Old 3rd June 2017, 18:41   #3441  |  Link
pinterf
I'm on the XP problem, so far no success.
EDIT:
Arggh. It was a compiler setting problem: /Zc:threadSafeInit- was missing.
But now I see what happens.
During autoload, these DLLs called GetCPUFlags in their Init, after AddFunction and caused Avisynth+ to crash.
VerticalCleanerSSE2.dll
RepairSSE2.dll
RemoveGrainSSE2.dll
RemoveDirtSSE2.dll
SSE2Tools.dll
e.g. in old RemoveGrain source
extern "C" __declspec(dllexport) const char* __stdcall AvisynthPluginInit2(IScriptEnvironment* env)
#ifdef	MODIFYPLUGIN
	env->AddFunction("Repair", "cc[mode]i[modeU]i[modeV]i[planar]b", CreateRemoveGrain, 0);
	env->AddFunction("TemporalRepair", "cc[smooth]i[grey]b[planar]b", CreateTemporalRepair, 0);
#else // MODIFYPLUGIN
	env->AddFunction("RemoveGrain", "c[mode]i[modeU]i[modeV]i[planar]b", CreateRemoveGrain, 0);
	env->AddFunction("Clense", "c[grey]b[reduceflicker]b[planar]b[cache]i", CreateClense, 0);
	env->AddFunction("MCClense", "ccc[grey]b[planar]b", CreateMCClense, 0);
	env->AddFunction("BackwardClense", clenseargs, CreateBackwardClense, 0);
	env->AddFunction("ForwardClense", clenseargs, CreateForwardClense, 0);
#endif // MODIFYPLUGIN
	AVSenvironment = env;
	if( (CPUFLAGS & env->GetCPUFlags()) != CPUFLAGS )
#if	ISSE > 1
		env->ThrowError("RemoveGrain needs an SSE2 capable cpu!\n");
#else
		env->ThrowError("RemoveGrain needs an SSE capable cpu!\n");
#endif
#if	0
	debug_printf(LOGO);
#endif
	return "RemoveGrain: remove grain from film";
The GetCPUFlags gave access violation.
From the two debug lines in GetCPUFlags, only the first one was displayed, seems that calling CPUCheckForExtensions gave an instant crash.
In cpuid.cpp
static int CPUCheckForExtensions()
int GetCPUFlags() {
  _RPT0(0, "GetCPUFlags() called\n");
  static int lCPUExtensionsAvailable = CPUCheckForExtensions();
  _RPT0(0, "GetCPUFlags() called 2\n");
  return lCPUExtensionsAvailable;
This static initialization fails under XP w/o the /Zc:threadSafeInit- flag.
Rebuild later, it's already dark here, and I have get home w/o police affairs (forgot to put front lamp on my bike)
pinterf is offline
Old 3rd June 2017, 22:26   #3442  |  Link
pinterf
Thank you for your patience, here come the fixed binaries
Download Avisynth+ r2504-MT (broken XP support hotfix)
pinterf is offline
Old 3rd June 2017, 22:34   #3443  |  Link
Groucho2004
Thank you for your patiance, here come the fixed binaries
Thank you, this seems to work fine now.
Groucho2004 is offline
Old 3rd June 2017, 23:15   #3444  |  Link
Groucho2004
Originally Posted by tuanden0 View Post
@Groucho2004:
Here is it I take it from test server of MeGUI
http://megui.tmebi.de/test/vsfilter.1.5.0.2827_x64.7z
If I use AVSmeter to write a log with avs+ 2502, the program said cannot load filter until I deleted all 32b and 64b filter folders?
Then, after deleted filter folder, i have a logs
According to your logs, there are no plugins in the listed auto-load directories which makes sense since you apparently deleted all auto-load directories. Judging by the auto-load entries in the registry it seems that you installed several Avisynth versions on top of each other without un-installing first.
You should clean this up and re-install:
- Delete "C:\Program Files (x86)\AviSynth+" and subdirs
- Delete these registry keys:
HKEY_CURRENT_USER\Software\Avisynth
HKEY_LOCAL_MACHINE\SOFTWARE\Avisynth
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Avisynth
Old 4th June 2017, 03:43   #3445  |  Link
tuanden0
How can I say "I love you" Groucho2004
tuanden0 is offline
Old 5th June 2017, 11:35   #3446  |  Link
jpsdr
@Pinterf : Are-you using VS2017 ? If i haven't try for now to update to VS2017, is that i don't know if XP is still supported. When your new version didn't work, i thought i was the case, i said to myself "No... He didn't forget the /Zc:threadSafeInit-, it's probably not so easy... ".
Another thing, i don't know if the it can be installed under a 32bits OS (bad surprise with last Intel Compiler which doesn't install under a 32bits OS... ).
jpsdr is offline
Old 5th June 2017, 12:38   #3447  |  Link
StainlessS
StainlessS's Avatar
Jpsdr, see here:- https://www.visualstudio.com/en-us/p...mpatibility-vs
XP supported as target, but last VS to support compilation on XP was vs 2010.
(Not sure, I think XP tool set was not provided until quite recently on vs 2017, I guess that they
finally realized that not everyone was willing to drop support for some millions of the old OS users).
I sometimes post sober.
StainlessS is offline
Old 5th June 2017, 12:48   #3448  |  Link
qyot27
qyot27's Avatar
IIRC, when installing VS2017, you can also install VS2015's compilers/toolsets, so it could be configured to use v140_xp. The difference would be that there's also a v141_xp now (specifically for VS2017, apparently) too.
But I installed it a couple months ago and don't remember too well.
qyot27 is offline
Old 6th June 2017, 08:31   #3449  |  Link
pinterf
I'm not using it for production releases yet. When I have edited the cmake list file for vs2017, the XP support switch was moved (and not copied) from the vs2015 section so vs2015 build missed that option.
pinterf is offline
Old 7th June 2017, 21:21   #3450  |  Link
VS_Fan
Problem with CombinePlanes?
FFmpegSource2(source="MVI_2038.avi")
#ConvertToYV12()
c0 = last
Y8=ExtractY()
U8=ExtractU()
V8=ExtractV()
Y8= <luma Separate filter(s)>
U8= <chroma Separate filter(s)>
V8= <chroma Separate filter(s)>
CombinePlanes(Y8, U8, V8, planes="YUV", sample_clip=c0) #, pixel_type="YUV420P8" #, source_planes="YYY")
This will work if I convert to YV12 (YUV420P8), but my source is YV16 (YUV422P8), and I would of course prefer to keep it that way.
Am I doing anything wrong?
This is the error message I get when trying it with YUV422 material:
"CombinePlanes: source and target plane dimensions are different"
VS_Fan is offline
Old 7th June 2017, 23:58   #3451  |  Link
raffriff42
Retried Guesser
raffriff42's Avatar
I think I found it:
avs_core\filters\planeswap.cpp, Line 870
    int target_plane_width = vi_default.width >> vi_default.GetPlaneWidthSubsampling(current_target_plane);
    int target_plane_height = vi_default.height >> vi_default.GetPlaneWidthSubsampling(current_target_plane);
raffriff42 is offline
Old 8th June 2017, 07:52   #3452  |  Link
pinterf
Originally Posted by raffriff42 View Post
I think I found it:
Oops, thanks.
pinterf is offline
Old 8th June 2017, 12:18   #3453  |  Link
pinterf
CombinePlanes fixed, thanks for the report.
Download Avisynth+ r2506
20170608 r2506
  - Fix CombinePlanes: feeding YV16 or YV411 target with Y8 sources
pinterf is offline
Old 11th June 2017, 18:35   #3454  |  Link
edcrfv94
after r1858 update to r2506.
r2506 will not load libfftw3f-3.dll under plugins+/plugins64+, libfftw3f-3.dll must under System32/SysWOW64.
It is a bug?
edcrfv94 is offline
Old 11th June 2017, 19:26   #3455  |  Link
Groucho2004
It is a bug?
No, it's a feature.
libfftw3f-3.dll is not a plugin, it's not supposed to be in the auto-load directory. It has to be either in the current directory, the same directory of the calling program or in a directory to which the "PATH" environment variable points. For simplicity, just put it in System32/SysWOW64.
Old 20th June 2017, 23:24   #3456  |  Link
Sharc
For the same source, same script and same x264 encoder settings (1-pass crf) I am getting about 45% bigger file size (and more noise) for AVS+ (x86) compared to AVS 2.6.0. How is this possible?
Sharc is offline
Old 20th June 2017, 23:27   #3457  |  Link
sneaker_ger
High bitdepth/dithering?
Show sample, scripts, program versions and logs.
sneaker_ger is offline
Old 21st June 2017, 01:19   #3458  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
I'm running FrameRateConverter with 1 thread
FrameRateConverter(60, output="auto")
FPS (min | max | average):      2.044 | 68778 | 12.90
Memory usage (phys | virt):     353 | 349 MiB
Thread count:                   21
CPU usage (average):            13%
and with 8 threads
FPS (min | max | average):      2.332 | 129914 | 31.80
Memory usage (phys | virt):     785 | 784 MiB
Thread count:                   29
CPU usage (average):            42%
What is causing such a bottleneck at 42% CPU usage?
MysteryX is offline
Old 21st June 2017, 07:57   #3459  |  Link
pinterf
Are you using 32 or 64 bit Avisynth? What is your SetMemoryMax?
Perhaps try SetLogParams("log.txt", LOG_DEBUG) and look at the output. Is there any serialized mt mode filter in between?
pinterf is offline
Old 21st June 2017, 09:26   #3460  |  Link
Sharc
I think I found the culprit. I am using in my script
temporalsoften(4,4,8,10,mode=2)
It seems to have no effect with AVS+ r2506, while it works as expected in AVS260.
Sharc is offline
