Old 6th July 2009, 16:21   #281  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
No... just uncrop... you don't need to resize.
Old 6th July 2009, 16:31   #282  |  Link
maldino800
But without resize 128*720 the result resolution will not be exact 1280*720,and may be will happen the black bar when playing AVCHD in ps3?
maldino800 is offline   Reply With Quote
Old 6th July 2009, 16:35   #283  |  Link
deank
deank's Avatar
No it won't. You seem not to understand what is 'resize' and what is 'uncrop'.
The program will use your original resolution and add borders to extend it to 720p. That's why you don't need to use resize - leave it to default.
Resize is applied to the original resolution, so you don't want to change it!
Old 6th July 2009, 16:46   #284  |  Link
maldino800
Ok in my case now 1280*544 we do not need resize.in wich case we need to use the resize,one example?
Is 11 hour normal with 9 gb mkv film?
Old 6th July 2009, 16:54   #285  |  Link
deank
deank's Avatar
What you get in the PREVIEW window - that's how the output will look like. If you need to resize - you'll know.
It depends on the speed of your computer and encoding time varies.
Old 6th July 2009, 17:27   #286  |  Link
maldino800
That I get in the PREVIEW window in my pc will be the same size and quality video in my ps3?
Old 6th July 2009, 17:29   #287  |  Link
deank
deank's Avatar
More help you may get here.
I think you're trying to challenge my patience and my will to help you.
If you can't figure out how to use uncropMKV - there are many other (may be better) programs that you can use.
Old 6th July 2009, 17:46   #288  |  Link
maldino800
Please do not be angry with me,I really need to know all about program and need your help...now the last equation.
I have 1280*544 resolution
If I use resize 1280*720 there will be full screen
but if I use original 1280*544 there will be black border(not full screen)
So wich will be good quality video with full screen or with black border?
Old 6th July 2009, 17:50   #289  |  Link
deank
deank's Avatar
The better way is to let the resize option to (no change) (1280x544) and get the black bars (uncropping).
If you use resize to 1280x720 (full screen) your video will be STRETCHED vertically and the aspect ratio will be wrong.
Dean
Old 6th July 2009, 17:53   #290  |  Link
@maldino800
Where did you get the 9 gb mkv film?
Old 6th July 2009, 17:57   #291  |  Link
maldino800
Dean
Ok.now I am understanding a lot of in your program.It is really great program..
I am sorry if I asked you so many equations that is because I am newbee this program is new for me.
Old 6th July 2009, 17:58   #292  |  Link
maldino800
Originally Posted by neuron2 View Post
@maldino800
is 8.98 gb
Old 6th July 2009, 18:05   #293  |  Link
deank
deank's Avatar
Not good.
Old 7th July 2009, 11:17   #294  |  Link
maldino800
Hey
I uncropped one film 1920*1040 I used original resize 1920*1080 and uncrop to 1920*1080 and the results was 1920*1120,it is perfect when I playing with computer,but in my TV sound and subtitle perfect but the screen is all black and no foto,what did I am wrong?
Old 7th July 2009, 14:01   #295  |  Link
Where did you get the 1920*1040 film?
Old 7th July 2009, 14:09   #296  |  Link
maldino800
Why you try to make me violate forum rule,this is not good brother.you violated forum rule with that and do not respect to other..
Where I am get the film is not the issues here.
Old 9th July 2009, 17:20   #297  |  Link
djhazardous
Whenever I click 'Queue' & then 'Start' a Command Prompt opens for a matter of seconds with MKVMerge and immediately closes.
The program then tells me the operation has been completed but obviously, nothing happened at all.
Any idea why MKVMerge keeps closing? I am using the latest version of MultiAVCHD with uncropMKV and also FFDShow, Haali Media Splitter & AVISinth.
djhazardous is offline   Reply With Quote
Old 22nd July 2009, 01:18   #298  |  Link
djhazardous
Help, please?
Old 22nd July 2009, 11:27   #299  |  Link
deank
deank's Avatar
When you load your mkv file if you don't see a preview then it won't work. No preview means - no proper ffdshow/avisynth/splitter configuration.
Old 28th July 2009, 12:41   #300  |  Link
konstlaoum
Bad sync with audio
HI Dean, and thanks for the uncropmkv-seems to be a great application. Ihave done some mkv, files uncropped with good results,but with the last one :1920.1072 to1920.1080 there seems to be a problem with bad audio and subs sync. Ihave tried it three times , i have tried to deactivate pre and post processing in ffdshow ( as you mentioned before, but i am not sure if i did it correctly), i tried trim end(but the output file was much smaller and of bad quality), but no results at all. Any suggestions? Kostas, Greece
konstlaoum is offline   Reply With Quote
avchd, bdmv, compliant, mkv, multiavchd
