1st November 2012, 01:03 | #16042 | Link |
Labyrinth
Hello. With "Labyrinth" the Secondary Video's DTS Express is being removed from the render for the PNP while doing a Full Backup. I cannot get BD-RB to enable it. I'm limited in my lips reading ability. HEHE!
[Options] VERSION=0.42.0.4 MULTIPROCESS=0 ENABLE_TEST=1 FORCE_NOENCODE=1 MODE=0 ENCODE_QUALITY=5 ONEPASS_ENCODING=0 AUTO_QUALITY=0 TARGET_SIZE=23500 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; SD_PROGRESSIVE=0 SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 DEINTERLACE=0 SD_TO_1080=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AVCHD=1 REMOVE_WORKFILES=0 MOVIE_ONLY_LOOP=0 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 USE_LAVF=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 UNMASK_CHAPTER=0 COMPLETION_BEEP=0 DGDECNV=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=1500 QUICK_EXTRAS=0 ENABLE_BLANKING=1 MOVIEONLY_TYPE=0 ALTCRF=20 ALT_TARGET=7900 ALTMETHOD=2 ALTAUTOCROP=0 [Paths] SOURCE_PATH=J:\!BLU-RAY RIPS\LABYRINTH\ WORKING_PATH=E:\BLU-RAY\REBUILDER\
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 1st November 2012 at 01:52. |
1st November 2012, 03:38 | #16043 | Link |
Is anyone else noticing Saved Projects aren't being applied when "Opened" again?
[Options] VERSION=0.42.0.4 MULTIPROCESS=0 ENABLE_TEST=1 FORCE_NOENCODE=1 MODE=1 ENCODE_QUALITY=5 ONEPASS_ENCODING=0 AUTO_QUALITY=0 TARGET_SIZE=23500 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; SD_PROGRESSIVE=0 SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 DEINTERLACE=0 SD_TO_1080=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=0 AVCHD=1 REMOVE_WORKFILES=0 MOVIE_ONLY_LOOP=0 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 USE_LAVF=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 UNMASK_CHAPTER=0 COMPLETION_BEEP=0 DGDECNV=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=1500 QUICK_EXTRAS=1 ENABLE_BLANKING=1 MOVIEONLY_TYPE=0 ALTCRF=20 ALT_TARGET=7900 ALTMETHOD=2 ALTAUTOCROP=0 [Paths] SOURCE_PATH=J:\!BLU-RAY RIPS\TOY_STORY_3\ WORKING_PATH=E:\BLU-RAY\REBUILDER\ [Batch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hough it looks to be saved, by the File Keep/Don't Keep (On/Off...1/0). Any thoughts? A Bug? Or is that not the purpose of BD-RB Saving a Project? Thanks.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by jdobbs; 1st November 2012 at 04:18. |
1st November 2012, 07:09 | #16045 | Link |
All video/audio/sup-titles...Agreed. Are they for you, jdobbs? ANYONE else?! BD-RB has access to those locations on my HDDs, no Errors reported when saved.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 1st November 2012 at 07:16. |
1st November 2012, 12:48 | #16047 | Link | |
The whole purpose of saving/loading a project is so you can make specific settings for a job and load it later -- without having to worry about things. But -- if you then make changes after loading that will make BD-RB reexamine the source (like, for instance, changing from Full to Movie-Only or changing one of the SETUP parameters) -- then you have just rendered the settings back to default and the information from "Load" doesn't apply any longer. You have to make sure you have 100% of the settings you want fixed before doing a "Save". With that said, I'll do some testing to make sure Load/Save of projects is working correctly. |
1st November 2012, 19:42 | #16050 | Link | |
I did notice this: QUICK_CRF=n n = 10..50 -- CRF value for "Quick Extras" encoding, defaults are BD5=30,BD9=24,BD25=20 QUICK_USE_QUALITY=n n = 0/1 - if set to 1, BD-RB will use the current quality selection for Quick CRF encodes EMOVE_OUTPUT=n n = 0/1 - 0=OFF (default) - if set to "1", the OUTPUT folder is removed after burning REMOVE_WORKING=n n = 0/1 - 0=OFF (default) - if set to "1", the WORKFILES folder is removed after rebuild Feels like an "R" should be there, hehe. Update: After adding the option, my Standalone plays the PIP with Sound but PowerDVD 12 doesn't.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 2nd November 2012 at 07:56. |
2nd November 2012, 16:22 | #16051 | Link | |
@AmigaFuture
BTW, what is the brand and model number of your standalone player (that properly processes DTS Express audio)? |
2nd November 2012, 20:13 | #16052 | Link |
@setarip_old
You have P.M.s turned off. LG BD590 with a 250GB Hard Drive. The video quality is excellent for BD, however, XviD, DivX, H.264 when played from the HDD doesn't look "as clear" from a BD/AVCHD disk or my HD TVs USB. @jdobbs Back to BD-RB. It looks and sounds to play correctly. I've not noticed any sync or jitters with PIP or Movie. I did notice that the DTS isn't re-rendered to AC3 so DTSX_ENABLE=1 is overriding rerender. Personally, that's fine as long as audio is there with video.
2nd November 2012, 21:14 | #16054 | Link | |
2nd November 2012, 23:47 | #16055 | Link |
Ok so here my log, I am having this issue with both Constantine and V for Vendetta, it seems they both crash. Any suggestions? heres my log.
I know I have everything installed correctly but my encoding keeps crashing! Heres my log: [11/2/12] BD Rebuilder v0.42.04 (beta) [07:16:19] Source: VOLUME_ID - Input BD size: 25.50 GB - Approximate total content: [03:26:52.308] - Target BD size: 23.30 GB - Windows Version: 6.1 [7601] - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [07:16:20] PHASE ONE, Encoding - [07:26:20] Processing: VID_00003 (1 of 9) - [07:26:20] Extracting A/V streams [VID_00003] - [07:26:56] Reencoding video [VID_00003] - [07:26:56] Reencoding secondary video [TRK_02] - Encode failed. Aborting. - BD-Rebuilder v0.42.03 (beta) - Windows Version: 6.1 [7601] - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: 1.9.42.1, Ok - FFDSHOW: 3882, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libmpeg2": Ok - FFDSHOW AVC set to "ffmpeg-mt": Ok - AnyDVD settings check: Ok. - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [07:59:04] - Failed video encode, aborted Last edited by Crocluvr92; 2nd November 2012 at 23:50. |
3rd November 2012, 01:25 | #16058 | Link |
@Ch3vr0n and jdobbs,
Thank You for the Enlightening information.. Ahhhh...Now I know why BD-RB didn't.
