4th August 2019, 07:51 | #301 | Link |
well, I think F3KDB_3 is stable now, hope there are no bugs left
======== F3KDB_3 updates and features difference from F3KDB:- 1- sample_mode 3 and 4 (4 is the Default) 2- new pass parameter (2 is Default if sample_mode = 4) 3- new chroma parameter 4- work with HBD and old lsb/interleaved hack and all avs/avs+ Versions ======= if you use it without chroma=false or still using avs 2.5 you need flash3kyuu deband 1.5.1:- x86 / x64 if you use it with chroma=false and avs 2.6 / avs+ then you need f3kdb-b98d6bc in Attachments if you use it with old lsb/interleaved hacks then you will need dither tools and HDRCore (in Attachments) ========= note:- if F3KDB() added sample_mode 3 and 4 and pass parameter and others then this function will update to take that into account since coding those in dll will make them faster ====== download:- this is a old one, see the 1st OP post pastebin and in Attachments ===== Samples:- with this using ConvertBits(16).F3KDB_3(pass=4).ConvertBits(8, dither=1) ------- with this (got it from here) F3KDB() /// F3KDB_3() Hqdn3d_2().F3KDB() /// Hqdn3d_2().F3KDB_3() edit: see this post for last update info
See My Avisynth Stuff Last edited by real.finder; 23rd March 2020 at 22:43. |
4th August 2019, 11:00 | #302 | Link |
What is the difference between f3kdb-b98d6bc and flash3kyuu 1.5.1 or v2.0pre?
EDIT: Only avs 2.5 compatibility?
4th August 2019, 12:14 | #303 | Link |
flash3kyuu 1.5.1 has bug with Y8 and input_mode > 0, I think 2.0pre fix that, but f3kdb-b98d6bc was the last one by SAPikachu (2.0pre may has some bugs that fixed in b98d6bc but the main reason is b98d6bc has x64 and x86 while 2.0pre is only x86)
See My Avisynth Stuff |
4th August 2019, 13:12 | #304 | Link |
And is this version (F3KDB Version 2.1 with native high bit depth) supported? https://forum.doom9.org/showthread.php?t=176553
4th August 2019, 16:42 | #305 | Link | ||
and above Quote:
6th August 2019, 08:59 | #306 | Link |
new update for F3KDB_3 in the same post above
new masking parameter (true by default) with mask_thr and mask_radius parameters that make it act like f3kdbmod16 / flash3kyuuMOD16 edit: new parameter added (bool lastpassmask) edit: test sample with the same things here https://forum.doom9.org/showthread.p...77#post1880477 but with smam(filter=daa3mod(slow=4)) instead of smam(filter=daa3mod()), with all scripts updates until today https://i.imgur.com/TQkDvyO.png edit: new F3KDB_3_adg https://pastebin.com/e196hcN9 (not part of Advanced Denoising.avsi)
See My Avisynth Stuff Last edited by real.finder; 13th August 2019 at 04:55. |
18th August 2019, 21:01 | #308 | Link | |
anyway you can copy the missing functions (like AvsPlusVersionNumber) from SMDegrain in any script you use
See My Avisynth Stuff Last edited by real.finder; 18th August 2019 at 21:23. |
26th August 2019, 20:01 | #310 | Link |
DeHaloHmod
new update for DeHaloHmod https://pastebin.com/mGRFQjje
now can work with minideen and still can work with old deen if minideen not present edit: it's not work with minideen yet https://forum.doom9.org/showthread.p...58#post1883458 it will use old deen until this fixed edit: it's fixed in r3 and r4 of minideen
See My Avisynth Stuff Last edited by real.finder; 13th September 2019 at 01:24. |
6th September 2019, 18:24 | #311 | Link |
from https://forum.doom9.org/showthread.php?p=1884083
I haven't switched to 64 bit AviSynth+ because when I did my testing RAM went up over 90% on my single 8 GB RAM, so I planning to buy another 8 GB RAM as I use the same computer to do stuff while I wait for encode to finish. Also, when I tried to use it on 32 bit AviSynth+ it would say this on avspmod: "I don't know what 'AvsPlusVersionNumber' means C:\ path\plugins\ResizeX_v1.0.1_mod 9.avsi, line 70 C:\ path\plugins\DebilinearM_v1.3.1_mod_1.25.avsi, line 76" So I just went back to how I did it normally till I get to 64 bit. On 64 bit AviSynth+ I can't use it without the lsb hack because when I use ConvertBits(bits=16) or ConvertBits(bits=32) with Code:
ly = DebilinearM(1280,544,thr=01,lsb_inout=true, DeResizeMT=true) lc = nnedi3_resize16(1280*2, 544*,lsb_in=true,lsb=true,kernel_d="Spline64",kernel_u="Spline64",src_top=0.0,src_left=0.50) lu = lc.UtoY() lv = lc.VtoY() YtoUV(lu,lv,ly) "lsb hack is not Compatible with native high bit depth C:\ path\plugins64+\ResizeX_v1.0.1_mod9.35.avsi, line 79 C:\ path\plugins64+\DebilinearM_v1.3.1_mod1.25.avsi, line 87" It works fine if I use the lsb hack dither_convert_8_to_16() You should be how to do it like that tho? Remember? https://forum.doom9.org/showthread.p...23#post1879523 Same thing when I use Gradfun3mod with HBD Code:
ly = GradFun3mod(thr=0.35, smode=2,thr_det=2,elast=4,mode=6, yuv444=true, resizer="DebilinearMTM", lsb_in=true, lsb=true) lc = nnedi3_resize16(1280*2, 720*2,lsb_in=true,lsb=true,kernel_d="Spline64",kernel_u="Spline64",src_top=0.0,src_left=0.50) lu = lc.UtoY() lv = lc.VtoY() YtoUV(lu,lv,ly) "ConvertToYV411: 8 bit only C:\ path\plugins64+\GradFun3mod 3.1.avsi, line 176" Works fine if I use the lsb hack dither_convert_8_to_16() for this too. You showed me to do it this way also, https://forum.doom9.org/showthread.p...09#post1879909 Can you show me how to do it properly cuz I don't get it as you know I'm still new to this HBD thing as I am so use to using the lsb hack. If you know how to could you edit those posts above to include the HBD please leave lsb hack too. On 32 bit AviSynth+ version I can't get around the thing it says that it doesn't know what AvsPlusNumber is. So until I get that RAM I can't use your scripts till I switch to 64 bit version and buy another 8 GB RAM. Or maybe I'm missing something again? Last edited by dREV; 6th September 2019 at 18:35. Reason: stuff |
6th September 2019, 19:38 | #312 | Link | |||
ConvertBits(bits=16) ly = DebilinearM(1280,544,thr=01, DeResizeMT=true) lc = edi_rpow2(1280*2, 544*2,cshift="Spline64",src_top=0.0,src_left=0.50) lu = lc.ExtractU() lv = lc.ExtractV() YtoUV(lu,lv,ly) Code:
ConvertBits(bits=16) #if it not 16 HBD already ly = ConvertToStacked().GradFun3mod(thr=0.35, smode=2,thr_det=2,elast=4,mode=6, yuv444=true, resizer="DebilinearMTM", lsb_in=true, lsb=true).ConvertFromStacked() lc = edi_rpow2(1280*2, 720*2,cshift="Spline64",src_top=0.0,src_left=0.50) lu = lc.ExtractU() lv = lc.ExtractV() YtoUV(lu,lv,ly)
See My Avisynth Stuff Last edited by real.finder; 6th September 2019 at 20:45. |
7th September 2019, 00:08 | #313 | Link |
Noob
nnedi3 resize16 and gradfun dont support HBD i think. you can try like this
Dither_convert_8_to_16() or ConvertBits(16).ConvertToStacked() Nnedi3_resize16(lsb_in=true, lsb=true) GradFun3mod(lsb_in=true, lsb=true) DitherPost(mode=0) or ConvertFromStacked().ConvertBits(8 or 10, Dither=0) |
9th September 2019, 18:00 | #314 | Link |
days ago I start read how Nnedi3_resize16 work to either make it work with HBD or add its features to edi_rpow2, and find it use Dither_limit_dif16, first time I didnt think of it can be replaced with something else, and there are SmoothAdjust but seems it only for tvrange vs full range things, then I start study Dither_limit_dif16 and find it work almost same as my sBlackerPixel and swhiterPixel, so I use them as a base to simulate Dither_limit_dif16 and it seems work!
# base on Dither_limit_dif16 idea (not 100% same output) function slimit_dif(clip "flt", clip "src", clip "ref", float "thr", float "elast", int "Y", int "U", int "V", bool "elastinfl") { thr = default(thr, 0.25) elast = default(elast, 3.0) elast2 = elast > 1.0 ? elast * thr : elast Y = default(Y, 3) U = default(U, 3) V = default(V, 3) elastinfl = default(elastinfl, false) Assert(!(elast < 1), "slimit_dif: elast must be more than 1") Assert((defined(flt) && defined(src)), "slimit_dif: both flt clip and src clip are needed") ldmask = elast!=1 ? VersionNumber() < 2.6 ? mt_lutxy(defined(ref) ? ref : src,flt,"x y - abs "+string(thr)+" <= 255 x y - abs "+string(elast2)+" <= ? 255 255 "+string(elast2)+" / x y - abs * - 0 ?", Y=Y,U=U,V=V) \ : mt_lutxy(defined(ref) ? ref : src,flt,"x y - abs "+string(thr)+" scalef <= range_max x y - abs "+string(elast2)+" scalef <= ? range_max range_max "+string(elast2)+" scalef / x y - abs * - 0 ?", Y=Y,U=U,V=V,use_expr=2) : nop() elast!=1 ? VersionNumber() < 2.6 ? smaskmerge(src,flt, elastinfl ? ldmask.mt_inflate(155) : ldmask, Y=Y,U=U,V=V) : Mt_Merge(src,flt, elastinfl ? ldmask.mt_inflate(155) : ldmask, Y=Y,U=U,V=V) : \ VersionNumber() < 2.6 ? defined(ref) ? ref.mt_lutxyz(flt,src,"x y - abs "+string(thr)+" <= y z ?", Y=Y,U=U,V=V) : src.mt_lutxy(flt,"x y - abs "+string(thr)+" <= y x ?", Y=Y,U=U,V=V) \ : defined(ref) ? ref.mt_lutxyz(flt,src,"x y - abs "+string(thr)+" scalef <= y z ?",use_expr=2, Y=Y,U=U,V=V) : src.mt_lutxy(flt,"x y - abs "+string(thr)+" scalef <= y x ?",use_expr=2, Y=Y,U=U,V=V) } but as it process choma, avoid use it with float clip if you process choma for now, I will add it in Advanced Denoising.avsi soon so any update will be in Advanced Denoising.avsi not the code above
See My Avisynth Stuff Last edited by real.finder; 11th September 2019 at 02:37. |
12th September 2019, 10:50 | #315 | Link |
posted another one https://forum.doom9.org/showthread.p...73#post1884673...
I've put in SMDegrain.avsi and trying out Code:
ConvertBits(bits=16) ly = DebilinearM(1280,544,thr=01, DeResizeMT=true) lc = edi_rpow2(1280*2, 544*2,cshift="Spline64",src_top=0.0,src_left=0.50) lu = lc.ExtractU() lv = lc.ExtractV() YtoUV(lu,lv,ly) Script error: edi_pow2 does not have a named argument "src_top" So I went and edited the edi out to, edi_rpow2(1280*2, 544*2,cshift="Spline64"). Now gives a new error edi_rpow2: rfactorX must be a power of 2 (C:\path\plugins\edi_rpow2+ v1.0 mod 7.avsi, line 205) ...... So tried the other one you put using Code:
ConvertBits(bits=16) #if it not 16 HBD already ly = ConvertToStacked().GradFun3mod(thr=0.35, smode=2,thr_det=2,elast=4,mode=6, yuv444=true, resizer="DebilinearMTM", lsb_in=true, lsb=true).ConvertFromStacked() lc = edi_rpow2(1280*2, 720*2,cshift="Spline64",src_top=0.0,src_left=0.50) lu = lc.ExtractU() lv = lc.ExtractV() YtoUV(lu,lv,ly) Gradfun3mod: wrong resizer value. (C:\path\plugins\GradFunmod.avsi, line 187) I've got all your scripts Import("C:\path\plugins\SMDegrain+ v.3.1.2.104s.avsi") Import("C:\path\plugins\edi_rpow2+ v1.0 mod 7.avsi") Import("C:\path\plugins\ResizeX+_v1.0.1_mod 9.35.avsi") Also, not sure if I like having to give up my friend, nnedi3_resize16() yet. |
12th September 2019, 16:26 | #316 | Link |
sorry, I didn't note that edi_pow2 does not have src_top, so I will try add it in edi_pow2 or port the nnedi3_resize16 to support HBD
and it need to be like this edi_rpow2(fwidth=1280*2, fheight=544*2,cshift="Spline64") to work but will not give right output in your case since there are no src_top and about "Gradfun3mod: wrong resizer value." are you sure you use the MT edit I did of Gradfun3mod?
12th September 2019, 22:48 | #317 | Link | |
Sorry I forgot to add your modded GradFun3mod, I didn't see it on your Avisynth script page, so had to look around but found them again, https://forum.doom9.org/showthread.p...09#post1879909.
Got errors though Code:
ConvertBits(bits=16) #if it not 16 HBD already ly = ConvertToStacked().GradFun3mod(thr=0.35, smode=2,thr_det=2,elast=4,mode=6, yuv444=true, resizer="DebilinearMTM", lsb_in=true, lsb=true).ConvertFromStacked() lc = edi_rpow2(1280*2, 720*2,cshift="Spline64") lu = lc.ExtractU() lv = lc.ExtractV() YtoUV(lu,lv,ly) (C:\path\plugins\edi_rpow2+ v1.0 mod 7.avsi, line 205) Then I put in the other one you told me to write instead but got errors too Code:
ConvertBits(bits=16) #if it not 16 HBD already ly = ConvertToStacked().GradFun3mod(thr=0.35, smode=2,thr_det=2,elast=4,mode=6, yuv444=true, resizer="DebilinearMTM", lsb_in=true, lsb=true).ConvertFromStacked() lc = edi_rpow2(fwidth=1280*2, fheight=544*2,cshift="Spline64") lu = lc.ExtractU() lv = lc.ExtractV() YtoUV(lu,lv,ly) But I forgot had to change edi_rpow2(fwidth=1280*2, fheight=544*2,cshift="Spline64") to edi_rpow2(fwidth=1280*2, fheight=720*2,cshift="Spline64") and it worked because of how GradFun3mod is strict as it forces to use only 1280x720 resolution and won't allow any another resolution. So for sources where I have to crop (like the one I been having trouble on) I need to use DebilinearM or something else. When I use some functions of edi_rpow2 to use the functions of nedi3_resize16() specifically nsize=6,pscrn=4,qual=2,etype=0 seems the screenshots I take became smaller instead of be the same or increase. Odd but I found the culprit to be pscn= when using "3" or "4" but using "1" and "2" do fine. The nnedi3 documentation Quote:
-------------------------------------------------------------------------------- I'm playing around with the HBD with your modded Gradfun3mod and having major issues with implementing certain functions such as f3kdb(Y=65,Cb=65,Cr=65,grainY=65,grainC=65,mt=true,input_depth=16,output_depth=16) Dither_add_grain16() And I'm certain other filters that I need after resizing but basically majority of my scripts is centered around the lsb hack. It's slow trying to transition to HBD. I think I read that these filters can't use HBD and I also use s16 = last s16.Dither_limit_dif16 (last, thr=, elast=) before I resize and cannot figure out how to implement this or even if I can do it in the first place with HBD. How can i replace lsb with hbd on clean sources Code:
#sometimes use 8 bit filter(s) here dither_convert_8_to_16() s16 = last DitherPost() Turn. #sometimes line darkening filter #anti-aliasing filter.Turn dither_convert_8_to_16() s16.Dither_limit_dif16 (last, thr=0.25, elast=4.0) SmoothGrad() # resizer 4:4:4 DebilinearM or GradFun3mod # grain filter # if not using gradfun3mod resizer I use banding filter here Dither_out() Thanks for your time in helping me out and trying to work out the other stuff. I also noticed how fast the resizer is with HBD and took less RAM on [iavspmod[/i] really interested if can get this to work completely. Can you help me out on the AddBorders() question too if you don't mind? Have issues with H264 but it works fine with HEVC. https://forum.doom9.org/showthread.p...73#post1884673 Last edited by dREV; 13th September 2019 at 00:39. Reason: forgot important details |
13th September 2019, 01:04 | #318 | Link |
the edit I did for Gradfun3mod not for HBD, because it use "dither tools" or better call it "lsb or Stacked tools" and it not work with HBD ofc, so you can't mix "dither tools" things with HBD or bad things happen unless you use http://avisynth.nl/index.php/ConvertStacked
about x264, you must ask someone else, anyway try put ConvertFromDoubleWidth() after Dither_out() and it will output native (HBD) 16 bit and remove --input-depth 16 (like you encode 8 bit clip)
13th September 2019, 02:31 | #319 | Link | |
Didn't you say you can't mix dither tools with HBD? Dither_out() is part of the dither tools. Well I tried what you said Code:
ConvertBits(bits=16) #if it not 16 HBD already ly = ConvertToStacked().GradFun3mod(thr=0.35, smode=2,thr_det=2,elast=4,mode=6, yuv444=true, resizer="DebilinearMTM", lsb_in=true, lsb=true).ConvertFromStacked() lc = edi_rpow2(fwidth=1280*2, fheight=720*2,cshift="Spline64") lu = lc.ExtractU() lv = lc.ExtractV() YtoUV(lu,lv,ly) Dither_out().ConvertFromDoubleWidth() ConvertFromDoubleWidth: Input double width clip must be YV12, YV16, YV24, Y8, RGB24 or RGB32 I've tried manipulating around that and ConvertToStacked and I just can't figure it out.... I'm about to give up on this HBD thing. There's not enough information to the documentation nor examples for me to customize it like I did for lsb hack that came with the dither tools. If I can't get around this HBD to use other filters there's really no point. Sorry for wasting your time with me on that. --------------------------------------------------------------------------------------------------- Also, I found something odd. I have some screenshot sample results of the same frame. With DebilinearM: DebilinearM (original script) 709 KB DebilinearM (your version) 764 KB With Gradfun3mod() I get: Gradfunmod3 (original script) 794 KB Gradfunmod3 (your version) 761 KB Changed both the original and your version's thr from "01" instead of default "10" in the DebilinearM.avsi script as it gives too much sharpness creating halos. They also are using the lsb version not the HBD. I've manipulated scripts around and eliminating what may be the reason why it gives low output and it seems to be your modded version of nnedi3_resize16_v3.3. Everything else was the same file size except when I used that script it would go down and that one only. Latest screenshots results were using GradFun3mod original 781 kb your version 755 kb In addition when I use GradFun3mod(thr=0.35, smode=2,thr_det=2,elast=4,mode=6, yuv444=true, resizer="DebilinearM", lsb_in=true, lsb=true) file size is high (781 kb) but when I switch to GradFun3mod(thr=0.35, smode=2,thr_det=2,elast=4,mode=6, yuv444=true, resizer="DebilinearMTM", lsb_in=true, lsb=true) it goes down (to 755 kb) both using the original nnedi3_resize16_v3.3 script. However, even when I use your modded nnedi3 version together with both functions of Gradfun3mod they still give results 755 kb. Only when returning to the original nnedi3 script does it return to normal as well as using the original GradFun3mod function. All of this was using your updated scripts from ResizeX v1.0.1 mod 9.35, edi_rpow2 v1.0 mod 7, Gradfun3mod r6 mod 3.1, DebilinearM v1.3.1 mod 1.25, etc Seems the original Gradfun3mod output has increased detail moreso then with both the original and your version of DebilinearM also. What you think? Last edited by dREV; 13th September 2019 at 03:43. Reason: typos |
13th September 2019, 05:41 | #320 | Link |
I think you need to know the basic of what lsb (aka dither tools things aka Stack16) and what is HBD in avs+, why don't you read the wiki link I post many many times?!!! they can't be mixed UNLESS with http://avisynth.nl/index.php/ConvertStacked (the link you don't read or don't understand its content every time) and btw you already mixed both (even without ConvertFromDoubleWidth by using Dither_out with HBD input so the output will be 100% wrong indeed) but in wrong way
do not expect getting a result identity by 100% matching if the script or the used plugins or even the avs changed/updated, and that normal since the edit I did for GradFun3mod and DebilinearM will use yet another plugins away from original Debilinear.dll and my edit of nnedi3_resize16 in avs+ even with lsb it will use some HBD features to get real 16bit as possible since nnedi3_resize16 with lsb don't do real 16 bit proccess in first place since nnedi3 don't has lsb support, so yes without set the nlsb in nnedi3_resize16 to false in avs+ you will get a different result and it should be a better
See My Avisynth Stuff Last edited by real.finder; 13th September 2019 at 06:31. |
avisynth, avs script, avs+, banding, generator, hbd, mod |
