Old 20th August 2020, 20:18   #29881  |  Link
cartman0208
I was hoping this might be a quick fix, especially after I noted the differences... but it doesn't look like it is getting any attention at all.
I could probably write code to make this fix myself, but I'd hesitated since the last time I did that a fix was made a couple days later. Another reason for hesitating is that it will add time (since I'd have to scan and rewrite the entire HEVC file after the encode is done).
I would wait ... several days with no contribution or blog activity ... maybe rigaya is on vacation ?
Old 21st August 2020, 00:19   #29882  |  Link
BD Rebuilder v0.61.12
I have updated the first post of this thread with a link to the latest version (v0.61.12) of BD Rebuilder. Cumulative changes for this release (since the last public release):
- This list includes changes made since the
  last public release (v0.61.05).
- Added support for NVIDIA NVENC encoding.
- Corrected an error that could cause BD-RB
  to exit in failure when attempting a size-
  correcting second pass in CRF mode while
  doing a UHD backup.
- Added code that will update the HDR flags
  in the MPLS file for sources in which HDR
  was not established until after reencoding
  on full backups.
- Fixed an error in which MPEG2 sources may
  not make video adjustments detected during
  import when reencoding. This could result
  in stretched or compressed images.
- Created a workaround for a problem with
  converting PAL to NTSC flags during import
  which could confuse TSMUXER's recognition
  of video resolution.
- Added code to adapt to UHD sources that are
  not sized to either 3840(h) or 2160(v).
- Corrected an issue in which video sources
  that are an odd size during import might
  use the wrong resizing when HEVC encoding
  is enabled.
- Fixed a bug in which large audio offsets
  detected during import were not being
  interpreted correctly.
- Fixed a bug that could cause undersizing
  when an AC3 stream is kept intact because
  the original is smaller than the selected
  reencoder bitrate.  This typically only
  happens on DVD imports.
- Fixed an error that could result in wrong
  aspect ratio on imported sources that are
  being resized.
- Corrected an issue in which some command
  line settings were not being set when a
  non-UHD source is output as V3.
- Added a routine to ensure formatting of
  CRF values consistent.
- Updated CQM prediction routines.
- Fixed an issue that can cause the CQM/CRF
  sample file to have a zero length when
  used in other-than-US regions.
- Modified NVENCC options to eliminate vbrhq
  from the command line, as it is targeted
  to be deprecated.  Replaced by "vbr" and
  manually enabling "--multipass 2pass-full"
  (the newer equivalent of vbrhq).
- Rewrote the "Bitstream Exception" TSMUXER
  error workaround routine so it now uses
  a more efficient method -- and better
  adjusts audio sync.  It also now adjusts
  for Dolby Vision exception errors.
- Fixed an issue in which BT709 sources were
  not being encoded with proper settings.
- Increased the accepted value of the THREADS
  hidden option from 16 to 128. Note:  While
  128 is accepted for x264 -- realistically
  you should never set it that high.
- Added support for HDR10+ in X265 encoding
  and experimental (needs testing) support
  for NVENCC. A JSON file is created con-
  currently with video extraction. HDR10+
  streams are now identified in the streams
  list by a "+" next to "HEVC". Note that "*"
  indicates Dolby Vision. "*+"=both. To enable
  experimental support in NVENCC, as the
  hidden value NVENC_ENABLE_10PLUS=1 to your
  BDREBUILDER.INI file.
- Corrected an error that would result in
  only 48 frames being encoded during CRF
  prediction when using X265.
- Changed the ALTERNATE settings so creating
  a preset that outputs HEVC to MP4 is now
  allowed.
- Fixed an issue that could result in an
  error "ExtractAudioSubs() 00058  1605".
- Fixed a problem that could cause multipart
  sources to fail during rebuild when
  outputting to ALTERNATE choices.
- Implemented a method by which a different
  background image could be used for multpage
  menus. Menu pages 2-x can be changed by
  adding additional file(s) into the same
  folder as the initial background image.
  Example:  If the background image is called
  "BACKGROUND.JPG".  You can us another
  image for page 2 by creating an image called
  "BACKGROUND_2.JPG" (page 3=BACKGROUND_3.JPG)
  etc.
- Updated the included version of MP4BOX to
  support HEVC.
- Updated the included versions of X265 to a
  newer (v3.2.1) release.
Old 21st August 2020, 07:22   #29883  |  Link
meadrocks
Howls Moving Castle
Ran Howls Moving Castle w/ the new version, same problem. I'll try with a mp4 container.
$ mediainfo HOWLS_MOVING_CASTLE.mkv
General
Unique ID                                : 221294904985475506127951980034512522439 (0xA67BD931150DAFE18584E1C6A43E0CC7)
Complete name                            : HOWLS_MOVING_CASTLE.mkv
Format                                   : Matroska
Format version                           : Version 2
File size                                : 2.44 GiB
Duration                                 : 3 h 53 min
Overall bit rate                         : 1 495 kb/s
Encoded date                             : UTC 2020-08-21 06:17:34
Writing application                      : mkvmerge v9.7.1 ('Pandemonium') 32bit
Writing library                          : libebml v1.3.4 + libmatroska v1.4.5
Video
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main 10@L4@Main
Codec ID                                 : V_MPEGH/ISO/HEVC
Duration                                 : 1 h 59 min
Bit rate                                 : 2 611 kb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Frame rate                               : 23.976 (23976/1000) FPS
Original frame rate                      : 23.976 (24000/1001) FPS
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.053
Stream size                              : 2.18 GiB (89%)
Writing library                          : x265 3.2.1+3-b4b2ecac21f6:[Windows][GCC 9.2.0][64 bit] 10bit
Encoding settings                        : cpuid=1111039 / frame-threads=3 / numa-pools=8 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 /
input-res=1920x1080 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud /
no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=240 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 /
rc-lookahead=20 / lookahead-slices=6 / scenecut=40 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 /
tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra /
strong-intra-smoothing / max-merge=3 / limit-refs=1 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / no-hme / weightp / no-weightb /
no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=3 / selective-sao=4 / early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless /
b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=23.7 / qcomp=0.60 /
qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 /
no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 /
display-window=0 / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps /
no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt / no-dhdr10-opt /
no-idr-recovery-sei / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao /
ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt /
no-field / qp-adaptation-range=1.00
Audio
Format                                   : AAC LC
Format/Info                              : Advanced Audio Codec Low Complexity
Codec ID                                 : A_AAC-2
Bit rate                                 : 277 kb/s
Channel(s)                               : 6 channels
Channel layout                           : C L R Ls Rs LFE
Sampling rate                            : 48.0 kHz
Frame rate                               : 46.875 FPS (1024 SPF)
Stream size                              : 237 MiB (9%)
Text #1
Format                                   : PGS
Muxing mode                              : zlib
Codec ID                                 : S_HDMV/PGS
Codec ID/Info                            : Picture based subtitle format used on BDs/HD-DVDs
Duration                                 : 3 h 49 min
Bit rate                                 : 10.8 kb/s
Count of elements                        : 2845
Stream size                              : 17.7 MiB (1%)
Default                                  : No
Text #2
Format                                   : PGS
Muxing mode                              : zlib
Bit rate                                 : 7 807 b/s
Count of elements                        : 2062
Stream size                              : 13.0 MiB (1%)
Default                                  : No
Menu
00:00:00.000                             : en:00:00:00.000
00:01:09.069                             : en:00:01:09.069
00:05:03.302                             : en:00:05:03.302
00:12:27.037                             : en:00:12:27.037
00:18:27.397                             : en:00:18:27.397
00:23:21.691                             : en:00:23:21.691
00:28:56.025                             : en:00:28:56.025
00:33:18.287                             : en:00:33:18.287
00:40:14.703                             : en:00:40:14.703
00:45:35.023                             : en:00:45:35.023
00:49:20.248                             : en:00:49:20.248
00:55:30.618                             : en:00:55:30.618
00:58:36.804                             : en:00:58:36.804
01:04:58.185                             : en:01:04:58.185
01:10:58.545                             : en:01:10:58.545
01:15:28.815                             : en:01:15:28.815
01:20:30.116                             : en:01:20:30.116
01:25:26.412                             : en:01:25:26.412
01:32:35.841                             : en:01:32:35.841
01:38:39.204                             : en:01:38:39.204
01:44:26.551                             : en:01:44:26.551
01:48:27.792                             : en:01:48:27.792
01:52:24.028                             : en:01:52:24.028
01:54:43.209                             : en:01:54:43.209
01:59:27.201                             : en:01:59:27.201
meadrocks is offline   Reply With Quote
Old 21st August 2020, 08:47   #29884  |  Link
MrVideo
MrVideo's Avatar
  etc.
Somehow I missed that new feature. I like it and will be using it. Thanks.
Old 21st August 2020, 14:21   #29885  |  Link
@meadrocks
I notice that the source is 1920x1080. Was it imported into BD-RB, or was it from a BD disc?
Old 21st August 2020, 15:58   #29886  |  Link
meadrocks
Howls Moving Castle
@meadrocks
The source is a BD disk.
When making a mp4 I get an "ERROR in attempt to mux (MP4BOX)"
Trying Watchmen DC disk now.
Old 21st August 2020, 16:20   #29887  |  Link
Are you sure you are using the new version -- including the helper files that are included with the new version?
I didn't make any changes to affect the subtitles -- but I did multiple tests with MP4BOX without error.
By "Watchmen DC" are you referring to the Directors Cut (DC)?
Old 21st August 2020, 16:45   #29888  |  Link
BD Rebuilder v0.61.13
Updated the first post of this thread with a new version (v0.61.13) of BD Rebuilder. Changes for this release:
This is nothing more than a recompile of v0.61.12. Apparently some antivirus software was (incorrectly) flagging BD-RB.EXE. Changing the version number seems to have "fixed" it. Just another antivirus false positive. Go figure.
I've also updated the v0.61.12 zip file so it downloads v0.61.13. The last thing I need is people driving me crazy with reports of false positives from antivirus mistakes.
Old 21st August 2020, 21:25   #29889  |  Link
meadrocks
Yes Watchmen Dir Cut. its 186 minutes long. Both of these BD disks (Howls Moving Castle & Watchmen Dir Cut) are multi part.
Old 21st August 2020, 23:27   #29890  |  Link
meadrocks
Heres the Input file.
[Status]
LABEL=WATCHMEN
VERSION=v0.61.12
SOURCE_SIZE=35145842688
SOURCE_VIDEO_SIZE=35145842688
TARGET_SIZE=4686086144
REDUCTION=.133332587458487
RESIZE_1080=0
RESIZE_1440=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=0
SUBS_TO_KEEP=all
BACKUP_MODE=1
MOVIEONLY_TYPE=41
USE_LAVF=0
INSTANCES=1
DGDECNV=0
DGDECIM=0
FRIMSOURCE=0
FFMS2=0
SSIF_MODE=0
UHD_V3_MODE=0
QUICK=0
ENCODE_STEP=0
COMPLETED=25
REBUILD_COMPLETE=0
[00500]
AUDIO=100
PGS=100010
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=268696
NSIZE=0
FLINK=-1
MLINK=0
[00501]
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=15032236
AUDIO=100
NSIZE=0
FLINK=-1
MLINK=0
[00502]
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=57589438
AUDIO=100
NSIZE=0
FLINK=-1
MLINK=0
[00503]
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=78818887
AUDIO=100
NSIZE=0
FLINK=-1
MLINK=0
[00504]
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=378957342
AUDIO=100
NSIZE=0
FLINK=-1
MLINK=0
[00505]
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=69512008
AUDIO=100
NSIZE=0
FLINK=-1
MLINK=0
[00506]
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=574395251
AUDIO=100
NSIZE=0
FLINK=-1
MLINK=0
[00507]
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=65900995
AUDIO=100
NSIZE=0
FLINK=-1
MLINK=0
[00508]
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=134614287
AUDIO=100
NSIZE=0
FLINK=-1
MLINK=0
[00509]
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=45525147
AUDIO=100
NSIZE=0
FLINK=-1
MLINK=0
[00510]
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=94264817
AUDIO=100
NSIZE=0
FLINK=-1
MLINK=0
[00511]
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=65805968
AUDIO=100
NSIZE=0
FLINK=-1
MLINK=0
[00512]
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=597088602
AUDIO=100
NSIZE=0
FLINK=-1
MLINK=0
[00513]
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=56924251
AUDIO=100
NSIZE=0
FLINK=-1
MLINK=0
[00514]
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=802112735
AUDIO=100
NSIZE=0
FLINK=-1
MLINK=0
[00515]
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=93446440
AUDIO=100
NSIZE=0
FLINK=-1
MLINK=0
[00516]
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=473949605
AUDIO=100
NSIZE=0
FLINK=-1
MLINK=0
[00517]
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=69221194
AUDIO=100
NSIZE=0
FLINK=-1
MLINK=0
[00518]
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=334745366
AUDIO=100
NSIZE=0
FLINK=-1
MLINK=0
[00519]
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=69143370
AUDIO=100
NSIZE=0
FLINK=-1
MLINK=0
[00520]
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=87712073
AUDIO=100
NSIZE=0
FLINK=-1
MLINK=0
[00521]
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=64320767
AUDIO=100
NSIZE=0
FLINK=-1
MLINK=0
[00522]
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=366298316
AUDIO=100
NSIZE=0
FLINK=-1
MLINK=0
[00523]
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=90352339
AUDIO=100
NSIZE=0
FLINK=-1
MLINK=0
[00524]
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=86016
AUDIO=100
NSIZE=0
FLINK=0
MLINK=0
Heres the output file.
[08/21/20] BD Rebuilder v0.61.12
[08:05:09] Source:  WATCHMEN_00100
  - Input BD size: 32.73 GB
  - Approximate total content: [03:06:28.385]
  - Windows Version: 6.2 [9200]
  - Mode: MP4 Container, HEVC 1920x1080, Auto-AAC
  - Quality: High Quality (Default)
[08:05:09] PHASE ONE, Encoding
 - [08:05:09] Processing: VID_00500 (1 of 25)
 - [08:05:09] Extracting A/V streams [VID_00500]
[08:05:40]PHASE ONE aborted by user request
[08:06:43] Source:  WATCHMEN_00100
[08:06:46] PHASE ONE, Encoding
 - [08:06:46] Processing: VID_00500 (1 of 25)
 - [08:06:46] Extracting A/V streams [VID_00500]
 - [08:11:41] Reencoding video [VID_00500]
   - Rate/Length: 23.976fps, 96 frames
 - [08:11:41] Reencoding: VID_00500, Pass 1 of 1
   - Analyzing 43.95 24.40 1.00 [1.00]
 - [08:11:51] Video Encode complete
 - [08:11:51] Processing audio tracks
   - Track 4352 (eng): Reencoding audio to AAC...
snip
 - [14:51:53] Processing: VID_00524 (25 of 25)
 - [14:51:53] Extracting A/V streams [VID_00524]
 - [14:51:57] Reencoding video [VID_00524]
   - Rate/Length: 23.976fps, 29 frames
 - [14:51:57] Reencoding: VID_00524, Pass 1 of 1
   - Analyzing 42.60 25.00 14.60 1.00 [1.00]
 - [14:52:05] Video Encode complete
[14:52:05]PHASE ONE complete
[14:52:05]PHASE TWO - Rebuild Started
 - [14:52:05] Building ALTERNATE OUTPUT Structure
 - ERROR in attempt to mux (MP4BOX)
[14:54:35] - Failed to REBUILD
Old 22nd August 2020, 11:21   #29891  |  Link
Ch3vr0n
Just a quick question. I don't see a mentioning of updated FRIM. Is it still the "old" one or the new one that supposedly fixes pixellation issues on 3D for software players?
Old 22nd August 2020, 13:48   #29892  |  Link
Sorry, but I haven't updated it yet. I haven't had time to test it. By testing I mean making sure that it still works the same and doesn't cause other issues. I can't test the pixellation issue since it doesn't happen to me.
Old 22nd August 2020, 13:56   #29893  |  Link
Ch3vr0n
Yeah no worries, I'll see it updated when it gets updated. Was just a question
Sent from my Pixel 3 XL using Tapatalk
Old 22nd August 2020, 14:14   #29894  |  Link
Weird. Yesterday someone indicated that their antivirus software was give a hit on BD-RB. This wasn't the first time I'd gotten a false negative in a new release. I ran a scan with AVG (the AV software I use) and it also showed it. So I recompiled and what I assume was a false negative went away. I packed the new compile into a ZIP file and posted it for download. I even downloaded it and ran the test again. No problem.
Now today that user told me he got it again, and sure enough, AVG showed it too -- and it also found something else in the FRIMSource.dll. Huh? There'd been a virus database update earlier. I scanned my entire system -- nothing found. But I've blocked the downloads until I do some more in-depth checking.
A long time ago I put special code in BD-RB that performs a checksum at startup and it exits with a warning if the EXE has been modified. It also is protected via EXE compression (from reverse engineering) so it would be very hard for malware to "attach" itself to it. So I have to assume another false negative, FRIMSource.dll hasn't changed in years. But it is getting annoying.
The two hits were with AVG and AVAST -- can someone scan the new version of BD-RB with another A/V checker and see if it gets an all-clear?
Old 22nd August 2020, 14:29   #29895  |  Link
musiclover
All files in the BD_Rebuilder v0.61.13 folder are getting the all-clear from Malwarebytes
Old 22nd August 2020, 14:41   #29896  |  Link
MajorEvent
Passed Newbie Inquisition
MajorEvent's Avatar
All clear with Malwarebytes and Windows Defender both .zip and extracted with BD-RBV06112
MajorEvent is offline   Reply With Quote
Old 22nd August 2020, 14:43   #29897  |  Link
Thanks. Yeah, the odds are high that it's another false positive. It's happened before. Sometimes A/V software can be just as bad as the things they are designed to protect you against.
Anyone else?
Old 22nd August 2020, 15:04   #29898  |  Link
prologic
can not download from the main site, re-direction .. not working here .
prologic is offline   Reply With Quote
Old 22nd August 2020, 15:28   #29899  |  Link
raul124
raul124's Avatar
first page redirected me to this
https://jammernhilftnichts.de/jdobbs/BD-RBV06113.zip
raul124 is offline   Reply With Quote
Old 22nd August 2020, 16:23   #29900  |  Link
Sorry, I blocked it until it could be tested by a few different packages. Try this link.
Thanks,
