27th July 2020, 03:34 | #29721 | Link |
3D MVC MKVs - is it possible?
Is there a way to make a movie only MKV backup with MVC 3D? All my full 3D BD-25 Blu-ray backups using BDRebuilder always come out pixelated when using Powerdvd playback but fine if burn and use a hardware player, never can figure out how to get around this, so I want to try a 3D MVC MKV option.
27th July 2020, 07:57 | #29722 | Link | |
27th July 2020, 10:24 | #29723 | Link | ||
[07.27.20] BD Rebuilder v0.61.09 [11:05:18] Source: SPECTRE_00800 - Input BD size: 37,52 GB - Approximate total content: [02:28:06.878] - Windows Version: 6.2 [9200] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV, HEVC, NO_RESIZE, Auto-AC3 - Quality: Good (Fastest, BD-25+) - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [11:05:20] PHASE ONE, Encoding - [11:05:20] Processing: VID_02211 (1 of 1) - [11:05:20] Extracting A/V streams [VID_02211] - [11:14:02] Reencoding video [VID_02211] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 213.072 frames - [11:14:02] Reencoding: VID_02211, Pass 1 of 1 Running the contents of LASTCMD returns nothing. Quote:
x265 [error]: unable to open input file <-> |
27th July 2020, 13:06 | #29724 | Link | |
27th July 2020, 13:19 | #29725 | Link |
[Options] VERSION=0.61.0.7 ENCODER=0 MODE=3 ENCODE_QUALITY=5 ONEPASS_ENCODING=0 AUTO_QUALITY=0 MOVIEONLY_TYPE=1 ALTCRF=25 ALT_TARGET=1024 ALT_CRF_TARGET=1024 ALTMETHOD=0 ALTAUTOCROP=0 AUDIO_TO_KEEP=deu;eng;ger; SUBS_TO_KEEP=all SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=1 SD_TO_1080=0 IGNORE_3D=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=0 AUDIO_DRC=0 DECODER=0 AVCHD=1 REMOVE_WORKFILES=0 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 FRIMSOURCE=0 COMPLETION_BEEP=0 OUTPUT_SBS=0 NEROAAC=0 SUPTITLE=0 PGSTOSRT=1 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=23500 [Paths] SOURCE_PATH=V:\FULLDISC\SPECTRE\ WORKING_PATH=V:\OUTPUT\ Code:
# The options below show up in the Alternate Output Dialog # Settings: # caption=Text to show on alternate selection list # vEncoder=Video encoder, 0=x264 (default), 1=x265, 2=HC Encoder (MPEG-2) # Note: A cType of 3 or 4 (see below) forces MPEG-2 via HCEncoder # vBitrate=Bitrate to use for two-pass video encoding, * = variable (DVD only) # aBitrate=Bitrate to use for audio encoding, * = automatic (constant quality encode, not allowed for iPod & iPad) # aType=Output Audio Type, 0=AC3, 1=AAC (Note: Audio bitrate less than 384Kbs implies stereo downmix) # 2=[Intact audio -- MKV & MP4 only] # vFormat=Video Format: 0=320x240/180, 1= 480x360/270, 2= 640x480/360, 3= 1024x768/576, # 4= 1280x720, 5= 1920x1080, 6= 720x480/576, 7= No Resizing, 8=Intact # vKeyint=Video GOP size (interval): Default=24, "Auto" = 10x framerate (MKV & MP4 only) # cType= Container/limits type, 0=iPod (mp4), 1=MKV, 2=iPad (mp4), 3=DVD-5, 4=DVD-9, 5=MP4 6=iPad 2+ (MP4) [00001] caption=MKV, HEVC, NO_RESIZE, Auto-AC3 aBitrate=640 aType=0 cType=1 vEncoder=1 vFormat=7 vKeyint=Auto vBitrate=0 [00002] caption=MP4, HEVC, NO_RESIZE, Auto-AC3 aBitrate=640 aType=0 cType=5 vEncoder=1 vFormat=7 vKeyint=Auto vBitrate=0 [00003] caption=MKV, HEVC, 1080p, Auto-AC3 aBitrate=640 aType=0 cType=1 vEncoder=1 vFormat=5 vKeyint=Auto vBitrate=0 [00004] caption=MP4, HEVC, 1080p, Auto-AC3 aBitrate=640 aType=0 cType=5 vEncoder=1 vFormat=5 vKeyint=Auto [00005] caption=MKV, H264, NO_RESIZE, Auto-AC3 aBitrate=640 aType=0 cType=1 vEncoder=0 vFormat=7 vKeyint=Auto vBitrate=0 [00006] caption=MP4, H264, NO_RESIZE, Auto-AC3 aBitrate=640 aType=0 cType=5 vEncoder=0 vFormat=7 vKeyint=Auto vBitrate=0 [00007] caption=MKV, H264, 1080p, Auto-AC3 aBitrate=640 aType=0 cType=1 vEncoder=0 vFormat=5 vKeyint=Auto vBitrate=0 [00008] caption=MP4, H264, 1080p, Auto-AC3 aBitrate=640 aType=0 cType=5 vEncoder=0 vFormat=5 vKeyint=Auto Code:
[07.27.20] Checking System Settings - BD-Rebuilder v0.61.09 - Windows Version: 6.2 [9200] - Working Path Free Space: 632,36GB - AVISYNTH Version: 2.6.0.6, Ok - LAVFILTERS: Ok - X264: Ok - X265: Wrong version found - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [07.27.20] Systems Settings Check complete |
27th July 2020, 13:41 | #29726 | Link |
I updated x265 and forgot to update the checksum. I'll fix that for the next release.
[Edit] Yep. I used your INI and ALTERNATE settings and I got the same error. I'll have to trace it now and see why. Last edited by jdobbs; 27th July 2020 at 13:49. |
27th July 2020, 13:56 | #29727 | Link | |
I made no manual changes since then ... only Settings and Setup menu |
27th July 2020, 14:05 | #29728 | Link | |
It turns out I had commented out a line when I was working on the X265 call subroutine (I don't even remember doing it) and failed to enable it again. Last edited by jdobbs; 27th July 2020 at 14:08. |
27th July 2020, 15:15 | #29730 | Link | |
27th July 2020, 15:54 | #29731 | Link |
Yeah. But that's a 32 bit version of X264 (it has to be to work with AVISYNTH) -- and it has a reduced memory limit. With that said, though, 25MB isn't really that much. Something must have gotten it close to the limit before that happened (the large frame size, maybe?)
This part bothers me: Code:
clpi_parse.c:138: failed signature match expected (HDMV0200) got (HDMV0300) Last edited by jdobbs; 27th July 2020 at 15:57. |
27th July 2020, 18:33 | #29733 | Link | |
I cant't think of anything wrong ... Maybe someone else can do some tests? |
27th July 2020, 19:17 | #29734 | Link |
I know you've been looking at NVENCC lately, and I love it.. especially since my one drive crashed and I have begun to re-rip a bunch of discs to Alt Movie Only... Its been working great, NVENCC and all...
Unfortunately today I ran into an issue with Avatar Extended Collector's Edition 3 disc set. Disc 1 has Three versions of the movie on it. Theatrical, Special Edition Re-Release, and Collector's Extended Cut. BR-RB seems to not see anything by 800.MPLS, even when selecting "other movie". Apparently the correct play lists are 850, 851 and 852 respectively, and it uses branching? (based on google searches). I tried looking back in the thread to see if this was discussed, and couldn't find it (used "Search this thread..." and did just AVATAR as the search term. Found plenty on the RED_BIRD_2D disc which is the standard theatrical only disc, subtitle questions, and 3D, but not this). Does anyone remember anything about this, or how to possibly get around it? |
27th July 2020, 20:40 | #29735 | Link | |
Does it crash right away, or after running for some period? Do you have enough time to bring up the task manager and see how much memory it is using? Which ALTERNATE preset are you using? Can you post the contents of the AVS file right after it fails so I can see if that may have an impact? Last edited by jdobbs; 27th July 2020 at 21:01. |
27th July 2020, 21:18 | #29736 | Link | |
Preset is 00005 The AVS file is pretty short: Code:
#Created by BD Rebuilder - v0.61.09 DirectshowSource("V:\FULLDISC\JUSTICE_LEAGUE\BDMV\STREAM\00015.m2ts", fps=23.976, framecount=172689, audio=false) ConvertToYV12().AssumeFPS(24000,1001) |
28th July 2020, 08:39 | #29737 | Link |
It seems to me, that most of my encodes work with "Automatically crop black borders", just a relatively few of my encodes do not fail, but when I find an encode that fails, it will consistently fail. When I use the "UHD_LIMIT_ENCODE=n", if the encode is going to fail, will still fail with only 10 minutes of data, so that is how I can tell that an encode will fail without spending several days processing the encode (I also turn down all the quality settings). Next encode that fails, I will post the details of both the successful and failed logs. Thanks JDobbs!
28th July 2020, 13:55 | #29739 | Link | |
28th July 2020, 15:22 | #29740 | Link | |
BUT ... when I delete "--bframes 3" from the string, it works ... The failed signature message is still there but no malloc error ... and I see progress Is there anything more I can do to localize the issue? |
