Old 6th October 2021, 15:09   #30921  |  Link
Originally Posted by gamete View Post
I can buy this pc in forum
No scam
But i ask to you if this pc can be good for male backup 4k in bd25
Honestly, if you are planning to do 4K backups, you'd probably be better off investing in an NVIDIA video card that does encoding (mine is a GTX-1660). The prices have gone up recently (I'm guessing it's the global chip shortage -- but don't know). But, if you look around you can find them cheap enough. Encoding with the GPU is several times faster than CPU -- and 4K encoding can really bog down a CPU.
But, as always, that's just an opinion. Yours matters more.
Old 8th October 2021, 21:21   #30922  |  Link
jetli
version 61.22, movie only mode
movie ends instead of repeats and restarts at beginning.
what is causing this.
can i fix it back to restart movie at beginning after the end?
thanks tony
jetli is offline   Reply With Quote
Old 8th October 2021, 23:59   #30923  |  Link
thanks tony
Nothing has changed related to that in this version. But there is a hidden option to enable that behavior. See HIDDENOPTS.TXT.
You can add:
MOVIE_ONLY_LOOP=1
to rebuilder.ini.
Old 12th October 2021, 15:59   #30924  |  Link
@Timmy256
Please review rules 7 and 8. Repeating a post (I've removed the repeat), especially one as large as yours, isn't appropriate. If you do it again I'll be forced to issue a strike. It's good that you provide detail, but I'd suggest you make the images smaller -- when a post is as large as yours and has giant images dominating the view, people tend to just skip over it.
Old 17th October 2021, 01:00   #30925  |  Link
Timmy256
Thanks @jdobbs!
Sorry for the repost. I though that my post wasn’t working, after waiting for a week to register and post; hence why I reposted. I didn’t see it here, neither did I get any notification saying that it wasn’t approved for some reason.
I’ll try to re-adapt it to fit the rules you mentioned. I’ve tried to include as much detail as possible, as the support posts I’ve read, pretty much always miss a lot of detail on the issue; that’s why I went overboard.
Would it be OK to try posting after I readapt it to the rules or is there any way to pre-check with you if it’s OK by then?
Thanks again!
Timmy256 is offline   Reply With Quote
Old 17th October 2021, 01:57   #30926  |  Link
videoh
Useful n00b
Welcome to the forum Timmy! Sending you a friend request.
Old 20th October 2021, 01:38   #30927  |  Link
Timmy256
Thanks videoh! I just accepted it.
Old 20th October 2021, 03:36   #30928  |  Link
videoh
Useful n00b
Thank you. Onward and upward, Timmy.
Old 13th November 2021, 17:53   #30929  |  Link
LowDead
Elit Amans
A couple of interesting updates/fixes from NVEncC 5.35, if you want to add it to the next BDRB release jdobbs.
Latest NVEenC
Windows 10 Pro 64-bit, Intel i7-8700K@3.70GHz, 32GB, Intel UHD Graphics 630 128MB, NVIDIA RTX 2070 8GB, PIONEER BDR-S09XLT, ASUS BW-16D1HT, LG CX 65", Samsung UBD-K8500, Sony PS3
Old 15th November 2021, 14:25   #30930  |  Link
Latest NVEenC
I'll do some testing an add it to the next release.
Old 16th November 2021, 09:31   #30931  |  Link
RetsimLegin
Originally Posted by jdobbs
Modified the method for reencoding E-AC3 files that are imported. Some systems and sources had randomly experienced channel count discrepancies in the old method.
Just confirming - I have recently worked a few E-AC3 titles and have not seen the previous miscalculation of channel numbers recur. Thanks.
RetsimLegin is offline   Reply With Quote
Old 16th November 2021, 17:18   #30932  |  Link
SquallMX
Special SeeD
I'm getting desync subtitles on v0.61.25 even when using "No Reencode":
[11/16/21] BD Rebuilder v0.61.25
[09:44:30] Source:  MAD_MAX_3_BEYOND_THUNDERDOME
  - Input BD size: 28.25 GB
  - Approximate total content: [02:01:48.667]
  - Target BD size: 28.32 GB
  - Windows Version: 6.2 [9200]
  - MOVIE and MENUS mode enabled
  - Quality: High Quality (Default), Two Pass
  - X264 Tweak(s) enabled
  - Decoding/Frame serving: DGDecNV
[09:44:34] PHASE ONE, Encoding
 - [09:44:34] Blanking: VID_00007 (1 of 38)
 - [09:44:34] Blanking: VID_00016 (2 of 38)
 - [09:44:34] Blanking: VID_00035 (3 of 38)
 - [09:44:34] Blanking: VID_00042 (4 of 38)
 - [09:44:34] Blanking: VID_00043 (5 of 38)
 - [09:44:34] Blanking: VID_00046 (6 of 38)
 - [09:44:34] Blanking: VID_00024 (7 of 38)
 - [09:44:34] Blanking: VID_00037 (8 of 38)
 - [09:44:34] Blanking: VID_00051 (9 of 38)
 - [09:44:34] Blanking: VID_00021 (10 of 38)
 - [09:44:34] Blanking: VID_00048 (11 of 38)
 - [09:44:34] Blanking: VID_00052 (12 of 38)
 - [09:44:34] Blanking: VID_00038 (13 of 38)
 - [09:44:34] Blanking: VID_00039 (14 of 38)
 - [09:44:34] Blanking: VID_00050 (15 of 38)
 - [09:44:34] Blanking: VID_00047 (16 of 38)
 - [09:44:34] Blanking: VID_00022 (17 of 38)
 - [09:44:34] Blanking: VID_00041 (18 of 38)
 - [09:44:34] Blanking: VID_00034 (19 of 38)
 - [09:44:34] Blanking: VID_00049 (20 of 38)
 - [09:44:34] Blanking: VID_00008 (21 of 38)
 - [09:44:34] Blanking: VID_00045 (22 of 38)
 - [09:44:34] Blanking: VID_00044 (23 of 38)
 - [09:44:34] Blanking: VID_00055 (24 of 38)
 - [09:44:34] Blanking: VID_00010 (25 of 38)
 - [09:44:34] Blanking: VID_00018 (26 of 38)
 - [09:44:34] Blanking: VID_00069 (27 of 38)
 - [09:44:34] Blanking: VID_00011 (28 of 38)
 - [09:44:34] Blanking: VID_00006 (29 of 38)
 - [09:44:34] Processing: VID_00003 (30 of 38)
 - [09:44:34] Extracting A/V streams [VID_00003]
 - [09:44:38] Reencoding video [VID_00003]
 - [09:44:38] Keeping original video (no reencode)
 - [09:44:38] Processing audio tracks
 - [09:44:38] Multiplexing M2TS
 - [09:44:42] Blanking: VID_00002 (31 of 38)
 - [09:44:42] Blanking: VID_00004 (32 of 38)
 - [09:44:42] Blanking: VID_00012 (33 of 38)
 - [09:44:42] Blanking: VID_00014 (34 of 38)
 - [09:44:42] Blanking: VID_00013 (35 of 38)
 - [09:44:42] Processing: VID_00057 (36 of 38)
 - [09:44:42] Extracting A/V streams [VID_00057]
 - [09:44:47] Reencoding video [VID_00057]
 - [09:44:47] Keeping original video (no reencode)
 - [09:44:47] Processing audio tracks
 - [09:44:47] Multiplexing M2TS
 - [09:44:51] Blanking: VID_00015 (37 of 38)
 - [09:44:51] Processing: VID_00061 (38 of 38)
 - [09:44:51] Extracting A/V streams [VID_00061]
 - [09:45:30] Reencoding video [VID_00061]
 - [09:45:30] Keeping original video (no reencode)
 - [09:45:30] Processing audio tracks
   - Track 4353 (fra): Keeping original audio
   - Track 4354 (deu): Keeping original audio
   - Track 4355 (ita): Keeping original audio
   - Track 4356 (spa): Keeping original audio
   - Track 4357 (spa): Keeping original audio
   - Track 4358 (por): Keeping original audio
   - Track 4359 (ces): Keeping original audio
   - Track 4360 (hun): Keeping original audio
   - Track 4361 (pol): Keeping original audio
   - Track 4362 (rus): Keeping original audio
   - Track 4363 (jpn): Keeping original audio
 - [09:45:30] Multiplexing M2TS
[09:46:07]PHASE ONE complete
[09:46:07]PHASE TWO - Rebuild Started
 - [09:46:07] Rebuilding BD file Structure
[09:46:33] - Encode and Rebuild complete
[09:46:33] JOB: MAD_MAX_3_BEYOND_THUNDERDOME finished.
[Status]
LABEL=MAD_MAX_3_BEYOND_THUNDERDOME
VERSION=v0.61.25
SOURCE_SIZE=30331871654
SOURCE_VIDEO_SIZE=29999794176
TARGET_SIZE=30408704000
REDUCTION=1.00256109577117
RESIZE_1080=0
RESIZE_1440=0
AUDIO_TO_KEEP=all
KEEP_HD_AUDIO=-1
SUBS_TO_KEEP=all
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=0
INSTANCES=1
DGDECNV=-1
DGDECIM=0
FRIMSOURCE=0
FFMS2=0
SSIF_MODE=0
UHD_V3_MODE=0
QUICK=1
ENCODE_STEP=0
COMPLETED=38
REBUILD_COMPLETE=1
[00007]
USE_ORIGINAL=1
[00016]
USE_ORIGINAL=1
[00035]
USE_ORIGINAL=1
[00042]
USE_ORIGINAL=1
[00043]
USE_ORIGINAL=1
[00046]
USE_ORIGINAL=1
[00024]
USE_ORIGINAL=1
[00037]
USE_ORIGINAL=1
[00051]
USE_ORIGINAL=1
[00021]
USE_ORIGINAL=1
[00048]
USE_ORIGINAL=1
[00052]
USE_ORIGINAL=1
[00038]
USE_ORIGINAL=1
[00039]
USE_ORIGINAL=1
[00050]
USE_ORIGINAL=1
[00047]
USE_ORIGINAL=1
[00022]
USE_ORIGINAL=1
[00041]
USE_ORIGINAL=1
[00034]
USE_ORIGINAL=1
[00049]
USE_ORIGINAL=1
[00008]
USE_ORIGINAL=1
[00045]
USE_ORIGINAL=1
[00044]
USE_ORIGINAL=1
[00055]
USE_ORIGINAL=1
[00010]
USE_ORIGINAL=1
[00018]
USE_ORIGINAL=1
[00069]
USE_ORIGINAL=1
[00011]
USE_ORIGINAL=1
[00006]
USE_ORIGINAL=1
[00003]
USE_ORIGINAL=1
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=14419941
NSTART=27000000
NEND=27495495
NSIZE=14383104
FLINK=0
MLINK=0
[00002]
USE_ORIGINAL=1
[00004]
USE_ORIGINAL=1
[00012]
USE_ORIGINAL=1
[00014]
USE_ORIGINAL=1
[00013]
USE_ORIGINAL=1
[00057]
USE_ORIGINAL=1
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=152693680
NSTART=27000000
NEND=31930550
NSIZE=152371200
FLINK=0
MLINK=0
[00015]
USE_ORIGINAL=1
[00061]
USE_ORIGINAL=1
AUDIO=111111111111
PGS=1111111111111111111111111111111
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=29909872218
NSTART=27000000
NEND=315822909
NSIZE=27788673024
FLINK=0
MLINK=0
This is the subtitle from the non-procesed BD (demuxed using TSMuxer):
https://1drv.ms/u/s!AiCgDguh7E_OgZdr...abQuw?e=8dJRZt
This is the subtitle from the output BD created by BD-Rebuilder (demuxed using TSMuxer):
https://1drv.ms/u/s!AiCgDguh7E_OgZdq...-G2Nw?e=0AbAFy
SquallMX is offline   Reply With Quote
Old 17th November 2021, 05:26   #30933  |  Link
MrVideo
MrVideo's Avatar
Please "code" wrap the text, don't "quote" wrap it.
Old 19th November 2021, 12:09   #30934  |  Link
lauguru
Hello, after a long time without hardly using computers, I would like to know what is the best configuration to convert full uhd with custom 48200mb, Nvenc codec to obtain the highest quality (vbr), ENCODE_QUALITY = 4 (ultra high extremly slow), what else could I add o remove?. Thanks
other question for update the new Nvenc codec 5.41https://github.com/rigaya/NVEnc/releases?page=1 in bd rebuilder copy and paste the files from https://github.com/rigaya/NVEnc/rele...cC_5.41_x64.7z and paste in path bdrebuilder /tools /nvenc an rename NVEncC64.exe to NVEncC.exe correct?
[Options]
[Options]
VERSION=0.61.0.25
ENCODER=1
MODE=0
ENCODE_QUALITY=4
AUTO_TWOPASSONLY=1
ONEPASS_ENCODING=2
B_PYRAMID=1
QUALITY_ULTRA=2
UHD_MAXRATE=60000
UHD_VBV_BUFFER=60000
AUTO_QUALITY=0
TARGET_SIZE=48200
AUDIO_TO_KEEP=all
SUBS_TO_KEEP=all
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=1
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AUDIO_DRC=0
DECODER=0
AVCHD=1
REMOVE_WORKFILES=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=0
PGSTOSRT=0
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=1
CUSTOM_TARGET_SIZE=48000
NVENC_CAPABLE=1
[Paths]
SOURCE_PATH=G:\
WORKING_PATH=E:
lauguru is offline   Reply With Quote
Old 23rd November 2021, 08:46   #30935  |  Link
RetsimLegin
@jdobbs I encountered something entirely new yesterday.
I'm not going into where or how I got the source but the video is encoded at EXACTLY 24fps (not 23.976) - which I gather (from here https://forum.doom9.org/showthread.php?t=154533) IS a valid frame rate for BD-Video. The video does need re-encoding as it has letterboxed content and the black bars aren't in the source (i.e. it's not 1080 pixels high).
BDRB re-encoded the video at 23.976 an re-encoded the EC3 audio without other amendment (i.e. equivalent to 24fps) - meaning that the lip-sync drifted throughout and was was off by something like 1/2 second at the end.
So instead, I'm having to try avidemux to re-encode both whilst retaining the 24fps timing.
Old 23rd November 2021, 14:24   #30936  |  Link
When BD-RB converts rates, it should also adjust the audio. Can you look at the AVS for audio and see if it does?
Old 23rd November 2021, 17:04   #30937  |  Link
Mark_Venture
not a bug, but a question... (should I be asking outside of this thread??)
When doing Alt-Movie Only for a normal Blurays, I had been selecting "MKV Container, 1920x1080, Intact Audio" . It works great and I'm happy with the output. Looking at Alternate.txt it has vFormat=5 (where 5=1920x1080). Does it actually resize the video on a normal bluray? I mean, a typical bluray is 1080p, so I would think it shouldn't, but I have to ask. Or does it cause black bars inserted or something to make the video a full 1080 lines for movies that aren't 16:9 aspect ratio or something?
When I do UHD disks, I've been using "MKV Container, HEVC, NO_RESIZE, Intact Audio" which has vFormat=7 (where 7=No Resizing)
Other than h264 vs H265, if I switch to "MKV Container, HEVC, NO_RESIZE, Intact Audio" for all, should I expect the same output for my regular blurays?
Old 23rd November 2021, 18:36   #30938  |  Link
RetsimLegin
AVS? (sorry!)
Certainly
a) the BDRB output lost sync
b) the AVIDEMUX output (24p exactly) did not
c) ...and neither does the original
Old 23rd November 2021, 23:32   #30939  |  Link
MrVideo
MrVideo's Avatar
That begs the question... why is BDRB converting 24fps to 23.976 in the first place?
Old 24th November 2021, 00:38   #30940  |  Link
There was a good reason at the time I wrote it... but, to be honest, I can't remember why now.
