26th April 2010, 22:18 | #7962 | Link | |
Just to be clear, don't throw out your existing copies. Copy the rips back to your harddrive, use the PS3BDFix program and then burn back to a new disk. This worked for me! Let me know how it works. Moviewatcher666 |
26th April 2010, 22:59 | #7963 | Link |
jdobbs is there any way to convert dts hd to ac3? cause when bdrebuilder convert dts hd to regular dts, its still to big for dvd5/dvd9...
i saw the problem...: [17:09:49] PHASE ONE, Encoding - [17:09:49] Reencoding audio tracks (if req'd) - ERROR in attempt to reencode audio (AFTEN) [AUD_00001__4352.AVS] |
27th April 2010, 00:20 | #7964 | Link | |
27th April 2010, 00:49 | #7965 | Link | |
Hey,
I bought The Hurt Locker on blu-ray, and tried to back it up to a DVD-5 using BDRebuilder. I get through the encoding phase no problem, but when I get to the reencoding phase, i get an error "X264.exe has stopped working" and the shrinking process is aborted. Quote:
27th April 2010, 01:39 | #7966 | Link | |
For info to jdobbs, in fact AC3 encoding that is an acoustic compression algorithm is especially normalized to a -6db level. This normality sound level is due to the decode=>compress/expand sound signal that characterize this kind of format. It's an audio level normality defined by Dolby that all receivers recognize and use to process the signal. It is used for example in the LFE or CENTER compression processed independently of the other channels. In amplifying the AC3 signal by 1.2, you would prevent some audio receivers to manage the sound compression efficiently in reducing the margin of action and even some time causing overdrives and distortions. So yes the sound is higher and nearer to 0db, but despite the specific AC3 acoustic compression management. Last edited by SoniG; 27th April 2010 at 02:16. |
27th April 2010, 02:18 | #7967 | Link | |
Also -- use the newest version. |
27th April 2010, 02:25 | #7968 | Link | |
MHO: They just set the volume too low to impress their friends with their "greater dynamic range". But, anyone who doesn't want to amplify can very easily change it to no amplification with the hidden command AUDIO_AMPLIFY=1. Last edited by jdobbs; 27th April 2010 at 02:32. |
27th April 2010, 02:26 | #7969 | Link |
There are a lot of posts here. I've read through a bunch of them but there is no way for me to get through them all. So if someone would please indulge me.
I am trying to make a full backup, not movie only, of a Blu-ray onto a standard DVD (DVD-9 or DVD-5) to play on my PS3 which has firmware 3.30 on it. I am using BD Rebuilder 0.33.06 beta. Right now everything I have tried keeps resulting in my PS3 seeing my DVD as a data disc. Even if I use AVCHD Patcher 1.06. From reading these forums my key problem seems to be my desire for a full backup with menu's, special features and everything else burned onto a standard DVD. So right now it is not possible to do this in a way which is PS3 compatible. Is that correct? |
27th April 2010, 02:37 | #7970 | Link |
I'm not sure what has changed, but lately almost all my 2 pass attempts fail when starting the second pass. X264 cannot seem to load the stats file created from the first pass.
I think something changed in anydvd to cause this. Even dvdfab cannot re-ecode the video. I can do a 1 pass CBR with bdrebuilder that is successful though. I'm running a fresh xp image in virtualbox with 2 processors and 512MB memory assigned to it. Rob |
27th April 2010, 02:52 | #7971 | Link | ||
still get the x264.exe error in the newest version. any ideas? thanks |
27th April 2010, 03:14 | #7972 | Link | |
I just looked at the code -- and it can't output a log with a video encode error without those things... Last edited by jdobbs; 27th April 2010 at 03:51. |
27th April 2010, 03:31 | #7973 | Link |
jdobbs : Yeah that's what I was trying to explain. Anyway, when we set AUDIO_AMPLIFY=1, it should be well to remove the command line from AVS files instead of process it as 1. And I don't understand ConvertAudioTo16bit(ResampleAudio(audio, 48000)), is it not already the specs of the original AC3 tracks?
27th April 2010, 03:48 | #7974 | Link | |
27th April 2010, 05:03 | #7975 | Link | |
I just would like to know if someone else here has tester full backup with bd rebuilder in BD-R 25GB and movies played fine because i was planning to purchass an Ps3. Any feedback is appreciated.
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. |
27th April 2010, 05:41 | #7976 | Link |
Question:
When resuming an project; did the video encoded when it has beem resumed can be corrupt? Did we have an option to restart from the begining the encoding the current batch filename? I have resumed an project and i would like to must be sure that the resumed file (main movie) will be good.
27th April 2010, 06:03 | #7977 | Link |
8ternity : No worry, backup is always resumed in restarting the last pass/track process. No corrupt possible. Even if you modify an important thing in the setup, then the present backup is cancelled and restarted from the beginning. However in pure batch layout, I didn't test it yet but you can watch what it's done in the log tab.
jdobbs : Mmh I understand, I suspected it was again for a compliancy purpose. I don't know if amplify or changing a sample rate with the same value degrade in some way the original track, even a bit, but eventually, one day, it would be nice for standard AC3/DTS tracks to just be demuxed/remuxed without any process, but I'm sure you already thought about it. Last edited by SoniG; 27th April 2010 at 06:21. |
27th April 2010, 06:09 | #7978 | Link | |
27th April 2010, 06:10 | #7979 | Link | |
BD-RB will create the AVS file either way (in case someone changes the option and the "resumes") -- but it doesn't necessarily use it. It's the same with encoding. It is possible that the AC3 encoding is done, but the original (core) is multiplexed. But, as I said, I'll go back and look. Also, if it is movie-only and is going to BD-5/9, you're not supposed to keep DTS because DTS is not supported by AVCHD. I have a hidden option, though, that will allow you to override that -- but I wouldn't recommend it. Last edited by jdobbs; 27th April 2010 at 06:23. |
27th April 2010, 07:24 | #7980 | Link |
jdobbs : I never use any BD9/AVCHD settings, I just try to reduce original BD size in using the best quality possible to archive and play from a server. And just for this, I'm really grateful your software exists, and I think it is the most advanced. I always try to have a 10-12000 Kbps bitrate for the main movie video track and just remove the HD audio in keeping core or original AC3/DTS tracks. However I noticed these commands on the AVS in normally standard AC3 files. But I hear you about the fact you don't always use them. Pity... bad for me! By the way, did you have a look at my Batman Returns bonus sample?
