31st October 2019, 20:25 | #57721 | Link | |
I know all that, and that's why I reacted like I did to tp4tissue's comment about 'sustained 1000 nits all day' or whatever. Consumer displays don't need to output sustained full field 1000 nits.
It may just be me being paranoid, but I'm afraid that if most displays start being able to output sustained full field very high nits, some producers may start requesting making the overall picture brighter to give a movie more impact, even at the risk of sacrificing dynamic range. Like what happened with audio CDs but applied to video.I had to do that with my old CRT which had a fricking bright *blue* power LED! Thankfully the LEDs of my current hardware and the VFDs on low brightness are tolerable.
HTPC: Windows 10 22H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400 oc'd, GeForce 1050 Ti 536.40 Last edited by el Filou; 31st October 2019 at 20:28. |
1st November 2019, 15:22 | #57723 | Link |
Maybe it's better to use <= and => with runtime? I don't know if madVR considers seconds and if so how it rounds up. You have to match an exact runtime?
2nd November 2019, 01:38 | #57725 | Link | |
4th November 2019, 16:37 | #57729 | Link |
Heads up guys, i1Display Pro was recently on sale for $155 (after rebate), record low price $135 (no rebate) a few black fridays ago.
This black friday, look out for bhphoto (seller) or adorama (seller) sales on rakuten (marketplace) (bf coupon stack). Movies are unwatchable without Madvr's greatest feature, 3DLut.
Ghetto | 2500k 5Ghz Last edited by tp4tissue; 4th November 2019 at 16:40. |
4th November 2019, 20:36 | #57731 | Link | |
Just kidding, I know what you mean.
4th November 2019, 22:53 | #57732 | Link | |
I wouldn't say it's unwatchable without a 3D LUT though, it depends on the display. After an Autocal, a JVC is very close to reference so a 3D LUT doesn't bring much. But if your display can't be calibrated to a reasonable baseline, then yes, a 3D LUT can make a big difference. It can also make things significantly worse if you don't know what you're doing
5th November 2019, 10:52 | #57733 | Link | |
Btw, 88" OLEDs are coming ...
5th November 2019, 12:48 | #57735 | Link |
Hopefully they will be cheaper in 4k (not 8k) especially after Samsung jumped in (3-4 years).
8th November 2019, 01:32 | #57736 | Link |
Is this a known bug?
Even though "madVR Settings > devices > [Display] > display modes > switch to matching display mode..." is DISABLED, madVR switches to 1920x1080p23 when I play a 1920x1080p23 MVC H.264 MKV file. If I play a 2D 1920x1080p23 H.264 MKV nothing happens. If I disable "madVR Settings > rendering > stereo 3d > enable stereo 3d playback" madVR does not switch the resolution anymore but I can't see the the video in 3D. If I set "madVR Settings > devices > [Display] > display modes > list of all display modes madVR may switch to:" to 2560x1440p144 the screen still goes black for a second, the windows are getting rearranged, screen flickers again and the video finally plays. I played with EDID and custom modes already. I can't get the same settings which are used before playing the MVC file, thus I want to completely DISABLE that monitor switching. |
8th November 2019, 02:07 | #57737 | Link |
Not a bug, working as intended. madVR only supports 3D in 23.976 Hz.
madVR options explained |
8th November 2019, 02:46 | #57738 | Link |
That is not directly correct because if I set "madVR Settings > devices > [Display] > display modes > list of all display modes madVR may switch to:" to 2560x1440p144 I can watch 3D in 144-ish Hz.
However, my main goal is to stop madVR from switching the display mode at all. |
8th November 2019, 02:56 | #57739 | Link |
you can not watch 3d without switching into 3d mode which is a mode switch.
madVR 3d may work in other modes but that doesn't change that it only support 1080p23 3D. btw. dispalyport doesn't have the bandwidth for 1440p 144 hz 3d that's like 1440p 288 hz 2d. |
8th November 2019, 03:15 | #57740 | Link |
Uhm, I may have forgotten to say Side-By-Side!
MPC-HC / madVR never goes into real 3D mode, simply because I don't have any 3D capable display. Instead madVR shows the MVC H.264 MKV in Side-By-Side mode. I tested this on my second PC which has the identical monitor but using HDMI. On HDMI the monitor supports a maximum of 60 Hz and does NOT support 23 or 24 Hz. If I play the same file there no display mode change happens. I made sure the settings for MPC-HC and madVR are identical on both PCs. Last edited by an3k; 8th November 2019 at 03:21. |
