26th September 2014, 03:36 | #41 | Link | |
[Edit] Ok... it will keep DTS-HD it if you have "Keep HD Audio for BD25 /Alternate Intact" checked in SETUP. Last edited by jdobbs; 26th September 2014 at 03:39. |
26th September 2014, 03:47 | #42 | Link | |
Any feed back on why it does that.
26th September 2014, 14:09 | #43 | Link | |
Also, if the output is selected as x265, Intact Video may not work. But I'd have to test it. That's because it might assumes the source couldn't be HEVC (since that would be illegal for the source BD). Last edited by jdobbs; 26th September 2014 at 14:32. |
26th September 2014, 14:19 | #44 | Link |
You may have encoded by a m2ts affecting the bluray menu, first try only encode the m2ts main movie and edit with tsmuxer and create new mpls and m2ts and copy and paste on structure bd and playback with powerdvd 14
26th September 2014, 15:42 | #45 | Link | ||
Preset Quote:
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 26th September 2014 at 15:48. |
26th September 2014, 15:43 | #46 | Link |
Doesn't work. I created blu-ray structure with tsmuxer for movie only, which I encoded with HEVC.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 26th September 2014 at 15:51. |
26th September 2014, 16:01 | #48 | Link | ||
Also Jdobbs, there is bug in file output name and need fixing.
I am working with CAPT_AMERICA_WINTER_SOLDIER_3D and have chosen alternate output with two pass encode and encoding with X265. X265 batch file contents Pass 1 Quote:
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 26th September 2014 at 16:32. |
26th September 2014, 16:02 | #49 | Link |
Are you testing with 3D source or 2D? All I know I have MKV intact video and audio and source is 3D and BD-RB still want to encode it.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 26th September 2014 at 16:04. |
26th September 2014, 16:29 | #50 | Link |
Jdobbs, I notice if you are outputting to MKV and using hevc. If encoder is doing second pass and user abort and restart it want to start from creating stats file and doing two pass on video again.
26th September 2014, 17:37 | #51 | Link | |
26th September 2014, 17:43 | #52 | Link | |
Are you sure you're looking at the right .BAT files? I don't think so. Here's the second pass of a 3D SBS encode:
26th September 2014, 17:57 | #53 | Link | |||
Here are my bdrebuilder.ini file setting Quote:
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 26th September 2014 at 18:00. |
27th September 2014, 01:27 | #54 | Link | |
30th September 2014, 22:10 | #55 | Link |
jdobbs for create MKV Container, HEVC Intact Video, Intact Audio. This is correct?and as applied in alternate.txt?
[00037] caption=MKV Container, HEVC 1980x1080, Intact Video, Intact Audio vEncoder=1 aType=2 vFormat=8 cType=1 Last edited by lauguru; 30th September 2014 at 22:20. |
30th September 2014, 22:45 | #57 | Link |
i try , and m2ts to convert is mpeg2 is 720x576 use vFormat= 6= 720x480/576, or 7= No Resizing ?
[00037] caption=MKV Container, HEVC 1920x1080, Intact Audio vEncoder=1 vBitrate=2000 vKeyint=Auto aType=2 vFormat=5 cType=1 |
30th September 2014, 22:49 | #58 | Link |
Change V format to 6 and might want to rename caption=MKV Container, HEVC 720x480/576, Intact Audio
bd-rb, h.265, hevc |
