19th November 2017, 14:38 | #5721 | Link |
It's not always enough -- the patch https://patches.videolan.org/patch/15688/ is forgotten, x265cli.h has changed and now this patch doesn't apply cleanly.
19th November 2017, 19:10 | #5722 | Link |
I'm just trying to encourage participation. Sure, ideally we'd love patches to be in the right format, able to be applied cleanly to the latest development tip. But for our documentation, we can certainly handle an email to the developer mailing list with your suggested update to the documentation for a particular feature. Our team can figure out how to turn this into the official patch. Developing x265 is a big job... but this is open source, so we want to encourage participation.
Ma - I'm sorry if something was missed. We'll check into it. |
20th November 2017, 08:57 | #5724 | Link |
Not speaking for the developers, just my personal guess: I would not expect a revolution anymore, at least in the home consumer area (8-10 bit depth), rather evolution - at most finetuning. "Miracle time" is over, the HEVC specs indicate the range of algorithms which can be used (how to search for redundancies to spare and how to encode the video stream efficiently), and "revolutionary" improvements may not be supported by HEVC specs anymore (but there is e.g. AOMedia AV1). The biggest change I hope for would be integration of libav and AviSynth input modules.
But I could imagine room for more features for professional and specific "niche" usage cases. And of course, steady improvements of speed-up technologies, from more assembly to smarter algorithms in depth. |
20th November 2017, 10:04 | #5725 | Link | |
20th November 2017, 11:50 | #5726 | Link |
x265 2.5+65-a7c2f80c18af
Disable opt-qp-pps and opt-ref-list-length-pps by default; use AVC CU analysis data in anlysis-reuselevel 7 and 8; update an outdated help message for --bframes |
21st November 2017, 12:43 | #5727 | Link |
Should have waited one more day...
x265 2.5+66-dae558b40d99 merge with stable + fixed compiler warning (parentheses) Milestone v2.6 is in sight! _ P.S.: The compilation of x265 will switch from YASM to NASM (min. v2.13); I wonder which were the main reasons: Instruction set support, compilation efficiency, bugs? Last edited by LigH; 21st November 2017 at 13:37. |
21st November 2017, 14:05 | #5729 | Link |
For the record, x264 did the same switch some weeks ago for the same reason.
23rd November 2017, 10:44 | #5730 | Link |
Yasm is more or less EOL. No real development anymore. I also read once that YASM would need a rewrite to support AVX-512. So not going to happen anytime soon.
Some quotes from the x264 mailing list: "Yes, but I don't see anyone willing to add support for AVX-512. the entire instruction syntax is different so it's a lot of work. I have 0 hope of yasm ever getting avx-512 support since the instruction encoding is completely different from the old stuff, so it'd be tons of work to add it. Yes. Yasm is essentially dead. Nasm is actively maintained. Intel adds support to all new instruction sets to nasm themselves." |
23rd November 2017, 10:47 | #5731 | Link |
Its unfortunate that nasm still suffers from a bunch of shortcomings that yasm didn't have. But maybe there is hope they'll fix it .... after all the years?
25th November 2017, 19:32 | #5734 | Link |
I wouldn't be surprised if the most useful instructions for encoding in x265 aren't in the supported feature sets of the mainstream processors. AVX-512 is broken down into several feature sets, only required one is foundation. Heavy AVX-512 use may also be am issue thermal wise but that remains to be seen.
26th November 2017, 00:42 | #5736 | Link | |
Who knows why they split it up like this, maybe in the future there will be CPUs with smaller subsets, but right now the one "mainstream" CPU core that supports it supports all of the relevant things. But its also the first SIMD instruction set that was built "extensible" like this, previously we got AVX2 to extend AVX1 with integer instructions, now we get AVX512-BW/DQ On that note, its already confirmed that Cannonlake and Icelake will only extend the current AVX512 instructions, and not take away features again. Of course no-one knows what happens if AMD ever implements AVX512. The bigger problem with AVX512 is the thermal behavior and as such the downclocking it entails. So for AVX512 to be worthwhile to be used, you need to spend a significant amount of time doing AVX512 things, or the downclocking will slow down other things more then the AVX512 helps. I believe the x265 developers have had experience with this with AVX2 in the past, which also causes a downclock to some degree, although with more optimized nodes that effect has gone down in newer CPUs.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 26th November 2017 at 00:51. |
26th November 2017, 03:34 | #5737 | Link | ||
28th November 2017, 05:11 | #5738 | Link | ||
28th November 2017, 08:27 | #5739 | Link |
Partially ... more efforts don't guarantee better quality retention in every case (objective vs. subjective metrics). I would prefer increasing the bitrate over passing a "threshold of sanity" (which would be somewhere near preset "slower" for me, personally; provided I had potent hardware).
29th November 2017, 06:41 | #5740 | Link |
x265 version 2.6 is now out! The key new improvements include support for segmented encoding, and introducing the ability of x265 to reuse and refine analysis from previously done HEVC and AVC encodes. The tarball of this release can be downloaded from the downloads page.
Release date - 29th November, 2017. ============================ New features ------------------ 1) x265 can now refine analysis from a previous HEVC encode (using options --refine-inter, and --refine-intra), or a previous AVC encode (using option --refine-mv-type). The previous encode’s information can be packaged using the x265_analysis_data_t data field available in the x265_picture object. 2) Basic support for segmented (or chunked) encoding added with --vbv-end that can specify the status of CPB at the end of a segment. String this together with --vbv-init to encode a title as chunks while maintaining VBV compliance! 3) --force-flush can be used to trigger a premature flush of the encoder. This option is beneficial when input is known to be bursty, and may be at a rate slower than the encoder. 4) Experimental feature --lowpass-dct that uses truncated DCT for transformation. Encoder enhancements -------------------------------- 1) Slice-parallel mode gets a significant boost in performance, particularly in low-latency mode. 2) x265 now officially supported on VS2017. 3) x265 now supports all depths from mono0 to mono16 for Y4M format. API changes ----------------- 1) Options that modified PPS dynamically (--opt-qp-pps and --opt-ref-list-length-pps) are now disabled by default to enable users to save bits by not sending headers. If these options are enabled, headers have to be repeated for every GOP. 2) Rate-control and analysis parameters can dynamically be reconfigured simultaneously via the x265_encoder_reconfig API. 3) New API functions to extract intermediate information such as slice-type, scenecut information, reference frames, etc. are now available. This information may be beneficial to integrating applications that are attempting to perform content-adaptive encoding. Refer to documentation on x265_get_slicetype_poc_and_scenecut, and x265_get_ref_frame_list for more details and suggested usage. 4) A new API to pass supplemental CTU information to x265 to influence analysis decisions has been added. Refer to documentation on x265_encoder_ctu_info for more details. Bug fixes ------------- 1) Bug fixes when --slices is used with VBV settings. 2) Minor memory leak fixed for HDR10+ builds, and default x265 when pools option is specified. 3) HDR10+ bug fix to remove dependence on poc counter to select meta-data information. Happy compressing! |
