives, it should arrive this week.
stax76 is offline
Old 11th January 2010, 19:57   #2989  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@stax76
sweet at least we know it's possible that's a good thing
Old 11th January 2010, 20:30   #2990  |  Link
neo_sapien
@multitask
I did two encodes to test out x264 Film HQ, one using that profile (which came out to about 760kbps), and another using a 2-pass encode which came out to 2,112 kbps. In the Film HQ one, forehead creases and walls were noticeably smoother and compressed-looking, while in the much larger version, they looked sharp and crisp. A third encode was done at 55% compressibility, which came out just a few kbps smaller than the Film HQ one, but the two looked about the same.
Old 11th January 2010, 20:45   #2991  |  Link
stax76
stax76's Avatar
@neo_sapien
At the time 50% for x264 was established a long time ago it was similar quality to 60% XviD/DivX which was the recommended value when post processing was used. I've recently changed the assistant to only complain if it's 20% from what is defined in the encoder options.
stax76 is offline
Old 11th January 2010, 21:18   #2992  |  Link
myksto
StaxRip Fan
myksto's Avatar
@stax76
@neo_sapien
I always use quality mode set to 20 (is it a good setting?) for my H264 encodings in the encoder properties.
What i'd like to ask you is how I should use the "aimed quality ratio" (maybe the one you've been talking about) that is always set to 50% and that I always set to 95%.
myksto is offline
Old 11th January 2010, 22:01   #2993  |  Link
stax76
stax76's Avatar
@myksto
Best thing you can do is encode samples and movies with different values and compare the output size and image quality. CRF 18 is 100% quality and this result in large files. I always use crf values between 20 and 24, depends on various factors but mostly on the image size, small image > 20-22, large image > 22-24.
stax76 is offline
Old 11th January 2010, 23:03   #2994  |  Link
stax76
stax76's Avatar
Here is a new test built:
http://www.filedropper.com/staxrip1141
It allows to customize quality, preset and tune directly from the main dialog using a context menu and has some fixes and a couple of other small changes.
stax76 is offline
Old 11th January 2010, 23:40   #2995  |  Link
sneaker_ger
Do you have version 1141? If so then I forgot to reset the main menu, you can do this in three different ways, do you know one of them? I can't help with the command shell unless somebody built a console app with my code, 100 lines simple VB.NET code, should take less an hour to port.
Yes, I'm using version 1141. I've found the option to reset the menu and it works now. It doesn't demux the attachments though.
sneaker_ger is offline
Old 11th January 2010, 23:42   #2996  |  Link
stax76
stax76's Avatar
@sneaker_ger
Please upload a sample or mkvinfo output.
stax76 is offline
Old 11th January 2010, 23:49   #2997  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@stax76
thanks stax76 i will test asap
can you please upload to your site or MediaFire i'am getting very slow speeds and i want to test something that you might like to include with StaxRip
Old 11th January 2010, 23:57   #2998  |  Link
sneaker_ger
http://www.mediafire.com/?mldmmlzzjm1
(MKVInfo) + EBML-Kopf an 0
(MKVInfo) |+ Dokumententyp: matroska an 5
(MKVInfo) |+ Dokumententyp Version: 2 an 16
(MKVInfo) |+ Dokumententyp Leseversion: 2 an 20
(MKVInfo) + Segment, Größe 2351265 an 24
(MKVInfo) |+ Seek-Kopf an 36
(MKVInfo) | + Seek-Eintrag an 41
(MKVInfo) |  + Seek ID: 0x15 0x49 0xa9 0x66 (KaxInfo) an 44
(MKVInfo) |  + Seek-Position: 4099 an 51
(MKVInfo) | + Seek-Eintrag an 56
(MKVInfo) |  + Seek ID: 0x16 0x54 0xae 0x6b (KaxTracks) an 59
(MKVInfo) |  + Seek-Position: 4262 an 66
(MKVInfo) | + Seek-Eintrag an 71
(MKVInfo) |  + Seek ID: 0x11 0x4d 0x9b 0x74 (KaxSeekHead) an 74
(MKVInfo) |  + Seek-Position: 2351164 an 81
(MKVInfo) | + Seek-Eintrag an 87
(MKVInfo) |  + Seek ID: 0x1c 0x53 0xbb 0x6b (KaxCues) an 90
(MKVInfo) |  + Seek-Position: 2351144 an 97
(MKVInfo) | + Seek-Eintrag an 103
(MKVInfo) |  + Seek ID: 0x19 0x41 0xa4 0x69 (KaxAttachments) an 106
(MKVInfo) |  + Seek-Position: 5540 an 113
(MKVInfo) |+ EbmlVoid (Größe: 4014) an 118
(MKVInfo) |+ Segment-Information an 4135
(MKVInfo) | + Zeitstempelskalierungsfaktor: 1000000 an 4141
(MKVInfo) | + Muxeranwendung: libebml v0.7.9 + libmatroska v0.8.1 an 4148
(MKVInfo) | + Schreibende Anwendung: mkvmerge v3.0.0 ('Hang up your Hang-Ups') gebaut am Jan  6 2010 22:49:38 an 4186
(MKVInfo) | + Dauer: 10.395s (00:00:10.395) an 4261
(MKVInfo) | + Datum: Mon Jan 11 22:55:25 2010 UTC an 4268
(MKVInfo) | + Segment-UID: 0x8e 0x74 0x06 0x43 0x99 0x7d 0xc1 0x4c 0x8b 0xb9 0xa6 0xde 0x88 0xdb 0xea 0x89 an 4279
(MKVInfo) |+ Segment-Tracks an 4298
(MKVInfo) | + Ein Track an 4304
(MKVInfo) |  + Tracknummer: 1 an 4307
(MKVInfo) |  + Track UID: 1653795474 an 4310
(MKVInfo) |  + Tracktyp: video an 4317
(MKVInfo) |  + Aktiv: 1 an 4320
(MKVInfo) |  + Standardtrack-Flag: 1 an 4323
(MKVInfo) |  + Flag für erzwungene Anzeige: 0 an 4326
(MKVInfo) |  + Flag für Paketbündelung: 0 an 4330
(MKVInfo) |  + MinCache: 1 an 4333
(MKVInfo) |  + Zeitstempelskalierungsfaktor: 1 an 4337
(MKVInfo) |  + Maximale BlockAddition ID: 0 an 4345
(MKVInfo) |  + Codec-ID: V_MPEG4/ISO/AVC an 4349
(MKVInfo) |  + Codec alle frames decodieren: 1 an 4366
(MKVInfo) |  + private Codecdaten, Länge 42 an 4369
(MKVInfo) |  + Standarddauer: 41.708ms (23.976 Bilder pro Sekunde im Falle eines Videotracks) an 4414
(MKVInfo) |  + Sprache: und an 4422
(MKVInfo) |  + Video-Track an 4429
(MKVInfo) |   + Pixelbreite: 1280 an 4431
(MKVInfo) |   + Pixelhöhe: 528 an 4435
(MKVInfo) |   + Interlaced: 0 an 4439
(MKVInfo) |   + Anzeigebreite: 1280 an 4442
(MKVInfo) |   + Anzeigehöhe: 528 an 4447
(MKVInfo) | + Ein Track an 4452
(MKVInfo) |  + Tracknummer: 2 an 4454
(MKVInfo) |  + Track UID: 3943032720 an 4457
(MKVInfo) |  + Tracktyp: audio an 4464
(MKVInfo) |  + Aktiv: 1 an 4467
(MKVInfo) |  + Standardtrack-Flag: 1 an 4470
(MKVInfo) |  + Flag für erzwungene Anzeige: 0 an 4473
(MKVInfo) |  + Flag für Paketbündelung: 1 an 4477
(MKVInfo) |  + MinCache: 0 an 4480
(MKVInfo) |  + Zeitstempelskalierungsfaktor: 1 an 4484
(MKVInfo) |  + Maximale BlockAddition ID: 0 an 4492
(MKVInfo) |  + Codec-ID: A_AAC an 4496
(MKVInfo) |  + Codec alle frames decodieren: 1 an 4503
(MKVInfo) |  + private Codecdaten, Länge 7 an 4506
(MKVInfo) |  + Standarddauer: 42.667ms (23.438 Bilder pro Sekunde im Falle eines Videotracks) an 4516
(MKVInfo) |  + Sprache: und an 4524
(MKVInfo) |  + Audio track an 4531
(MKVInfo) |   + Abtastrate: 24000 an 4533
(MKVInfo) |   + Kanäle: 2 an 4539
(MKVInfo) |   + Ausgabeabtastrate: 48000 an 4542
(MKVInfo) |+ EbmlVoid (Größe: 1024) an 4549
(MKVInfo) |+ Dateianhänge an 5576
(MKVInfo) | + Anhang an 5583
(MKVInfo) |  + Dateiname: avatar_poster.jpg an 5588
(MKVInfo) |  + MIME-Typ: image/jpeg an 5608
(MKVInfo) |  + Dateiinhalt, Größe: 99221 an 5621
(MKVInfo) |  + Datei-UID: 3940027820 an 104847
(MKVInfo) |+ Cluster an 104854
Old 12th January 2010, 00:03   #2999  |  Link
stax76
stax76's Avatar
@MuLTiTaSK
Here is a mirror:
http://www.stax76.bplaced.net/files/...Rip_1.1.4.1.7z
@sneaker_ger
Thanks for the sample, I'll try to fix it.
stax76 is offline
Old 12th January 2010, 00:07   #3000  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@stax76
attempting to open x264 settings i got a crash
gui, h.264, h.265, hevc, mkv, x264, x265
