Old 10th March 2010, 23:04   #7241  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
That error is coming back from TSMUXER when it attempts to multiplex. For some reason that app doesn't appear to have access to that folder -- or at least is getting an error when trying to create it.
That's really odd... maybe an access rights issue?
It is good to add some kind of NTFS/FAT32 check for the destination folder.
You know that most users/admins(?!) chose FAT32 for system drive and that would cause such issues with backups.
Dean
Old 10th March 2010, 23:11   #7242  |  Link
laserfan
Aging Video Hobbyist
It is good to add some kind of NTFS/FAT32 check for the destination folder. You know that most users/admins(?!) chose FAT32 for system drive and that would cause such issues with backups.
But how might a FAT32 partition solve the riddle of: works for "movie only" but not "full backup"? Are filename restrictions different maybe?
Old 11th March 2010, 02:42   #7243  |  Link
audit13
I searched but couldn't find an answer. I'm using 32.08 and movie-only to dvd-9. When I drop the index.bdmv into avchd patcher 1.06 with indx version 0100, I get an error message that says the file was patched and doesn't change the indx.bdmv but it changes the movieobject.bdmv file. Am I doing something wrong? When I burn the movie to a dvd-9, it plays in my Samsung standalone but not in my friend's Samsung soundbar BD player.
Does 32.08 automatically patch the indx and movieobject files when I select movei-only to dvd-9? Any info would be appreciated. Thanks.
audit13 is offline   Reply With Quote
Old 11th March 2010, 03:32   #7244  |  Link
DK
DK's Avatar
concerning playback on a samsung:
- did you use "strict avchd mode"? if not, give it a go.
- did you make sure to omit auxdata folder? samsung player dont like it.
- my samsung (1600) does not accept -ROM as booktype; any chance you use -rom instead of +r or -r?
Old 11th March 2010, 09:39   #7245  |  Link
tonimacarronis
I´ve format the pc and only install ffdshow, haali and avisynth (all versions recommended). I made the same work then ever and at the end the same results in ps3= not good. Only codified works in pc.
tonimacarronis is offline   Reply With Quote
Old 11th March 2010, 11:31   #7246  |  Link
TheSly
jdobbs, firstly awesome program, and your dedication to this thread is impressive. Was looking back cause I'm sure I saw you comment that allowing the full HD audio sound for a DVD9 wasn't feasible as the movie would be shrunk too much. I just converted Kung Fu Panda to BD25 with HD Audio and the main movie ended up at 8.3Gb, which would be perfect as a movie only DVD9. Would it be possible to have the feature for full HD Audio and movie only enabled for DVD9? In some situations it might suit people. I know if I could get a 6000kbps rip and HD Audio I would be very happy.
Thanks,
TheSly is offline   Reply With Quote
Old 11th March 2010, 13:53   #7247  |  Link
Thanks,
Sorry but it's just not feasible. I'd be spending most of my time responding to posts/e-mails about how X264 and BD Rebuilder both suck because the output is so blocky. Most people who use the software don't even know what a "bitrate" is... There might be an exception every now and then -- but for the most part you just have to resign yourself to the fact that you can't put 10 pounds of crap in a 5 pound bag.
Go back through this thread and count the number of times someone had to be instructed to install the software from the first post and you'll understand...
Old 11th March 2010, 18:49   #7248  |  Link
DVDIT
Originally Posted by DVDIT View Post
I did two backups since updating to V32.05 and I am having issues with both backups, one full movie on BD-25 and the other movie only on BD-9. Whenever I press FF or REW keys, the picture freezes and the only way to unfreeze it (resume playback ) is by powering down the player. I am only having issues with Pioneer BDP-51-FD. I don't have a problem with the PS3.
I have done many backups with 31.05 and 31.06 and in all my of my backups the FF and REW function work fine with all my players. What could be causing this issue ?
BTW, I didn't want to upgrade from 31.06 because I never had any issues at all but when I launch BR-RB the program doesn't launch but keep saying to upgrade to the latest beta version. Since my primary player is the Pioneer 51FD, this is a major bug for me. Is there anyway I could keep using the 31.06 without the need to upgrade to the latest version ?
I did two backups with V32.07 and the FF and REW issues I had with Pio FD51 is gone.
DVDIT is offline   Reply With Quote
Old 11th March 2010, 18:50   #7249  |  Link
dvdmansion
Can someone please explain to me why this is happening? I'm trying to do it to a 25GB but fails to encode, tried 3 different computers same thing :-(
Any help is much appreciated. Great software btw have used it for quite a few movies just having an issue with this one that's all..and please keep up the great work.
[12:09:27] BD Rebuilder v0.32.05 (beta)
- Source: 24336595_THE_DEPARTED
- Input BD size: 26.64 GB
- Approximate total content: [03:35:55.200]
- Target BD size: 22.66 GB
- Windows Version: 6.1 [7600]
[12:09:27] PHASE ONE, Encoding
- [12:09:27] Extracting A/V streams [VID_00006]
- [12:09:49] Reencoding: VID_00006 (1 of 4)
- [12:09:49] Collecting video information
- Source Video: MPEG-2, 720x480
- Rate/Length: 29.970fps, 34,909 frames
- [12:09:49] Reencoding: VID_00006, Pass 1 of 1
- [12:10:56] Video Encode complete
- [12:10:56] Reencoding audio tracks (if req'd)
- [12:10:56] Multiplexing M2TS
- [12:10:59] Extracting A/V streams [VID_00004]
- [12:11:22] Reencoding: VID_00004 (2 of 4)
- [12:11:22] Collecting video information
- Rate/Length: 29.970fps, 37,997 frames
- [12:11:22] Reencoding: VID_00004, Pass 1 of 1
- [12:12:47] Video Encode complete
- [12:12:47] Reencoding audio tracks (if req'd)
- [12:12:47] Multiplexing M2TS
- [12:12:53] Extracting A/V streams [VID_00005]
- [12:13:20] Reencoding: VID_00005 (3 of 4)
- [12:13:20] Collecting video information
- Rate/Length: 29.970fps, 43,263 frames
- [12:13:20] Reencoding: VID_00005, Pass 1 of 1
- [12:14:53] Video Encode complete
- [12:14:53] Reencoding audio tracks (if req'd)
- [12:14:53] Multiplexing M2TS
- [12:14:59] Extracting A/V streams [VID_00000]
- [12:27:44] Reencoding: VID_00000 (4 of 4)
- [12:27:44] Collecting video information
- Rate/Length: 23.976fps, 217,679 frames
- Bitrate: 12,911 Kbs
- [12:27:44] Reencoding: VID_00000, Pass 1 of 2
- Encode failed. Retrying.
- Reached retry limit. Aborting.
- FFDSHOW Revision: (3154)
- FFDSHOW: VC-1 not set to wmv9
[12:30:53] - Failed video encode, aborted
dvdmansion is offline   Reply With Quote
Old 11th March 2010, 19:12   #7250  |  Link
laserfan
Do you perhaps need to set VC-1 decoding in ffdshow to WMV9?
Old 11th March 2010, 19:23   #7251  |  Link
dvdmansion
I'm trying that now, ty.
Old 11th March 2010, 20:50   #7252  |  Link
Take a couple of minutes to go to the first post of this thread and read/download those versions of the supporting software. Also -- upgrade to the newest version. It doesn't do any good to post bug reports on software that's three versions out of date. I wouldn't be posting updates if there wasn't something that needed to be fixed.
Old 11th March 2010, 21:26   #7253  |  Link
stage_man
Can you post the meta file? I've seen that error before for DTS Express streams, but BD-RB shouldn't be attempting to extract those...
Put the file on a hosting site instead. Any help is appreciated.
http://rapidshare.com/files/36208540...0269.meta.html
stage_man is offline   Reply With Quote
Old 11th March 2010, 21:39   #7254  |  Link
TheSly
I understand that you've tested it and know why it won't work, but I was perplexed why the full BD rip including menus, etc for KFP ended up with an 8.3Gb main M2TS inc the HD Audio. Quality of it was perfect.
How about a switch to enable it for Pro users? haha
Old 11th March 2010, 21:39   #7255  |  Link
Race Guy
Thanks,
What I've done a couple of times is "combo up" 2 or more flix, with HD audio, onto one BD-25.
You take Dean's multiAVCHD & select the playlists for the main titles. Dump all your unneeded sound & subs, do a "top menu" (personally I like carousel), then output it "full size" (meaning you don't do any recoding) as a BluRay.
Now, you open that output with BD-RB & do a full backup (I like ABR HQ) to BD-25. You end up with the HD audio PLUS probably a higher vid bitrate than you'd get going to 9. You could prolly do the recode with multi, but I like BD-RB 'cause it ALWAYS hits the size "target". I've had multi overshoot on me a few times.
I'd guess that with those animation flix you mentioned, you could EASILY get three on a BD-25 with hi-rez sound & maybe four or five if you went SD audio!
WHATEVER you do, if you can't get this "method" to work for you, DON'T post a report here & call it a BD-RB "BUG"!!!
Race Guy is offline   Reply With Quote
Old 11th March 2010, 21:42   #7256  |  Link
TheSly
You're right. It's not a bug, I'm in the wrong thread. Sorry, and thanks for the method you've mentioned.
Old 11th March 2010, 23:13   #7257  |  Link
ftb32
Hello I have not had problems with encoding but playback on PS3 when I do full backup, I'm using the latest beta with parameter "B_PYRAMID = 1" and can not play. Thanks for your help.
This is the .ini:
[Options]
MODE=1
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
SD_CONVERT=0
COLOR_BOOST=0
RESIZE_1080=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
KEEP_HD_AUDIO=1
AVCHD=0
REMOVE_WORKFILES=0
FULL_AVCHD=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=1
CUSTOM_TARGET_SIZE=23450
TARGET_SIZE=23200
ENCODE_QUALITY=5
ONEPASS_ENCODING=1
AUTO_BURN=2
B_PYRAMID=1
[Paths]
SOURCE_PATH=E:\RIP_BDW\TERMINATOR SALVATION DC\
WORKING_PATH=S:\WORKING\
ftb32 is offline   Reply With Quote
Old 11th March 2010, 23:21   #7258  |  Link
ftb32
This is the .ini:
[Options]
MODE=1
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
SD_CONVERT=0
COLOR_BOOST=0
RESIZE_1080=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
KEEP_HD_AUDIO=1
AVCHD=0
REMOVE_WORKFILES=0
FULL_AVCHD=0
AUDIO_TRACK_LIMIT=1
TARGET_SIZE=23200
ENCODE_QUALITY=5
ONEPASS_ENCODING=1
AUTO_BURN=2
B_PYRAMID=1
[Paths]
Fast and Furius no sound and no video on the menu but if the buttons on a sony bx2
Old 11th March 2010, 23:49   #7259  |  Link
MikeyBK
MikeyBK's Avatar
Hey has anyone else been experiencing random and occasional pixelations in BDs encoded with BDRebuilder ever since version 32.05?
Up until that version all of my movie only BD-9s have encoded perfectly. But every BD-9 from that version on is ending up with random, occasional pixelations of differing length and severity.
I'm just trying to see if it's related to my PC alone of an others are experiencing similar things. My system is running Win7 64 bit
MBK
MikeyBK is offline   Reply With Quote
Old 12th March 2010, 00:11   #7260  |  Link
Capsbackup
No problems like that for me!
