23rd September 2015, 18:29 | #33103 | Link |
Hmmmm... Thanks! For some reason the log is empty, though. And the freeze report doesn't contain any information about LAV at all, which is rather weird. I'm not sure what went wrong there. Are you sure you downloaded the correct version of the LAV debug symbols? If so, maybe you could try creating another freeze report with 32bit MPC-HC? Maybe that works better than 64bit, I'm not sure...
23rd September 2015, 18:34 | #33104 | Link | |
Also, when I use NNEDI3 for chroma upsampling the image is completely green. I can still see the image but it's all in green. This is even when not using image doubling. If you want me to run the player for 5 minutes when using the debugging I have no problem with doing that. I won't be able to do it until I get home in about 3 hours or so though.
Intel i5 3470, EVGA GTX 1050Ti SC ACX 2.0, Windows 10 Pro 64 bit, 16 GB 1600 mhz DDR3 RAM |
23rd September 2015, 18:34 | #33105 | Link | |
for the lavfilter version i used stable 0.66 and the linked PDB in the forum post with 0.66 in the zipped folder name. i will try 32 bit now and i install lavfilter to another folder program files under windows 10 has some heavy right "problems". edit: v2: http://filehorst.de/d/bdntmfqu i put content from LAVFilters-0.66-symbols.zip in LAV Filters\x86 and i made sure mpc-hc 32 used that lavfilter version. the freeze report doesn't look any different to me than the last one. there is content in the log. Last edited by huhn; 23rd September 2015 at 18:47. |
23rd September 2015, 19:01 | #33106 | Link | |||
So now I think the best course of action is the following: Step 1: We need to find the exact madVR build which introduced the problem. From your earlier posts it seems the problem occurs with v0.89.2, but not with v0.88.16, right? So some build in between must have introduced the problem. Could you try the last 88 build v0.88.21? If that build works for you, probably v0.89.0 has introduced the problem. Could you double check that with v0.89.0 then, just to confirm? If the problem also occurs with v0.88.21, can you check the versions in between v0.88.21 and v0.88.16 to find the exact version which introduced the problem? The most likely candidates would then be v0.88.17, v0.88.20 or v0.88.21. Step 2: I would then create some test builds which are somewhere between the last build that still works and the first build which doesn't work, anymore, so we can isolate the exact change in my code which introduced the problem. This is a painful way of debugging, but I'm out of other ideas. I hope for you it wouldn't be too much effort, because I don't need any more logs or reports or anything. Just a "yes/no" for each test build. Would that be ok for you? The previous madVR builds are all available for download here: http://www.videohelp.com/software/ma...sions#download Usually you can just overwrite the files, no need to uninstall/reinstall. Thanks!! Quote:
FWIW, have you tried reinstalling the GPU driver or installing a different/newer driver version? Quote:
@nevcairiel, are you listening? From the freeze report it doesn't look like madVR is directly involved. Could you check the thread callstacks? I've copied the most interesting here. Maybe you can see what's wrong? Could it be that threads $e34 and $175c are blocking each other? Or maybe cuvidDecodePicture is simply frozen? From the madVR debug log it seems that the decoder simply stops sending frames at some point, for unknown reasons... Code:
date/time : 2015-09-23, 19:39:53, 991ms operating system : Windows 10 x64 build 10240 free disk space : (C:) 65.12 GB display mode : 1920x1080, 32 bit allocated memory : 387.14 MB largest free block : 1.97 GB executable : mpc-hc.exe thread $e34: 7079307f +00f nvcuvid.dll cuvidDecodePicture 70bd50e3 +0d3 LAVVideo.ax cuvid.cpp 854 +43 CDecCuvid.HandlePictureDecode 7078f284 +024 nvcuvid.dll cuvidParseVideoData 70bd5b7c +1ec LAVVideo.ax cuvid.cpp 1168 +62 CDecCuvid.Decode 70bd1bef +10f LAVVideo.ax quicksync.cpp 76 +28 CDecBase.Decode 70be0700 +350 LAVVideo.ax decodethread.cpp 380 +122 CDecodeThread.ThreadProc 70c6d514 +034 LAVVideo.ax wxutil.cpp 124 +8 CAMThread.InitialThreadProc 70c75780 +018 LAVVideo.ax threadex.c 376 +13 _callthreadstartex 70c758a6 +077 LAVVideo.ax threadex.c 354 +55 _threadstartex 75ce3742 +022 KERNEL32.DLL BaseThreadInitThunk thread $e28: 75068d03 +93 KERNELBASE.dll WaitForSingleObjectEx 75068c5d +0d KERNELBASE.dll WaitForSingleObject 70c6d4c8 +08 LAVVideo.ax wxutil.cpp 183 +1 CAMThread.GetRequest 70be9236 +16 LAVVideo.ax lavvideo.cpp 2144 +4 CLAVControlThread.ThreadProc 70c6d514 +34 LAVVideo.ax wxutil.cpp 124 +8 CAMThread.InitialThreadProc 70c75780 +18 LAVVideo.ax threadex.c 376 +13 _callthreadstartex 70c758a6 +77 LAVVideo.ax threadex.c 354 +55 _threadstartex 75ce3742 +22 KERNEL32.DLL BaseThreadInitThunk thread $175c: 75068d03 +093 KERNELBASE.dll WaitForSingleObjectEx 75068c5d +00d KERNELBASE.dll WaitForSingleObject 70be0108 +158 LAVVideo.ax decodethread.cpp 186 +35 CDecodeThread.Decode 70be7a34 +134 LAVVideo.ax lavvideo.cpp 1290 +31 CLAVVideo.Receive 70c6e979 +059 LAVVideo.ax transfrm.cpp 763 +8 CTransformInputPin.Receive 70c674e6 +016 LAVVideo.ax decssinputpin.cpp 375 +2 CDeCSSTransformInputPin.Receive 723a5559 +019 LAVSplitter.ax amfilter.cpp 2695 +8 CBaseOutputPin.Deliver 723777f0 +540 LAVSplitter.ax outputpin.cpp 535 +96 CLAVOutputPin.DeliverPacket 77a48c0a +00a ntdll.dll NtWaitForSingleObject 75068d03 +093 KERNELBASE.dll WaitForSingleObjectEx 723771b9 +1f9 LAVSplitter.ax outputpin.cpp 412 +38 CLAVOutputPin.ThreadProc 723a890a +02a LAVSplitter.ax wxutil.cpp 117 +1 CAMThread.InitialThreadProc 723a8914 +034 LAVSplitter.ax wxutil.cpp 124 +8 CAMThread.InitialThreadProc 723ac2e8 +018 LAVSplitter.ax threadex.c 376 +13 _callthreadstartex 723ac40e +077 LAVSplitter.ax threadex.c 354 +55 _threadstartex 75ce3742 +022 KERNEL32.DLL BaseThreadInitThunk thread $1764: 750713c2 +092 KERNELBASE.dll SleepEx 7507131a +00a KERNELBASE.dll Sleep 72376dea +0aa LAVSplitter.ax outputpin.cpp 341 +12 CLAVOutputPin.QueuePacket 7237ba8e +2be LAVSplitter.ax lavsplitter.cpp 844 +62 CLAVSplitter.DeliverPacket 7237b75c +29c LAVSplitter.ax lavsplitter.cpp 741 +59 CLAVSplitter.ThreadProc 723a890a +02a LAVSplitter.ax wxutil.cpp 117 +1 CAMThread.InitialThreadProc 723a8914 +034 LAVSplitter.ax wxutil.cpp 124 +8 CAMThread.InitialThreadProc 723ac2e8 +018 LAVSplitter.ax threadex.c 376 +13 _callthreadstartex 723ac40e +077 LAVSplitter.ax threadex.c 354 +55 _threadstartex 75ce3742 +022 KERNEL32.DLL BaseThreadInitThunk modules: 00860000 mpc-hc.exe 1.7.9.0 C:\Program Files (x86)\MPC HomeCinema 05910000 avcodec-lav-56.dll 56.57.100.0 C:\lav filter\LAV Filters\x86 4a400000 madVR.ax 0.89.3.0 C:\madVR |
23rd September 2015, 19:13 | #33107 | Link | |
Bye Last edited by CiNcH; 23rd September 2015 at 19:21. |
23rd September 2015, 19:19 | #33108 | Link |
there is an other nnedi3 issue.
render queue drops down 2-3 and render times getting higher easily to 40-42 ms. there are no frame drops. here 2 screens from the same file with the same settings: normal: http://abload.de/img/anothernnedi3issue8arbf.png problem: http://abload.de/img/anothernnedi3issue291rz8.png this is usually created after a seek sometimes from the start. i had a VRAM issue that's why i don't use 8 present frames in advance |
23rd September 2015, 19:26 | #33109 | Link |
So far, NNEDI3 has been totally stable here with the new versions, apart from that small upscaling refinement bug.
12 frames prerendered and D3D11 also seem to be totally fine here so far in windowed mode on Win 10 (GTX 980, 355.98). |
23rd September 2015, 19:28 | #33110 | Link | |
The exact time I haven't taken notice of but, for 23.9 fps video it skips about 350 fps on average. For 30 fps videos its skips 450 to 500 fps on average. Absolutely nothing changed between v0.89.2 and v0.89.3. I did try reinstalling the driver with Display Driver Uninstaller when this first started happening when I upgraded from Windows 8.1 to Windows 10. When AMD came out with a beta driver for windows 10 just 2 weeks ago or so I switched to that using Display Driver Uninstaller. No of this made a difference either.
23rd September 2015, 19:46 | #33111 | Link | ||||
23rd September 2015, 19:50 | #33112 | Link |
I made some tests and found out that the freeze issue under WIN10 in my case is caused by two things:
1) LAV CUVID + MadVR NNEDI3 chroma upscaling or 2) LAV CUVID + SVP OPEN CL
Raven RVZ01 * i7-4790k * 16GB RAM * Zotac GTX 970 4G * SSD 850Evo 500GB * Blu-Ray Burner Slot-In * PSU SFX 80+ Gold 450Watt * Windows 10 64bit * MPCHC+MadVR+SVP * Panasonic 50" VT30 ^^ |
23rd September 2015, 19:56 | #33114 | Link | |
http://madshi.net/madVRcinch1.rar Thanks! |
23rd September 2015, 19:57 | #33115 | Link | |
How would one go about checking registry access rights? What should i look for? If the administrator account has full access rights (I use my home PC with only the Administrator account) or if madVR itself has read/write access rights?
23rd September 2015, 20:03 | #33117 | Link | |
so I guess (at least this time ) it's not MadVR's fault. I posted the issue in SVP forum by the way.
23rd September 2015, 20:06 | #33118 | Link | |
It seems that any kind of OpenCL freezes in combination with LAV CUVID. I think the only one who can do something about it is nevcairiel, because neither SVP nor madVR know whether CUVID is active or not, nor can we disable it. Ultimately it's NVidia's fault, though, that's very obvious now. |
23rd September 2015, 20:09 | #33119 | Link | |
Bye |
23rd September 2015, 20:16 | #33120 | Link | |
