Old 23rd August 2010, 05:37   #9301  |  Link
Lynxs
@Capsbackup
I'll try those settings and see if that works. I didn't keep the WORKFILE directory but I'll use the settings trying to rip the BR again and I'll let you know. Thanks
Lynxs is offline   Reply With Quote
Old 23rd August 2010, 08:21   #9302  |  Link
setarip_old
setarip_old's Avatar
@Lynxs
and I'm using TMT2.5 and 3
Sorry I didn't initially notice this.
One thing we've all learned here is that we shouldn't jump to conclusions based on playback under PC software players. Now that you "seem" to have a problem (based on TMT playback), you should burn a disc and see if the same problem exists when played on a standalone player...
Old 23rd August 2010, 18:01   #9303  |  Link
longtom
Multiple Profiles for BD Rebuilder
Is there any possibility to have 2 profiles to start with?
e.g. One is BD5 with AC3 2.0 and 720p, other one is Custom Size 1080p with HD Audio.
longtom is offline   Reply With Quote
Old 24th August 2010, 12:20   #9304  |  Link
espinha
Hello.
Where I can get profiles to load on BDRebuilder?
espinha is offline   Reply With Quote
Old 24th August 2010, 15:02   #9305  |  Link
bluestarCVO
Originally Posted by espinha View Post
Hello.
In a new thread. This one is for bug reports only.
bluestarCVO is offline   Reply With Quote
Old 24th August 2010, 21:40   #9306  |  Link
Dirk Diggler
Will we be able to benefit from the latest Matroska Spiltter with the latest enhancements
    * Fixed items:
          o Fixed aspect ratio processing in certain Matroska files, which caused errors on open
# 20/05/2010
    * New Features:
          o Added support for WebM files
    * Fixed items:
          o Fixed a lot of issues with mp4 muxer
          o Better support for VC-1 in MPEG Transport streams
# 27/03/2010
    * New Features:
          o Added AC-3 in MP4 support
    * Fixed items:
          o Show error code in GDSMux when muxing is aborted
          o Accept more AAC media types in the muxer
          o Use correct timescales when processing MP4 edit lists
          o Scan the folder for more segments only if the file references external segments
19/12/2009
    * New Features:
          o Added a 64-bit version
          o A shell extension was removed from the splitter. This will be available seprately at a later date.
          o Added truehd and mlp support for Matroska files and transpor streams
    * Fixed items:
          o Fixed lpcm in transport streams support
Dirk Diggler is offline   Reply With Quote
Old 24th August 2010, 22:47   #9307  |  Link
    * Fixed items:
# 20/05/2010
    * New Features:
    * Fixed items:
# 27/03/2010
    * New Features:
    * Fixed items:
19/12/2009
    * New Features:
    * Fixed items:
1. So what in this release affects BD-RB?
2. Has it been tested with all stream types? The problem in the past are that a new release sometimes will make things that used to work stop working.
Old 25th August 2010, 03:03   #9308  |  Link
Dirk Diggler
1. I am not sure which is why I asked "will we" benefit from the update
2. I am aware of this as I ran into this issue when I first started using BD Rebuilder and ran the wrong version
Old 25th August 2010, 07:21   #9309  |  Link
likwid8
Quick question for anyone who can help. I did one movie using BDR and it worked fine, but after that kept getting encode failed. One thing I noticed was when I attempt to run the INSPECT.EXE I get a runtime error and in the window it shows AVSCRIPT OK and windows version 6.0, nothing else.
Was wondering if I needed to fix this issue before continuing to post the logs as it may serve a purpose as to why it's not letting me encode? Also, the encode error appears to happen at around 5%. Any help is appreciated and I can post the log upon request, thank you.
likwid8 is offline   Reply With Quote
Old 25th August 2010, 13:19   #9310  |  Link
What runtime error do you get when you run INSPECT?
Old 25th August 2010, 17:34   #9311  |  Link
likwid8
Run-time error '13':
Type mismatch
EDIT: Just realized that the BD Rebuilder fails when it reached a VC-1 file, the MPEG-2 seems to work fine but it fails on encode when it reaches VC-1 codec. What is the solution to this? thank you.
Old 25th August 2010, 18:56   #9312  |  Link
Capsbackup
Type mismatch
I would uninstall Haali, delete the folder for Haali in your Program folder, uninstall ffdshow and Avisynth then reboot.
Then download the correct versions from the first page of this thread and reinstall those three programs and try again.
Old 25th August 2010, 19:59   #9313  |  Link
setarip_old
@liqwid8
Hi!
From within ffdshow, there are three possible settings for VC-1. Try each of them to see which one works best with your system's configuation...
Old 25th August 2010, 21:11   #9314  |  Link
@liqwid8
Hi!
Most of the time WMV9 is the best choice unless you are using XP and have Windows Media Player 11 installed in which case "Disabled" may be better.
Old 25th August 2010, 21:49   #9315  |  Link
likwid8
Will try the above steps and repost, and I will also uninstall windows media player as I only use VLC. Thanks will post back asap.
Old 25th August 2010, 22:19   #9316  |  Link
likwid8
Looks like re-installing did the job, now it resumed from when it previously failed "00041.mts" and its encoding it! Phewww
thanks guys
Old 26th August 2010, 14:15   #9317  |  Link
likwid8
One more thing I looked over the thread but seems I cannot find the answer for this. Whats the option to choose 1-pass ABR instead of the 2?
When I goto encoder settings I only see "normal", "default" (check-marked), "high priority", "automatically quality settings" (also checked).
Old 26th August 2010, 15:08   #9318  |  Link
Capsbackup
Just select "automatically quality settings", and it will uncheck it, and the other options will become available.
Old 27th August 2010, 00:32   #9319  |  Link
stonej01
Just have a quick question. I just ran BOLT through bd-rebuilder and i have a strange issue. Audio is set to English. The first part of the movie is fine until about 3:39 it switches to Spanish audio then back again around the 11 minute mark. Any ideas? Tried on two different builds also.
stonej01 is offline   Reply With Quote
Old 27th August 2010, 00:54   #9320  |  Link
setarip_old
@stonej01
Hi!
BOLT...Audio is set to English. The first part of the movie is fine until about 3:39 it switches to Spanish audio then back again around the 11 minute mark
Sounds like either a bad rip or bad source material...
