Old 7th May 2017, 01:21   #1181  |  Link
BakaProxy
@Khanatila, I think I found a(n edge case) bug.
http://screenshotcomparison.com/comparison/209076
(If it's not obvious, check the black smudge at the top.)
This happens with bigger a values (9 on this example on a 480p clip) and If I recall correctly knlmeanscl internally pads the video clip, so I think that this is just the black padding leaking into the image. (if so, maybe you could mirror instead?)
Though this is just my hypothesis, feel free and I'd love you to prove me wrong.
As for the data on this specific scenario they're in the screenshot using info=true, if more is necessary I'm ready to provide such.
BakaProxy is offline   Reply With Quote
Old 12th May 2017, 23:01   #1182  |  Link
Logan9778
Hey guys, I'm new to all this GitHub stuff. How would you compile the code for KNLMeansCL to get the .dll file in Windows 10 ( I use AviSynth )?
Logan9778 is offline   Reply With Quote
Old 12th May 2017, 23:17   #1183  |  Link
Groucho2004
Why do you feel the need to compile it if there are perfectly adequate releases?
Groucho's Avisynth Stuff
Old 12th May 2017, 23:36   #1184  |  Link
Khanattila
Khanattila's Avatar
Originally Posted by dipje View Post
@Khanattila:
A bit off topic, but on your Github I see an old project KPassFilterCL. Do I see correctly that it's Avisynth only? I tried using it in Vapoursynth through the core.avs.LoadPlugin stuff, and it appears to be working. I use fmtconv routines to convert 16bit Vapoursynth to avisynth's "stacked" format, then use the routines from KPassFilterCL with their 'lsb_inout' set to True. This works OK (I guess) for 'mode = magnitude' but seems to only produce black output when 'mode = phase' ? If I switch to 8bit I do suddenly get output.
Can you explain a bit of it? I'm trying to separate an image into multiple images based on frequeny content (or wavelets maybe?), to apply different filtering to different frequency-ranges and then merge it all back into a single image. KPassFilterCL seems to be made for that but I'm not sure if that's going to work or if I'm using it wrong.
With the 'low pass' routine I'm trying to get, well, only low-frequency content, which I expect to be a very blurry picture (I'm talking about a grayscale luminance only clip BTW), but in brightness / contrast / levels to be pretty much the same as the starting image.
But I only seem to get very dark output, when I change the 'cutoff' parameter the image starts to look more like the original in brightness / contrast, but also less blurry, so more high-freq content is getting in .
Is it normal that the cutoff parameter seems to require very high values (as in over 250000.0) to do something?
And if I would want to split an image into three parts, very blurry parts (almost no details, low-frequency), course details (mid-frequency) and small (micro) details (high frequency) can I do that with this plug? If so, could you give an example?
Sorry if I did not answer you first but that filter was born almost for fun and I never optimized or improved its effectiveness.
If you really want to use it for something I have to check it for a moment, because I really do not remember what all the functions do.
github.com
Khanattila is offline   Reply With Quote
Old 12th May 2017, 23:40   #1185  |  Link
Khanattila
Khanattila's Avatar
Ok, this is bug maybe. I have to check. Or maybe I did it, since the version you use is old.
github.com
Old 13th May 2017, 00:21   #1186  |  Link
Logan9778
Why do you feel the need to compile it if there are a perfectly adequate releases?
Ahh, thanks, I didn't see the zip had the .dll inside it.
Old 27th May 2017, 16:48   #1187  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Originally Posted by MysteryX View Post
With this simple code, it produces random results and mixes frames together. I can't believe I went to long without realizing it.
It fails when running as MT_SERIALIZED. The only MT mode that works is MT_MULTI_INSTANCE -- which isn't ideal for this type of filter.
For the records, this is probably due to this bug in Avisynth+ with MT_SERIALIZE
https://forum.doom9.org/showthread.p...03#post1807903
MysteryX is offline   Reply With Quote
Old 9th June 2017, 00:03   #1188  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
This doesn't work in 16-bit
ConvertToYV24()
ConvertBits(16)
KNLMeansCL(D=2, A=2, h=1.5, channels="YUV")
KNLMeansCL: 'channels = YUV' require a YV24 pixel format!
Old 13th June 2017, 17:54   #1189  |  Link
Khanattila
Khanattila's Avatar
ConvertToYV24()
ConvertBits(16)
I am very busy so I do not have time now, but I notice your reports
github.com
Old 17th June 2017, 06:52   #1190  |  Link
goorawin
KNLMeansCL 64bit suddenly not loading
I have been using KNLMeansCL 64bit for sometime without problems on windows10 pro with a GeForce GTX 650 graphics card.
Now after some major windows updates, it no longer works in 64 bit. It will not load the plugin and comes up with the error “there is no function named KNLMeansCL”. I have tried a number of versions of KNLMeansCL (including v1.1.0) but all have the same problem. All other 64bit plugin work as they should. Even xnlmeans works which I assume is not much different to KNLMeansCL except for GPU usage.
Interestingly the32 bit version of KNLMeansCL works just fine, so what's the difference?.
The other interesting thing is that, on another windows 10 pro computer with an on board Intel HD Graphics 630 card which has also had the same updates, everything work as it should in 64bit.
So what are the dependencies of KNLMeansCL in 64bit?
Any help would be appreciated.
goorawin is offline   Reply With Quote
Old 17th June 2017, 08:25   #1191  |  Link
Groucho2004
Run AVSMeter64 with the switch "-avsinfo", it will report any missing dependencies.
Old 18th June 2017, 01:00   #1192  |  Link
goorawin
From my experence reinstalling GeForce driver after Win10 major updates solves this issue. YMMV.
That did the trick thank you. Interesting that it only caused an issue with 64bit scripts.
Old 30th June 2017, 19:14   #1193  |  Link
SaurusX
Great filter, khanatilla. Non-local means is an excellent noise reduction theory and with OpenCL its actually usable in my computer. Thanks for your hard work!
SaurusX is offline   Reply With Quote
Old 25th July 2017, 15:51   #1194  |  Link
SaurusX
Well, I found a way to break the filter while encoding some cartoons. Here's the pseudo-script:
MPEG2SOURCE("myclip")
TComb(mode=0, blah, blah) #for dot-crawl removal
TFM()
TDecimate()
the masked and motion-compensating derainbowing procedure found here
Bifrost(interlaced=false) #1.1 version for final de-rainbowing
KNLMeansCL(d=2,a=3,h=1.2,device_type="GPU") #Using Intel HD4000 graphics
maa2() #anti-alias
msharpen() #resharpen
dehalo_alpha() #de-halo
awarpsharp2() #sharpen chroma
It seems like too much temporal analysis will cause mask pops, frame flashing, and mistimed chroma in the final encode. I can remove TComb or remove Bifrost or change the d parameter to 1 and the problems disappear. This may not be a specific problem to KNLMeansCL, but I thought you'd like to know about it.
Old 1st August 2017, 18:22   #1195  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
ConvertToYV24()
ConvertBits(16)
This one is an easy bug, any plans to fix it soon?
Old 10th August 2017, 12:39   #1196  |  Link
tuanden0
Sorry Sir, but after update my VGA card driver, the KNLMeansCL fillter make my PC reboot because the GPU load over 100%.
I tried to reinstall old driver but the issue still there.
I'm using NVIDIA GeForce GTX 650Ti.
tuanden0 is offline   Reply With Quote
Old 24th August 2017, 18:32   #1197  |  Link
Ben_Nicholls
Have you confirmed that your GPU is 100% stable?
Running MSI Kombustor or FurMark should let you know: if either one crashes, your GPU isn't stable and probably needs replacing.
Ben_Nicholls is offline   Reply With Quote
Old 27th August 2017, 10:45   #1198  |  Link
tuanden0
Thank for your reply,
My problem solved, my VGA card is dirty, so they crashed because it's too hot
I cleaned my VGA so it's OK
Old 27th August 2017, 18:21   #1199  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Just cleaned my laptop too. Removing dust fixes a few things
Old 18th September 2017, 10:34   #1200  |  Link
Khanattila
Khanattila's Avatar
Originally Posted by bcn_246 View Post
Roughly what does NLMeansCL2(h=radius*1.5,u=3,v=3) convert to for KNLMeansCL()?
KNLMeansCL(d=0), but the results are different.
NLMeansCL2 worked on a smaller image.
github.com
