Old 16th November 2020, 13:41   #2221  |  Link
44vince44
hevron,
1) for JPSDR:
-default one in Staxrip releases is Clang W7 AVX to allow compatibility with older generation CPUs
-you can manually replace with Release tClang W7 AVX2 if you have a more recent processor (by recent I mean not older than 4-5 years approximately)
2) for AviSynth+, we use the 3.6xx fork, not the 2.x, get it here https://github.com/AviSynth/AviSynthPlus/releases
44vince44 is offline
Old 16th November 2020, 16:10   #2222  |  Link
hevron
44vince44, thanks a lot for the clarification, Release Clang W7 AVX2 is more suitable for me.
This link https://github.com/AviSynth/AviSynthPlus/releases has AviSynth + 3.6.1/ Date = 2020-06-20, but we have Version 3.6.2 test 2 /Date = 2020-08-31
hevron is offline
Old 21st November 2020, 07:45   #2223  |  Link
44vince44
You're welcome hevron!
I don't know where Stax76 got the beta, but I believe soon there'll be an official release. When Stax76 includes a beta in Staxrip, it's due to a specific fix that he has been expecting.
Old 23rd November 2020, 12:27   #2224  |  Link
DavidRyan
I tried to use DSS2 as a source filter for the first time (StaxRip v2.1.3.0) as I wanted to try it on a variable frame rate MKV (from a DVD using makemkv). But I run into the following error every time:
Does anyone have an idea of what is wrong? I don't use vapoursynth, only avisynth so not sure if the "VS_In" refers to that. Checking in the apps-manage menu it says "DSS2mod - status OK". Here is the mediainfo of the file if that matters:
"Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Variable
Frame rate : 24.035 FPS
Original frame rate : 29.970 (30000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits"
Would appreciate any advice if anyone has an idea on how to get DSS2 working.
EDIT: Resolved, as described below
DavidRyan is offline
Old 24th November 2020, 08:49   #2225  |  Link
Mister XY
A small question, is it possible that i can use my own compiled ffmpeg version to encode videos? If i change the folder for ffmpeg, ffmpeg crashed with error message.
Error Video encoding x265 (2.1.4.8)
Video encoding x265 returned error exit code: 1 (0x1)
It's unclear what the exit code means, in case it's a Windows system error then it possibly means:
Unzulässige Funktion
------------------------- Video encoding x265 -------------------------
ffmpeg 4.3.1
"C:\Program Files\FFmpeg 4.3\ffmpeg.exe" -i "E:\BluRay\Temp\Movie_t01_temp\ffmpegMovie_t01.avs" -c:v libx265 -crf 20 -pix_fmt yuv420p10le -x265-params profile=main10 -an -y -hide_banner "E:\BluRay\Temp\Movie_t01_temp\ffmpegMovie_t01_out.h265"
[avs2 @ 00000221323e8940] Format avs2 detected only with low score of 1, misdetection possible!
[davs2 info]: davs2: 1.6.205 b06d7585620f4e90.8, 2020-11-20 05:32:11
[davs2 info]: CPU Capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX AVX2 FMA3 LZCNT BMI2
[davs2 info]: Manager 221323fbe20: using 1 thread(s): 1(frame/AEC)+0(pool/REC), 2 tasks
[davs2 error]: Manager 221323fbe20: Invalid input Byte-Stream, not start code: 416464
[libdavs2 @ 00000221323f2780] Decoder error: can't read packet
[avs2 @ 00000221323e8940] decoding for stream 0 failed
[avs2 @ 00000221323e8940] Could not find codec parameters for stream 0 (Video: avs2 (libdavs2), none): unspecified size
Consider increasing the value for the 'analyzeduration' and 'probesize' options
Input #0, avs2, from 'E:\BluRay\Temp\Movie_t01_temp\ffmpegMovie_t01.avs':
Duration: N/A, bitrate: N/A
Stream #0:0: Video: avs2, none, 25 tbr, 1200k tbn, 25 tbc
[davs2 warn]: Manager 22132444fc0: Max number of thread reached, forcing to be 8
[davs2 info]: Manager 22132444fc0: using 8 thread(s): 8(frame/AEC)+0(pool/REC), 9 tasks
Stream mapping:
Stream #0:0 -> #0:0 (avs2 (libdavs2) -> hevc (libx265))
Press [q] to stop, [?] for help
[davs2 error]: Manager 22132444fc0: Invalid input Byte-Stream, not start code: 416464
[libdavs2 @ 00000221323e9d00] Decoder error: can't read packet
Error while decoding stream #0:0: Generic error in an external library
Cannot determine format of input stream 0:0 after EOF
Error marking filters as finished
Conversion failed!
StaxRip.ErrorAbortException: Video encoding x265 returned error exit code: 1 (0x1)
ffmpeg 4.3.1
Stream mapping:
Conversion failed!
bei StaxRip.Proc.Start() in D:\Projekte\VB\staxrip\General\Proc.vb:Zeile 399.
bei StaxRip.ffmpegEnc.Encode(String args) in D:\Projekte\VB\staxrip\Encoding\ffmpegEnc.vb:Zeile 139.
bei StaxRip.ffmpegEnc.Encode() in D:\Projekte\VB\staxrip\Encoding\ffmpegEnc.vb:Zeile 125.
bei System.Threading.Tasks.Parallel.<>c__DisplayClass4_0.<Invoke>b__0()
--- Ende der Stapelüberwachung vom vorhergehenden Ort, an dem die Ausnahme ausgelöst wurde ---
bei System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
bei StaxRip.GlobalClass.ProcessJob(String jobPath) in D:\Projekte\VB\staxrip\General\GlobalClass.vb:Zeile 312.
Mister XY is offline
Old 24th November 2020, 11:20   #2226  |  Link
DavidRyan
Originally Posted by DavidRyan View Post
I tried to use DSS2 as a source filter for the first time (StaxRip v2.1.3.0) as I wanted to try it on a variable frame rate MKV (from a DVD using makemkv). ...
If anyone else has this issue, I resolved it by installing lavfilters. DSS2 requires lavfilters to either be:
- installed on the system
- LAVFilters.ax files in the \LAVFilters subfolder in the same folder where avss.dll is placed (not the case with staxrip)
- a path to the LAVFilters.ax files specified using "lavf_path"
Old 24th November 2020, 11:40   #2227  |  Link
ChaosKing
Makes sense, as DirectShow uses codecs installed on your system. DSS2 does *not* require lavfilter but it happens to be that it installed the needed codec on your system.
Why not just use ffms2 or lsmash?
ChaosKing is offline
Old 26th November 2020, 10:37   #2228  |  Link
Mister XY
A little problem. If I want to create a 2 pass video with ffmpeg, it saves the file ffmpeg2pass-0 in the Staxrip folder. The problem with this is if Staxrip does not have rights access to it will be prohibited. Can't you do it so that the ffmpeg2pass-0 file is saved in the Temp Files folder?
Thx
Old 28th November 2020, 05:13   #2229  |  Link
44vince44
Mister XY I confirm this. It's a bug. The command line of ffmpeg should include the -passlogfile option with the temp location specified. This is a real bug, I will create a ticket in github, mentioning your find.
The problem is solved by adding the custom switch -passlogfile "%temp_dir%\ffmpeg2passlog"
I've noted that as well in the bug report.
Old 28th November 2020, 13:53   #2230  |  Link
Mister XY
I must do anything wrong. I add this line -passlogfile "%temp_dir%\ffmpeg2passlog" to the custom line in ffmpeg window, but when start to encode i get this message.
Cannot write log file '%temp_dir%\ffmpeg2passlog-0.log' for pass-1 encoding: No such file or directory
Old 29th November 2020, 07:28   #2231  |  Link
44vince44
You're doing nothing wrong. The macro value is not being passed :-(
Another bug?
Not only %temp_dir%, but ALL MACROS are not passed from the custom line :-((((( It seems the custom line does not support macros.
So in that case, only as workaround, use a system env variable -passlogfile "%temp%\ffmpeg2passlog"
This will use the global user temporary folder (as defined in your system)
Old 29th November 2020, 08:43   #2232  |  Link
Mister XY
OK, i have also seen, that the macros did not passing. If i have set decoder to another decoder looks like software, dxva2 etc. i must set the crop values. If i set the values via macros, it did not pass.
Old 29th November 2020, 11:57   #2233  |  Link
VincAlastor
[AOMediaCodec/SVT-AV1] Pre-release v0.8.6 - SVT-AV1 v0.8.6
default setting changed: --irefresh-type 2
[0.8.6] - 2020-11-28
Encoder
Further quality-speed tradeoffs tuning for VOD use cases
Improved TPL support within 1-pass and 2-pass CRF moode
Continued non-optimized support for 2pass VBR and CRF
Align kernel nomenclature to prefix svt_aom for kernels brough from libaom to avoid symbol conflicts
Build and Testing
Bug fixes
Improve CI
Added CI support for gitlab
Improve Unit Test Coverage
Address C vs asm mismatches
Fix static analysis warnings / errors
Add address sanitizer
Fix symbol conflicts with libaom and libvpx when staticly linked to ffmpeg
https://github.com/AOMediaCodec/SVT-...ses/tag/v0.8.6
VincAlastor is offline
Old 6th January 2021, 23:23   #2234  |  Link
Z'Hadum
Just noticed 2.1.6.0 stable is out:
https://github.com/staxrip/staxrip/releases
Z'Hadum is offline
Old 7th January 2021, 16:12   #2235  |  Link
44vince44
It has some unfortunate bugs, get directly the fixed beta 2.1.6.1
here: https://www.dropbox.com/sh/4ctl2y928...dd3yqcAHa?dl=0
Stax76 has released a new Stable 2.1.7.0
Old 8th January 2021, 01:45   #2236  |  Link
Trench
I've been fighting an error similar to what Mister XY just mentioned, but I seem to have a different root cause. A log in my case will show:
------------------------- System Environment -------------------------
StaxRip    : 2.1.7.0
Windows    : Windows 10 Pro 2009
Language   : English (United States)
CPU        : Intel(R) Xeon(R) CPU E3-1280 V2 @ 3.60GHz
GPU        : Microsoft Remote Display Adapter, NVIDIA GeForce GTX 1050 Ti
Resolution : 1920 x 1080
DPI        : 96
----------------------- Media Info Source File -----------------------
C:\Files\Staxrip\The.File.mkv
General
Complete name            : C:\Files\Staxrip\The.File.mkv
Format                   : Matroska
Format version           : Version 4
File size                : 598 MiB
Duration                 : 51 min 8 s
Overall bit rate         : 1 636 kb/s
Movie name               : The.File
Encoded date             : UTC 2021-01-06 03:04:57
Writing application      : mkvmerge v51.0.0 ('I Wish') 64-bit
Writing library          : libebml v1.4.0 + libmatroska v1.6.2
Video
Format                   : HEVC
Format/Info              : High Efficiency Video Coding
Format profile           : Main 10@L4@Main
Codec ID                 : V_MPEGH/ISO/HEVC
Bit rate                 : 1 424 kb/s
Width                    : 1 920 pixels
Height                   : 960 pixels
Display aspect ratio     : 2.000
Frame rate mode          : Constant
Frame rate               : 23.976 (24000/1001) FPS
Color space              : YUV
Bit depth                : 10 bits
Bits/(Pixel*Frame)       : 0.032
Stream size              : 521 MiB (87%)
Default                  : Yes
Forced                   : No
Color range              : Limited
Color primaries          : BT.709
Transfer characteristics : BT.709
Matrix coefficients      : BT.709
Audio
Format                   : AAC LC SBR
Format/Info              : Advanced Audio Codec Low Complexity with Spectral Band Replication
Commercial name          : HE-AAC
Format settings          : Explicit
Codec ID                 : A_AAC-2
Bit rate                 : 206 kb/s
Channel(s)               : 6 channels
Channel layout           : C L R Ls Rs LFE
Sampling rate            : 48.0 kHz
Frame rate               : 23.438 FPS (2048 SPF)
Compression mode         : Lossy
Delay relative to video  : 23 ms
Stream size              : 75.5 MiB (13%)
Language                 : English
Default                  : Yes
Forced                   : No
Text #1
Format                   : UTF-8
Codec ID                 : S_TEXT/UTF8
Codec ID/Info            : UTF-8 Plain Text
Duration                 : 48 min 51 s
Bit rate                 : 52 b/s
Count of elements        : 744
Stream size              : 18.9 KiB (0%)
Title                    : English
Language                 : English
Default                  : No
Forced                   : No
------------------------------ Demux MKV ------------------------------
mkvextract 52
C:\Users\Trench\StaxRip-x64-2.1.7.0-Stable\Apps\Support\MKVToolNix\mkvextract.exe C:\Files\Staxrip\The.File.mkv tracks 2:"C:\Files\Staxrip\The.File_temp\ID1 English {English}.srt" 1:"C:\Files\Staxrip\The.File_temp\ID1 23ms English.aac" --ui-language en
Error: Failed to create the file 'C:\Files\Staxrip\The.File_temp\ID1 23ms English.aac': 0 (open file error)
Start:    5:33:38 PM
End:      5:33:38 PM
Duration: 00:00:00
-------------------------------- Error --------------------------------
no output found
-------------------------- Error Demux Audio --------------------------
Demux Audio returned error exit code: 1 (0x1)
Incorrect function
----------------------------- Demux Audio -----------------------------
ffmpeg N-100448-gab6a56773f-x64-gcc10.2.0 Patman
C:\Users\Trench\StaxRip-x64-2.1.7.0-Stable\Apps\Encoders\ffmpeg\ffmpeg.exe -i C:\Files\Staxrip\The.File.mkv -vn -sn -y -hide_banner -c:a copy "C:\Files\Staxrip\The.File_temp\ID1 23ms English.m4a"
Input #0, matroska,webm, from 'C:\Files\Staxrip\The.File.mkv':
  Metadata:
    title           : The.File
    encoder         : libebml v1.4.0 + libmatroska v1.6.2
    creation_time   : 2021-01-06T03:04:57.000000Z
  Duration: 00:51:08.61, start: 0.000000, bitrate: 1635 kb/s
    Stream #0:0: Video: hevc (Main 10), yuv420p10le(tv, bt709), 1920x960, SAR 1:1 DAR 2:1, 23.98 fps, 23.98 tbr, 1k tbn, 23.98 tbc (default)
    Metadata:
      BPS-eng         : 1424359
      DURATION-eng    : 00:51:08.607000000
      NUMBER_OF_FRAMES-eng: 73573
      NUMBER_OF_BYTES-eng: 546350126
      _STATISTICS_WRITING_APP-eng: mkvmerge v51.0.0 ('I Wish') 64-bit
      _STATISTICS_WRITING_DATE_UTC-eng: 2021-01-06 03:04:57
      _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
    Stream #0:1(eng): Audio: aac (HE-AAC), 48000 Hz, 5.1, fltp (default)
    Metadata:
      BPS-eng         : 206485
      DURATION-eng    : 00:51:08.459000000
      NUMBER_OF_FRAMES-eng: 71917
      NUMBER_OF_BYTES-eng: 79199106
    Stream #0:2(eng): Subtitle: subrip
    Metadata:
      title           : English
      BPS-eng         : 52
      DURATION-eng    : 00:48:51.678000000
      NUMBER_OF_FRAMES-eng: 744
      NUMBER_OF_BYTES-eng: 19353
C:\Files\Staxrip\The.File_temp\ID1 23ms English.m4a: Permission denied
  Metadata:
    title           : The.File
    Metadata:
      BPS-eng         : 1424359
    Metadata:
      BPS-eng         : 206485
    Metadata:
      title           : English
      BPS-eng         : 52
Start:    5:33:38 PM
End:      5:33:39 PM
Duration: 00:00:00
------------------------------ Exception ------------------------------
StaxRip.ErrorAbortException: Demux Audio returned error exit code: 1 (0x1)
Incorrect function
  Metadata:
    title           : The.File
    Metadata:
      BPS-eng         : 1424359
    Metadata:
      BPS-eng         : 206485
    Metadata:
      title           : English
      BPS-eng         : 52
   at StaxRip.Proc.Start() in D:\Projekte\VB\staxrip\General\Proc.vb:line 384
   at StaxRip.ffmpegDemuxer.DemuxAudio(String sourcefile, AudioStream stream, AudioProfile ap, Project proj, Boolean overrideExisting) in D:\Projekte\VB\staxrip\General\Demux.vb:line 366
   at StaxRip.mkvDemuxer.Demux(String sourcefile, IEnumerable`1 audioStreams, IEnumerable`1 subtitles, AudioProfile ap, Project proj, Boolean onlyEnabled, Boolean videoDemuxing, Boolean overrideExisting, String title, Boolean useStreamName) in D:\Projekte\VB\staxrip\General\Demux.vb:line 963
   at StaxRip.mkvDemuxer.Run(Project proj) in D:\Projekte\VB\staxrip\General\Demux.vb:line 731
   at StaxRip.MainForm.Demux() in D:\Projekte\VB\staxrip\Forms\MainForm.vb:line 3212
   at StaxRip.MainForm.OpenVideoSourceFiles(IEnumerable`1 files, Boolean isEncoding) in D:\Projekte\VB\staxrip\Forms\MainForm.vb:line 2134
It's not a permissions issue of being able to create or write files in the temporary directory, because the Staxrip log shown is being created and written there successfully by Staxrip.exe.
But two different tools as shown in the log -- mkvextract.exe trying to create "ID1 23ms English.aac", and then ffmpeg.exe trying to create "ID1 23ms English.m4a" -- complain as though files cannot be created in the "C:\Files\Staxrip\The.File_temp" temp area.
Microsoft's Process Monitor shows me the tools are receiving ACCESS_DENIED in their attempt to create those files, as though it actually is a permissions issue.
But Staxrip creates the log file in the temp area successfully, and I can create files in the temp area using File Explorer. Both Staxrip.exe and File Explorer are running as normal non-elevated processes. Running Staxrip.exe as administrator still results in the same failure for mkvextract.exe and ffmpeg.exe.
I've concluded that the issue this: In the path shown, C:\Files\ is a mount point. Meaning C:\ itself is an SSD drive, but C:\Files\ is the mount point of a multi-terabyte magnetic drive for work space. The successful temp folder creation & successful log file creation by Staxrip.exe itself receives REPARSE in response to the C:\Files\-involved path, but the tools simply fail with ACCESS_DENIED.
It seems like "suddenly" Staxrip processing cannot traverse a mount point. Staxrip.exe itself can still traverse that path; but not the tools being launched.
This happens with 2.1.5.5.Beta and 2.1.7.0.Stable. Note the log says "Windows 10 2009", and my WinVER confirms "20H2 19042.685".
If I run 2.1.3.0.Stable or 2.1.4.8.Beta against the same source file in the same folder setup, the tools are able to create and write to files in the temporary area just fine.
Some unintended consequence of how the tools were updated for long path handling? Or can someone refute these results, and you are able to use a mount point in the path under Windows 20H2 successfully; meaning I should continue digging for a more specific root cause?
Trench is offline
Old 8th January 2021, 10:43   #2237  |  Link
44vince44
@Trench, is it possible to edit the properties of your C:\Files\Staxrip\ folder and set permissions (full control) to you as user? do mount points allow that ?
We must know if the problem persists after that.
Old 8th January 2021, 16:36   #2238  |  Link
stax76
stax76's Avatar
@Trench
The only relevant change I remember is changing the current directory of the staxrip process to the video temp folder, this was not long ago. Before the current folder of the staxrip process was usually the startup folder where staxrip is located. That's something a child process inherits.
stax76 is offline
Old 8th January 2021, 17:57   #2239  |  Link
44vince44
When creating folders directly in C:\ the system does not give them proper permissions for free read/write operations. Unlike a folder created in the user's official temp tree, or in the user's tree more generally.
As we are discussing something happening with a temp folder, it is wise to check the permissions on the folder C:\Files\Staxrip\ in Trench's case.
This should not be considered as a problem in Staxrip, even if it used to work otherwise.
So, @Trench, please check and do the permissions change, or set your paths to locations that you have R/W control on.
Old 18th January 2021, 16:00   #2240  |  Link
LazyNcoder
@stax76 Can you please compile Staxrip more often?
I see there are more than 75 changes since the last release 2.1.7.0
I'm impatiently waiting...
Thank you
LazyNcoder is offline
