17th August 2016, 08:50 | #24741 | Link | |
It's the only disc I know where a 2D movie has 3D extras on it... |
18th August 2016, 14:21 | #24746 | Link |
BD Rebuilder v0.50.18
I have updated the first post of this thread with a link to the latest update to BD-RB (v0.50.18). Changes for this release:
- Added a new hidden option MENU_ITEMS_PAGE. It is used for identifying specific item counts for each menu page when importing multiple sources. It's particularly useful for creating discs comprised of multiple episodic seasons. See HIDDENOPTS.TXT for details. - Added to the list of supported DIVX Codec IDs supported during import of video files. - Made changes to the import algorithm for import resizing (to meet standards). This should assure better retention of original aspect ratio in oddly formatted sources. - Fixed an issue in which conversions from PAL to FILM during import was not making necessary timing corrections in subtitles. - Added hidden option ALTERNATE_KEEP_SRT, it allows you to reintegrate extracted SRT files from an import when outputting to ALTERNATE formats (rather than the PGC that was created from the SRT during the import) See HIDDENOPTS.TXT for details. - Made changes to prevent a rare XVID import problem that could result in audio that is out of sync. - Replaced the SPLIT.EXE tool which was mistakenly regressed in the last release. - Other minor corrections and cosmetic fixes. |
18th August 2016, 18:51 | #24748 | Link | |
I'm not sure how it happened. I had a hard drive fail last month and had to restore some of the files to a new drive. Apparently the version of SPLIT.EXE must have been the wrong one. At least that's my best guess. Last edited by jdobbs; 18th August 2016 at 18:54. |
18th August 2016, 19:02 | #24749 | Link |
i'll let you know. I'll remove it from the AV deep scan exclusion list to see what happens. Hey shit happens.
** edit ** @jdobbs SUCCES!! 4 way split active on "The Revenant" each process consuming about 20-25% of CPU @ 0.7-1.3MB/sec doing +-104-150fps i did notice something strange GUI wise when it was doing the splitting itself. The progress bar should normally go from 0-100, well in my case it went something like 0-25-63-42-89-12-0-75-92... and after about 10-20 seconds or so bdrb didn't care that happened and started the 4-way conversion. I'll report later if the split is in sync. When it reached the splitting fase for the main title it went like 0-6-18-28-53-75-98-0-12-22-47... quite a few times but in the end chugged along nicely below you'll find a link to a small avi file displaying the progress bar issue https://drive.google.com/file/d/0B_k...ew?usp=sharing Merging went fine too. Turning it into an iso with bdrb=>imgburn right now Code:
---------------------- [08/18/16] BD Rebuilder v0.50.18 [20:06:10] Source: THE_REVENANT - Input BD size: 42,70 GB - Approximate total content: [03:43:55.962] - Target BD size: 22,95 GB - Windows Version: 6.2 [9200] - Auto Quality: Good (Very Fast), ABR - Output folder: D:\Blu-ray\Rebuilds\BDRB\ - Decoding/Frame serving: DirectShow [4-way] - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [20:06:10] PHASE ONE, Encoding - [20:06:10] Processing: VID_00191 (1 of 3) - [20:06:10] Extracting A/V streams [VID_00191] - [20:06:17] Reencoding video [VID_00191] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1*432 frames - Bitrate: 9*694 Kbs - [20:06:17] Reencoding: VID_00191, Pass 1 of 1 - [20:06:29] Video Encode complete - [20:06:29] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:06:29] Multiplexing M2TS - [20:06:34] Processing: VID_00200 (2 of 3) - [20:06:34] Extracting A/V streams [VID_00200] - [20:07:33] Reencoding video [VID_00200] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 63*408 frames - Bitrate: 7*452 Kbs - [20:07:33] Reencoding: VID_00200, Pass 1 of 1 - [20:16:29] Video Encode complete - [20:16:29] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:16:29] Multiplexing M2TS - [20:17:11] Processing: VID_00800 (3 of 3) - [20:17:11] Extracting A/V streams [VID_00800] - [20:24:40] Reencoding video [VID_00800] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 224*928 frames - Bitrate: 11*500 Kbs - [20:24:40] Reencoding: VID_00800, Pass 1 of 1 - [21:02:14] Video Encode complete - [21:02:14] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:02:14] Multiplexing M2TS [21:11:08]PHASE ONE complete [21:11:08]PHASE TWO - Rebuild Started - [21:11:08] Rebuilding BD file Structure [21:16:05] - Encode and Rebuild complete [21:16:05] Writing BD structure to ISO file - ImgBurn completed successfully - THE_REVENANT folder removed. - WORKFILES folder removed. [21:23:44] JOB: THE_REVENANT finished. Last edited by Ch3vr0n; 19th August 2016 at 02:15. |
19th August 2016, 23:27 | #24755 | Link |
great. Just got a couple new discs to try it on. Test disc: Jungle Book ^^. I'll let you know. Oh and if you've seen the video file above (nothing visible but BDRB ), let me know. Then i'll pull it off gdrive, or you can edit the post and remove the link
** edit ** rebuild of that 3D disc didn't go too well. Succesful log, yet the ISO is only 15GB in size and the video locks up at chapter 12 while audio continues playing and so does the playtime counter (40+min left) Code:
[08/19/16] BD Rebuilder v0.50.18 [20:24:05] Source: BATMAN_V_SUPERMAN_DAWN_JUSTICE - Input BD size: 43,73 GB - Approximate total content: [02:38:47.851] - Target BD size: 22,95 GB - Windows Version: 6.2 [9200] - Quality: Good (Very Fast), ABR - Output folder: D:\Blu-ray\Rebuilds\BDRB\ - MVC 3D Output Mode enabled - Decoding/Frame serving: FRIMDecode - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [20:24:09] PHASE ONE, Encoding - [20:24:09] Processing: VID_00052 (1 of 2) - [20:24:09] Extracting A/V streams [VID_00052] - [20:35:37] Reencoding video [VID_00052] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 218*209 frames - Bitrate: 18*147 Kbs - Using FRIMEncoder for MVC encoding - [20:35:37] Reencoding: VID_00052, Pass 1 of 1 - [23:13:59] Video Encode complete - [23:13:59] Processing audio tracks - Track 4352 (eng): Keeping original audio - [23:13:59] Multiplexing M2TS - [23:22:28] Scanning for 3D CLPI info... - [23:25:41] Processing: VID_00103 (2 of 2) - [23:25:41] Extracting A/V streams [VID_00103] - [23:25:49] Reencoding video [VID_00103] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 8*159 frames - Bitrate: 4*805 Kbs - Using FRIMEncoder for MVC encoding - [23:25:49] Reencoding: VID_00103, Pass 1 of 1 - [23:30:16] Video Encode complete - [23:30:16] Processing audio tracks - [23:30:16] Multiplexing M2TS - [23:30:20] Scanning for 3D CLPI info... [23:30:22]PHASE ONE complete [23:30:22]PHASE TWO - Rebuild Started - [23:30:22] Converting SSIF file references - [23:30:55] Rebuilding BD-3D file Structure [23:33:48] - Encode and Rebuild complete [23:33:48] Writing BD structure to ISO file - ImgBurn completed successfully - BATMAN_V_SUPERMAN_DAWN_JUSTICE folder removed. - WORKFILES folder removed. [23:40:59] JOB: BATMAN_V_SUPERMAN_DAWN_JUSTICE finished. Last edited by Ch3vr0n; 20th August 2016 at 00:37. |
20th August 2016, 02:38 | #24758 | Link | |
Also, I can't test the file. I'm on the road with nothing but my iPad for a couple days. Last edited by jdobbs; 20th August 2016 at 02:42. |
20th August 2016, 03:06 | #24759 | Link |
Oh i load all 8 cores too at 100% with auto-split. Though i'm not going to cry about 8-way manual split not working. The conversion times i have now compared to my old rig are like 4x less, i'm happy with that. About the file, no worries. Just send me a pm or tag me or something when you've had the chance to take a look. I'll leave it up until then.
20th August 2016, 04:13 | #24760 | Link | |
Seems like CRF for backup is almost always the way to go then. Thanks JD! |
