24th February 2017, 00:43 | #25701 | Link |
Menu problem Pirates of the Caribbean - At World's End Disk 2 Extras
Greetings,
Strange problem. Surprised it is happening on an older movie. I did a full disc encode of the Blu-ray of Pirates of the Caribbean - At World's End Disk 2 Extras so that I can fit on single layer disk. Encode successfully. Burned to rewritable disc and popped into Samsung Blu-ray player. Copy plays fine until the menu. The background video plays but the menu never displays. The background video just keeps looping and no menu. I am attaching the log and the ini file. Anybody got any great ideas for a quick fix for this problem? Thanks! Edit - Crap! Never mind. Bad rip. Ripped again and all OK. Last edited by Moviewatcher666; 25th February 2017 at 23:23. Reason: Update |
24th February 2017, 03:20 | #25702 | Link |
I started to deinterlace when converting interlaced bonus features, so there would be no need to have projector/computer w/display do the conversion during playback. It's been a while, so I'd actually forgotten the disadvantages of doing so with the main program material; I'll have to be cognizant of that going forward. Thanks for the reminder.
24th February 2017, 15:35 | #25705 | Link |
That's a little complicated and beyond the scope of this thread, but I'll give you a short answer.
- HEVC is High Efficiency Video Coding (also known as H.265) - AVC is Advanced Video Coding (also known as H.264) X264 is a program that encodes AVC. X265 is a program that encodes HEVC. AVC has been around for a while and is in use in many areas -- including Blu-Ray. HEVC is newer and more efficient but it isn't as widely implemented. It is especially good at giving you better pictures at low bitrates. HEVC is in-use in Blu-Ray only in players that support Ultra High Resolution (UHD) which are still pretty new and expensive. In my testing of X264 and X265, I'm not seeing a lot of difference between the two (in terms of SSIM, a quality measuring metric) at typical HD bitrates. But that's likely because X264 has been around a while and has had a lot of tweaks that get maximum efficiency out of AVC. X265 is fairly new. Generally it should be expected that you can get an equivalent quality picture with HEVC at a lower bitrate (meaning less bandwidth for broadcast, and less required storage). Tests I've read about that were done by Netflix seem to show significant savings with HEVC. Hope that helps. Last edited by jdobbs; 24th February 2017 at 15:40. |
25th February 2017, 06:19 | #25708 | Link | |
I'm going to try this will some stuff and see what happens.
25th February 2017, 22:24 | #25712 | Link | |
Using selectevery() speeds up the recoding process since the software isn't going thru the time consuming frame doubling and field extraction to find the 2:3 pattern. The AVS script just drops a frame out of every five, resulting in the new frame rate: 23.976. You gotta love what can be done with AVS scripts. |
26th February 2017, 00:10 | #25713 | Link | |
26th February 2017, 00:59 | #25714 | Link | |
But, that said, selectevery() should be faster, as it doesn't have to spend time comparing frames. The un-selected frame is just dropped. Last edited by MrVideo; 26th February 2017 at 02:46. |
