14th May 2017, 14:55 | #2023 | Link |
Version 1.4.3.7 does not accept a changed path to MKVToolnix, or it just ignores it.
I have MKVToolnix installed in another path, because it updates much more often and is not only used by staxrip. But since 1.4.3.7 (didn't try any other since 1.3.x.x) it always pops up the settings dialog for the programs loctions, despite having already set it up correct (F11). Only if I copy the MKVToolnix files to the location, where staxrip wants them (within it's own apps folder), can I get going. When updating I overwrote every file exept "StaxRip.pdb" in the program folder. Could that be the reason for such weird behaviour? And why? Last edited by Schattenspieler; 14th May 2017 at 14:58. |
15th May 2017, 17:03 | #2024 | Link | |||
@aegisofrime
Automatic filter selection should work, first you have to load a VapourSynth filter setup and after that change the source filter to Automatic. If you change the source filter to Manual the last build will offer VapourSynth DGSource/DGSourceIM in the filter selection dialog. I improved the code that adds the required LoadPlugin calls, in the last build you can use code like this: clip = core.avs.DGSource(r"%source_file%") clip = core.avs.yadifmod2(clip) and staxrip automatically adds: core.avs.LoadPlugin(r"D:\Software\Medien\DGDecNV_2052\DGDecodeNV.dll") core.avs.LoadPlugin(r"D:\Projekte\VS\VB\StaxRip\bin\Apps\Plugins\avs\yadifmod2\yadifmod2.dll") Quote:
16th May 2017, 14:26 | #2025 | Link |
Today I rewrote the manual source filter selection dialog:
It don't show AviSynth and VapourSynth together but rather only AviSynth or VapourSynth depending on what scripting engine is active (the script engine can be changed with: Filters > Filter Setup, to make it default after startup use: Project > Safe As Template > Load template on startup) The shown filters are not hardcoded but rather taken from the filter profiles, if you have two DGSource VapourSynth filter profiles for instance both should show in the dialog. It has a much more lightweight look and feel. https://github.com/stax76/staxrip/bl.../test-build.md
18th May 2017, 22:44 | #2026 | Link |
Noob
bugs
whats up with all these bugs in new test builds ? i am still on 1.4.3.2 and i didnt upgrade because there were several files missing in staxrip's folder and i want to upgrade asap. what i think is that there are compatibility issues with c++2017 and dot net 4.7.
18th May 2017, 23:04 | #2027 | Link |
What files were missing? With the removal of C# scripting support lot's of DLLs are no longer needed.
Systems prior Creators Update need .NET 4.7. I've added a requirements section in the test build page. https://github.com/stax76/staxrip/bl.../test-build.md
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 18th May 2017 at 23:19. |
20th May 2017, 13:59 | #2028 | Link |
To address the issue with high memory usage I changed the job processing in the build from today:
job processing is now always done in a new instance after every finished job the instance shuts done and starts a new instance before in case there are more jobs to process
20th May 2017, 17:57 | #2030 | Link |
You can't, portable mode isn't supported and I don't plan to support it in the future.
21st May 2017, 21:40 | #2032 | Link |
Again I totally rewrote job processing today, I hope it's much better now.
22nd May 2017, 22:44 | #2033 | Link |
I modified much layout and scaling related code today and could need some help with testing because I want to release a stable build this week finally and pause for some time.
23rd May 2017, 01:11 | #2034 | Link |
Hi Stax,
I'm currently testing 1.4.5.1 and i'm setting this error. Only seems to happen on my W7 machine, W10 is fine. Code:
Exception Could not load type 'System.ValueTuple`3' from assembly 'mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'. System.TypeLoadException: Could not load type 'System.ValueTuple`3' from assembly 'mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'. at StaxRip.MainForm.ModifyFilters() at StaxRip.MainForm.OpenVideoSourceFiles(IEnumerable`1 files, Boolean isNotEncoding) in D:\Projekte\VS\VB\StaxRip\Forms\MainForm.vb:line 1689
A Man Eating Duck Last edited by AMED; 23rd May 2017 at 01:42. |
25th May 2017, 04:23 | #2035 | Link |
Hi Stax,
I've been testing 1.4.5.3 and this error appeared. The error didn't stop staxrip encoding and it's still happily going through the jobs. the error on the left is the original error, the error on the right was after clicking the copy message link from the original error window. Code:
StaxRip x64 : 1.4.5.3 OS : Windows 10 Pro 1703 Language : English (New Zealand) CPU : Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz GPU : Radeon (TM) RX 480 Graphics
A Man Eating Duck |
25th May 2017, 14:33 | #2036 | Link |
@AMED
Clicking on 'Copy Message' was supposed to copy the error message to the clipboard and show a message box 'Error was copied to clipboard'. Even though I couldn't understand why (something threading related I think) it didn't work, I think it is fixed now. The exception that was happening is hopefully fixed too. https://github.com/stax76/staxrip/bl.../test-build.md
26th May 2017, 18:58 | #2037 | Link |
If everything goes right then I'll release a stable version this Sunday, last one is already 7 months old.
Test build from today: https://github.com/stax76/staxrip/bl.../test-build.md
26th May 2017, 20:43 | #2038 | Link |
Noob
4.7
what was the last build with worked fine without .net 4.7 ? on my win 10 installation of 4.7 is blocked and it says os not supported. whenever u make the stable release, please if possible, make a build which can work fine without 4.7 also. thanks.
26th May 2017, 20:46 | #2039 | Link |
Did you consider updating to creators update?
