15th January 2014, 14:50 | #18861 | Link |
This doesn't make sense. If the issue was in the encode it would always be there. How could it correct itself when you change playback settings? It has to be a result of the playback device.
15th January 2014, 16:34 | #18862 | Link | |
I am gone play on hardware player and see what is happening, when I played on software player my result is identical limobar.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 15th January 2014 at 16:37. |
15th January 2014, 16:43 | #18863 | Link | |
This is why I hesitate to accept bug reports from software players -- you never know whether the issue is in the player (and it usually is). Last edited by jdobbs; 15th January 2014 at 16:45. |
15th January 2014, 16:53 | #18864 | Link |
True, hardware player would be big help. I am gone run some test and hopefully have meaningful report.
Just quick question can you test sample as well. It is only 29 second and it would add weight to report.
15th January 2014, 17:07 | #18866 | Link |
I will do the same, in fact I already ordered it and hopefully I will have it soon.
15th January 2014, 17:42 | #18869 | Link |
Thank you, marvelous to hear such a news. I am doing backup as well and will also test for sure (extra test doesn't hurt)
16th January 2014, 00:06 | #18870 | Link | |
I'm loving the DTS Express support. Thus far, Karate Kid is doing well with PowerDVD 12 and LG Player. I have some others to try soon. Yay!
16th January 2014, 00:35 | #18871 | Link | |
aka Rabomil
That it's the hardware accelerated decoding that gives artifacts and not the software decoding, is odd. I would think that HW decoding has strict rules and that software decoding can be more forgiving when it comes to used encoder settings. Knowing that HW decoding goes wrong, there's no reason to exclude the FRIM encoder as the reason for the artifacts, at this point. |
16th January 2014, 01:11 | #18872 | Link | |
I've seen hardware acceleration cause problems in all kinds of scenarios. That's why it's an option that can be disabled. This scenario is no different. I have no vested interest in whether FRIMEncode works or doesn't work -- I'm just using logic here, and everything points to the decoder. Last edited by jdobbs; 16th January 2014 at 01:19. |
16th January 2014, 01:24 | #18873 | Link |
aka Rabomil
You can disagree with me, but what I'm saying is logical.
You can create an encode that gets decoded fine by more forgiving decoders, but if that encode doesn't meet the required standard it is supposed to meet, the encode is still to blame and not the decoder that only allows that required standard. |
16th January 2014, 01:28 | #18874 | Link |
The bottom line is that the ONLY good test is using a standalone player, and having done a large number of 3D discs with FRIMEncoder I have not encountered a single one that has playback issues (on two different brands of players).
While anything is possible in a quantum world, the probabilities point heavily toward the decoder. Last edited by jdobbs; 16th January 2014 at 01:33. |
16th January 2014, 01:31 | #18875 | Link | |
FRIM Version 1.20
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 16th January 2014 at 01:35. |
16th January 2014, 01:34 | #18876 | Link | |
I'll check on the subtitle depth issue. |
16th January 2014, 01:40 | #18877 | Link |
I am quite happy with compression of FRIM, I am gone do movie with longest run time I have and see how it goes.
16th January 2014, 01:55 | #18878 | Link |
I ran a group of PSNR tests with 2D encodes from FRIM and X264 at different settings. X264 did better overall, but it really wasn't as great a difference as I would have thought, and I think it was mainly due to it's two pass ability. I may do another comparison using ABR on both.
16th January 2014, 02:02 | #18879 | Link |
You really can't compare them even with ABR, unless disable advance options such as lookahead and MB Tree etc.
16th January 2014, 02:08 | #18880 | Link |
Jdobbs, I notice something interesting I was extracting main movie from cloudy with chance of meat balls 2 and I used mpls, but when I finish tsmuxer only extracted mvc stream from first segment which is 7 min 34 sec.
I am wondering if it has to do something with faulty playback of 3D in software when mux is done. I am gone send this info to Roman as well.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 16th January 2014 at 02:11. |
