28th November 2012, 02:28 | #2162 | Link | |
47.952fps@71.928Hz
You can extract the subtitles and convert them and let AVStoDVD load them. SRT format are the best, imo. Converting to an IDX/SUB format tends to leave a lot of artifacts around the subtitles.
Win10 (x64) build 19041 NVIDIA GeForce GTX 1060 3GB (GP106) 3071MB/GDDR5 | (r435_95-4) NTSC | DVD: R1 | BD: A AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
28th November 2012, 02:31 | #2164 | Link |
47.952fps@71.928Hz
DirectShow Filters > DirectVobSub > Misc > Hide Subtitles
9th December 2012, 23:15 | #2166 | Link |
47.952fps@71.928Hz
Is there anyway to change settings to the subtitles default status?
Normal subtitles (not forced) seem to be enabled by default during playback. I have to turn them off when the disc starts whether on my DVD/BD machine or media player on my PC.
10th December 2012, 12:45 | #2167 | Link |
I just burned my first dual layer dvd (8 - 48min .avi files) using AVS2DVD. I like the menu setup, and the way it is easier to customize them compared to DVDFlick which I have been using for several years.
However, AVS2DVD took a total of 22 hours and 17 minutes from start to finish to complete the project. Is this normal? or did I set things up wrong? That amount of time for a project is 4 times as long as it takes DVDFlick to complete a project of the sae type (8 - 48min .avi files). I love AVS2DVD, but obviously, I cannot tie up my laptop for a full 24 hours to complete one project when I have over 400 episodes of Perry Mason and Ironside to compile to DVD. Any suggestions on why it took so long to complete the project? Have a great week! Thanks, Ed Wood |
10th December 2012, 13:50 | #2169 | Link |
MrC
I will search for the log file to post. Where is it located, and what is it titled? You raised the point that is probably my problem. The laptop has a cpu speed of 1.3mhz. There is 2mb ram installed, and the hdd size is 80mb of which it is probably 1/2 full. I have a 1tb external usb drive that I will see if the laptop will recognize and use. That should speed up the process considerably if AVS2DVD will support the external drive. Thanks, Ed |
10th December 2012, 17:49 | #2170 | Link | ||
AVStoDVD Dev
BTW, let's see the project log file. Bye |
11th December 2012, 15:53 | #2171 | Link |
MrC
Here are the log files from my last project that took 22+ hours to complete. There are 8 of them. #1 [Input info] Bitrate=192 Actual rate=192.000000 Sampling Frec=48000 TotalFrames=96616 Bytesperframe= 768.0000 Filesize=74201088 FrameDuration= 32.0000 Framespersecond= 31.2500 Duration=00:51:31.712 Channels mode=2/0: L+R LFE=LFE: Not present [Target info] StartFrame=5 EndFrame=96615 NotFixedDelay= 0.0000 Duration=00:51:31.552 ====== PROCESSING LOG ====================== Seeking.... Done. Processing.... Number of written frames = 96611 Number of Errors= 0 #2 [Input info] Bitrate=192 Actual rate=192.000000 Sampling Frec=48000 TotalFrames=96575 Bytesperframe= 768.0000 Filesize=74169600 FrameDuration= 32.0000 Framespersecond= 31.2500 Duration=00:51:30.400 Channels mode=2/0: L+R LFE=LFE: Not present [Target info] StartFrame=5 EndFrame=96574 NotFixedDelay= 0.0000 Duration=00:51:30.240 ====== PROCESSING LOG ====================== Seeking.... Done. Processing.... Number of written frames = 96570 Number of Errors= 0 #3 [Input info] Bitrate=192 Actual rate=192.000000 Sampling Frec=48000 TotalFrames=96490 Bytesperframe= 768.0000 Filesize=74104320 FrameDuration= 32.0000 Framespersecond= 31.2500 Duration=00:51:27.680 Channels mode=2/0: L+R LFE=LFE: Not present [Target info] StartFrame=5 EndFrame=96489 NotFixedDelay= 0.0000 Duration=00:51:27.520 ====== PROCESSING LOG ====================== Seeking.... Done. Processing.... Number of written frames = 96485 Number of Errors= 0 #4 [Input info] Bitrate=192 Actual rate=192.000000 Sampling Frec=48000 TotalFrames=96795 Bytesperframe= 768.0000 Filesize=74338560 FrameDuration= 32.0000 Framespersecond= 31.2500 Duration=00:51:37.440 Channels mode=2/0: L+R LFE=LFE: Not present [Target info] StartFrame=5 EndFrame=96794 NotFixedDelay= 0.0000 Duration=00:51:37.280 ====== PROCESSING LOG ====================== Seeking.... Done. Processing.... Number of written frames = 96790 Number of Errors= 0 #5 [Input info] Bitrate=192 Actual rate=192.000000 Sampling Frec=48000 TotalFrames=96632 Bytesperframe= 768.0000 Filesize=74213376 FrameDuration= 32.0000 Framespersecond= 31.2500 Duration=00:51:32.224 Channels mode=2/0: L+R LFE=LFE: Not present [Target info] StartFrame=5 EndFrame=96631 NotFixedDelay= 0.0000 Duration=00:51:32.064 ====== PROCESSING LOG ====================== Seeking.... Done. Processing.... Number of written frames = 96627 Number of Errors= 0 #6 [Input info] Bitrate=192 Actual rate=192.000000 Sampling Frec=48000 TotalFrames=96654 Bytesperframe= 768.0000 Filesize=74230272 FrameDuration= 32.0000 Framespersecond= 31.2500 Duration=00:51:32.928 Channels mode=2/0: L+R LFE=LFE: Not present [Target info] StartFrame=5 EndFrame=96653 NotFixedDelay= 0.0000 Duration=00:51:32.768 ====== PROCESSING LOG ====================== Seeking.... Done. Processing.... Number of written frames = 96649 Number of Errors= 0 #7 [Input info] Bitrate=192 Actual rate=192.000000 Sampling Frec=48000 TotalFrames=96932 Bytesperframe= 768.0000 Filesize=74443776 FrameDuration= 32.0000 Framespersecond= 31.2500 Duration=00:51:41.824 Channels mode=2/0: L+R LFE=LFE: Not present [Target info] StartFrame=5 EndFrame=96931 NotFixedDelay= 0.0000 Duration=00:51:41.664 ====== PROCESSING LOG ====================== Seeking.... Done. Processing.... Number of written frames = 96927 Number of Errors= 0 #8 [Input info] Bitrate=192 Actual rate=192.000000 Sampling Frec=48000 TotalFrames=96786 Bytesperframe= 768.0000 Filesize=74331648 FrameDuration= 32.0000 Framespersecond= 31.2500 Duration=00:51:37.152 Channels mode=2/0: L+R LFE=LFE: Not present [Target info] StartFrame=5 EndFrame=96785 NotFixedDelay= 0.0000 Duration=00:51:36.992 ====== PROCESSING LOG ====================== Seeking.... Done. Processing.... Number of written frames = 96781 Number of Errors= 0 I have installed the 1gb external drive on my laptop and tried to access it through AVS2DVD. I was able to import the .avi files into AVS2DVD, and set the output folder to the external drive. I have not, as yet, tried to burn a DVD. I will try that next to see if there is any speedup in the project with a larger available drive to operate with. Thanks for your help. Ed Wood |
11th December 2012, 17:25 | #2172 | Link |
AVStoDVD Dev
These are not logs from AVStoDVD.
AVStoDVD .log file is just ONE file named with the DVD label you have inserted in the main AVStoDVD window and located in the Output Folder you have selected in the main AVStoDVD window. For example, if you have labeled you DVD as "My DVD" and you have selected "D:\Movies" as output folder, then the log file will be: D:\Movies\My DVD.log Bye |
11th December 2012, 19:33 | #2173 | Link |
MrC.
I found 4 text files titled Ironside_D1_S1_0, Ironside_D1_S1_1, Ironside_D1_S1_2, Ironside_D1_S1_3. They were all document files, not log files. I tried to post them on this forum board but each one by itself far exceeded the 16,000 characters allowed in posts. If that is not the log file you refer to, I cannot find it on my computer. I am now in the process of burning a 2nd dvd and timing the burn, since I am writing to an external 1tb drive with 400gb free space. I will let you know what happens. Regards, Ed |
11th December 2012, 20:55 | #2174 | Link |
47.952fps@71.928Hz
Just saw the 2.6.0 Alpha (December 11, 2012) update on VideoHelp.com
http://www.videohelp.com/tools/AVStoDVD Looking forward to trying out the new features and new look.
12th December 2012, 13:44 | #2176 | Link |
AVStoDVD Dev
Release 2.6.0 Alpha 121205 is available to download.
Change log: - Some bugs fixed - Added 'FFmpeg (Safe Mode)' to AC3 Audio Encoding profiles in 'Preferences'/'Audio' - Added 'Adjust Frame Strategy' in 'Preferences'/'AviSynth' - Added 'DeBlock' AviSynth deblocking filter (by Manao) in 'Title Edit'/'AviSynth' - Added a time cap (2h) to AC3 audio encoding step (Wavi+Aften profile). Overrun leads to process kill and 'FFmpeg (Safe Mode)' start as backup. - Added a framerate consistency check vs selected Video Standard to source titles during 'Add Title' routine - Added audio ON/OFF control to 'Preview Clip' section - Added ffdshow 1.2.4422.0 32bit to Installer package - Added GraphStudio 0.3.2.0 beta to NoInstall and Installer packages - Added 'Codecs' as new element in Main AVStoDVD Menu - Added 'ffdshow Video Configuration' option from 'Codecs' (Main Menu) - Added 'ffdshow Audio Configuration' option from 'Codecs' (Main Menu) - Added 'Build Graph Filter' option from 'Codecs' (Main Menu) - Moved 'AviSynth FrameServing Check' from 'Title' to 'Codecs' (Main Menu) - Removed ImgBurn Installer from AVStoDVD Installer Package. There is still a link to ImgBurn webpage. - Changed 'Adjust ffdshow Mixer Output at runtime' to 'Adjust ffdshow Settings at Runtime' (now including Raw Video and Raw Audio adjustments for Preview Clip section) - Improved 'Quick StartUp Tutorial' section - Improved 'Fix SRT' routine for authored subtitles - Improved log activity (Audio Encoding section) - Improved GUI graphics (progress bars color change) - Re-organized AviSynth filters options disposition in 'Title Edit'/'AviSynth' - FFmpeg updated to build git-8b6aeb1 - FFMpegSource updated to 2.17 - Haali Media Splitter updated to 1.11.96.14 - MKVToolNix updated to 5.8.0 - MediaInfo updated to 0.7.61 Happy testing. Bye |
12th December 2012, 16:41 | #2177 | Link |
Thanks MrC for the new version, I like the improvements very much. I tested it with two small conversion jobs, no problems so far.
One small thing I noticed was when my source was a VOB file from a DVD (unencrypted) that GraphEdit could not build the graph. No big deal... Thanks again Cheers manolito |
12th December 2012, 19:03 | #2178 | Link | |
BatchMux version --> 1.3 Destination Folder --> F:\Ironside Burned DVD\DVD_0\VIDEO_TS MuxMan Script File --> C:\Users\EDWOOD~1\AppData\Local\Temp\DVD_0_MuxMan.mxp MuxMan Log String --> -l "C:\Users\EDWOOD~1\AppData\Local\Temp\DVD_0_MuxMan.log" Folder of the MuxMan executable --> C:\Program Files\AVStoDVD\MuxMan Check presence of MuxMan.exe --> PASSED Palette File --> C:\Users\EDWOOD~1\AppData\Local\Temp\DVD_0_Palette.txt Default Palette --> SUCCESSFULLY REDEFINED Segment memory resources --> RELEASED Local Stack memory --> RELEASED File i/o structures --> DEALLOCATED The DVD log file is to long to post. I think the problem was caused by the external drive going to sleep and the process aborted before the drive came up. I have searched the properties of the external drive and I cannot find any way to prevent the drive from going into sleep mode. Any suggestions? Ed |
13th December 2012, 13:44 | #2179 | Link |
AVStoDVD Dev
@manolito
the VOB is indexed? If not, it should be resolved by directshow. Make sure that ffdshow is setup with libmpeg2 for mpeg1/2 decoding. @edwood please post the whole log file. You can attach the file. Bye |
13th December 2012, 20:33 | #2180 | Link | |
Rendering a 1GB VOB from a DVD simply takes longer than 10 secs, and by default GraphStudio aborts rendering after 10 secs. There is an option in GraphStudio to turn this off, and with this option disabled the VOB is rendered correctly. Unfortunately GraphStudio does not save this setting, and it also does not support startup parameters, so nothing can be done about it. But as I said, this is no big deal... Cheers manolito |
