13th October 2017, 11:07 | #14381 | Link |
To sumarize the problem here.
I found two kind of EAC3 streams detected by eac3to without core (2 English) or with core (3 Spanish) like is show here (sample): Code:
eac3to Eac30.m2ts ------------------------------------------------------------------------------ M2TS, 1 video track, 2 audio tracks, 0:01:23, 24p /1.001 1: h264/AVC, 1080p24 /1.001 (16:9) 2: E-AC3, English, 5.1 channels, 640kbps, 48kHz 3: E-AC3, Spanish, 7.1 channels, 768kbps, 48kHz, dialnorm: -27dB (core: AC3, 5.1 channels, 448kbps, 48kHz, dialnorm: -27dB) eac3to Eac30.m2ts 2: output.eac3 [-core] -> OK eac3 output eac3to Eac30.m2ts 2: output.ac3 [-core] -> OK recoded to ac3 All ok over track 2 eac3to Eac30.m2ts 3: output.eac3 -> ERROR eac3to Eac30.m2ts 3: output.eac3 -core -> OK AC3.eac3 output eac3to Eac30.m2ts 3: output.ac3 -> ERROR eac3to Eac30.m2ts 3: output.ac3 -core -> useless, recoded core Over track 3, can't extract or recode (maybe because: Dependent substream decoding is not implemented) the full eac3. Can extract a perfect AC3 core (when demand eac3 extensión) or recode the core (useless) Now the same m2ts converted to mkv with MkvToolNix is show by eac3to like: Code:
eac3to Eac30.mkv ------------------------------------------------------------------------------ MKV, 1 video track, 2 audio tracks, 0:01:23, 24p /1.001 1: h264/AVC, English, 1080p24 /1.001 (16:9) 2: EAC3, English, 5.1 channels, 48kHz 3: EAC3, Spanish, 5.1 channels, 48kHz Bitstream parsing for tracks 2 and 3 failed. <WARNING> Demuxing these tracks may still produce correct results - or not. <WARNING> eac3to Eac30.mkv 2: output.eac3 [-core] -> OK eac3 output eac3to Eac30.mkv 2: output.ac3 [-core] -> ERROR eac3to Eac30.mkv 3: output.eac3 [-core] -> OK eac3 output eac3to Eac30.mkv 3: output.ac3 [-core] -> ERROR Can extract both tracks but never decode/recode EDIT: Decoding track 3 with ffmpeg show always (from m2ts or mkv) the message: Dependent substream decoding is not implemented. Then MkvToolNix don't extract the AC3 core, preserve the substream to convert 5.1 -> 7.1 even when eac3to show only 5.1 on mkv. Remuxed the mkv to m2ts with tsMuxeR the track 3 is showed by eac3to like original Eac30.m2ts Without free tools to decode EAC3 7.1 (always decode the core) the recommended option, by now, is extract the core from m2ts eac3to Eac30.m2ts 3: output.eac3 -core and rename to .ac3
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 13th October 2017 at 12:12. Reason: add info |
13th October 2017, 11:12 | #14382 | Link |
thanks Madshi for the great tool!
I think there are a few things that may/could use some updating: 1) E-AC3 audios with embedded Core (mentioned before) 2) libFLAC (very old version used, maybe worth updating) 3) libDcaDec (I think it's part of ffmpeg now?) |
13th October 2017, 12:30 | #14383 | Link | |
Life's clearer in 4K UHD
It would seem that most if not all our current tools are unable to correctly identify Dolby Digital Plus audio streams Have you noticed that when you run your 'Eac30.m2ts' sample file through TSmuxerGUI that it reports the first audio track as having 17 channels. And when you run the same file through MediaInfo it's unable to detect the AC3 cores at all. Or identify that the second audio track has been encoded with 7.1 channels. By contrast, my Oppo UDP-203 is able to identify the first audio track as being a 5.1 channel Dolby Digital Plus stream and second audio track as being a 7.1 channel Dolby Digital Plus stream. But neither of my LG 'smart' TV's (which support Dolby Digital Plus) are able to detect either of the audio streams at all (ie: total silence). But my Panasonic 'smart' TV can detect the first audio stream. Cheers
14th October 2017, 09:21 | #14386 | Link |
nope
eac3to v3.32 command line: "C:\Users\zeropc\Desktop\eac3to 3.32\eac3to.exe" "H:\xmen atmos.mkv" 2: "H:\x\xa1.thd" +18ms ------------------------------------------------------------------------------ MKV, 1 video track, 3 audio tracks, 29 subtitle tracks, 2:23:58, 24p /1.001 1: h265/HEVC, 3840x1600 24p /1.001 (12:5), 10 bits 2: TrueHD (Atmos), English, 7.1 channels, 48kHz 3: AC3, English, 5.1 channels, 640kbps, 48kHz 4: AAC, English, 2.0 channels, 48kHz, 9ms "Commentary with director Bryan Singer and writer Simon Kinberg" 5: Subtitle (PGS), English, "Forced" 6: Subtitle (PGS), English, "SDH" 7: Subtitle (PGS), Spanish 8: Subtitle (PGS), French 9: Subtitle (PGS), French 10: Subtitle (PGS), Spanish 11: Subtitle (PGS), Danish 12: Subtitle (PGS), Dutch 13: Subtitle (PGS), Finnish 14: Subtitle (PGS), German 15: Subtitle (PGS), Italian 16: Subtitle (PGS), Norwegian 17: Subtitle (PGS), Swedish 18: Subtitle (PGS), Chinese 19: Subtitle (PGS), Chinese 20: Subtitle (PGS), Japanese 21: Subtitle (PGS), English, "Commentary" 22: Subtitle (PGS), Spanish, "Commentary" 23: Subtitle (PGS), French, "Commentary" 24: Subtitle (PGS), French, "Commentary" 25: Subtitle (PGS), Spanish, "Commentary" 26: Subtitle (PGS), Danish, "Commentary" 27: Subtitle (PGS), Dutch, "Commentary" 28: Subtitle (PGS), Finnish, "Commentary" 29: Subtitle (PGS), German, "Commentary" 30: Subtitle (PGS), Italian, "Commentary" 31: Subtitle (PGS), Japanese, "Commentary" 32: Subtitle (PGS), Norwegian, "Commentary" 33: Subtitle (PGS), Swedish, "Commentary" [a02] Extracting audio track number 2... [a02] Creating file "H:\x\xa1.thd"... Video track 1 contains 207088 frames. eac3to processing took 16 minutes, 6 seconds. Done. |
14th October 2017, 13:28 | #14387 | Link |
Matroska find' ich toll
Feature request
Hi madshi
Is it possible that eac3to scan the sup tracks and find forced sup's before I demux the sup track. While eac3to scans the mpls (all tracks are listed) and for the sup tracks, you could add an info "forced sup's detected". Code:
M2TS, 1 video track, 3 audio tracks, 10 subtitle tracks, 0:43:05, 24p /1.001 1: Chapters, 8 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: DTS Master Audio, English, 5.1 channels, 16 bits, 48kHz (core: DTS, 5.1 channels, 1509kbps, 48kHz) 4: DTS Master Audio, German, 5.1 channels, 16 bits, 48kHz (core: DTS, 5.1 channels, 1509kbps, 48kHz) 5: DTS Master Audio, Spanish, 5.1 channels, 16 bits, 48kHz (core: DTS, 5.1 channels, 1509kbps, 48kHz) 6: Subtitle (PGS), English 7: Subtitle (PGS), English 8: Subtitle (PGS), Danish 9: Subtitle (PGS), Finnish 10: Subtitle (PGS), German, forced detected 11: Subtitle (PGS), Hindi 12: Subtitle (PGS), Norwegian 13: Subtitle (PGS), Spanish 14: Subtitle (PGS), Swedish 15: Subtitle (PGS), Turkish Code:
M2TS, 1 video track, 3 audio tracks, 10 subtitle tracks, 0:43:05, 24p /1.001 1: Chapters, 8 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: DTS Master Audio, English, 5.1 channels, 16 bits, 48kHz (core: DTS, 5.1 channels, 1509kbps, 48kHz) 4: DTS Master Audio, German, 5.1 channels, 16 bits, 48kHz (core: DTS, 5.1 channels, 1509kbps, 48kHz) 5: DTS Master Audio, Spanish, 5.1 channels, 16 bits, 48kHz (core: DTS, 5.1 channels, 1509kbps, 48kHz) 6: Subtitle (PGS), English 7: Subtitle (PGS), English 8: Subtitle (PGS), Danish 9: Subtitle (PGS), Finnish 10: Subtitle (PGS), German 11: Subtitle (PGS), Hindi 12: Subtitle (PGS), Norwegian 13: Subtitle (PGS), Spanish 14: Subtitle (PGS), Swedish 15: Subtitle (PGS), Turkish 16: Subtitle (PGS), German, forced hubble Last edited by hubblec4; 14th October 2017 at 13:31. |
14th October 2017, 16:11 | #14388 | Link | ||||
You can replace libFLAC.dll with libFLAC_dynamic.dll (renamed) from
http://www.rarewares.org/files/lossl...170314-icl.zip Quote:
Just by curiosity I check some tsMuxeR versions and the first audio track is: tsMuxeR 1.8.8: track not recognized tsMuxeR 2.6.9: channels 94 tsMuxeR 2.6.11 or 12: channels 91 What is your version than show 17 channels?. Quote:
BTW is know than eac3to can't delay thd tracks. Only decoding that delay can be applied. Quote:
When you demux these tracks the log show the forced captions found. For me is enough, there are other tools to manage sup's.
14th October 2017, 17:38 | #14389 | Link | |
I'm using tsMuxeR GUI 2.6.12. But I've just noticed that if you drop the same 'Eac30.m2ts' file into the application, then remove it, and re-add it, the application reports different information... Cheers (oh bugger... I've run out of beer )
14th October 2017, 18:44 | #14390 | Link | |
So: eac3to Eac30.mkv 2: output.eac3 then rename to output.ac3 then eac3to output.ac3 output2.wav -whatever At least it works with my files that have eac3 tracks and no core. I always need to demux and rename, then decoding and recoding work. That seems like a eac3to bug to me. |
14th October 2017, 23:56 | #14391 | Link | |
I hope madshi has also the Bluray-specs and can do what makemkv does. There is not long scan to identify the forced sup's. |
15th October 2017, 10:03 | #14393 | Link | ||
And you don't need rename, eac3to identify the stream by the header not by extension, work fine also: eac3to Eac30.mkv 2: output2.eac3 then eac3to output2.eac3 output2.wav With track 3: eac3to Eac30.mkv 3: output3.eac3 then eac3to output3.eac3 output3.wav --> Code:
E-AC3, 7.1 channels, 0:01:23, 768kbps, 48kHz, dialnorm: -27dB (core: AC3, 5.1 channels, 0:01:23, 448kbps, 48kHz, dialnorm: -27dB) Removing AC3 dialog normalization... Extracting E-AC3 core... Decoding with libav/ffmpeg... [libav] frame CRC mismatch <WARNING> [libav] get_buffer() failed <WARNING> The libav decoder reported error -22 while decoding. <ERROR> Aborted at file position 262144. <ERROR> ffmpeg -drc_scale 0 -i output3.eac3 -acodec pcm_s24le output3.wav Quote:
ffmpeg -drc_scale 0 -i Eac30.mkv -map 0:2 -acodec pcm_s24le output3.wav with the same WARNING
15th October 2017, 10:15 | #14394 | Link | ||
All other GUI's are abandoned.
15th October 2017, 13:12 | #14396 | Link | |
High DPI VapourSynth x265 full implementation AV1 NVEnc QSVEnc
15th October 2017, 14:44 | #14397 | Link |
I would like to suggest small cosmetic addition to eac3to. It would be cool if extension .265 was also supported during demuxing. Currently only .h265 is recognized.
15th October 2017, 14:50 | #14398 | Link |
There is also hvc due to most file extensions being 3 characters in Windows.
264 h264 avc 265 h265 hvc hevc
15th October 2017, 21:10 | #14400 | Link |
The .h265 extracted with eac3to v3.32 from this sample don't play fine.
Extracted with MkvExtract is ok.
eac3to |
