Old 28th April 2020, 19:27   #5561  |  Link
pinterf
I found no failing plugins so far. But I have only a limited set of them compared to the community.
pinterf is offline
Old 28th April 2020, 19:40   #5562  |  Link
tormento
Acid fr0g
tormento's Avatar
The infamous recompile of KNLMeansCL is not necessary?
@turment on Telegram
tormento is offline
Old 28th April 2020, 20:26   #5563  |  Link
pinterf
Ah yes. I forgot it because I had fixed it for my tests.
pinterf is offline
Old 28th April 2020, 20:29   #5564  |  Link
tormento
Acid fr0g
tormento's Avatar
[2020-04-28][21:28:30] error: System exception - Access Violation
[2020-04-28][21:28:30] (D:/Programmi/Media/AviSynth+/plugins64/Zs_RF_Shared-1.121.avsi, line 698)
[2020-04-28][21:28:30] (D:/Programmi/Media/AviSynth+/plugins64/SMDegrain-3.1.2·106.avsi, line 610)
[2020-04-28][21:28:30] (D:/Programmi/Media/AviSynth+/plugins64/SMDegrain-3.1.2·106.avsi, line 181)
[2020-04-28][21:28:30] (E:\in\2_15 Amabili resti\resti_4_500.avs, line 16)
[2020-04-28][21:28:30] PROCESS EXITED WITH ERROR CODE: 1
I noticed.
tormento is offline
Old 29th April 2020, 06:41   #5565  |  Link
real.finder
And finally. 3.5.2. test builds, files only.
There are plugins and plugins64 folder inside, not plugins+ and plugins64+, sorry. But I think not much mixed environment (with avs 2.6) are left by now.
Those who cannot wait for the feature explanations please check readme_history.txt for changes.
But until I post about the new features use these builds as usual. If they fail in something test them with other scripts. Thank you.
This one with array support (preferred)
https://drive.google.com/open?id=1_4...lTIp3u5jFpAgRW
Without arrays
https://drive.google.com/open?id=1EY...uD--nSj12hILX4
thank you for the update
I note MP_Pipeline still need return last, also another cases https://forum.doom9.org/showthread.p...56#post1906156
and all https://github.com/chikuzen plugins now don't work
chikuzen, we need you back, please come back!
See My Avisynth Stuff
real.finder is offline
Old 29th April 2020, 07:16   #5566  |  Link
pinterf
Yes, probably they are using the old avs+ specific IScriptEnvironment2. I found TMM2_avx2 at myself, which ones are actively used?
pinterf is offline
Old 29th April 2020, 07:35   #5567  |  Link
real.finder
addition to TMM2, I have those
https://github.com/chikuzen/TCannyMod (I have fork for names changes https://github.com/realfinder/TCannyMod)
https://github.com/chikuzen/CombMask (also I have fork for names changes https://github.com/realfinder/CombMask)
https://github.com/chikuzen/MPEG2DecPlus (this one also need HBD deblock update from https://github.com/mysteryx93/Avisynth-Deblock)
https://github.com/chikuzen/yadifmod2
https://github.com/chikuzen/DCTFilter
https://github.com/chikuzen/PlanarTools
https://github.com/chikuzen/TEMmod
https://github.com/chikuzen/ReduceFlicker
maybe you should wait chikuzen for some time (few days) before update them
Old 29th April 2020, 07:48   #5568  |  Link
pinterf
Anyway, the current working branch is here:
https://github.com/AviSynth/AviSynthPlus/tree/neo
I'm using the new AviSynth headers from there.
They are not 100% final but those things that are needed for a rebuild are there.
pinterf is offline
Old 29th April 2020, 07:51   #5569  |  Link
pinterf
PlanarTools is for what?
pinterf is offline
Old 29th April 2020, 07:54   #5570  |  Link
real.finder
IIRC, it's faster in convert YUY2 to YV16
Old 29th April 2020, 09:06   #5571  |  Link
jpsdr
I think i missed this one.
What do you mean exactly ?
Do you mean that the new version doesn't look anymore for "+" folders, and if i stay with my actual configuration with plugins in "+" and "not +" folders, the plugins within the "+" folders will not be loaded ?
My github.
jpsdr is offline
Old 29th April 2020, 09:19   #5572  |  Link
pinterf
No, no, recently we were asked why the "filesonly" distribution is changing its internal folder names, plus or non-plus. The installer puts them into plugins(64)+ directory, while I provide it sometimes without the plus in the name inside the zip file.
I meant that in an Avisynth+-only system it is not problem if those appear in the main plugin directory and not in the plus (as long as you don't have two sets of the bundled plugins, one in the plugins the other in the plugins+ folder)
pinterf is offline
Old 29th April 2020, 09:41   #5573  |  Link
jpsdr
Ok, fine.
My github.
jpsdr is offline
Old 29th April 2020, 09:44   #5574  |  Link
tormento
Acid fr0g
tormento's Avatar
KNLMeansCL badly needed here.
Testing purposes, of course.
tormento is offline
Old 29th April 2020, 10:51   #5575  |  Link
StainlessS
StainlessS's Avatar
31st October 2018, 11:25
I guess thread control means editing the very first post. Good idea, considering.
28th April 2019, 07:08:
Regarding the new thread, yeah, I'll start it, promise, unfortunately my draftsman is on holiday , I wanted to write a proper intro w/o mis-spelling.
Anyway it's time for a new release but I found way too many other tasks and coding adventures for myself, so it's just a question of weeks.
Wonderful new Avs+ v3.x version with arrays and such, what a great opportunity to have its own thread, or do you need think about it for a little while.
I sometimes post sober.
StainlessS is offline
Old 29th April 2020, 11:12   #5576  |  Link
ChaosKing
With new stuff like arrays, why not make life easier and add also a official scripts folder while we are at it?
We would have then 2 plugins and 1 script folder.
ChaosKing is offline
Old 29th April 2020, 11:42   #5577  |  Link
pinterf
Unofficial test, grab it from here
https://github.com/pinterf/KNLMeansC...or_avs3.5.2.7z
pinterf is offline
Old 29th April 2020, 11:50   #5578  |  Link
Groucho2004
Works, thanks!
Groucho's Avisynth Stuff
Groucho2004 is offline
Old 29th April 2020, 15:03   #5579  |  Link
tormento
Acid fr0g
tormento's Avatar
Avisynth+
+1 to have AVSI folder.
In my dreams a repo where AVS+ automatically downloads needed plugins and AVSI functions to run a script...
tormento is offline
Old 29th April 2020, 15:07   #5580  |  Link
real.finder
there are this already https://forum.doom9.org/showthread.php?t=176443
