Old 26th December 2017, 08:19   #21  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
ChangeLog for ffxvid 1.2.2
* Initial support for HDR to SDR conversions. Requires FFmpeg to be compiled with the zimg library as it needs the zscale filter https://github.com/sekrit-twc/zimg
Old 27th December 2017, 15:05   #22  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.2.3
* Renamed array variable CHARS to VCHARS in the video_chars_func() function
* Report pixel format in the video_chars_func() function
* Use -v quiet instead of -v error log level for ffprobe
* Cosmetics
Old 2nd January 2018, 00:06   #23  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.2.4
* Reworked the video_chars_func() function and added reporting of video bit depth
* Initial support for audio codec metadata when doing audio copy
* Increased default E-AC-3 audio bitrate from 768 to 960 kbps
* Set dialnorm for AC-3/E-AC-3 to its FFmpeg default (-31)
* Use a desat value of 2.5 for the tonemap filter when doing HDR to SDR conversions
* Don't use pix_fmts in the format filter. It is not really needed
* Removed 12-bit options from the video_pixfmt_func() function
* Cosmetics
Old 4th January 2018, 22:42   #24  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.2.5
* Don't hardcode the desaturation strength of the tonemap filter but let is be an option
* Removed the matrix and primaries options in the zscale filter as it leads to over-saturation of colors
* Support tweaking the tonemap algorithms for HDR to SDR conversion
* Support applying color saturation correction when doing an HDR to SDR conversion
* Added bt2020-12 to the list of transfers when doing color characteristics copy
* Added HDR_to_SDR_instructions.txt file to the package
Old 9th January 2018, 21:43   #25  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.2.6
* Moved the eq filter to almost the end of the video filter chain as it can lead to banding in certain cases in case the filter is in front of most other ones
* If the eq filter is used, also insert the format one after it if a pixel format has been chosen
* Fixed a possible devision by 0 that may occur when one copies audio and the bitrate for metadata is reported as N/A by ffprobe
Old 20th February 2018, 12:52   #26  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.2.7
* Fixed an issue where in some cases write-testing the output directory will fail due usage of readlink -f instead of readlink -m
* Update transfer chars to support latest changes to zimg from git
Old 26th February 2018, 21:51   #27  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.2.8
* Set the eq saturation default value to 1.0 (same as filter default)
* Add the colorspace and colormatrix filters when doing an HDR to SDR conversion
* Lower tonemap desat strength to 2.8
* Support white point adaptation for HDR to SDR
* Moved the colorspace filter after the scale one
* Moved the pixel format filter near the end of the filter chain
Old 14th June 2019, 19:42   #28  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.2.9
* Added support for the bm3d denoise filter
Old 23rd July 2019, 12:23   #29  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 1.3.0
* Added support for crop preview using MPlayer when autocrop is enabled in the config file. This was ported over from my h264enc script
Old 21st August 2019, 15:38   #30  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.3.1
* Add audio sample rate to the audio metadata
Old 29th August 2019, 08:53   #31  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.3.2
* Use a comma instead of a dash for the audio sample rate metadata
Old 5th September 2019, 04:33   #32  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.3.3
* Code optimization in the audio sample rate metadata
Old 13th September 2019, 15:13   #33  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.3.4
* Add audio channel metadata when using audio copy
Old 18th September 2019, 09:01   #34  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.3.5
* Improvements to the audio copy metadata
Old 19th September 2019, 05:00   #35  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.3.6
* Support encoding to WMAv1 and WMAv2 audio
* Update high bit depth pixel formats options
* Add WMAv1 and WMAv2 audio detection metadata when doing audio copy
Old 21st September 2019, 06:33   #36  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.3.7
* Add side channel info to the audio metadata
Old 22nd September 2019, 05:54   #37  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.3.8
* For audio stream copy, in case ffprobe reports channels layout as unknown, try to guess the amount of channels based on channel detection and use that as metadata
* Set Mobisu transform as default for HDR to SDR
* Updated the man page
Old 25th September 2019, 07:26   #38  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.3.9
* Use the audindex[i] variable for audio metadata during audio copy
* Don't use audio metadata when using audio copy and running in batch mode
* Updated default audio bitrates for some codecs
Old 25th September 2019, 15:06   #39  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.4.0
* Revert using audindex[i] var for audio metadata during copy
Old 11th October 2019, 11:28   #40  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.4.1
* Support hardcoding external or embedded subtitles. Requires libass support in FFmpeg
* Fixed a typo in the subtitles code
