28th August 2014, 22:19 | #20901 | Link |
Are you creating copy in 3D or 2D? Also can you post screenshot of BD-RB when it opened lego movie and 2D backup is selected.
28th August 2014, 23:19 | #20902 | Link |
Possible bug with Import in 48.02
Sanctuary BD season 3 or 4 Importing the season discs with 48.02 results in an import folder with video only. Reverting to 47.07 and it imports fine INI file is same for both versions. Code:
[Options] VERSION=0.48.0.2 MULTIPROCESS=1 FIXED_CRF=18 HC_PROFILE=BEST DEFAULT_LANG=eng ENABLE_TEST=1 ENABLE_BLANKING=0 IMPORT_FOLDER=D:\ KEEP_HD_LPCM=1 DEINTERLACER_TYPE=3 UPRESIZE=LanczosResize SD_PROGRESSIVE=1 MOVIE_ONLY_LOOP=0 REMOVE_IMPORT=1 USE_ZLIB=0 MODE=0 ENCODE_QUALITY=3 ONEPASS_ENCODING=1 AUTO_QUALITY=0 MENU_BACKGROUND=C:\Program Files (x86)\BD_RB\misc\menuback.jpg MIN_M2TS_SIZE=1 IMPORT_THRESHOLD=35 QUICK_PLAY_THRESHOLD=10 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP= SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=1 SD_TO_1080=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AVCHD=0 REMOVE_WORKFILES=1 MOVIE_ONLY_LOOP=0 REMOVE_OUTPUT=1 USE_FILTERS=0 BDMV_CERT_ONLY=1 USE_LAVF=0 IVTC_PULLDOWN=1 ASSUME_DVD_PAL=0 UNMASK_CHAPTER=0 COMPLETION_BEEP=0 DGDECNV=1 OUTPUT_3D=0 NEROAAC=0 SUPTITLE=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=8600 TARGET_SIZE=8600 MOVIEONLY_TYPE=0 ALTCRF=18 ALT_TARGET=1024 ALTMETHOD=0 ALTAUTOCROP=1 AUTO_BURN=0 MENU_AUTO_BACKGROUND=1 MENU_PLAY_SEQUENTIAL=0 MENU_START_WITH_MENU=1 IGNORE_3D=1 OUTPUT_SBS=0 FRIMSOURCE=0 ENCODER=0 DGDECIM=0 TWEAK_PASS_ONE= --tune film TWEAK_PASS_TWO= --tune film DECODER=3 [Paths] SOURCE_PATH=D:\IMPORTS\SANCTUARY_S3_D1\ DGIndexNV=C:\Program Files (x86)\dgdecnv\DGIndexNV.exe DGDecNV=C:\Program Files (x86)\dgdecnv\DGDecodeNV.dll WORKING_PATH=W:\SERIES\ Code:
MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --custom-chapters=00:00:00.000;00:08:05.985;00:18:43.831;00:27:35.820;00:37:55.064;00:43:09.795;00:45:19.717 --vbv-len=500 --start-time=27000000 V_MPEG4/ISO/AVC, "I:\SANCTUARY SEASON 3\SANCTUARY_S3_D1\BDMV\PLAYLIST\00004.mpls",fps=23.976,contSPS,track=4113 A_DTS,"I:\SANCTUARY SEASON 3\SANCTUARY_S3_D1\BDMV\PLAYLIST\00004.mpls",lang=eng,track=4352 A_AC3,"I:\SANCTUARY SEASON 3\SANCTUARY_S3_D1\BDMV\PLAYLIST\00004.mpls",lang=fra,track=4353 A_AC3,"I:\SANCTUARY SEASON 3\SANCTUARY_S3_D1\BDMV\PLAYLIST\00004.mpls",lang=eng,track=4354 S_HDMV/PGS,"I:\SANCTUARY SEASON 3\SANCTUARY_S3_D1\BDMV\PLAYLIST\00004.mpls",fps=23.976,lang=eng,track=4608 S_HDMV/PGS,"I:\SANCTUARY SEASON 3\SANCTUARY_S3_D1\BDMV\PLAYLIST\00004.mpls",fps=23.976,lang=fra,track=4609 Code:
MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --custom-chapters=00:00:00.000;00:08:05.985;00:18:43.831;00:27:35.820;00:37:55.064;00:43:09.795;00:45:19.717 --vbv-len=500 --start-time=27000000 V_MPEG4/ISO/AVC, "I:\SANCTUARY SEASON 3\SANCTUARY_S3_D1\BDMV\PLAYLIST\00004.mpls",fps=23.976,contSPS,track=4113 Last edited by gonca; 28th August 2014 at 23:24. |
28th August 2014, 23:56 | #20905 | Link |
Ughh... this was a serious one that pretty much makes BD importing inoperable -- and it's caused by a silly line I added. I can't believe I didn't pick up on this in testing. Interesting that I did it right in the DVD section but really screwed-the-pooch in the BD import.
I'll put out an interim version in a short while that fixes this. |
29th August 2014, 01:29 | #20908 | Link |
BD Rebuilder v0.48.03 (beta)
I have updated the first post of this thread with a link to the most recent version of BD-RB (v0.48.03). Changes for this release:
- Corrected an issue in which ALTERNATE output to DVD was no longer working as of release of v0.48.01 due to HC encoder issues associated with the necessary FFVideoShow seek mode. - Corrected an error that could prevent preview from working when HAALI/FFDSHOW is not installed and DGDecNV or FRIM is selected. - Changed settings so FRIM is used for all previews. This avoids the issue in which attempting to preview with FFVideoSource can pause for a long period while the source is being indexed. - Corrected an issue that could cause encoding of 2D from 3D sources when using ALTERNATE presets to fail. - Added a workaround for incorrectly formatted 3D sources, having shortened M2TS files, that are used for 2D ALTERNATE output. - Fixed an error in the BD import routine that removes audio and subtitle tracks during BD import. - Fixed an issue in which selecting LAVF as the frame server could result in the chapter file not being read and used for encoding. - Other minor corrections and cosmetic fixes. |
29th August 2014, 02:37 | #20910 | Link | |||
Jdobbs, couple of things I noticed with 0.48.03
1. Program still fails to create 2D backup of lego movie & It sees total size of movie 1.73 GB only. 2. Rebuilding phase get stuck and never finish. {Status} Quote:
Also I notice in alternate output except DVD, BD-RB uses one pass encode even though I specifically chosen two pass option. I am thinking if frim can be launched twice with x264 it should be possible, like it does with HCencoder.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 29th August 2014 at 03:44. |
29th August 2014, 04:03 | #20911 | Link |
The fix is for ALTERNATE output. You selected 2-pass from the ALTERNATE dialog? The settings there are the only ones that matter for ALTERNATE encoding.
[Edit] I just tested ALTERNATE 2-pass encoding with LEGO 2 and it is working correctly. Last edited by jdobbs; 29th August 2014 at 04:13. |
29th August 2014, 04:13 | #20912 | Link | |
Also when I enable option process 3D as 2D, file size is not correct for input of BD-RB. It reports 1.73GB and both 2d backup and alternate fail.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 29th August 2014 at 04:16. |
29th August 2014, 04:15 | #20913 | Link | |
FRIMSource is used because of the requirement to read from the SSIF on that source (since the M2TS is a runt that doesn't include the entire movie). FFVideoSource and DGDecNV both fail to index the SSIF. Last edited by jdobbs; 29th August 2014 at 04:18. |
29th August 2014, 04:18 | #20914 | Link | |
[update] I see you are using frim as well. I will do some more checking on that. SO far what I know is frim is feeding frames to both encoder. DVD output works in alternate with 2 pass, however no matter what I do x264 is using crf, no matter what option I have chosen.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 29th August 2014 at 04:22. |
29th August 2014, 04:27 | #20915 | Link |
Not on my system. FRIM is used on that title because it is illegally formatted and it has to be to use the SSIF. It isn't necessarily used on others. See below:
[08/28/14] BD Rebuilder v0.48.03 (beta) [21:20:15] Source: LEGO_MOVIE_3D_00098 - Input BD size: 32.56 GB - Approximate total content: [01:40:35.320] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Quality: High Quality (Default), ABR - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [21:20:18] PHASE ONE, Encoding - [21:20:18] Processing: VID_00042 (1 of 1) - [21:20:18] Extracting A/V streams [VID_00042] - [21:25:53] Reencoding video [VID_00042] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 144,703 frames - Bitrate: 1,230 Kbs - [21:25:53] Reencoding: VID_00042, Pass 1 of 2 I tried it and it works correctly with both the bitrate and target size 2-pass options. I haven't worked on any code to do 2D from a 3D to a regular movie-only backup on illegally formatted 3D sources. So I can't say what will happen there... I'll test it. If there is a problem I'll fix it in a future version. [Edit] Yeah. Clicking on the 3D to 2D checkbox in SETUP makes it recognize only the M2TS on that disc. That's something for another day... like I said before, the problem isn't BD-RB... it is the illegally structured disc by the BD standard. In the meantime you can always output to an MKV using intact video/audio -- and then import the MKV back in to create a 2D version. Last edited by jdobbs; 29th August 2014 at 04:46. |
29th August 2014, 06:47 | #20916 | Link |
It's probably my fault JD lol. Whenever I download the newest version, a bug is found, that requires immediate attention lol. Perhaps I should wait on 4803 :S
29th August 2014, 14:49 | #20917 | Link |
I hope you don't. I prefer problems are found immediately. I do testing before posting -- but BD-RB has gotten to a point where there are so many options and interdependencies that I just can't test them all. That's when I rely on people like you.
29th August 2014, 19:13 | #20919 | Link | |||
@jdobbs,
BD Rebuilder v0.48.03 (beta) has fixed the BD to DVD issue using FFVideoSource. Thanks! However, something I now notice that did not occur with releases prior to 48.03. By selecting either DirectShow and FFVideoSource, the BD to DVD conversion now does a 2 pass encode. The finished file size of the DVD, using either DirectShow or FFVideoSource, is quite a bit larger than using 48.02 or prior releases, even though the bitrate is identical! (Bitrate: 8,552 Kbs) Both tests, DirectShow or FFVideoSource, using 48.03 turn out 3.46GB. Using DirectShow with 48.02; 2.78GB. DVD9 was the selected preset. I'm not sure why or how, using the same source, and all three tests select the same bitrate, there can be such a discrepancy. Since I am not sure that this is even a bug, I felt the need to report my findings. I have done quite a few of these over the last year, and the resulting DVD's have always been consistently comparable with the versions prior to and including 48.02. Quote:
29th August 2014, 20:03 | #20920 | Link |
It always did a 2 pass encode, I just changed the way it is presented to better reflect it. In previous versions the 2nd pass started at 50%...
Since you have DVD-9 selected and are getting a size much smaller, it is likely that the maximum Q is being reached and the extra bitrate can't be used, so the fact that the specified bitrate is the same is really inconsequential. The difference is size is likely due to the fact that I regressed the version of HCENCODER. For some reason the lastest version lost the *AVSRELOAD capability. That was the root of the problem that had to be fixed in v0.48.03 when used with FFVideoSource. The quality of the output will shouldn't be affected by the regression, the only differences between the HC versions are some additional options that aren't used in BD-RB and the removal of *AVSRELOAD. Last edited by jdobbs; 29th August 2014 at 20:07. |
