1st January 2019, 18:58 | #161 | Link | |
I thought on using the dynamic mode because if I only use iterations I felt it was being stucked into some ranges. Leaving it at low iterations and 5 run cycles it would get out of said ranges but now it would totally ignore past cycle logs which is undesired. I will try to do some other tests with low cycles and high iterations. |
1st January 2019, 21:24 | #162 | Link |
Following your indications and still get the least-change variables.
Best result: Code:
smdegrain(tr=1,thSAD=100,contrasharp=0,prefilter=0,blksize=32,overlap=12,divide=0) |
1st January 2019, 22:41 | #163 | Link | |
[EDIT] I have a suspicion of what the problem is. If your video is very grainy then the degraining process cannot remove a lot of noise in order to look like the original. This add noise -> remove noise -> compare only works well when the original video doesn't have much (or any) noise. You could try finding a part of the video where there is very little noise or perhaps even use a completely different video (with very little noise but similar content and movement) as the source in the optimization. Last edited by zorr; 1st January 2019 at 22:52. |
1st January 2019, 22:55 | #164 | Link |
Here's the link with the 3 clips. A slightly modified version of smdegrain to test contrasharp and divide. Prefilter has a few dependencies so you might want to comment it.
1st January 2019, 23:56 | #165 | Link |
Thanks. I don't know why but my 7zip says it doesn't support the compression method. I downloaded the latest version but apparently it needs a reboot in order to install and I'm in the middle of optimization process so I don't want to do it now. Can you provide the files in another zip format?
2nd January 2019, 03:01 | #166 | Link |
Zorr, My version 7zip from April 2018 opens Dogway zip no problem, yours must be reasonably old version.
Latest update 2 days ago, 2018 Dec 30:- https://www.7-zip.org/download.html No reboot required here (x64 version). I think about 12 -> 18 months ago, some fancy new algo was added to 7zip. For 7zip using zip archive, should perhaps set to Normal compression, and whatever you wish for 7z archives.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 2nd January 2019 at 03:25. |
2nd January 2019, 22:29 | #167 | Link | |
The source video doesn't have any grain so it should work well... I'm going to have to delay the testing a bit because I also need to update MVTools2 and the optimization task I'm running uses an older version. I don't want to do anything radical while it's running... should be done tomorrow. |
2nd January 2019, 22:43 | #168 | Link | |
The way I would do it: take a single frame (or even a small part of the frame) where the halo effect is clearly visible and use Photoshop or whatever to remove it manually (using the clone stamp tool for example). Then use a halo removal filter in AviSynth and optimize its parameters so that it replicates the result. The same parameters should then work well for the whole video. |
2nd January 2019, 22:44 | #169 | Link |
Here it is, in the rush I forgot to include it. This is not a release or anything, I modified it a bit to test divide and integer type data for contrasharpening (the generic "val" data type wasn't suited for the variable). I skipped prefilter=3 because I can't make dfttest work on my end. The denoised version was denoised with: smdegrain(tr=3,thSAD=250,contrasharp=40,prefilter=2,blksize=16,overlap=8,divide=0,refinemotion=true,lsb=true). Which is (maybe?) a good starting point for grainy 1080p, in lack of better denoisers for avs+ like BM3D.
Whenever you have time is ok, I use the mvtools2 from pinterf github. Last edited by Dogway; 2nd January 2019 at 22:46. |
2nd January 2019, 23:04 | #170 | Link | |
Does anyone know whether MDeGrain uses pixel-based motion compensation (like MFlowInter) or the block based (like MCompensate)? I think it's the latter but I'm not sure. Another open question: if you find good parameters for MCompensate (or MFlowInter) do they work equally well with MDeGrain? Even if they're not similar there's the MAnalyze (and MRecalculate) part which should work in identical way for all use cases. |
2nd January 2019, 23:21 | #171 | Link | |
2nd January 2019, 23:49 | #172 | Link |
Yes I dabbled with MCompensate back then, we used it for all kinds of filtering I guess I wanted to keep things simple and fast at that time but I had some beta version with it included. I want to run some tests with avsoptimizer and see where it takes me.
I think it uses MCompensate internally, you can see the vectors with MMask. In my opinion MFlowInter artifacts are less forgivable but I have been long out of the loop so things might have changed. |
3rd January 2019, 10:03 | #173 | Link |
Pig on the wing
Regarding denoising, do you have any plans for the Vapoursynth support that was briefly discussed when the optimization method was published?
4th January 2019, 00:18 | #174 | Link | |
So just add a line to load the original clip: orig=ffvideosource("source.avi") and then calculate SSIM between the original and denoised. Remove global ssim = SSIM_FRAME(source, denoised) and replace with global ssim = SSIM_FRAME(orig, denoised) I'm running a small test with such modifications and seems like it prefers tr=4 (as it should). |
4th January 2019, 00:29 | #177 | Link |
The official site and for a quickstart my portable pack https://forum.doom9.org/showthread.php?t=175529 <- there are some bat ecnode and VS editor examples
It's very similar to avisynth.
4th January 2019, 00:31 | #179 | Link | |
EDIT:
here "Learn X in Y Minutes" for Python3:- https://learnxinyminutes.com/docs/python3/ [already linked on Vapoursynth home site] EDIT: Python 2 is somewhat different to Python 3, so give tutorials on that a wide berth.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 4th January 2019 at 00:44. |
4th January 2019, 01:19 | #180 | Link |
Here are some basics:
from vapoursynth import core import somescript as xy clip = core.d2v.Source(r'E:\test.d2v') # r means raw string, so u can copy paste a windows path. Alternatively use (without r) 'E:\\test.d2v' video = clip # call a function from our imported script clip = xy.Filter(clip) clip = somescript.Filter(clip) #alternative # call a plugin function. All plugins have a namespace. clip = core.dfttest.DFTTest(clip, sigma=5) clip = clip.dfttest.DFTTest(sigma=5) #alternative #compare clip = core.std.StackHorizontal([video.text.Text("original"), clip]) clip.set_output() Oh and it would be also very easy to run Avisynth plugins/scripts within VS Code:
clip = core.d2v.Source(r'E:\test.d2v') clip_distorted = core.avsw.Eval('FineDehalo(darkstr =0)', clips=[clip], clip_names=["last"], slave_log=r"D:\debug.txt", avisynth =r"D:\AVSPLUS_x86\Avisynth.dll") vmaf.VMAF(clip_reference, clip_distorted) # https://github.com/HomeOfVapourSynthEvolution/VapourSynth-VMAF
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 4th January 2019 at 10:20. |
