4th September 2012, 20:35 | #12101 | Link |
When I change subtitle language, the video pauses for half a second. Doesn't matter much as I don't often change subs mid-film (=)), but why does this happen?
LAV-everything + MPC-HC + madVR. |
4th September 2012, 20:40 | #12102 | Link |
I'm having a small problem with MPC-HC with Lav Filters with i3-2100 when trying to playback a MKV made from a NTSC TV Show episode ripped with MakeMKV, it's mpeg2 9000kbps and DD 2.0 audio, when I playback it seems fine but when move the mouse to the bottom to get the seekbar, instead of the seekbar I get the bottom inch of the picture froze (The rest still plays fine) and then the mouse does not do anything, I have to ctrl-alt-delete to get out of it.
Same thing happens if I try and right click, it freezes. I have tried DXVA on and off, its still the same, any suggestions? Blu-ray are fine! |
4th September 2012, 20:40 | #12103 | Link | |
契約者
@nev Btw what if for example I use cuvid or dxva cb on nvidia but sending result to iGPU (using LucidVirtu)? Or the other way, if I decode via quicksync but then sending stuff to discrete GPU? Would it mean that with this approach bandwidth requirement will be split between GPUs? |
4th September 2012, 20:47 | #12105 | Link | |
This means no MadVR, limited CUVID (max 30fps), limited interlacing,... Last edited by Pat357; 4th September 2012 at 22:01. |
4th September 2012, 21:00 | #12106 | Link |
契約者
No madvr, deinterlacing or anything else - sure. I never said you can have this all (I never even do realtime deinterlacing or play interlaced streams at all). They can do 24-30fps cuvid, this is all I care about and this all I say. (EDIT: not sure about any OEM cards though)
4th September 2012, 21:18 | #12108 | Link | ||
It would be possible to avoid that, however the problem is that streams are read-ahead and buffered a bit, so if you change the stream without doing the pause and reset buffers dance, it might take a bunch of seconds until the switch occurs. You can see that with Gabest, if you switch now, it takes a while until it actually changes (more obvious with audio), i prefer an instant switch with a small playback glitch. Quote:
I would be very careful with that card. Going the lowest you can find that might potentially still work is not a strategy i would generally recommend.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 4th September 2012 at 21:31. |
4th September 2012, 23:30 | #12109 | Link | |
Im guessing this is more of an academic point you're making; which is understandable.
From a practical/real-life point... it's a little amusing. I've never had to worry about "bandwidth" when playing back standard BD discs; even on my 6 year old PC. PowerDVD works just fine; with a little help from Reclock, the picture is on par with my 24P capable standalone device; at least my eyes can't tell the difference. I've upgraded my display adapter since 2006; more than once.. But, it wasn't because of 2D bluray playback. I do enjoy watching 3D bluray though very much with my GT640 display card. Quote:
5th September 2012, 11:27 | #12112 | Link | |
5th September 2012, 11:42 | #12113 | Link | ||
I know its not an huge issue, but it would be nice to get it working 100%, users could report troublesome discs and what the correct playlist should be, then it could be added to a list of some kind. Not sure if this is even possible ? I'd be happy to maintain a list of some kind. |
5th September 2012, 14:04 | #12114 | Link |
You can simply run the appropriate mpls file from the PLAYLIST folder, instead of the index.bdmv.
LAV does not save such information, and it never will.
5th September 2012, 15:11 | #12115 | Link |
If the splitter ever gets a tray icon, it could show the available playlists in there.
MPC-HC 2.2.1 |
5th September 2012, 15:19 | #12116 | Link |
Nevcairiel, any chance you could try the subtitles surface overlay on DXVA, it would be a nice feature for us that use subtitles and prefer to use DXVA.
Windows 10 Pro 2004 with Media Center, 2 x DVB-C with cable cards MPC-HC (madVR, LAV Filters, XySubFilter) Sony Bravia 85X950H/85XH95 Yamaha RX-V685 Yamaha Piano Black NS-777/555/C444/YST-SW315 Last edited by Joniii; 5th September 2012 at 15:23. |
5th September 2012, 15:42 | #12118 | Link | ||
I will never write a dvd navigator or anything crappy like that. Video support is still planned, but its annoying, and i don't watch DVDs, so its a low priority.
5th September 2012, 15:56 | #12119 | Link | |
So is it not possible for LAV to ever work 100% correctly with all Blu-ray discs? Or is it possible in the future maybe? Edit: The main reason I'm asking is I noticed AnyDVD HD seems to always show the correct playlist in its status window (On all my discs anyway) I'm just wondering what it does differently to determine that. Last edited by ddjmagic; 5th September 2012 at 16:05. |
5th September 2012, 16:06 | #12120 | Link |
@ddjmagic
You can try mediaportal (don't want to push it lol or maybe a little) but with bdhandler plugins, you get a selection list and with 1.3.0Alpha MP has a native Blu-ray player (working with non BD-J one and best user experience with LAV Suite (Thanks Nevcairiel)).
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355. |
