Old 1st December 2015, 04:07   #761  |  Link
JohnLai
Originally Posted by Magik Mark View Post
Thanks. I think CPU encoding is a lot better. We just have to be patient. Do you know any guides using x265 in transcoding videos? Maybe presets for different type of videos. Dark, action, dram etc.
Sigh......I suggest you to wait 1 or 2 years before using x265. Current x265 still lack those "tune" preset compared to x264.
-.- Tell you something......using 10bit x265 -crf 28 -preset medium encoding to encode hevc 1080p (note: no resizing, source video is hardware decoded) with core I5-3570K 4.2Ghz is very slow. The encoding fps is averaging 5-8 fps. I not sure if the trade off is worth it.
You might want to take a look on some sample quality comparison here;
http://forum.doom9.org/showthread.ph...75#post1733375
http://forum.doom9.org/showthread.ph...64#post1733664
JohnLai is offline   Reply With Quote
Old 2nd December 2015, 10:11   #762  |  Link
Lupissimo
After "upgrading" to Win 10 I got the following error trying a reencode:
Environment
StaxRip x64 : 1.3.1.7
OS : Windows 10 Pro
Language : German (Germany)
CPU : Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz
GPU : NVIDIA GeForce GTX 750
Source file MediaInfo
E:\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar.mkv
General
Unique ID : 193564096130464958721878217292158638466 (0x919F16C177DF236F9B582AFC921C9982)
Complete name : E:\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar.mkv
Format : Matroska
Format version : Version 2
File size : 3.44 GiB
Duration : 1h 55mn
Overall bit rate : 4 254 Kbps
Encoded date : UTC 2012-12-17 16:44:08
Writing application : mkvmerge v5.7.0 ('The Whirlwind') built on Jul 8 2012 20:08:51
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L3.1
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Muxing mode : Header stripping
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 55mn
Bit rate : 3 977 Kbps
Width : 1 276 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.181
Stream size : 3.22 GiB (93%)
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 1h 55mn
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 159 MiB (5%)
Language : English
Default : Yes
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : English
Default : Yes
Forced : No
Text #2
Format : UTF-8
Language : Romanian
Default : No
Forced : No
Demux audio using mkvextract
"C:\StaxRip_x64_1.3.1.7_beta\Apps\MKVToolNix\mkvextract.exe" tracks "E:\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar.mkv" 1:"E:\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar temp files\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar ID2 English.ac3" --ui-language en
Extracting track 1 with the CodecID 'A_AC3' to the file 'E:\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar temp files\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar ID2 English.ac3'. Container format: Dolby Digital (AC3)
Start: 10:00:39
End: 10:01:34
Duration: 00:00:54
General
Complete name : E:\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar temp files\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar ID2 English.ac3
Format : AC-3
File size : 155 MiB
Duration : 1h 53mn
Overall bit rate mode : Constant
Overall bit rate : 192 Kbps
Audio
Format : AC-3
Duration : 1h 53mn
Bit rate : 192 Kbps
Stream size : 155 MiB
Demux subtitles using mkvextract
"C:\StaxRip_x64_1.3.1.7_beta\Apps\MKVToolNix\mkvextract.exe" tracks "E:\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar.mkv" 2:"E:\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar temp files\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar ID3 English.srt" --ui-language en
Extracting track 2 with the CodecID 'S_TEXT/UTF8' to the file 'E:\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar temp files\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar ID3 English.srt'. Container format: SRT text subtitles
Start: 10:01:34
End: 10:01:41
Duration: 00:00:06
Demux chapters using mkvextract
"C:\StaxRip_x64_1.3.1.7_beta\Apps\MKVToolNix\mkvextract.exe" chapters "E:\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar.mkv" --redirect-output "E:\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar temp files\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar_Chapters.xml"
Start: 10:01:42
End: 10:01:42
Duration: 00:00:00
Index with ffmsindex
"C:\StaxRip_x64_1.3.1.7_beta\Apps\Plugins\both\ffms2\ffmsindex.exe" "E:\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar.mkv" "E:\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar temp files\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar.ffindex"
Writing index... done.
Start: 10:01:44
End: 10:01:51
Duration: 00:00:07
Script
FFVideoSource("E:\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar.mkv", cachefile = "E:\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar temp files\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar.ffindex")
Crop(0, 0, -4, -0)
Script Properties
source frame count : 166612
source frame rate : 23.976024
source duration : 01:55:49.1090000
target frame count : 166612
target frame rate : 23.976024
target duration : 01:55:49.1090000
Audio Source File MediaInfo
General
Format : AC-3
File size : 155 MiB
Duration : 1h 53mn
Audio
Format : AC-3
Duration : 1h 53mn
Bit rate : 192 Kbps
Encoding using NVEncC
"C:\StaxRip_x64_1.3.1.7_beta\Apps\NVEncC\NVEncC64.exe" --cqp 20:23:25 --input "E:\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar temp files\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar_new.avs" --output "E:\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar temp files\Day for Night 1973 720p WEB-DL AAC 2.0 H.264-HDStar_new_out.h264"
NVEnc 1.10 (x64), using NVENC API v5.0
OS Version Unknown (x64)
CPU Intel Core2 Duo E8400 @ 3.00GHz (2C/2T)
GPU GeForce GTX 750 (4 EU) @ 1110 MHz (353.82)
Input Buffers CUDA, 16 frames
Input Info Avisynth 2.60 (yv12) -> nv12 [SSE2], 1272x720, 24000/1001 fps
Output Info H.264/AVC high
1272x720p 1:1 23.976fps (24000/1001fps)
Rate Control CQP
CQP I:20 P:23 B:25
GOP length 240 frames
B frames 3 frames
Ref frames 3 frames
MV Quality Q-pel
CABAC/deblock cabac / on
Error Encoding using NVEncC
Encoding using NVEncC failed with error code -1073741819
Rate Control CQP
CQP I:20 P:23 B:25
B frames 3 frames
Ref frames 3 frames
MV Quality Q-pel
Start: 10:05:43
End: 10:05:43
Duration: 00:00:00
Any idea what I did wrong?
Old 2nd December 2015, 12:32   #763  |  Link
JohnLai
1073741819 is access violation error code.
-.- Anyway, you better update your staxrip first.....
https://github.com/stax76/staxrip/wi...ment-Changelog
Scroll down to get the download link.....
AND UPDATE YOUR GPU DRIVER!
Old 3rd December 2015, 12:20   #764  |  Link
stax76
stax76's Avatar
I've added different decoding modes to the NVEncC GUI and fixed the menu to copy and execute the command line, after execution the shell stays open.
I'm not sure if QSVencC and x265 still work, I'll shortly make similar changes to QSVencC and x265.
Old 3rd December 2015, 14:22   #765  |  Link
JohnLai
So....I selected CUVID as decoder......but I need to manually enter the --output-res 1280x720 for resizing to the "Custom Switches" section. Sliding around Resize slider (right click, select hardware encoder) doesn't work.
Strangely enough, the resize slider option works for QSVenc decoder. Too bad I can't really use QSVenc decoder.
Awaiting your next build.
Oh, and since you implement the decoder menu selection at 'basic', the 'use qsvencc as decoder ......' at 'advanced' section should be removed.
Old 3rd December 2015, 15:12   #766  |  Link
stax76
stax76's Avatar
I looked for --output-res in the help and because it was missing I thought it's probably not yet supported.
Old 4th December 2015, 07:35   #767  |  Link
NikosD
@Stax76
Anything new regarding my questions about:
1) Unicode support
2) File Batch mode (configuration like subtitles, demux and indexing)
3) Just Mux mode
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
Old 4th December 2015, 16:39   #768  |  Link
stax76
stax76's Avatar
Unicode support
I can try to allow Unicode using VapourSynth, AviSynth+ don't yet support Unicode.
Is it possible to somehow configure the "File Batch" mode ?
For example, I have some files with embedded subtitles which in "File Batch" mode, the subtitles disappeared after transcoding. (No subs included)
Which subtitle languages are added can be defined in the options, by default it's local and English, adding all is possible (see tooltip), if it don't work it's either a bug or a limitation.
What is the use and gain of using "Demux and Index before creating jobs" option in "File Batch" mode?
It's useful when batch jobs need manual adjustment before processing.
Is it possible to avoid "indexing" when in video encoders profiles "Just Mux" is selected for both single file processing and "file batch" processing ?
In any case StaxRip opens always the video with either AviSynth+ or VapourSynth so the only way to avoid indexing is by choosing a source filter that don't index.
Old 4th December 2015, 19:18   #769  |  Link
cegy
@stax76 these bugs i've listed here http://forum.doom9.org/showpost.php?...&postcount=755 even in the latest test version (2015-12-03) also i noticed it doesn't change the color you know like this is bad you can't mux ac3 to mp4 for example
cegy is offline   Reply With Quote
Old 5th December 2015, 07:52   #770  |  Link
NikosD
That version - the latest 03/12/2015 - broke completely the Intel H.264 template.
When you select that template, even the import modes don't work (single file, file batch etc)
It just imports the file without the screen of sources selection and it doesn't even display the path of the file in the source and destination fields!
I use AviSynth+, haven't installed yet VapourSynth, but that move could be useful to others, probably.
Waiting for AviSynth+ to support it then.
It seems that it's a file type specific bug, the subtitle is recognized as "undetermined" and even using the magic word "all" doesn't work. It's a PGS sub.
So, here is a sample:
https://www.sendspace.com/file/wgkspi
How ? Can you give me an example ?
You mean DSS/DSS2 ?
Because I think all the others use indexing (haven't tried DG*)
Old 6th December 2015, 08:44   #771  |  Link
NikosD
NVEncC v2.00β2 is out supporting CUVID deinterlacing and NVCUVID decoding under Windows 10, as it is based to NVIDIA Video Codec SDK 6.0 which adds following new features.
Unified SDK for video encoding and decoding
Windows 10 official support
Support for H.264 Motion Estimation only mode
Support for input surfaces in RGB format
Support for SEI and VUI fields for H.265
Support for Adaptive Quantization for improved subjective visual quality with H.265 (adaptive quantization for H.264 is already supported)
GPUs supported for H.265 (HEVC) encoding
GeForce GTX 960, GTX 980. GTX Titan X
Quadro M4000, M5000, M6000
Tesla M4, M6, M60
Various quality and performance improvements in encoding
SDK samples no longer require the CUDA toolkit installed in order to build.
https://developer.nvidia.com/nvidia-video-codec-sdk
Old 6th December 2015, 09:15   #772  |  Link
JohnLai
Eh? GTX 970 and 950 is missing from the list?
So...before this SDK.....adaptive quantization for hevc encoding didn't work in the first place? Oh my.....
Well, I am still waiting for staxrip --output-res sliders support for nvencc+cuvid. ^.^
Eh? CUVID 6.0 finally add HEVC decoding, not sure hybrid decode is supported.
*OH darn, only GM206 based gpu support cuvid hevc decode.
Old 8th December 2015, 07:54   #773  |  Link
kartola
Hi guy,
I have to change my video card.
Is it possible to encode with staxrip using GPU at the same quality of cpu encoding (no streaming)? I use to encode with x264 1080 50p or 50i video.
Do you suggest to buy a nvidia gtx970 or ATI r9 390? Or it's the same for encoding because it's better to use CPU?
thx
kartola is offline   Reply With Quote
Old 9th December 2015, 13:40   #774  |  Link
luigizaninoni
just installed vapoursynth r29; staxrip seems to work fine. Only issue, crop editor no longer works, it shows a blank screen
luigizaninoni is offline   Reply With Quote
Old 11th December 2015, 13:53   #775  |  Link
Blowis
Is that there's a scheduled update.
You made the updated only when there's enhancements or bug.
For I have updated the apps MKVToolNix, x264 and X265. It's true that compared to other software can do it manually.
For a month I use for my encoding according to my test is faster than XMedia Recode (which is also a very good simple software primarily to normalize the sound with an analysis that calculates the db and subtitle part) . With XMedia Recode I still make the analysis of his to add or remove db I put on StaxRip and makes encoding.
I wish I had the same thing on a part StaxRip and subtitle.
Thank you for this software.
Blowis is offline   Reply With Quote
Old 12th December 2015, 13:21   #776  |  Link
Magik Mark
JohnLai,
tried the cuvid decoder and its 10x faster. May I know if you have any info on image quality? What benefits do you get from avisynth / vaporsynth as decoders
Old 12th December 2015, 17:55   #777  |  Link
JohnLai
JohnLai,
=.=......well for one........it turned out the adaptive quantization was not working for HEVC in the first place for nvenc SDK 5.0 and any driver version lower than R358.
Just make sure you update the driver to latest version first, otherwise the adaptive quantization will not work (there isn't any indicator whether it is working or not, blame nvidia for it)
Now, the answer to your question.
First, update the nvencc64.exe first
http://rigaya34589.blog135.fc2.com/blog-entry-710.html
Latest beta uses SDK 6.0 with proper support for adaptive quantization for hevc.
Now, since stax76 hasn't implement the resize slider functionality for nvencc yet....you will need to manually enter --output-res 1280x720 at 'Custom Switches" if you wanna take advantage of hardware based resizer. It turns out cuvid gpu based hardware resizer is using bilinear algorithm (I compared it with avisynth cpu based bicubic and bilinear, the cuvid hardware resizer result almost similar to avisynth cpu based bilinear resizer). Rigaya CUVID decoder only support H.264 / MPEG1 / MPEG2 for now. I speculate rigaya CUVID is using direct memory copy (zero copy) for decode+resize+encode. (complete nvidia gpu transcoding)
AVISYNTH/VAPORSYNTH are the normal stuff we used in previous version. The decoders depends on Source Filters ; https://github.com/stax76/staxrip/wiki/Source-Filters
There shouldn't be any different in decoding quality output. (Except post processing stuff = color space conversion, resize?). The only benefit of avisynth/vaporsynth = can support more format? For example, nvencc CUVID decoder will crash if the input file has AVI extension where avisynth doesn't.
Old 12th December 2015, 18:39   #778  |  Link
bungie240
Help with error message
Can anyone help with the error I receive below?
Error Demux M2TS using eac3to
Demux M2TS using eac3to failed with exit code: 1 (0x1)
The exit code might be a system error code: STATUS_WAIT_1
The exit code might be a system error code: Incorrect function.
M2TS, 1 video track, 4 audio tracks, 1 subtitle track, 2:04:42, 24p /1.001
1: Chapters, 20 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: DTS Master Audio, English, 7.1 channels, 24 bits, 48kHz
(core: DTS, 5.1 channels, 1509kbps, 48kHz)
4: AC3 Surround, English, 2.0 channels, 192kbps, 48kHz, dialnorm: -27dB
5: AC3, English, 2.0 channels, 192kbps, 48kHz, dialnorm: -27dB
6: TrueHD/AC3, English, 5.1 channels, 96kHz
(embedded: AC3, 5.1 channels, 448kbps, 48kHz)
7: Subtitle (PGS), English
Creating file "C:\Users\Livingroom-PC\Desktop\DVDFab 9.2.1.8\MOVIE DEMUX\OBLIVION_Chapters.txt"...
s07 Extracting subtitle track number 7...
a03 Extracting audio track number 3...
v02 Extracting video track number 2...
v02 Muxing video to Matroska...
a03 Creating file "C:\Users\Livingroom-PC\Desktop\DVDFab 9.2.1.8\MOVIE DEMUX\OBLIVION ID3 English.dtsma"...
s07 Creating file "C:\Users\Livingroom-PC\Desktop\DVDFab 9.2.1.8\MOVIE DEMUX\OBLIVION ID7 English.sup"...
Unfortunately the Haali Muxer cannot handle this source file.
It doesn't contain enough seek/recovery points.
The "-seekToIFrames" option may work around that.
However, using this option may result in artifacts when seeking.
Aborted at file position 23160946688.
StaxRip.ErrorAbortException: Demux M2TS using eac3to failed with exit code: 1 (0x1)
at StaxRip.Proc.Start() in D:\Projekte\GitHub\staxrip\General\Proc.vb:line 259
at StaxRip.MainForm.Showeac3toDemuxForm(String playlistFolder, Int32 playlistID) in D:\Projekte\GitHub\staxrip\Forms\MainForm.vb:line 5202
bungie240 is offline   Reply With Quote
Old 12th December 2015, 22:54   #779  |  Link
Magik Mark
Thanks a lot JohnLai. Have you noticed that using qaac encoder doesn't work? It keeps getting an error about controlaudiotoolbox not found
Does the ff filters work on nvidia:
1. Remove Grain
2. TDeint
3. Spatio-Temporal Noice filter
Old 13th December 2015, 12:36   #780  |  Link
JohnLai
1. Remove Grain
2. TDeint
With nvencc integrated CUVID? Sorry, I don't think those filters will works.
