18th June 2020, 22:33 | #7481 | Link | |
If you maybe have interest to improve staxrip integration, there are about five mpv CLI options it uses, for instance: --aid (or alias --audio) It selects an audio track via index. https://mpv.io/manual/master/#options-aid
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 18th June 2020 at 22:37. |
19th June 2020, 12:52 | #7482 | Link | |
20th June 2020, 11:19 | #7485 | Link |
I could not notice the problem.
Need to watch a video from start to finish? Is the problem observed when using the EVR-CP?
21st June 2020, 06:38 | #7487 | Link |
MPC Video Renderer 0.4.7.1356
Description Changes: Added Sync Offset graph in statistics. Fixed getting the current image using IBasicVideo::GetCurrentImage. Improved playback support for some protected DVD-Video. Added support for mirroring ("flip"). Added ability to change Swap effect during playback. Added support for exclusive full screen in DX9 mode. Fixed subtitles flickering after rewind. Recommended version of MPC-BE 1.5.5.5342 or later. |
21st June 2020, 08:39 | #7488 | Link |
21st June 2020, 09:39 | #7489 | Link |
I also can't reproduce it anymore. Sorry for false report.
Anyway, I really appreciate your work on all Projects: MPC-BE, MPC Video Renderer, Image Source Filter and Script Source Filter from a long time user and little contributor |
22nd June 2020, 11:21 | #7490 | Link |
Active pixel shader not applied in Screenshot ?
Issue: Active pixel shader (ex: Invert.hlsl) isn't applied when saving a Screenshot. I'm using EVR-CP on Mpc-Be v1.5.4 x64.
from the changelog: Correction shaders are also used when creating screenshots and thumbnails. |
22nd June 2020, 12:05 | #7491 | Link |
Save screenshot - not using any external shaders, it's say about internal.
22nd June 2020, 12:26 | #7492 | Link |
To get the image displayed, use Shift+F5 (the image will be saved in the same place where the save is done through the menu).
22nd June 2020, 17:20 | #7494 | Link |
The sync issue is back for me when using MPC Audio Renderer.
This video is better to watch it happen: https://www.youtube.com/watch?v=I_2D8Eo15wE I also downloaded it, here is a muxed mkv: https://drive.google.com/file/d/1q2y...ew?usp=sharing Again, if I apply a -120 ms (negative offset) on MPC Audio Renderer it is in sync for me, just like if it is played back in Directsound in MPC-BE and also in Firefox. Best if to watch this left guy clapping. He claps exactly with the beat -> perfect sync I made a screenshot and marked the guy, so no misunderstandings can occur: https://drive.google.com/file/d/1CaU...ew?usp=sharing Please ignore the woman on the motorcycle on the left, she claps wrong, but excatly wrong I think I wasn't able to reproduce, because the video wasn't the best to really watch/hear it happen. Last edited by Klaus1189; 22nd June 2020 at 20:14. |
22nd June 2020, 18:26 | #7495 | Link |
I did some more tests in the last hour and I think its an AMD driver issue, just restarted the pc and the issue is gone. The pc was running overnight, probably an issue which happens after extended period of time, I don't know.
I started some games and MSI Afterburner reported both static 100% GPU usage and 65535 rpm fan speed, which is the last value of 16 bit resolution. And again sorry for the false report, you guys are the best, there is nobody who comes close |
22nd June 2020, 18:57 | #7496 | Link |
Disable fast startup in Windows 10:
Windows Control Panel > Power Options > "Choose what the power buttons do" > uncheck "Turn on fast startup" Otherwise Windows will not do a proper clean restart. This fixes a variety of driver stability issues, including weird audio sync issues. |
22nd June 2020, 19:09 | #7497 | Link |
@Klaus1189
The link to mixed mkv is wrong. PS: I found the video "Photoshop_Tutorial_Rap.mp4" (which is a lot of words), chose DirectSound and set the delay to +150 ms. But I can hardly feel this delay. Maybe I've watched a lot of dubbing movies or because it's evening and I'm tired.
22nd June 2020, 20:23 | #7498 | Link |
Oops, sorry. I edited the post. I am sensitive to sync issues. If you play the video and create a delay of 150ms the beat is audible when the mentioned guy has his hands in widest position. Can not describe it better now, hope you understand what I try to say.
Yes, it is very different to watch movies with original language, the sound fits perfectly to the movements of the mouths of the people and other stuff. |
22nd June 2020, 22:14 | #7499 | Link |
Hungarian translation updated. "Do not reset speed for session" text.
https://www50.zippyshare.com/v/PFKDsasb/file.html |
23rd June 2020, 03:06 | #7500 | Link | |
After seeking also A/V desync ? P.S. Show filters list. Show MPC Audio Renderer settings.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 Last edited by Aleksoid1978; 23rd June 2020 at 04:07. |
