22nd July 2016, 09:24 | #24521 | Link | |
The Revenant movie itself is 2:36 long and video size is 39.5 GB. Downconverting audio saves some space but it is not that significant. The audio is more of a personal taste, if you have a system that can play DTS-HD Master Audio you'd might wanna keep that. |
22nd July 2016, 13:40 | #24522 | Link |
Resize 1080 -> 720
Some series and/or movies have their menu broken when choosing the option Resize 1080 -> 720? I had this with Game of Thrones. When entering the home menu it didn't fit anymore. Also Me and Earl and the Dying girl had this. When watching the movie and then using scene select, the bottom of the preview window is missing. Is it possible to resize only the movie and/or extra and leave the menu unaltered. |
22nd July 2016, 15:16 | #24524 | Link | |
22nd July 2016, 15:21 | #24525 | Link | |
You'd be surprised how much space is used by audio -- LPCM tracks are sometimes several gigabytes. IMHO anything greater than AC3 @ 640Kbs is a waste of space unless you really, really need more than 5.1 channels. I know people argue about that all the time, and that's why BD-RB allows you to do it however you want. But I trust science, and the double-blind tests (conducted by Dolby) show that 640Kbs AC3 encoding is indistinguishable to the human ear from the original audio (this is where I invariably get all the subjective "Yeah, but I can hear it with my magic ears" comments). I personally believe "HD Audio" to be nothing more than snake oil, it's just snake oil that happens to be selling very well. On the other hand, opinions are like assholes. Everybody has one -- and nobody cares about anybody elses. Mine included. Last edited by jdobbs; 22nd July 2016 at 17:59. |
22nd July 2016, 16:10 | #24526 | Link | |
Thinking shit in gets shit out, so a good original encode would stand a better chance of a quality compression, but there will always be a limit on how hard you can compress the source, right? Regarding audio I've seen a lot of blindtest results over the years and I guess some people will always buy "a couple bottles of Dr. Good". regards |
22nd July 2016, 16:18 | #24527 | Link |
It's always better to keep an original if possible -- because there is loss with any encode. But if you are going to re-encode anyway, the automatic setting just tries to save you from wasting a lot of time on overkill. But, for those who really don't care about time -- you can always force the "High Quality" setting. In my experience, though, you won't be able to detect a difference. When BD-RB (in automatic mode) runs into a source that has a lot of content it boosts the settings as needed.
22nd July 2016, 16:37 | #24528 | Link |
Well the 6700k has 4 cores and 8 logical processors, still only loads 1 x264 instance. Would it be possible (if this cpu processor amount is to "blame") that it forces the maximum recommended on it's own, without having to manually set multi to 4?
22nd July 2016, 17:59 | #24530 | Link |
Just as a note for reference, I ran "The Revenant" with a CRF of 18. The total video size was 8.5GB. So it doesn't take a lot of bells-and-whistles during the encode to get high-quality into a 25GB target.
22nd July 2016, 18:50 | #24533 | Link |
Open up a DOS window and type SET and enter. It will list all the environment variables.
Or, if you prefer, you can go to Control Panel>System and Security>System>Advanced System Settings and click on "Environment Variables" I just ran a test of "Revenant" using your settings and am getting 4 instances of X264. The one thing I had to change, though, was from DGDecNV to Directshow. I upgraded my video machine to Windows 10, and my Nvidia GT520 video card is one of the ones that isn't supported yet (by DGDecNV) on Win10, so I can't use DGDecNV anymore. Last edited by jdobbs; 22nd July 2016 at 19:06. |
22nd July 2016, 18:55 | #24534 | Link |
Just checked NUMBER_OF_PROCESSORS is listed as 8. However just to be on the safe side for you i've run the DOS command too and pasted the entire set of variables into a txt file for you. If there's anything else you need hardware info wise or other just let me know. i don't have my GTX 1080 yet, so im using the built-in video of the cpu. I can't use dgdecNV yet, and i don't want to "pollute" this new rig with my old 680 (drivers arent getting optimised for it anymore anyway) and risk potential driver issues when it arrives. So i'm using avysinth + only LAV filters. Perhaps that has some impact. FFDshow atm isn't installed (per instructions, it's optional)
22nd July 2016, 19:17 | #24536 | Link | |
@Ch2vr0n
22nd July 2016, 19:20 | #24537 | Link |
not according to the setup, unless that damn windows 10 virtualisation is kicking in despite disabled UAC. Any other locations bd-rebuilder.ini might be saved? The one in bdrb's program files folder does show dgdec as 1, but not in setup. For the record: C:\Users\<snip>\AppData\Roaming\BDREBUILDER is EMPTY. There has to be another location because the source & working path in the program files ini file don't match if i edit through bdrb itself.
