13th November 2013, 06:18 | #18261 | Link | |
13th November 2013, 07:36 | #18262 | Link |
Here is the log file:
[19:30:41] Importing DVD: BOURNE_TETRALOGY - Processing DVD title [1 of 4] - Collecting audio/video/subtitle streams... - Converting subtitles to BD format... - Multiplexing audio/video/subtitles... - Processing DVD title [2 of 4] - Collecting audio/video/subtitle streams... - Converting subtitles to BD format... - Multiplexing audio/video/subtitles... - Processing DVD title [3 of 4] - Collecting audio/video/subtitle streams... - Converting subtitles to BD format... - Multiplexing audio/video/subtitles... - Processing DVD title [4 of 4] - Collecting audio/video/subtitle streams... - Converting subtitles to BD format... - Multiplexing audio/video/subtitles... - Creating Quick-Play Menu... - Encoding menu background... - Building menu structure... [19:45:51] DVD import completed successfully. ---------------------- [11/12/13] BD Rebuilder v0.45.03 (beta) [19:50:11] Source: BOURNE_TETRALOGY - Input BD size: 17.82 GB - Approximate total content: [07:57:10.718] - Target BD size: 22.95 GB - Windows Version: 6.2 [9200] - Quick-Play Reauthoring mode enabled - Quality: High Quality (Default), CRF - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [19:50:11] PHASE ONE, Encoding - [19:50:11] Processing: VID_00001 (1 of 4) - [19:50:11] Extracting A/V streams [VID_00001] - [19:53:23] Reencoding video [VID_00001] - [19:53:23] Keeping original video (no reencode) - [19:53:23] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:53:23] Multiplexing M2TS - [19:54:34] Processing: VID_00002 (2 of 4) - [19:54:34] Extracting A/V streams [VID_00002] - [19:57:41] Reencoding video [VID_00002] - [19:57:41] Keeping original video (no reencode) - [19:57:41] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:57:41] Multiplexing M2TS - [19:58:38] Processing: VID_00003 (3 of 4) - [19:58:38] Extracting A/V streams [VID_00003] - [20:01:34] Reencoding video [VID_00003] - [20:01:34] Keeping original video (no reencode) - [20:01:34] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:01:34] Multiplexing M2TS - [20:02:32] Processing: VID_00004 (4 of 4) - [20:02:32] Extracting A/V streams [VID_00004] - [20:05:45] Reencoding video [VID_00004] - [20:05:45] Keeping original video (no reencode) - [20:05:45] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:05:45] Multiplexing M2TS [20:06:38]PHASE ONE complete [20:06:38]PHASE TWO - Rebuild Started - [20:06:38] Rebuilding BD file Structure - [20:06:38] Creating Quick-Play Menu... - Encoding menu background... - Building menu structure... [20:06:44] - Encode and Rebuild complete [20:06:44] JOB: BOURNE_TETRALOGY finished. All of the various players on my computer can play commercial blu ray, and blu ray created by Adobe Encore, Easy BD Lite or DVD2BD Express with no issues. I've done this same compilation before, using AVStoDVD to build an oversized dvd, then authored to blu ray in DVD2BD, and that one works fine. |
13th November 2013, 10:44 | #18264 | Link |
@jdobbs
When I open a Quick-Play authored BD (ROM) in BD-RB via "Browse" I can go to the Menu Editor and make changes to the Quick menu. When I now press "Save and Continue" it looks as if my changes became effective and I can proceed with "Backup" without a warning. Because the modified titles.inf cannot be written to the ROM (as I understand it the modified titles.inf is not saved to anywhere in this case?) I suggest that there should be an error message or a hint that one has to IMPORT the BD ROM in order to make any changes to the menu. Maybe this is just too obvious or I have missed something, but if something can go wrong it will .... |
13th November 2013, 15:36 | #18266 | Link | |
I should probably give a warning, or possibly save the titles.inf file in the working folder until a new title is selected. |
13th November 2013, 15:42 | #18267 | Link | |
One thing I know for sure is that the DVD source can't be MPEG-1 (because it isn't supported in BD). But MPEG-1 based DVDs are exceptionally rare -- and usually not commercial. I'm not familiar with BOURNE_TETRALOGY. Is it just the BOURNE DVDs combined? If it's not too expensive I'll see if I can find it. Last edited by jdobbs; 13th November 2013 at 15:52. |
13th November 2013, 15:54 | #18268 | Link |
Bourne Tetralogy is my term for the four Bourne movies...The Bourne Identity, The Bourne Supremacy, The Bourne Ultimatum and The Bourne Legacy. You won't find the complete set sold commercially under that name.
All four movies are bog standard mpeg2/ac3. All of the original files play in any player you want to try them in. All were ripped using AnyDVD HD. Here is the Inspect snapshot you wanted: I have not burned this to a disc to try in a stand alone player, but I use an HTPC rather than a blu ray player and getting access to one is a problem. |
13th November 2013, 16:10 | #18269 | Link |
I have those on BD but now DVD. I don't want to have to buy all of them, but I'll pick up one or two of them and give it a try later today. If I'm luck I might find the older ones on the discount rack.
Did you try it more than once? What happens when you try to play it? Nothing? Blank screen? Backdrop w/no titles? Titles w/no action? @ALL Is anyone having any problems playing back Quick-Play menus on a standalone (real) Blu-ray player? Last edited by jdobbs; 13th November 2013 at 16:34. |
13th November 2013, 16:33 | #18270 | Link | |
Now it seems that the disk is getting fully reencoded even though it already fits the target and I only made changes to the Quick menu. I would assume that most of the .m2ts files could simply be copied (?). Is it because the files are no longer available in the WORKFILES folder? |
13th November 2013, 16:35 | #18271 | Link | |
That's something I have to work on. |
13th November 2013, 16:57 | #18272 | Link | |
So for the time being when I see that it is getting re-encoded it is probably better to start from scratch, since the re-encoding of already encoded material will have a slightly negative impact on the final quality. |
13th November 2013, 17:09 | #18273 | Link | |
I like testing on software players before burning to disc, but using the quick play menu creation in BD-RB appears to not be very compatible for this for me too! And I am not really interested in buying anymore software players! Last edited by Capsbackup; 13th November 2013 at 17:14. |
13th November 2013, 17:34 | #18274 | Link | |
If someone points out issues with a commercial standalone player, then I usually assume BD-RB has a problem. Last edited by jdobbs; 13th November 2013 at 17:37. |
13th November 2013, 17:39 | #18275 | Link | |
If you IMPORT rather than do a Quick-Play backup you'll never have cross referenced playlists -- but, you also lose multiple angles, language directed playlists, etc. Last edited by jdobbs; 13th November 2013 at 17:44. |
13th November 2013, 18:40 | #18276 | Link | |
However, I do experience random freeze during playback. It is not reproducible frame-accurate, and it depends on the playback sequence and switching sequence between chapters. I suspected a bad burn, however it happens on 2 disks and I never had such effects before, so a bad burn seems a bit unlikely but I wouldn't totally exclude it. I do my backups on BD9 rather than BD25, and I am not sure if my standalone (SONY BDP-S360) has issues in general with blu-ray structure with menus on BD9. I never had problems with Movie Only backups, and those few which I have done with "Movie and Menu" were normally ok with very few exceptions. I need to do more tests, so just in case someone else has experienced occasional freezing as well .... |
13th November 2013, 18:49 | #18277 | Link | |
My BDP-S360 does a pretty good job with BD-9 -- the only issue I remember having is with backups containing DTS Express on secondary tracks. Hmm... I just remembered something though. When I use an original BD disc's video for a menu backdrop, I keep it intact. That could be an issue for a BD-5/9 because of the bitrate... I'd better look at that. Last edited by jdobbs; 13th November 2013 at 18:54. |
13th November 2013, 18:58 | #18278 | Link | |
Good to know that S360 is fine with BD-9. |
13th November 2013, 19:24 | #18279 | Link |
Man Of Steel Disc 1 - BD9 Possible?
Using BD-RB v.0.44.16.
Trying to make a BD9 (including only English streams) of Disc 1 of "Man of Steel". Smallest size I'm able to create is 10.8Gb. Are there any hidden or other default settings that need to be selected or deselected to allow for further compression? |
13th November 2013, 19:30 | #18280 | Link | |
I have tried recompiling it, but no change in the way the software players work with it. I also tried making an ISO with ImgBurn and mounting that, but again, there is no difference in the way the players react. I'll try again using blu ray sources and see if there are any differences in the behavior of the software players. Last edited by Kerry56; 13th November 2013 at 19:32. |
