30th January 2014, 10:20 | #18982 | Link |
On the first page of this thread is given to ensure that Uncompressed audio is set to "All Supported" in ffdshow. In the readme in the bd_rebuilder archive however this step is omitted. Is this step still valid?
30th January 2014, 11:21 | #18983 | Link |
Ah, good to have the forum back.
MKV output from multiple files is functioning well here. I didn't realize it wasn't since with the previous version I hadn't really used that feature. I've tested with several movies, and...Nice! I think I found a different kind of bug. When I edited Total Recall (Original not remake), and Iron Main 3 I edited both with BD-50 active with main machine. Noreencode happened except for audio.. As per normal. Then played both, and all looked/sounded good. Transfered them to my other machine for encoding in Batch BD25. I checked them each, unchecking the extras I had kept before and making sure the (banked) were set the same as with my machine. I repeated this for the other movie. Later, I check to find with Iron Man 3 some Extras weren't kept, and for Total Recall the same. Anyone else doing this and notice it? Using 0.46.05, Thanks.
30th January 2014, 15:52 | #18985 | Link |
pulsating dtc-blocks in bd-dvd output from certain Bluray-sources with BD-RBV04605
I had pulsating dtc-blocks in bd-dvd output from a certain Bluray-source with BD-RBV04605, so i have taken a short 10 min. clip from the certain Bluray-source for a test-run and encoded it with v0.45.03 with the latest x264.exe from v0.46.05. the result was quite better, there were no dtc-blocks anywhere to find. Here is the avs-script i have used everytime.
LoadPlugin("C:\video\dgdecnv2045\DGDecodeNV.dll") DGSource("C:\VIDEO\FILM\WORKFILES\VID_00001.DGI", fieldop=0) BicubicResize(1440,1080) ConvertToYV12().AssumeFPS(24000,1000) Now i will encode the whole bluray-source with v0.45.03! |
30th January 2014, 16:51 | #18986 | Link | |
The encode command line is stored in LASTCMD.TXT in the BD-RB folder. If you see a difference, please report it. The same version of X264, with the same source and the same command line cannot create different output. In fact I suspect they will have bit-for-bit identical .264 files. Last edited by jdobbs; 30th January 2014 at 16:55. |
30th January 2014, 18:23 | #18987 | Link |
BD Rebuilder v0.46.06 (beta)
I have updated the first post of this thread with a link to the newest version of BD-RB (v0.46.06). Changes for this release:
- Added a new type of IMPORT function. BD-RB will now import video files in 3D side-by- side (SBS) format, and when reencoding the created pseudo source to BD-5/9/25/50 they will be converted back to standard MVC for 3D playback in 3D-capable BD players. - Corrected an error the could result in a failed encode when outputting to ALTERNATE formats from a 3D source without having the "Enable SBS 3D Movie-Only output" selected. - Fixed a problem with some non-multipart sources using multiprocessing settings that could result in a "ERROR in attempt to mux (MKVMERGE)" error when ALTERNATE output has been selected. - Fixed an issue in which an ALTERNATE choice from a 3D source that has been selected for intact video output without SBS mode chosen might sometimes incorrectly reencode. - Other minor corrections and cosmetic fixes. |
30th January 2014, 18:31 | #18988 | Link | |
Here's a good question. When outputting to 3DBD(25/50), does it automatically create an .iso, or is user intervention required? We need to manually tell it to create the .iso?
Only one rooster, need be in the hen house... Last edited by omegaman7; 30th January 2014 at 18:58. |
30th January 2014, 19:52 | #18989 | Link |
It follows the same rules as backing up a 3D disc. By default it creates an ISO, but it can be changed with a hidden setting. I highly recommend ISO output, however, as currently (because of the way BD3D works) you will reduce quality when outputting to a folder.
30th January 2014, 20:18 | #18991 | Link | |
[Status] LABEL=ODD_THOMAS VERSION=v0.46.05 (beta) SOURCE_SIZE=29937389568 SOURCE_VIDEO_SIZE=29937389568 TARGET_SIZE=4771020800 REDUCTION=.15936662711233 RESIZE_1080=0 RESIZE_1440=-1 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=0 SUBS_TO_KEEP=all BACKUP_MODE=1 MOVIEONLY_TYPE=0 USE_LAVF=0 INSTANCES=1 DGDECNV=-1 SSIF_MODE=0 QUICK=0 ENCODE_STEP=3 [00003] AUDIO=11 PGS=11 APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=707924 SPLITS=1 i have used LAVF and DgdecoderNV - no change! and with older versions of bd-rebuilder i have the same problem. would it help to increase the target size? oh man, i'm sorry for this! but i have to run some tests! the problem in question appeares by rebuilding the main movie. Now i have tried strict avchd option. "C:\video\BD_Rebuilder\tools\x264.exe" "C:\VIDEO\FILM\WORKFILES\VID_00001.AVS" --preset medium --bluray-compat --b-pyramid none --weightp 1 --qpmin=0 --bitrate 4650 --level 4.0 --qpfile "C:\VIDEO\FILM\WORKFILES\VID_00001.CHP" --sar 4:3 --aud --nal-hrd vbr --pic-struct --vbv-bufsize 13000 --keyint 48 --min-keyint 1 --ipratio 1.1 --pbratio 1.1 --vbv-maxrate 15000 --threads auto --thread-input --stats "C:\VIDEO\FILM\WORKFILES\VID_00001.AVS.264.stats" --pass 2 --output "C:\VIDEO\FILM\WORKFILES\VID_00001.AVS.264" i go to sleep now! Last edited by pididdi; 30th January 2014 at 21:10. |
30th January 2014, 21:42 | #18993 | Link |
Jdobbs, for SBS option. Does program accept full and half option or is it limited to one type.
30th January 2014, 21:52 | #18994 | Link |
I'll have to look at it. I aimed at half-SBS at 1080 or less and didn't give much thought to full. If it doesn't work at full, I'll add it for the next release, it shouldn't be a big deal. The only other limitation is that it must be 23.976fps, as the output will be 1080p. I may add the ability to import 50/60fps at some point in the future for 720p backup, but I think those types of files will be pretty rare.
30th January 2014, 21:59 | #18995 | Link | |
Aldo did you notice or aware of frimsource.dll increase frame rate by 2.
30th January 2014, 22:32 | #18997 | Link | |
I'm not having any issues with output from frimsource() in my testing, so I don't think it has an impact. Last edited by jdobbs; 30th January 2014 at 22:36. |
30th January 2014, 22:52 | #18998 | Link |
Sorry for my neither bug nor 3D related questions....
From changes.txt: "any bitrate you use for secondaries is stolen directly from the primary video." If I used FIXED_CRF for primary video encoding would this statement be still remained? So, will the primary video's quality "suffer" some in this case as well? Thank you for the help. |
30th January 2014, 23:24 | #18999 | Link | |
