21st January 2012, 01:13 | #14062 | Link | |
21st January 2012, 01:16 | #14063 | Link | |
21st January 2012, 17:40 | #14064 | Link | |
Programmer
Is there a easy way to tell its a BD-J menu? Any one had luck on the Panasonics with this AVCHD=1? As I have many full backups on BD-9 that are not recognized as valid BD by my standalone Panny BD-85 player. I wonder if I can take these full backups and run them thru BD-Rebuilder again with AVCHD=1 set and it would fix them? |
21st January 2012, 21:10 | #14065 | Link |
@Jdobbs: i happened to be behind the computer when it was creating the final output structure. apparantly the redundant folder (without the _DVD) gets created during the stage "Creating ALTERNATE MOVIE-ONLY structure (Pt 1)..." and before converting the subtitles to dvd standard. The _DVD labelled folder was created during the final "Creating DVD File Structure" message. Maybe this will help you pinpoint the the place in the code and ease the fix
22nd January 2012, 05:04 | #14066 | Link | |
I apologize in advance if the answer to my problem exists in this thread, but the searches that I have done did not provide any answers.
So here is my issue. I CAN successfully make an MKV backup (movie only) of a Blu-Ray dvd. I have created at least 34 MKV files, so I know that I can make MKV's from ripped Blu-Ray disks. However, I cannot successfully make an MKV from a ripped DVD. I am using the method that Jdobbs posted here (post 18): Quote:
Now the interesting thing, is that I CAN successfully create an MP4 file, from the same source that I am trying to create an MKV file. Also, I have tried uninstalling and re-installing all the support files (Avisynth_258.exe, MatroskaSplitter.exe, ffdshow_rev3882_20110613_clsid.exe), and I downloaded the recommended version from the links at the first post on this thread. So here are my details: Code:
INSPECT: - Windows Version: 6.1 [7601] - AVISYNTH Version: [2.5.8.0], Ok - HAALI Splitter: [1.9.42.1], Ok - FFDSHOW: [3882], Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "ffmpeg-mt": Ok - BD Rebuilder v0.39.0.7, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok BD-REBUILDER.LOG (As you can see, I tried several times, using different settings the SUCCESSFUL MP4 file ALSO, NOT trying to be a jerk by posting a long LOG file, just want to show that I tried using different settings) [05:18:57] BD Rebuilder v0.39.07 (beta) - Source: AVCHD - Input BD size: 5.30 GB - Approximate total content: [02:23:57.411] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MP4 Container, 1920x1080, Auto-AAC - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [05:19:17] PHASE ONE, Encoding - [05:19:17] Processing: VID_00000 (1 of 2) - [05:19:17] Extracting A/V streams [VID_00000] - [05:23:25] Reencoding video [VID_00000] - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 191,941 frames - Convert: 1920x1080, 29.970fps, 191,941 frames - Bitrate: 9,005 Kbs - [05:23:26] Reencoding: VID_00000, Pass 1 of 2 - [07:43:45] Reencoding: VID_00000, Pass 2 of 2 - [14:16:13] Video Encode complete - [14:16:13] Processing audio tracks - Track 4352 (eng): Reencoding audio to AAC... - [14:31:16] Multiplexing M2TS - [14:31:16] Processing: VID_00001 (2 of 2) - [14:31:16] Extracting A/V streams [VID_00001] - [14:32:31] Reencoding video [VID_00001] - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 66,922 frames - Convert: 1920x1080, 29.970fps, 66,922 frames - Bitrate: 9,263 Kbs - [14:32:31] Reencoding: VID_00001, Pass 1 of 2 - [15:19:22] Reencoding: VID_00001, Pass 2 of 2 - [17:34:42] Video Encode complete - [17:34:42] Multiplexing M2TS [17:34:42]PHASE ONE complete [17:34:42]PHASE TWO - Rebuild Started - [17:34:42] Rebuilding stream 00000 [1 of 2] - [17:34:42] Rebuilding stream 00001 [2 of 2] - [17:34:42] Building ALTERNATE OUTPUT Structure [17:52:31] - Encode and Rebuild complete [17:52:31]JOB: AVCHD finished. -- [23:16:41] BD Rebuilder v0.39.07 (beta) - Source: AVCHD - Input BD size: 5.30 GB - Approximate total content: [02:23:57.411] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, Auto-AAC - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [23:16:45] PHASE ONE, Encoding - [23:16:45] Processing: VID_00000 (1 of 2) - [23:16:45] Extracting A/V streams [VID_00000] - [23:20:47] Reencoding video [VID_00000] - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 191,941 frames - Convert: 1920x1080, 29.970fps, 191,941 frames - [23:20:47] Reencoding: VID_00000, Pass 1 of 1 [23:40:18]PHASE ONE aborted by user request -- [00:01:56] BD Rebuilder v0.39.07 (beta) - Source: AVCHD - Input BD size: 5.30 GB - Approximate total content: [02:23:57.411] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: BP MKV Container, 720x480/576, 640Kbs DD5.1 - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [00:01:57] PHASE ONE, Encoding - [00:01:57] Processing: VID_00000 (1 of 2) - [00:01:57] Extracting A/V streams [VID_00000] - [00:05:38] Reencoding video [VID_00000] - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 191,941 frames - Convert: 1920x1080, 29.970fps, 191,941 frames - [00:05:38] Reencoding: VID_00000, Pass 1 of 1 - [01:07:48] Video Encode complete - [01:07:48] Processing audio tracks - Track 4352 (eng): Keeping original audio - [01:07:54] Multiplexing M2TS - [01:07:54] Processing: VID_00001 (2 of 2) - [01:07:55] Extracting A/V streams [VID_00001] - [01:08:42] Reencoding video [VID_00001] - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 66,922 frames - Convert: 1920x1080, 29.970fps, 66,922 frames - [01:08:43] Reencoding: VID_00001, Pass 1 of 1 - [01:28:51] Video Encode complete - [01:28:51] Multiplexing M2TS [01:28:51]PHASE ONE complete [01:28:51]PHASE TWO - Rebuild Started - [01:28:51] Rebuilding stream 00000 [1 of 2] - [01:28:51] Rebuilding stream 00001 [2 of 2] - [01:28:51] Building ALTERNATE OUTPUT Structure [01:29:12] - Failed to REBUILD -- [03:36:50] BD Rebuilder v0.39.07 (beta) - Source: AVCHD - Input BD size: 5.30 GB - Approximate total content: [02:23:57.411] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: BP MKV Container, 720x480/576, 640Kbs DD5.1 - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [03:36:53] PHASE ONE, Encoding - [03:36:53] Processing: VID_00000 (1 of 2) - [03:36:53] Extracting A/V streams [VID_00000] - [03:41:20] Reencoding video [VID_00000] - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 191,941 frames - Convert: 1920x1080, 29.970fps, 191,941 frames - [03:41:21] Reencoding: VID_00000, Pass 1 of 1 - [03:55:04] Video Encode complete - [03:55:04] Processing audio tracks - Track 4352 (eng): Keeping original audio - [03:55:15] Multiplexing M2TS - [03:55:15] Processing: VID_00001 (2 of 2) - [03:55:15] Extracting A/V streams [VID_00001] - [03:56:07] Reencoding video [VID_00001] - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 66,922 frames - Convert: 1920x1080, 29.970fps, 66,922 frames - [03:56:07] Reencoding: VID_00001, Pass 1 of 1 - [04:00:07] Video Encode complete - [04:00:07] Multiplexing M2TS [04:00:07]PHASE ONE complete [04:00:07]PHASE TWO - Rebuild Started - [04:00:07] Rebuilding stream 00000 [1 of 2] - [04:00:07] Rebuilding stream 00001 [2 of 2] - [04:00:07] Building ALTERNATE OUTPUT Structure [04:00:11] - Failed to REBUILD -- [04:01:56] BD Rebuilder v0.39.07 (beta) - Source: AVCHD - Input BD size: 5.30 GB - Approximate total content: [02:23:57.411] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: BP MKV Container, 720x480/576, 640Kbs DD5.1 - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [04:02:06] PHASE ONE, Encoding - [04:02:06] Processing: VID_00000 (1 of 2) - [04:02:06] Extracting A/V streams [VID_00000] - [04:06:15] Reencoding video [VID_00000] - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 191,941 frames - Convert: 1920x1080, 29.970fps, 191,941 frames - Bitrate: 872 Kbs - [04:06:16] Reencoding: VID_00000, Pass 1 of 2 - [04:19:49] Reencoding: VID_00000, Pass 2 of 2 - [04:34:03] Video Encode complete - [04:34:03] Processing audio tracks - Track 4352 (eng): Keeping original audio - [04:34:09] Multiplexing M2TS - [04:34:09] Processing: VID_00001 (2 of 2) - [04:34:09] Extracting A/V streams [VID_00001] - [04:34:55] Reencoding video [VID_00001] - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 66,922 frames - Convert: 1920x1080, 29.970fps, 66,922 frames - Bitrate: 872 Kbs - [04:34:55] Reencoding: VID_00001, Pass 1 of 2 - [04:39:33] Reencoding: VID_00001, Pass 2 of 2 - [04:44:22] Video Encode complete - [04:44:22] Multiplexing M2TS [04:44:22]PHASE ONE complete [04:44:22]PHASE TWO - Rebuild Started - [04:44:22] Rebuilding stream 00000 [1 of 2] - [04:44:22] Rebuilding stream 00001 [2 of 2] - [04:44:22] Building ALTERNATE OUTPUT Structure [04:44:36] - Failed to REBUILD -- [11:56:01] BD Rebuilder v0.39.07 (beta) - Source: AVCHD - Input BD size: 5.30 GB - Approximate total content: [02:23:57.411] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: BP MKV Container, 720x480/576, 640Kbs DD5.1 - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 - Resuming from previously started job. [11:56:05] PHASE ONE, Encoding [11:56:05]PHASE ONE complete [11:56:05]PHASE TWO - Rebuild Started - [11:56:05] Rebuilding stream 00000 [1 of 2] - [11:56:05] Rebuilding stream 00001 [2 of 2] - [11:56:05] Building ALTERNATE OUTPUT Structure [11:56:48] - Failed to REBUILD -- [12:02:39] BD Rebuilder v0.39.07 (beta) - Source: AVCHD - Input BD size: 5.30 GB - Approximate total content: [02:23:57.411] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: BP MKV Container, 720x480/576, 640Kbs DD5.1 - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 - Resuming from previously started job. [12:02:42] PHASE ONE, Encoding [12:02:42]PHASE ONE complete [12:02:42]PHASE TWO - Rebuild Started - [12:02:42] Rebuilding stream 00000 [1 of 2] - [12:02:42] Rebuilding stream 00001 [2 of 2] - [12:02:42] Building ALTERNATE OUTPUT Structure [12:03:27] - Failed to REBUILD -- [12:03:56] BD Rebuilder v0.39.07 (beta) - Source: AVCHD - Input BD size: 5.30 GB - Approximate total content: [02:23:57.411] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: BP MKV Container, 720x480/576, 640Kbs DD5.1 - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [12:04:03] PHASE ONE, Encoding - [12:04:03] Processing: VID_00000 (1 of 2) - [12:04:03] Extracting A/V streams [VID_00000] - [12:08:24] Reencoding video [VID_00000] - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 191,941 frames - Convert: 1920x1080, 29.970fps, 191,941 frames - Bitrate: 872 Kbs - [12:08:25] Reencoding: VID_00000, Pass 1 of 2 - [12:21:59] Reencoding: VID_00000, Pass 2 of 2 - [12:36:10] Video Encode complete - [12:36:10] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:36:16] Multiplexing M2TS - [12:36:16] Processing: VID_00001 (2 of 2) - [12:36:16] Extracting A/V streams [VID_00001] - [12:37:04] Reencoding video [VID_00001] - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 66,922 frames - Convert: 1920x1080, 29.970fps, 66,922 frames - Bitrate: 872 Kbs - [12:37:04] Reencoding: VID_00001, Pass 1 of 2 - [12:41:41] Reencoding: VID_00001, Pass 2 of 2 - [12:46:29] Video Encode complete - [12:46:29] Multiplexing M2TS [12:46:29]PHASE ONE complete [12:46:29]PHASE TWO - Rebuild Started - [12:46:29] Rebuilding stream 00000 [1 of 2] - [12:46:29] Rebuilding stream 00001 [2 of 2] - [12:46:29] Building ALTERNATE OUTPUT Structure [12:46:43] - Failed to REBUILD -- [14:42:31] BD Rebuilder v0.39.07 (beta) - Source: AVCHD - Input BD size: 5.30 GB - Approximate total content: [02:23:57.411] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, Auto-AAC - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [14:42:33] PHASE ONE, Encoding - [14:42:33] Processing: VID_00000 (1 of 2) - [14:42:33] Extracting A/V streams [VID_00000] - [14:46:36] Reencoding video [VID_00000] - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 191,941 frames - Convert: 1920x1080, 29.970fps, 191,941 frames - Bitrate: 3,000 Kbs - [14:46:36] Reencoding: VID_00000, Pass 1 of 2 - [16:14:29] Reencoding: VID_00000, Pass 2 of 2 - [17:41:15] Video Encode complete - [17:41:15] Processing audio tracks - Track 4352 (eng): Reencoding audio to AAC... - [17:56:20] Multiplexing M2TS - [17:56:20] Processing: VID_00001 (2 of 2) - [17:56:20] Extracting A/V streams [VID_00001] - [17:56:59] Reencoding video [VID_00001] - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 66,922 frames - Convert: 1920x1080, 29.970fps, 66,922 frames - Bitrate: 3,000 Kbs - [17:56:59] Reencoding: VID_00001, Pass 1 of 2 - [18:27:15] Reencoding: VID_00001, Pass 2 of 2 - [18:56:44] Video Encode complete - [18:56:44] Multiplexing M2TS [18:56:44]PHASE ONE complete [18:56:44]PHASE TWO - Rebuild Started - [18:56:44] Rebuilding stream 00000 [1 of 2] - [18:56:44] Rebuilding stream 00001 [2 of 2] - [18:56:44] Building ALTERNATE OUTPUT Structure [18:57:22] - Failed to REBUILD BDREBUILDER.INI [Options] VERSION=0.39.0.7 MODE=2 ENCODE_QUALITY=0 ONEPASS_ENCODING=0 AUTO_QUALITY=1 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 DEINTERLACE=1 SD_TO_1080=1 CONVERT_WIDE=0 DTS_REENCODE=1 AC3_REENCODE=1 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=0 AVCHD=0 REMOVE_WORKFILES=0 MOVIE_ONLY_LOOP=1 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 USE_LAVF=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 UNMASK_CHAPTER=0 COMPLETION_BEEP=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=10240 MOVIEONLY_TYPE=17 ALTCRF=20 ALT_TARGET=10240 ALTMETHOD=1 ALTAUTOCROP=0 AUTO_BIAS=3 TARGET_SIZE=23500 [Paths] WORKING_PATH=C:\BD_REBUILDER\WORKING PATH\ SOURCE_PATH=C:\MULTIAVCHD-WORK\DEVILS_ADVOCATE\AVCHD\ Avchd.inf [Status] LABEL=AVCHD VERSION=v0.39.07 (beta) SOURCE_SIZE=5695444992 SOURCE_VIDEO_SIZE=5695444992 TARGET_SIZE=24641536000 REDUCTION=4.32653392923859 RESIZE_1080=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=0 SUBS_TO_KEEP=all BACKUP_MODE=1 MOVIEONLY_TYPE=17 USE_LAVF=0 QUICK=0 ENCODE_STEP=0 COMPLETED=2 REBUILD_COMPLETE=0 [00000] AUDIO=1 PGS= SCAN=2 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=18145584644 NSIZE=0 FLINK=0 MLINK=0 [00001] SCAN=2 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=6495951356 AUDIO=1 NSIZE=0 FLINK=0 MLINK=0 Lastcmd.txt "C:\BD_Rebuilder\tools\x264.exe" "C:\BD_REBUILDER\WORKING PATH\WORKFILES\VID_00001.AVS" --preset superfast --bluray-compat --b-pyramid none --weightp 1 --qpmin=0 --bitrate 3000 --level 4.1 --qpfile "C:\BD_REBUILDER\WORKING PATH\WORKFILES\VID_00001.CHP" --aud --nal-hrd vbr --pic-struct --vbv-bufsize 15000 --keyint 48 --min-keyint 1 --ipratio 1.1 --pbratio 1.1 --vbv-maxrate 15000 --fake-interlaced --threads auto --slices 4 --thread-input --stats "C:\BD_REBUILDER\WORKING PATH\WORKFILES\VID_00001.AVS.264.stats" --pass 2 --output "C:\BD_REBUILDER\WORKING PATH\WORKFILES\VID_00001.AVS.264" alternate.txt (the one that I created) caption=MKV Container, 720x480/576, 640Kbs DD5.1 vBitrate=872 aBitrate=640 aType=0 vFormat=6 cType=1 And THANK YOU JDobbs for some really nice software! Last edited by BuddTX; 22nd January 2012 at 06:33. |
22nd January 2012, 07:12 | #14067 | Link |
No. That isn't the point I was making. Lots of players play BD-5/9 full backups fine. What I said was that AVCHD has many restrictions that differentiate it from standard blu-ray. For example it doesn't allow DTS audio, VC-1 or MPEG-2 video, or any BD-J... and there's a lot more.
22nd January 2012, 22:58 | #14069 | Link | |
just did about half a dozen rebuilds of the miniseries pillars of the earth. Rebuilds went succesful except for 2 things. If i choose pal output the audio was out of sync, ntsc and audio's fine. 2nd thing i noticed was that even though the output size was set to DVD-9 total size on job completion was way undersized and fits a DVD-5.
24th January 2012, 17:01 | #14074 | Link |
BUG .39.07 most recent
The option to create an ISO image is checked but GREYED OUT
HELP YOU have my email to be able to reply kctobyjoe@comcast.net |
26th January 2012, 18:56 | #14076 | Link |
jdobbs, I took your advise about deleting all the programs and the reinstalling them ( BDrebuilder, Avisynth, ffdshow, Matroska splitter), Everything worked fine. This week I went and bought Real Steel and 50/50 bluray movies, Ran both movies to my hard drive with DVDFab, Used BDrebuilder to rip Real Steel to a bd25 disk no problem, But when I went to do the same for movie 50/50 it did the same thing as last week ( x264.exe cannot continue). Seems like it will let me do 1 movie, then I have to delete everything and reinstall to continue, unless I do what I did last week (which it did work again) go into setup and enable x264's internal LAVF for decoding.
27th January 2012, 02:47 | #14077 | Link | |
If you have any CODECs or CODEC PACKS on your system -- remove them. FFDSHOW has every codec anyone should ever need. |
28th January 2012, 09:46 | #14078 | Link |
Probably not a bug, just an observation:
When I follow the route BD original => BD5 backup (movie only) => Alternate output DVD, the audio of the Alternate DVD is in some cases out of sync (up to few seconds). When I do BD original => Alternate output DVD, the audio of the Alternate DVD is in sync. So some video/audio sync info seems to get lost in the first case. |
28th January 2012, 15:04 | #14079 | Link | |
