Old 4th December 2012, 20:53   #20461  |  Link
sneaker_ger
Great, seems to have fixed a madVR DXVA2 decoding seeking issue I was having with the older betas.
/edit:
May be the cause of other problems. Be careful with the 12.11 betas.
sneaker_ger is offline
Old 5th December 2012, 07:17   #20462  |  Link
jmac698
Is there a guide to using mpc? When I play a dvd it's running at like 8fps. I don't know what's wrong! Even the first time I ran it, it wasn't working well, the motion was bad, and there was ghosting. It's a film dvd, win7, current build.
jmac698 is offline
Old 5th December 2012, 12:49   #20463  |  Link
Right-click into the running video, look in the "Filters" submenu, check which filters (splitter, decoder, renderer) are used. Tell us about your video related hardware (e.g. graphic card chipset).
LigH is offline
Old 6th December 2012, 05:01   #20464  |  Link
jmac698
MPC-HC Tests
Version:
1.6.5.6293 (e624b79)
Specs:
Intel G45 video
Settings 1:
filters:
-splitter MPC MPEG Source
-decoder MPC Video Decoder
-renderer MadVR
Result:
23.95fps, choppy, no dropped frames. video pauses twice a second. Is there any log to show this?
output:
direct3d no video at all
jmac698 is offline
Old 6th December 2012, 05:16   #20465  |  Link
jmac698
I tried every combination on VLC it worked fine, but I keep hearing mpc-hc and madvr is the best so I wanna try it.
jmac698 is offline
Old 6th December 2012, 09:43   #20466  |  Link
madshi
@jmac698, the madVR debug OSD (Ctrl+J) does not report any dropped frames? Try activating "overlay" in the madVR settings. That could help getting a smoother result with your Intel GPU. Does the choppy playback occur with all 23.976p movies? Or just with the one you've been testing with? I'd suggest to test with a Blu-Ray movie, just to be sure that the source is really 23.976p. Also I'd suggest installing LAV Filters because frankly, the built in MPC-HC splitters and decoders aren't all that good (IMHO). I usually recommend to disable them all. Or you can download MPC-HC "lite" (which already has all internal filters removed) from here:
http://xhmikosr.1f0.de/mpc-hc/lite/
madshi is offline
Old 6th December 2012, 10:21   #20467  |  Link
FarQueue
Is it possible to disable chapter markers?
FarQueue is offline
Old 6th December 2012, 10:23   #20468  |  Link
THX-UltraII
Maybe this question has been asked a few times before but I cannot find it with the search function:
Does MPC-HC support 3D yet and if not, is someone working on 3D for MPC-HC?
THX-UltraII is offline
Old 6th December 2012, 10:52   #20469  |  Link
jmac698
ok, I used ctrl-j, it doesn't show dropped frames but present max 5s sometimes says 48ms which could be bad. I'll try lavf
jmac698 is offline
Old 6th December 2012, 14:58   #20470  |  Link
vBm
MPC-HC Helper xD
vBm's Avatar
Yes it is, if you're using nightly (being that stable hasn't been released yet).
Go to Options -> Tweaks -> "Show chapter marks in seek bar" and untick it.
No, at the moment there's no 3D support as far as i know, and no one is working on it.
MPC-HC Links: official nightlies | Trac | GitHub | git log | IRC | Twitter | Facebook
vBm is offline
Old 6th December 2012, 17:26   #20471  |  Link
dukestravels07
Does anyone have a recent tutorial for getting dxva working with an older dxva card?
dukestravels07 is offline
Old 6th December 2012, 17:45   #20472  |  Link
wanezhiling
What's your old video card? and OS?
MPC-HC's default setting is using DXVA, but its DXVA decoders only support bitstream mode (full acceleration), which means your card must support ModeH264(MPEG2/VC1)_VLD.
Post your DXVA Checker info.
wanezhiling is offline
Old 10th December 2012, 07:32   #20473  |  Link
betaking
Fantasy Codecs writer
betaking's Avatar
S.Chinese update
http://www.mediafire.com/?5zu9tcj6kyy2l13
betaking is offline
Old 11th December 2012, 00:22   #20474  |  Link
vBm
MPC-HC Helper xD
vBm's Avatar
Originally Posted by betaking View Post
Thanks, pushed as 330defbd
vBm is offline
Old 11th December 2012, 22:05   #20475  |  Link
Amour
Amour's Avatar
enhancement request:
could you make all windows stretchable in MPC-HC, especially the Options and Properties ones?
thank you
Mystérieuse Amour
Amour is offline
Old 12th December 2012, 08:34   #20476  |  Link
wozio
Does internal MPC MPEG splitter support push filters? I've made some filter basing on UDP source which is pull filter but I have problems with it since splitters doesn't work good with source filters where there is no real known length of the media file.
Any clues how to build graph with such a filter? Just putting it into graph manually or by known protocol extension is enough? How splitter will know what streams to demux and use? From stream? Any way to hint it to not waste time since I know from the server which streams shall I use from stream?
Regards
Piotr
wozio is offline
Old 12th December 2012, 20:53   #20477  |  Link
vBm
MPC-HC Helper xD
vBm's Avatar
This thread will be closed in favor of NEW ONE of which we're in control. (we can edit first post to add valuable info.)
Swede approved this. Thanks again.
vBm is offline
dxva, h264, home cinema, media player classic, mpc-hc
