Old 20th May 2019, 18:27   #481  |  Link
NikosD
New HW transcoders from rigaya: (to include in your next update)
NVEncC v4.39
QSVEncC v3.20
VCEEncC v4.02
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
NikosD is offline
Old 20th May 2019, 19:16   #482  |  Link
stax76
stax76's Avatar
@NikosD
I've created an issue on the tracker so it cannot be forgotten, thanks.
stax76 is offline
Old 20th May 2019, 21:46   #483  |  Link
RanmaCanada
@RanmaCanada
Which StaxRip version are you using?
Staxrip.2.0.0.0.x64
though I will use whatever version I have to.
RanmaCanada is offline
Old 20th May 2019, 22:09   #484  |  Link
stax76
stax76's Avatar
Originally Posted by RanmaCanada View Post
Staxrip.2.0.0.0.x64
There was a demuxing issue but it was after 2.0.0.0.
Since 2.0.0.0 there were a couple of improvements:
https://github.com/staxrip/staxrip/releases
By default it should demux all audio and subtitle tracks, does that work?
You can add two audio tracks in the main dialog and if you need more audio tracks you can add them in the container options.
stax76 is offline
Old 20th May 2019, 22:24   #485  |  Link
gonca
Can StaxRip encode 2 videos at the same time with multiple jobs in the queue
i.e.
queue is
video 1
video 2
video 3
etc
can StaxRip_1 encode video 1
StaxRip_2 encode video 2
then
StaxRip_1 encodes video 3
so on
gonca is offline
Old 20th May 2019, 22:29   #486  |  Link
stax76
stax76's Avatar
@gonca
Yes but only if you run multiple staxrip instances, the job list is shared amongst multiple instances.
stax76 is offline
Old 21st May 2019, 01:38   #487  |  Link
gonca
@gonca
Thank you for the answer
gonca is offline
Old 21st May 2019, 01:55   #488  |  Link
RanmaCanada
I will endeavor and see if I can figure it out
Thank you.
Old 21st May 2019, 08:20   #489  |  Link
stax76
stax76's Avatar
Which icon should be used?
stax76 is offline
Old 21st May 2019, 09:46   #490  |  Link
Forteen88
Herr
I think the black.ico is more like a traditional clapperboard, so it's most suiting I think.
https://en.wikipedia.org/wiki/Clapperboard
Forteen88 is offline
Old 21st May 2019, 09:59   #491  |  Link
Natty
Noob
Black.ico
Natty is offline
Old 21st May 2019, 11:53   #492  |  Link
Havokdan
Havokdan's Avatar
Good morning, I would like to know how I create a new video profile to encode in mpeg1 and / or 2, I'm trying, but I'm getting the program: D, does anyone help me?
Havokdan is offline
Old 21st May 2019, 15:11   #493  |  Link
imhh11
my vote goes for the Black.ico too.
imhh11 is offline
Old 21st May 2019, 18:24   #494  |  Link
SaboraPie
Black.ico, i think.
SaboraPie is offline
Old 21st May 2019, 19:13   #495  |  Link
mcjordan
Also Black. Like John Snow ;-)
mcjordan is offline
Old 21st May 2019, 23:18   #496  |  Link
Natty
Noob
I like that too, most likely x265 does that, otherwise it was implemented by Revan.
its not appearing like that anymore. no idea what happened.
also --stylish doesn't work
Natty is offline
Old 22nd May 2019, 00:41   #497  |  Link
Rafawell
Vote on Black.ico
Rafawell is offline
Old 22nd May 2019, 01:40   #498  |  Link
frenchfries
Black icon with grey substituted for the black colour?
That way it addresses any dark mode or black taskbar issues, where the icon basically disappears.
frenchfries is offline
Old 22nd May 2019, 09:50   #499  |  Link
Alexander
Black icon with gray color
Alexander is offline
Old 22nd May 2019, 15:59   #500  |  Link
stax76
stax76's Avatar
I've uploaded a built that allows to define an icon file under:
Tools > Settings > User Interface
This icon is used within staxrip. The icon of the executable is the black one like requested, this is fixed.
The windows start menu uses windows links and windows links allow you to use custom icons so it's possible to configure which icon is used in the start menu.
The icons are located next to StaxRip.exe under:
Apps\Icons
Included are: Black, Grey, Classic, RIP
Most icons come from:
https://www.flaticon.com/search/8?word=movie
nulledone did the white border around the black icon to support dark mode
https://github.com/staxrip/staxrip/issues/1
The idea for custom icons comes from MusicBee.
https://github.com/staxrip/staxrip/b...r/changelog.md
stax76 is offline
