25th October 2010, 11:30 | #6781 | Link | |
The PS3 profile works like a charm. |
31st October 2010, 09:38 | #6784 | Link |
The lack of support for multiAVCHD development = none of the updates will be released
Former post deleted
Sorry, I was just too upset and sad, that mAVCHD ist not "puplic" anymore...... Last edited by pio011; 31st October 2010 at 15:39. |
31st October 2010, 16:15 | #6786 | Link |
Programmer (or just 教务长)
It is hard to find time and resources to update multiAVCHD at the moment. I posted the note because the project can't run without support (server up time, internet and bandwidth, forum, hosting, etc). Not only I spent hundreds of days and nights improving the program, but now I need to put money in it - I don't think so
I don't think I'm under an obligation to push updates and work constantly on bringing new features to you. multiAVCHD is a great tool as it is and works just fine for me in its current form. It is free and will always be, so I don't see the problem. Dean |
31st October 2010, 16:17 | #6787 | Link | |
31st October 2010, 18:21 | #6789 | Link | |
I use multiAVCHD quite often, and have been for some time. It allows me to do things that no other free program does. There may be a few bugs still, and improvements and added features are always welcome! But time and economics are a reality. So I understand and appreciate your situation. I will continue to follow and support you as I hope others will do too! Thanks deank for your generosity. |
1st November 2010, 00:39 | #6790 | Link |
On the "Select destination media and playback device type" screen it reads "Strict mode employs in-mux menu (static only). Suitable for Panasonic players and DVD media." for the AVCHD area. Apparently the 2nd quote does not apply in re-author mode. At least this is my current best guess at what might be going on with the report we received that a Panasonic DMP-BD85K was unable to play the AVCHD re-author in http://bit.ly/avshd709. Far as I can tell the original uses out-of-mux menus, so the re-author probably also uses out of mux menus. Is this a reasonable explination for why the re-author might not work on a Panasonic player?
Edit: After another report it seems like the out-of-mux menus could be why the Panasonic model is not playing the re-author. Last edited by alluringreality; 1st November 2010 at 04:53. |
2nd November 2010, 06:12 | #6791 | Link |
I recently authored a Bluray with 1080p24 and 720x480 (4:3) material, however on playback the 4:3 material is stretched to 16:9.
Have I missed a setting in multiAVCHD to tell the player to treat the 720x480 as 4:3, or is this just the way it is? I'm sure with a few official Bluray titles with 1080p24 and 720x480 (4:3) material that I have played in the past, the aspect ratio has been correct on playback, so there must be a setting somewhere. I assumed multiAVCHD handled it automatically. I'm also having issues with choosing a poster image from the material for the top menu: it always comes up blue in the preview and black when rendered. If I specifically direct the program to a jpg poster image, all is well. |
2nd November 2010, 12:40 | #6792 | Link |
Are you sure that you didn't check "Force AR flag to 16:9" in the author tab ?
If no, it should work if you put your video in a MKV container with 4/3 Aspect Ratio (I do it with MKVmerge) before adding it in MultiAVCHD. And you can also verify your player's setup. |
3rd November 2010, 00:43 | #6793 | Link | |
Fighting spam with a fish
3rd November 2010, 01:13 | #6794 | Link | |
I have been creating Bluray structures of DVD resolution material with ClownBD (since that retains chapters) and then importing those structures into multiAVCHD. It is those DVD resolution structures that give the black poster and thumbnail problem: 1080p structures are perfectly fine. As a previous poster has suggested, perhaps I should have been creating mkv first instead. |
3rd November 2010, 02:07 | #6796 | Link | |
Run multiAVCHD and you will see it in the log file just after startup of the program.
3rd November 2010, 05:05 | #6797 | Link |
Choppy Playback on Panasonic BD30
I have been testing a clip that has TrueHD on my Panasonic BD30. I've got the clip to work flawlessly from an SD card with the TrueHD converted to LPCM, but, when I burn, with Imgburn, to a DVD+R or DVD-R, it plays back very choppy. I've tried converting the TrueHD track to plain AC3, still plays back choppy on the BD30. I understand media plays a huge roll in this. Currently I have a crapload of JVC DVD-Rs and Playo DVD+Rs. I would like confirmation, before I shell out the cash, that if I switch to the Verbatims, that all these problems would go away.
3rd November 2010, 08:07 | #6798 | Link | |
Guess I'm going to be waiting a while for that to appear |
3rd November 2010, 11:08 | #6800 | Link | |
The Panasonic players can't send True HD and DTS HD from AVCHD burnt on dvd, my BD35 had the same problem and there's nothing to do.
I know that it's not logical because MultiAVCHD uses TSMuxer. |
