Old 8th October 2013, 08:24   #301  |  Link
Ruriko
thanks that new build fixes everything!
Ruriko is offline   Reply With Quote
Old 9th October 2013, 11:23   #302  |  Link
Ruriko
how do I make the subtitles hardsubbed/burn into video?
Old 9th October 2013, 14:54   #303  |  Link
ozok
TEncoder, TX264, TAC
ozok's Avatar
At the moment it is not possible. But I've found an up-to-date x264 build which can do that and I plan to use this build.
ozok is offline   Reply With Quote
Old 9th October 2013, 17:10   #304  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Really... That's a very clever implementation...
Old 25th October 2013, 09:49   #305  |  Link
Ruriko
any ETA on when you'll implement hard subs feature?
Old 25th October 2013, 20:41   #306  |  Link
ozok
ozok's Avatar
I'm afraid I cannot give any ETA at the moment.
Old 26th October 2013, 03:17   #307  |  Link
Ruriko
For some reason it won't encode the audio
[10/25/2013 5:09:57 PM] Started deleting temp files...
[10/25/2013 5:09:57 PM] Deleted 0 file(s).
[10/25/2013 5:09:57 PM] Finished deleting temp files.
[10/25/2013 5:10:03 PM] Started deleting temp files...
[10/25/2013 5:10:03 PM] Deleted 0 file(s).
[10/25/2013 5:10:03 PM] Finished deleting temp files.
[10/25/2013 5:10:03 PM] Starting encoding process
[10/25/2013 5:10:03 PM] Command lines:
 -y -i "C:\Users\Administrator\Downloads\Clan\Clan 01 [4A6B18D8].mkv" -vn  -f wav  "C:\Users\Administrator\AppData\Local\Temp\2\TX264\\Clan 01 [4A6B18D8].wav"
 -cbr 96000 -hev2 -if "C:\Users\Administrator\AppData\Local\Temp\2\TX264\\Clan 01 [4A6B18D8].wav" -of "C:\Users\Administrator\AppData\Local\Temp\2\TX264\\Clan 01 [4A6B18D8].aac"
 --crf 20 --profile high --level 4.1  --preset slow --tune animation --video-filter resize:width=1280,height=720,method=bicubic  --output "C:\Users\Administrator\AppData\Local\Temp\2\TX264\\Clan 01 [4A6B18D8].mkv" "C:\Users\Administrator\Downloads\Clan\Clan 01 [4A6B18D8].mkv"
 tracks "C:\Users\Administrator\Downloads\Clan\Clan 01 [4A6B18D8].mkv"  2:"C:\Users\Administrator\AppData\Local\Temp\2\TX264\\Clan 01 [4A6B18D8]1.ass"
 -o "C:\Users\Administrator\Downloads\TX264(0.9.7.3163)-2\TX264\\Clan 01 [4A6B18D8].mkv" "C:\Users\Administrator\AppData\Local\Temp\2\TX264\\Clan 01 [4A6B18D8].mkv" "C:\Users\Administrator\AppData\Local\Temp\2\TX264\\Clan 01 [4A6B18D8].aac"  "C:\Users\Administrator\AppData\Local\Temp\2\TX264\\Clan 01 [4A6B18D8]1.ass"  --default-language jpn
[10/25/2013 5:10:03 PM] Files to be deleted are as follows:
----Encoding Summary----
    +Video
        -CRF: 20.00
        -Preset: Slow
        -Profile: High
        -Tune: Animation
        -Level: 4.1
        -Force const FPS: False
        -Encoding depth: 8-Bit
        -Subtitles: True
        -Chapter: False
        -Container: MKV
    +Resize
        -Size: 1280x720
        -Method: Bicubic
    +Crop
        -Disabled
    +Aspect ratio
        -Disabled
    +Audio
        -Encoder: Nero AAC
        -CBR: 96 kbps
        -Profile: HE2
    +Effects
        -Disabled
    +Splitting
        -Disabled
    +Pause
        -Disabled
Output Folder: C:\Users\Administrator\Downloads\TX264(0.9.7.3163)-2\TX264\
Temp Folder: C:\Users\Administrator\AppData\Local\Temp\2\TX264\
[10/25/2013 5:10:42 PM] Done audio decoding
ffmpeg version N-49610-gc2dd5a1 Copyright (c) 2000-2013 the FFmpeg developers
  built on Feb  5 2013 13:20:59 with gcc 4.7.2 (GCC)
  configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
  libavutil      52. 17.101 / 52. 17.101
  libavcodec     54. 91.100 / 54. 91.100
  libavformat    54. 61.104 / 54. 61.104
  libavdevice    54.  3.103 / 54.  3.103
  libavfilter     3. 35.101 /  3. 35.101
  libswscale      2.  2.100 /  2.  2.100
  libswresample   0. 17.102 /  0. 17.102
  libpostproc    52.  2.100 / 52.  2.100
Input #0, matroska,webm, from 'C:\Users\Administrator\Downloads\Clan\Clan 01 [4A6B18D8].mkv':
  Metadata:
    title           : Clan 01.mkv
    creation_time   : 2011-09-26 09:52:12
  Duration: 00:24:11.66, start: 0.000000, bitrate: 6056 kb/s
    Chapter #0.0: start 0.000000, end 121.037000
    Metadata:
      title           : Prologue
    Chapter #0.1: start 121.037000, end 211.419000
    Metadata:
      title           : OP
    Chapter #0.2: start 211.419000, end 705.329000
    Metadata:
      title           : Part A
    Chapter #0.3: start 705.329000, end 1329.828000
    Metadata:
      title           : Part B
    Chapter #0.4: start 1329.828000, end 1419.835000
    Metadata:
      title           : ED
    Chapter #0.5: start 1419.835000, end 1451.660000
    Metadata:
      title           : Preview
    Stream #0:0(jpn): Video: h264 (High 10), yuv420p10le, 1920x1080, SAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
    Metadata:
      title           : Hi10P
    Stream #0:1(jpn): Audio: flac, 48000 Hz, 5.1(side), s16 (default)
    Metadata:
      title           : FLAC (5.1 Ch)
    Stream #0:2(eng): Subtitle: ssa (default)
    Metadata:
      title           : ASS
Codec 0x18000 is not in the full list.
    Stream #0:3: Attachment: unknown_codec
    Metadata:
      filename        : Alberta_Regular.ttf
      mimetype        : application/x-truetype-font
    Stream #0:4: Attachment: unknown_codec
    Metadata:
      filename        : AVGARDNEclipse.ttf
    Stream #0:5: Attachment: unknown_codec
    Metadata:
      filename        : BriemScriptStd-Medium.otf
    Stream #0:6: Attachment: unknown_codec
    Metadata:
      filename        : kaiu.ttf
    Stream #0:7: Attachment: unknown_codec
    Metadata:
      filename        : MTCORSVA.TTF
    Stream #0:8: Attachment: unknown_codec
    Metadata:
      filename        : segoepr.ttf
Output #0, wav, to 'C:\Users\Administrator\AppData\Local\Temp\2\TX264\\Clan 01 [4A6B18D8].wav':
  Metadata:
    INAM            : Clan 01.mkv
    ISFT            : Lavf54.61.104
    Metadata:
      title           : Prologue
    Metadata:
      title           : OP
    Metadata:
      title           : Part A
    Metadata:
      title           : Part B
    Metadata:
      title           : ED
    Metadata:
      title           : Preview
    Stream #0:0(jpn): Audio: pcm_s16le ([1][0][0][0] / 0x0001), 48000 Hz, 5.1(side), s16, 4608 kb/s (default)
    Metadata:
Stream mapping:
  Stream #0:1 -> #0:0 (flac -> pcm_s16le)
Press [q] to stop, [?] for help
size=  816559kB time=00:24:11.65 bitrate=4608.0kbits/s
video:0kB audio:816559kB subtitle:0 global headers:0kB muxing overhead 0.000019%
[10/25/2013 5:10:42 PM] Done audio encoding with neroaac
ERROR: Unsupported encoding configuration
*  Nero AAC Encoder                                         *
*  Copyright 2009 Nero AG                                   *
*  All Rights Reserved Worldwide                            *
*  Package build date: Feb 18 2010                          *
*  Package version:    1.5.4.0                              *
*  See -help for a complete list of available parameters.   *
[10/25/2013 6:20:51 PM] Done video encoding with x264
ffms [info]: 1920x1080p 1:1 @ 24000/1001 fps (vfr)
resize [warning]: converting from yuv420p10le to yuv420p16le
resize [info]: resizing to 1280x720
x264 [info]: using SAR=1/1
x264 [info]: using cpu capabilities: MMX2 SSE Cache64 BMI1
x264 [info]: profile High, level 4.1
x264 [info]: frame I:360   Avg QP:13.71  size:117177
x264 [info]: frame P:8667  Avg QP:17.97  size: 12286
x264 [info]: frame B:25778 Avg QP:22.58  size:  2032
x264 [info]: consecutive B-frames:  4.3%  5.4%  6.3% 28.6% 14.0% 41.5%
x264 [info]: mb I  I16..4: 17.4% 55.1% 27.4%
x264 [info]: mb P  I16..4:  4.2%  8.0%  2.1%  P16..4: 18.2%  5.6%  3.9%  0.0%  0.0%    skip:58.1%
x264 [info]: mb B  I16..4:  0.2%  0.6%  0.1%  B16..8:  8.7%  1.5%  0.5%  direct: 0.6%  skip:87.7%  L0:44.5% L1:51.2% BI: 4.2%
x264 [info]: 8x8 transform intra:56.6% inter:71.8%
x264 [info]: direct mvs  spatial:99.9% temporal:0.1%
x264 [info]: coded y,uvDC,uvAC intra: 53.5% 69.6% 34.2% inter: 4.4% 4.9% 0.5%
x264 [info]: i16 v,h,dc,p: 25% 23%  9% 43%
x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 14% 14% 18%  6% 11% 10% 11%  7%  9%
x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 22% 12% 15%  8% 11% 10%  8%  8%  7%
x264 [info]: i8c dc,h,v,p: 31% 35% 19% 14%
x264 [info]: Weighted P-Frames: Y:4.5% UV:3.6%
x264 [info]: ref P L0: 54.9%  6.8% 14.0%  7.5%  4.7%  4.1%  3.4%  2.1%  1.9%  0.5%  0.0%
x264 [info]: ref B L0: 76.7%  8.4%  5.6%  2.8%  2.1%  1.9%  1.5%  0.9%
x264 [info]: ref B L1: 96.0%  4.0%
x264 [info]: kb/s:1107.99
encoded 34805 frames, 8.31 fps, 1108.00 kb/s
[10/25/2013 6:21:09 PM] Done extracting subtitle from mkv
Extracting track 2 with the CodecID 'S_TEXT/ASS' to the file 'C:\Users\Administrator\AppData\Local\Temp\2\TX264\\Clan 01 [4A6B18D8]1.ass'. Container format: SSA/ASS text subtitles
Progress: 100%
[10/25/2013 6:21:10 PM] Done muxing to mkv
mkvmerge v6.3.0 ('You can't stop me!') built on Jun 28 2013 20:09:41
Error: The file 'C:\Users\Administrator\AppData\Local\Temp\2\TX264\\Clan 01 [4A6B18D8].aac' could not be opened for reading: open file error.
[10/25/2013 6:21:10 PM] Started deleting temp files...
[10/25/2013 6:21:10 PM] Deleted 3 file(s).
[10/25/2013 6:21:10 PM] Finished deleting temp files.
[10/25/2013 6:21:10 PM] Finished encoding in: 01:11:06
[10/25/2013 6:21:10 PM] Cannot find output file C:\Users\Administrator\Downloads\TX264(0.9.7.3163)-2\TX264\\Clan 01 [4A6B18D8].mkv
Old 26th October 2013, 03:20   #308  |  Link
ozok
ozok's Avatar
HEv2 only accepts stereo. Your source has 6 channels.
Old 26th October 2013, 05:31   #309  |  Link
Ruriko
So you can't make it convert from 6 channels to stereo?
Old 26th October 2013, 14:26   #310  |  Link
ozok
ozok's Avatar
You should mix it down to stereo. Audio Tab>Effects>Channels>Stereo
BTW 96kbps is a bit high for HEv2, LC or "Auto" might be better choice.
Old 3rd November 2013, 23:30   #311  |  Link
Ruriko
If the source has 2 audio tracks it only outputs 1 audio track. How can I get it to mux all audio tracks even if I already selected mkv as the container?
Old 3rd November 2013, 23:46   #312  |  Link
ozok
ozok's Avatar
That's not supported at the moment.
Old 4th November 2013, 07:52   #313  |  Link
Ruriko
Is it possible to select one of the two audios?
Old 4th November 2013, 16:13   #314  |  Link
ozok
ozok's Avatar
Yes. As default first one is selected. You can select the one you wanted from combobox. Selecting is enough, you don't have to do anything else.
Old 5th November 2013, 02:03   #315  |  Link
Ruriko
Is ja = Japanese?
Old 5th November 2013, 02:05   #316  |  Link
ozok
ozok's Avatar
AFAIK yes. I think there is a wikipedia page for language codes.
Old 5th November 2013, 13:03   #317  |  Link
Ruriko
I believe JP is the correct language code for Japanese and it's not in the list. I tried JA but it doesn't select the right audio
Old 5th November 2013, 15:42   #318  |  Link
ozok
ozok's Avatar
Are you selecting audio stream from this list right? http://i.imgur.com/cOJ91CB.png
That language list in the audio tab is for the output's language tag.
Old 6th November 2013, 01:18   #319  |  Link
Ruriko
oops i selected the wrong place
Old 6th November 2013, 05:08   #320  |  Link
nakTT
I'm planning to add support for lame and qaac.
I have a video divided into 2 parts in 2 CD that I need to encode and merge at the same time to make it into just one mkv file. Do this apps have the function for me to do it?
Thank you in advance.
nakTT is offline   Reply With Quote
faac, mkv, mp4, neroaacenc, x264
