29th July 2019, 13:43 | #56962 | Link |
no https://github.com/HomeOfVapourSynth...-Waifu2x-caffe
and there is a way to load shaders in avisynth so if you have the shader for NGU you could encode with it right now. |
29th July 2019, 14:17 | #56963 | Link |
Yeah, I had forgotten that, there is also an Avisynth plugin but both are extremely slow.
It would be great a NGU shader that could be used by Avisynth Shader, there is already a FSRCNN shader for mpv, maybe it can also be used in the same way. |
29th July 2019, 21:45 | #56964 | Link |
I assume this is a news which madVR can benefit from:
https://www.anandtech.com/show/14682...-geforce-cards |
29th July 2019, 21:59 | #56965 | Link |
It is not. madVR does not use OpenGL at all.
madVR options explained |
30th July 2019, 01:51 | #56968 | Link | |
If madVR switched to OpenGL my favorite player wouldn't work with it anymore.
30th July 2019, 04:43 | #56969 | Link |
I'm wondering if anyone can explain this screenshot: https://i.imgur.com/zGsB4T9.png
This is after about 40 minutes of playback. MadVR thinks there should be a frame drop every 2 minutes, but there isn't. Playback is 100% perfect. The presentation glitches are all from either adjusting the volume (there is exactly 1 presentation glitch every time the Windows volume indicator fades out) or looking at the seekbar (again 1 glitch every time the seekbar goes away). This is without using ReClock or any custom display mode. Could this have something to do with GSYNC (it's a GSYNC display btw), or does the Nvidia driver just happen to give me a video clock that's remarkably in sync with the audio clock at this refresh rate? This is in contrast to my other non-GSYNC display, which has a 24hz mode, but Nvidia gives me a clock of like 23.977hz, so I get a frame repeat about once every 12 minutes without using ReClock or custom display modes. Also just wanna throw in a quick thanks for madshi for doing so much for the HTPC community. It seems like nothing else really compares to madVR in terms of quality or features and it's awesome that it has been and continues to be free software. |
30th July 2019, 04:48 | #56970 | Link |
Hi all.
I am running MPC-BE v.1.5.3 with madvr 127.0.0.1 on a Windows 10 HTPC with an Nvidia RTX 2060. The video is fed via HDMI to a pre-pro and then to a Sony TV XBR85X850F. It can also be fed directly to the TV. I have madvr setup to open full screen and to change the refresh rate of the TV to match the video file. This works fine about 50% of the time. For the other 50% the video opens and plays as expected, full screen and with the adjusted refresh rate, but the menu bar is not available when placing the cursor at the bottom of the screen and right clicking does not open the context menu. There is no way to control playback when this occurs. However, if I double click on the video on screen to 'restore down', taking the application out of fullscreen mode, the menu bar and context menus return. Once the fault occurs it then keeps happening on each successive file until I reboot the computer. It then plays as expected for a random period of time and/or playback of a random number of files. There does not seem to be any common characteristics in the files that this fault occurs. Could be anything, an .avi, .mp4, or mkv etc. But next time they could play faultlessly. Has anyone encountered this sort of behaviour before and managed to resolve it? Appreciate your advice. Cheers, Allan. ps. Could you please let me know if this is better dealt with in another thread. a |
30th July 2019, 07:52 | #56971 | Link |
3d lut
HI , Saturday I am planning to create a 3D LUT.
I have a x-rite i1display pro colorimeter , with accompanied x-rite software , but also Calman software Which would be better for MadVR usage ? 1- CalMAN Setup Guide: madVR 3D LUT Calibration 2- Calman Studio ?
Livingroom: Ryzen 7 1700@3.9ghz - Win Insiders Fast Ring - MSI RTX 2700 Gaming - Philips 65OLED803 | Bedroom Ryzen 3 1200 - Win 8.1 - GTX1060 - LG OLED EG920V 55" > All with MadVR latest test build |
30th July 2019, 08:00 | #56972 | Link | |
The OSD report for drops/repeats is based off a perfect pattern, so 3:2 for 24 into 60. Sometimes that line is not very important. We can notice the judder from a frame presented for a single update instead of two but I am not sure about 4 or 6 updates instead of 5. madVR hates G-sync, you should make sure it is off for your video player (for a better refresh rate turn it off entirely and use 119Hz... but it is so nice in games and turning it off and on all the time is annoying so...). madVR expects the video card to have a precise v-sync event, not one that floats around due to the timing the software presents frames at. madVR does not precisely time when it presents frames. It is even worse with smooth motion and can go very odd, I get drifting frame rates anywhere from ~10-144. G-sync off for the video player and smooth motion on works very very well at 120+ Hz. I am not sure what you mean by 1 or 2, I like the Calman's ColorCube workflow for creating a 3DLUT for madVR.
madVR options explained Last edited by Asmodian; 30th July 2019 at 08:03. |
30th July 2019, 08:10 | #56973 | Link |
And you can also use the opensource DisplayCal.
Which display do you want to profile? Philips Oled?
30th July 2019, 08:51 | #56974 | Link | |
https://www.ghacks.net/2019/07/04/wi...adients-issue/ https://www.dsogaming.com/news/windo...-improvements/ c'mon it's easy......
AMD Ry 1500x - 8GB - RX460 4GB TV Philips 55pus6501+ Marantz 1608 avr WIN10(1903) 4K/444RGB Mediaportal - Mpc-hc MADVR-D3D11/10bit Last edited by mrmojo666; 30th July 2019 at 10:02. |
30th July 2019, 09:31 | #56975 | Link | |
After that the 709 When succesfull, I will do my LG Oled
30th July 2019, 10:24 | #56976 | Link | |
as I understood it , there a several software programs to achieve creating a 3D LUT . (my intent is to use this 100% just for MadVR) My question was, which program achieves the best result for that. Calman studio (with or without using MadVR TPG) , or another program like LightSpace. If there isn't much difference in regards to quality , then maybe there is in terms of friendly to use (not a huge learning curve)
30th July 2019, 10:47 | #56977 | Link | |
It appears, however, that Microsoft introduces a new bug that causes banding on gradients even when calibration is not active. Any program or game that loads an ICC profile may be affected by the issue. |
30th July 2019, 11:05 | #56978 | Link | |
If my Discus was supported by DisplayCAL, I'd definitely be using it. So assuming meter(s) is/are supported by all three, the order I would suggest is: 1) DisplayCAL 2) Calman 3) Lightspace
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K Last edited by Manni; 30th July 2019 at 11:08. |
30th July 2019, 11:44 | #56979 | Link | |
Is Florian the same person as Soulnight / Flo ? (From AVS thread: improving-madvr-hdr-sdr-mapping-projector)
Livingroom: Ryzen 7 1700@3.9ghz - Win Insiders Fast Ring - MSI RTX 2700 Gaming - Philips 65OLED803 | Bedroom Ryzen 3 1200 - Win 8.1 - GTX1060 - LG OLED EG920V 55" > All with MadVR latest test build Last edited by svengun; 30th July 2019 at 11:46. |
30th July 2019, 12:47 | #56980 | Link | |
